[QGIS Commit] r10009 - in trunk/qgis/src: app core providers/wms ui
svn_qgis at osgeo.org
Sat Jan 24 10:56:01 EST 2009
Author: mhugent
Date: 2009-01-24 10:56:01 -0500 (Sat, 24 Jan 2009)
New Revision: 10009
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/app/qgsoptions.h
trunk/qgis/src/core/qgshttptransaction.cpp
trunk/qgis/src/core/qgshttptransaction.h
trunk/qgis/src/providers/wms/qgswmsprovider.cpp
trunk/qgis/src/ui/qgsoptionsbase.ui
WMS: don't apply proxy to a list of selected urls. Done in QgsHttpTransaction::applyProxySettings so WFS & co can later also use this function. Not tested yet and still needs some cleanups
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2009-01-24 10:31:10 UTC (rev 10008)
+++ trunk/qgis/src/app/qgsoptions.cpp 2009-01-24 15:56:01 UTC (rev 10009)
@@ -72,6 +72,21 @@
QString settingProxyType = settings.value("proxy/proxyType", "DefaultProxy").toString();
mProxyTypeComboBox->setCurrentIndex(mProxyTypeComboBox->findText(settingProxyType));
+ //URLs excluded not going through proxies
+ QString proxyExcludedURLs = settings.value( "proxy/proxyExcludedUrls", "").toString();
+ if(!proxyExcludedURLs.isEmpty())
+ QStringList splittedUrls = proxyExcludedURLs.split("|");
+ QStringList::const_iterator urlIt = splittedUrls.constBegin();
+ for(; urlIt != splittedUrls.constEnd(); ++urlIt)
+ QListWidgetItem* newItem = new QListWidgetItem(mExcludeUrlListWidget);
+ newItem->setText(*urlIt);
+ newItem->setFlags( Qt::ItemIsEditable | Qt::ItemIsEnabled | Qt::ItemIsSelectable);
+ mExcludeUrlListWidget->addItem(newItem);
// set the current theme
cmbTheme->setItemText( cmbTheme->currentIndex(), settings.value( "/Themes" ).toString() );
@@ -275,6 +290,18 @@
settings.setValue( "proxy/proxyPassword", leProxyPassword->text() );
settings.setValue( "proxy/proxyType", mProxyTypeComboBox->currentText());
+ //url to exclude from proxys
+ QString proxyExcludeString;
+ for(int i = 0; i < mExcludeUrlListWidget->count(); ++i)
+ if(i != 0)
+ proxyExcludeString += "|";
+ proxyExcludeString += mExcludeUrlListWidget->item(i)->text();
+ settings.setValue( "proxy/proxyExcludedUrls", proxyExcludeString);
//general settings
settings.setValue( "/Map/identifyRadius", spinBoxIdentifyValue->value() );
settings.setValue( "/qgis/showLegendClassifiers", cbxLegendClassifiers->isChecked() );
@@ -547,3 +574,19 @@
return myList;
+void QgsOptions::on_mAddUrlPushButton_clicked()
+ newItem->setText("URL");
+ mExcludeUrlListWidget->setCurrentItem(newItem);
+void QgsOptions::on_mRemoveUrlPushButton_clicked()
+ int currentRow = mExcludeUrlListWidget->currentRow();
+ QListWidgetItem* itemToRemove = mExcludeUrlListWidget->takeItem(currentRow);
+ delete itemToRemove;
Modified: trunk/qgis/src/app/qgsoptions.h
--- trunk/qgis/src/app/qgsoptions.h 2009-01-24 10:31:10 UTC (rev 10008)
+++ trunk/qgis/src/app/qgsoptions.h 2009-01-24 15:56:01 UTC (rev 10009)
@@ -82,6 +82,12 @@
void on_mLineColourToolButton_clicked();
+ /**Add a new URL to exclude from Proxy*/
+ void on_mAddUrlPushButton_clicked();
+ /**Remove an URL to exclude from Proxy*/
+ void on_mRemoveUrlPushButton_clicked();
protected:
//! Populates combo box with ellipsoids
void getEllipsoidList();
Modified: trunk/qgis/src/core/qgshttptransaction.cpp
--- trunk/qgis/src/core/qgshttptransaction.cpp 2009-01-24 10:31:10 UTC (rev 10008)
+++ trunk/qgis/src/core/qgshttptransaction.cpp 2009-01-24 15:56:01 UTC (rev 10009)
@@ -27,6 +27,7 @@
#include <QApplication>
#include <QUrl>
+#include <QSettings>
#include <QTimer>
#include "qgslogger.h"
@@ -97,17 +98,17 @@
// Set the host in the QHttp object
http->setHost( qurl.host(), qurl.port( HTTP_PORT_DEFAULT ) );
- if ( httphost.isEmpty() )
+ if(!QgsHttpTransaction::applyProxySettings(*http, httpurl))
- // No proxy was specified - connect directly to host in URI
httphost = qurl.host();
httpport = qurl.port( HTTP_PORT_DEFAULT );
else
- // Insert proxy username and password authentication
- http->setProxy( QNetworkProxy(mProxyType, httphost, httpport, httpuser, httppass) );
+ //proxy enabled, read httphost and httpport from settings
+ QSettings settings;
+ httphost = settings.value( "proxy/proxyHost", "" ).toString();
+ httpport = settings.value( "proxy/proxyPort", "" ).toString().toInt();
// int httpid1 = http->setHost( qurl.host(), qurl.port() );
@@ -470,6 +471,63 @@
return mError;
+bool QgsHttpTransaction::applyProxySettings(QHttp& http, const QString& url)
+ //check if proxy is enabled
+ bool proxyEnabled = settings.value( "proxy/proxyEnabled", false ).toBool();
+ if(!proxyEnabled)
+ return false;
+ //check if the url should go through proxy
+ QStringList excludedURLs = proxyExcludedURLs.split("|");
+ QStringList::const_iterator exclIt = excludedURLs.constBegin();
+ for(; exclIt != excludedURLs.constEnd(); ++exclIt)
+ if(url.startsWith(*exclIt))
+ return false; //url does not go through proxy
+ //read type, host, port, user, passw from settings
+ QString proxyHost = settings.value( "proxy/proxyHost", "" ).toString();
+ int proxyPort = settings.value( "proxy/proxyPort", "" ).toString().toInt();
+ QString proxyUser = settings.value( "proxy/proxyUser", "" ).toString();
+ QString proxyPassword = settings.value( "proxy/proxyPassword", "" ).toString();
+ QString proxyTypeString = settings.value( "proxy/proxyType", "" ).toString();
+ QNetworkProxy::ProxyType proxyType = QNetworkProxy::NoProxy;
+ if(proxyTypeString == "DefaultProxy")
+ proxyType = QNetworkProxy::DefaultProxy;
+ else if(proxyTypeString == "Socks5Proxy")
+ proxyType = QNetworkProxy::Socks5Proxy;
+ else if(proxyTypeString == "HttpProxy")
+ proxyType = QNetworkProxy::HttpProxy;
+ else if(proxyTypeString == "HttpCachingProxy")
+ proxyType = QNetworkProxy::HttpCachingProxy;
+ else if(proxyTypeString == "FtpCachingProxy")
+ proxyType = QNetworkProxy::FtpCachingProxy;
+ http.setProxy( QNetworkProxy(proxyType, proxyHost, proxyPort, proxyUser, proxyPassword) );
+ return true;
void QgsHttpTransaction::abort()
if(http)
Modified: trunk/qgis/src/core/qgshttptransaction.h
--- trunk/qgis/src/core/qgshttptransaction.h 2009-01-24 10:31:10 UTC (rev 10008)
+++ trunk/qgis/src/core/qgshttptransaction.h 2009-01-24 15:56:01 UTC (rev 10009)
@@ -82,7 +82,11 @@
QString errorString();
+ /**Apply proxy settings from QSettings to a http object
+ @param return true if proxy settings was applied, false else*/
+ static bool applyProxySettings(QHttp& http, const QString& url);
public slots:
void dataStarted( int id );
Modified: trunk/qgis/src/providers/wms/qgswmsprovider.cpp
--- trunk/qgis/src/providers/wms/qgswmsprovider.cpp 2009-01-24 10:31:10 UTC (rev 10008)
+++ trunk/qgis/src/providers/wms/qgswmsprovider.cpp 2009-01-24 15:56:01 UTC (rev 10009)
@@ -638,6 +638,7 @@
QgsDebugMsg( "WMS request Url: " + url );
+#if 0 //MH: not necessary any more
//read proxy settings
QSettings settings;
QString proxyHost, proxyUser, proxyPassword;
@@ -675,8 +676,11 @@
QgsHttpTransaction http(url, proxyHost, proxyPort, proxyUser, proxyPassword, proxyType );
+#endif //0
+QgsHttpTransaction http(url);
// Do a passthrough for the status bar text
connect(
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2009-01-24 10:31:10 UTC (rev 10008)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2009-01-24 15:56:01 UTC (rev 10009)
@@ -5,17 +5,15 @@
<rect>
<x>0</x>
<y>0</y>
- <width>617</width>
- <height>559</height>
+ <width>851</width>
+ <height>776</height>
</rect>
</property>
<property name="windowTitle" >
<string>QGIS Options</string>
</property>
<property name="windowIcon" >
- <iconset>
- <normaloff/>
- </iconset>
+ <iconset/>
</property>
<property name="sizeGripEnabled" >
<bool>true</bool>
@@ -40,9 +38,18 @@
<string>Project files</string>
</property>
<layout class="QVBoxLayout" >
- <property name="margin" >
+ <property name="leftMargin" >
<number>11</number>
</property>
+ <property name="topMargin" >
+ <number>11</number>
+ </property>
+ <property name="rightMargin" >
+ </property>
+ <property name="bottomMargin" >
+ </property>
<item>
<widget class="QCheckBox" name="chbAskToSaveProjectChanges" >
<property name="text" >
@@ -81,7 +88,7 @@
<property name="orientation" >
<enum>Qt::Horizontal</enum>
</property>
- <property name="sizeHint" stdset="0" >
+ <property name="sizeHint" >
<size>
<width>40</width>
<height>20</height>
@@ -117,7 +124,7 @@
</property>
<size>
<width>40</width>
<height>20</height>
@@ -249,7 +256,7 @@
<enum>Qt::Vertical</enum>
</property>
<size>
<width>577</width>
<height>21</height>
@@ -316,9 +323,18 @@
<string>Rendering quality</string>
</property>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<item>
<widget class="QCheckBox" name="chkAntiAliasing" >
@@ -351,7 +367,7 @@
</property>
<size>
<width>20</width>
<height>40</height>
@@ -366,18 +382,36 @@
<string>&Map tools</string>
</attribute>
<layout class="QGridLayout" >
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<item row="2" column="0" >
<widget class="QGroupBox" name="groupBox_10" >
<property name="title" >
<string>Panning and zooming</string>
</property>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<item row="0" column="1" >
<widget class="QComboBox" name="cmbWheelAction" >
<item>
@@ -438,15 +472,24 @@
<string>Measure tool</string>
</property>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<item row="1" column="2" >
<spacer>
</property>
<size>
<width>191</width>
<height>20</height>
@@ -499,9 +542,18 @@
<string>Search radius</string>
</property>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<item row="1" column="0" colspan="2" >
<widget class="QLabel" name="textLabel2" >
@@ -546,7 +598,7 @@
</property>
<size>
<width>20</width>
<height>40</height>
@@ -560,7 +612,7 @@
<attribute name="title" >
<string>Digitizing</string>
</attribute>
- <layout class="QVBoxLayout" name="verticalLayout" >
+ <layout class="QVBoxLayout" >
<item>
<widget class="QGroupBox" name="mRubberBandGroupBox" >
@@ -631,7 +683,7 @@
</property>
<size>
<width>311</width>
<height>20</height>
@@ -661,7 +713,7 @@
</property>
<size>
<width>241</width>
<height>20</height>
@@ -691,7 +743,7 @@
</property>
<size>
<width>61</width>
<height>20</height>
@@ -730,7 +782,7 @@
</property>
<size>
<width>281</width>
<height>20</height>
@@ -756,7 +808,7 @@
<string>Enter attribute values</string>
</property>
- <layout class="QHBoxLayout" name="horizontalLayout" >
+ <layout class="QHBoxLayout" >
<item>
<widget class="QCheckBox" name="chkDisableAttributeValuesDlg" >
@@ -775,7 +827,7 @@
</property>
<size>
<width>547</width>
<height>71</height>
@@ -790,15 +842,24 @@
<string>CRS</string>
</attribute>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<item row="3" column="0" >
<spacer>
</property>
<size>
<width>51</width>
<height>31</height>
@@ -822,9 +883,18 @@
<string>When layer is loaded that has no coordinate reference system (CRS)</string>
</property>
<number>11</number>
</property>
+ </property>
+ </property>
+ </property>
<item>
<widget class="QRadioButton" name="radPromptForProjection" >
@@ -896,7 +966,7 @@
</property>
<size>
<width>501</width>
<height>51</height>
@@ -949,7 +1019,7 @@
</property>
</widget>
</item>
- <item row="0" column="1" colspan="2" >
+ <item row="0" column="1" colspan="5" >
<widget class="QLineEdit" name="leProxyHost" />
</item>
<item row="1" column="0" >
@@ -962,7 +1032,7 @@
</property>
</widget>
</item>
- <item row="1" column="1" colspan="2" >
+ <item row="1" column="1" colspan="5" >
<widget class="QLineEdit" name="leProxyPort" />
</item>
@@ -975,7 +1045,7 @@
</property>
</widget>
</item>
- <item row="2" column="1" colspan="2" >
+ <item row="2" column="1" colspan="5" >
<widget class="QLineEdit" name="leProxyUser" >
<property name="toolTip" >
<string>Leave this blank if no proxy username / password are required</string>
@@ -992,7 +1062,7 @@
</property>
</widget>
</item>
- <item row="3" column="1" colspan="2" >
+ <item row="3" column="1" colspan="5" >
<widget class="QLineEdit" name="leProxyPassword" >
@@ -1009,15 +1079,15 @@
</property>
</widget>
</item>
- <item row="4" column="1" >
+ <item row="4" column="1" colspan="2" >
<widget class="QComboBox" name="mProxyTypeComboBox" />
</item>
- <item row="4" column="2" >
+ <item row="4" column="3" colspan="3" >
<spacer>
</property>
<size>
<width>241</width>
<height>20</height>
@@ -1025,22 +1095,46 @@
</property>
</spacer>
</item>
+ <item row="5" column="0" colspan="2" >
+ <widget class="QLabel" name="mExcludeUrlsLabel" >
+ <property name="text" >
+ <string>Exclude URLs:</string>
+ </property>
+ </widget>
+ </item>
+ <item row="5" column="2" colspan="2" >
+ <widget class="QPushButton" name="mAddUrlPushButton" >
+ <string>Add</string>
+ </property>
+ </widget>
+ </item>
+ <item row="5" column="4" >
+ <widget class="QPushButton" name="mRemoveUrlPushButton" >
+ <string>Remove</string>
+ </property>
+ </widget>
+ </item>
+ <item row="5" column="5" >
+ <spacer>
+ <property name="orientation" >
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <size>
+ <width>391</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item row="6" column="0" colspan="6" >
+ <widget class="QListWidget" name="mExcludeUrlListWidget" />
+ </item>
</layout>
</widget>
</item>
- <item row="1" column="0" >
- <spacer>
- <property name="orientation" >
- <enum>Qt::Vertical</enum>
- </property>
- <size>
- <width>577</width>
- <height>251</height>
- </size>
- </property>
- </spacer>
- </item>
</layout>
</widget>
</widget>
@@ -1051,7 +1145,7 @@
</property>
<property name="standardButtons" >
- <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
</property>
</widget>
</item>
