[QGIS Commit] r10066 - in trunk/qgis: src/app src/core
src/core/composer src/gui src/providers/ogr src/python
tests/src/core
svn_qgis at osgeo.org
Sat Jan 31 11:26:57 EST 2009
Author: jef
Date: 2009-01-31 11:26:56 -0500 (Sat, 31 Jan 2009)
New Revision: 10066
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/app/qgsogrsublayersdialog.cpp
trunk/qgis/src/app/qgsogrsublayersdialog.h
trunk/qgis/src/app/qgsserversourceselect.cpp
trunk/qgis/src/core/composer/qgscomposermap.cpp
trunk/qgis/src/core/qgsgeometry.cpp
trunk/qgis/src/core/qgsvectorlayer.cpp
trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp
trunk/qgis/src/gui/qgsmapcanvas.cpp
trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
trunk/qgis/src/providers/ogr/qgsogrprovider.h
trunk/qgis/src/python/qgspythonutilsimpl.cpp
trunk/qgis/src/python/qgspythonutilsimpl.h
trunk/qgis/tests/src/core/testqgsrenderers.cpp
automatic indentation update (r10009-r10065)
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-01-31 16:26:56 UTC (rev 10066)
@@ -801,7 +801,7 @@
mActionLayerSelectionSaveAs->setStatusTip( tr( "Save the selection as a shapefile" ) );
connect( mActionLayerSelectionSaveAs, SIGNAL( triggered() ), this, SLOT( saveSelectionAsShapefile() ) );
mActionLayerSelectionSaveAs->setEnabled( false );
mActionRemoveLayer = new QAction( getThemeIcon( "mActionRemoveLayer.png" ), tr( "Remove Layer" ), this );
mActionRemoveLayer->setShortcut( tr( "Ctrl+D", "Remove a Layer" ) );
mActionRemoveLayer->setStatusTip( tr( "Remove a Layer" ) );
@@ -2173,15 +2173,16 @@
// If the newly created layer has more than 1 layer of data available, we show the
// sublayers selection dialog so the user can select the sublayers to actually load.
- if ( sublayers.count() > 1)
- askUserForSublayers(layer);
+ if ( sublayers.count() > 1 )
+ askUserForSublayers( layer );
- // The first layer loaded is not usefull in that case. The user can select it in
+ // The first layer loaded is not usefull in that case. The user can select it in
// the list if he wants to load it.
delete layer;
- }else // there is 1 layer of data available
+ else // there is 1 layer of data available
// Register this layer with the layers registry
QgsMapLayerRegistry::instance()->addMapLayer( layer );
@@ -2219,57 +2220,57 @@
} // QgisApp::addVectorLayer()
// This method is the method that does the real job. If the layer given in
-// parameter is NULL, then the method tries to act on the activeLayer.
-void QgisApp::askUserForSublayers(QgsVectorLayer *layer)
+// parameter is NULL, then the method tries to act on the activeLayer.
+void QgisApp::askUserForSublayers( QgsVectorLayer *layer )
- if (layer == NULL)
+ if ( layer == NULL )
- if (activeLayer() == NULL || activeLayer()->type() != QgsMapLayer::VectorLayer)
+ if ( activeLayer() == NULL || activeLayer()->type() != QgsMapLayer::VectorLayer )
return;
- layer = (QgsVectorLayer*) activeLayer();
- if (layer->dataProvider()->name() != "ogr")
+ layer = ( QgsVectorLayer* ) activeLayer();
+ if ( layer->dataProvider()->name() != "ogr" )
return;
QStringList sublayers = layer->dataProvider()->subLayers();
// We initialize a selection dialog and display it.
QgsOGRSublayersDialog chooseSublayersDialog( this );
chooseSublayersDialog.populateLayerTable( sublayers );
- if (chooseSublayersDialog.exec())
+ if ( chooseSublayersDialog.exec() )
QString uri = layer->source();
- if ( uri.contains('&', Qt::CaseSensitive) )
+ if ( uri.contains( '&', Qt::CaseSensitive ) )
// If we get here, there are some options added to the filename.
// A valid uri is of the form: filename&option1=value1&option2=value2,...
// We want only the filename here, so we get the first part of the split.
- QStringList theURIParts = uri.split("&");
+ QStringList theURIParts = uri.split( "&" );
uri = theURIParts.at( 0 );
// the user has done his choice
- loadOGRSublayers(uri, chooseSublayersDialog.getSelection());
+ loadOGRSublayers( uri, chooseSublayersDialog.getSelection() );
-// This method will load with OGR the layers in parameter.
+// This method will load with OGR the layers in parameter.
// This method has been conceived to use the new URI
// format of the ogrprovider so as to give precisions about which
// sublayer to load into QGIS. It is normally triggered by the
// sublayer selection dialog.
-void QgisApp::loadOGRSublayers( QString uri, QStringList list)
+void QgisApp::loadOGRSublayers( QString uri, QStringList list )
// The uri must contain the actual uri of the vectorLayer from which we are
// going to load the sublayers.
- QString fileName = QFileInfo(uri).baseName();
- for (int i = 0; i < list.size(); i++)
- QString composedURI=uri+"&layername="+list.at(i);
- QgsVectorLayer *layer=addVectorLayer(composedURI,fileName+":"+list.at(i),"ogr");
+ QString fileName = QFileInfo( uri ).baseName();
+ for ( int i = 0; i < list.size(); i++ )
+ QString composedURI = uri + "&layername=" + list.at( i );
+ QgsVectorLayer *layer = addVectorLayer( composedURI, fileName + ":" + list.at( i ), "ogr" );
/** This helper checks to see whether the file name appears to be a valid vector file name */
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/app/qgisapp.h 2009-01-31 16:26:56 UTC (rev 10066)
@@ -600,7 +600,7 @@
/** This method will open a dialog so the user can select the sublayers
* to load
- void askUserForSublayers(QgsVectorLayer *layer);
+ void askUserForSublayers( QgsVectorLayer *layer );
/** Add a raster layer to the map (passed in as a ptr).
* It won't force a refresh.
Modified: trunk/qgis/src/app/qgsogrsublayersdialog.cpp
--- trunk/qgis/src/app/qgsogrsublayersdialog.cpp 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/app/qgsogrsublayersdialog.cpp 2009-01-31 16:26:56 UTC (rev 10066)
@@ -23,8 +23,8 @@
: QDialog( parent, fl )
setupUi( this );
- QStringList labels=QStringList() << "Layer ID" << "Layer name" << "Nb of features" << "Geometry type";
- layersTable->setHeaderLabels(labels);
+ QStringList labels = QStringList() << "Layer ID" << "Layer name" << "Nb of features" << "Geometry type";
+ layersTable->setHeaderLabels( labels );
QgsOGRSublayersDialog::~QgsOGRSublayersDialog()
@@ -33,22 +33,23 @@
QStringList QgsOGRSublayersDialog::getSelection()
- QStringList list=QStringList();
- for (int i = 0; i < layersTable-> selectedItems().size(); i++)
+ QStringList list = QStringList();
+ for ( int i = 0; i < layersTable-> selectedItems().size(); i++ )
- QString theItem =layersTable-> selectedItems().at(i)->text(1);
- list.append(theItem);
+ QString theItem = layersTable-> selectedItems().at( i )->text( 1 );
+ list.append( theItem );
return list;
-void QgsOGRSublayersDialog::populateLayerTable (QStringList theList)
+void QgsOGRSublayersDialog::populateLayerTable( QStringList theList )
- for (int i =0; i< theList.size(); i++){
- QString ligne = theList.at(i);
- QStringList elements = ligne.split(":");
- QStringList item=QStringList();
- item << elements.at(0) << elements.at(1) << elements.at(2) << elements.at(3);
- layersTable -> addTopLevelItem(new QTreeWidgetItem(item));
+ for ( int i = 0; i < theList.size(); i++ )
+ QString ligne = theList.at( i );
+ QStringList elements = ligne.split( ":" );
+ QStringList item = QStringList();
+ item << elements.at( 0 ) << elements.at( 1 ) << elements.at( 2 ) << elements.at( 3 );
+ layersTable -> addTopLevelItem( new QTreeWidgetItem( item ) );
Modified: trunk/qgis/src/app/qgsogrsublayersdialog.h
--- trunk/qgis/src/app/qgsogrsublayersdialog.h 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/app/qgsogrsublayersdialog.h 2009-01-31 16:26:56 UTC (rev 10066)
@@ -28,8 +28,8 @@
public:
QgsOGRSublayersDialog( QWidget* parent = 0, Qt::WFlags fl = 0 );
~QgsOGRSublayersDialog();
- void populateLayerTable(QStringList theList);
- QStringList getSelection();
+ void populateLayerTable( QStringList theList );
+ QStringList getSelection();
Modified: trunk/qgis/src/app/qgsserversourceselect.cpp
--- trunk/qgis/src/app/qgsserversourceselect.cpp 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/app/qgsserversourceselect.cpp 2009-01-31 16:26:56 UTC (rev 10066)
@@ -77,7 +77,7 @@
int i = 1;
while ( iter != m_PotentialFormats.end() )
- QRadioButton* btn = new QRadioButton(iter.value().first);
+ QRadioButton* btn = new QRadioButton( iter.value().first );
m_imageFormatGroup->addButton( btn, iter.value().second );
m_imageFormatLayout->addWidget( btn );
if ( i == 1 )
@@ -584,7 +584,7 @@
QString imageEncoding = m_PotentialFormats.key( qMakePair( label, id ) );
//substitute blanks with %20 (e.g. in "image/png; mode=24bit")
- imageEncoding.replace(QRegExp(" "), "%20");
+ imageEncoding.replace( QRegExp( " " ), "%20" );
return imageEncoding;
Modified: trunk/qgis/src/core/composer/qgscomposermap.cpp
--- trunk/qgis/src/core/composer/qgscomposermap.cpp 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/core/composer/qgscomposermap.cpp 2009-01-31 16:26:56 UTC (rev 10066)
@@ -372,7 +372,7 @@
mExtent = QgsRectangle( mExtent.xMinimum(), mExtent.yMinimum(), mExtent.xMaximum(), mExtent.yMinimum() + newHeight );
mCacheUpdated = false;
emit extentChanged();
- if(mPreviewMode != Rectangle)
+ if ( mPreviewMode != Rectangle )
cache();
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/core/qgsgeometry.cpp 2009-01-31 16:26:56 UTC (rev 10066)
@@ -5453,29 +5453,29 @@
if ( mGeos == NULL )
return QList<QgsGeometry*>();
int type = GEOSGeomTypeId( mGeos );
- QgsDebugMsg("geom type: "+QString::number(type));
+ QgsDebugMsg( "geom type: " + QString::number( type ) );
QList<QgsGeometry*> geomCollection;
if ( type != GEOS_MULTIPOINT &&
type != GEOS_MULTILINESTRING &&
type != GEOS_MULTIPOLYGON &&
type != GEOS_GEOMETRYCOLLECTION )
// we have a single-part geometry - put there a copy of this one
- geomCollection.append( new QgsGeometry(*this) );
+ geomCollection.append( new QgsGeometry( *this ) );
return geomCollection;
int count = GEOSGetNumGeometries( mGeos );
- QgsDebugMsg("geom count: "+QString::number(count));
+ QgsDebugMsg( "geom count: " + QString::number( count ) );
for ( int i = 0; i < count; ++i )
const GEOSGeometry * geometry = GEOSGetGeometryN( mGeos, i );
- geomCollection.append( fromGeosGeom( GEOSGeom_clone(geometry) ) );
+ geomCollection.append( fromGeosGeom( GEOSGeom_clone( geometry ) ) );
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2009-01-31 16:26:56 UTC (rev 10066)
@@ -2324,7 +2324,7 @@
if ( !renderer )
- errorMessage = tr("Unknown renderer");
+ errorMessage = tr( "Unknown renderer" );
return false;
Modified: trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp
--- trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/gui/qgsdetaileditemdelegate.cpp 2009-01-31 16:26:56 UTC (rev 10066)
@@ -122,11 +122,11 @@
if ( theOption.state & QStyle::State_Selected )
drawHighlight( theOption, thepPainter, height( theOption, theData ) );
- thepPainter->setPen(theOption.palette.highlightedText().color());
+ thepPainter->setPen( theOption.palette.highlightedText().color() );
else
- thepPainter->setPen(theOption.palette.text().color());
+ thepPainter->setPen( theOption.palette.text().color() );
Modified: trunk/qgis/src/gui/qgsmapcanvas.cpp
--- trunk/qgis/src/gui/qgsmapcanvas.cpp 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/gui/qgsmapcanvas.cpp 2009-01-31 16:26:56 UTC (rev 10066)
@@ -431,14 +431,14 @@
myHeader += QString::number( myRect.xMinimum() ) + "\r\n";
//Origin Y (top left corner)
myHeader += QString::number( myRect.yMaximum() ) + "\r\n";
- QFileInfo myInfo = QFileInfo(theFileName);
+ QFileInfo myInfo = QFileInfo( theFileName );
QString myWorldFileName = myInfo.absolutePath() + QDir::separator() + myInfo.baseName() + "." + theFormat + "w";
- QFile myWorldFile(myWorldFileName);
- if (!myWorldFile.open(QIODevice::WriteOnly | QIODevice::Text))
+ QFile myWorldFile( myWorldFileName );
+ if ( !myWorldFile.open( QIODevice::WriteOnly | QIODevice::Text ) )
return;
- QTextStream myStream(&myWorldFile);
+ QTextStream myStream( &myWorldFile );
myStream << myHeader;
} // saveAsImage
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2009-01-31 16:26:56 UTC (rev 10066)
@@ -74,30 +74,30 @@
// message if the file is read only, because we cope with that
// ourselves.
- // This part of the code parses the uri transmitted to the ogr provider to
+ // This part of the code parses the uri transmitted to the ogr provider to
// get the options the client wants us to apply
QString mFilePath;
QString theLayerName;
- int theLayerIndex=0;
+ int theLayerIndex = 0;
// If there is no & in the uri, then the uri is just the filename. The loaded
// layer will be layer 0.
- if ( ! uri.contains('&', Qt::CaseSensitive))
+ if ( ! uri.contains( '&', Qt::CaseSensitive ) )
mFilePath = uri;
else
- // If we get here, there are some options added to the filename. We must parse
- // the different parts separated by &, and among each option, the name and the
- // value around the =.
- // A valid uri is of the form: filename&option1=value1&option2=value2,...
+ // If we get here, there are some options added to the filename. We must parse
+ // the different parts separated by &, and among each option, the name and the
+ // value around the =.
+ // A valid uri is of the form: filename&option1=value1&option2=value2,...
mFilePath = theURIParts.at( 0 );
- for (int i = 1 ; i < theURIParts.size(); i++ )
+ for ( int i = 1 ; i < theURIParts.size(); i++ )
QStringList theInstruction = theURIParts.at( i ).split( "=" );
if ( theInstruction.at( 0 ) == QString( "layerid" ) )
@@ -112,14 +112,14 @@
if ( theInstruction.at( 0 ) == QString( "layername" ) )
theLayerName = theInstruction.at( 1 );
- QgsDebugMsg("mFilePath: " + mFilePath);
- QgsDebugMsg("theLayerIndex: "+theLayerIndex);
- QgsDebugMsg("theLayerName: "+theLayerName);
+ QgsDebugMsg( "mFilePath: " + mFilePath );
+ QgsDebugMsg( "theLayerIndex: " + theLayerIndex );
+ QgsDebugMsg( "theLayerName: " + theLayerName );
CPLPushErrorHandler( CPLQuietErrorHandler );
ogrDataSource = OGROpen( QFile::encodeName( mFilePath ).constData(), TRUE, &ogrDriver );
CPLPopErrorHandler();
@@ -142,7 +142,7 @@
valid = true;
ogrDriverName = OGR_Dr_GetName( ogrDriver );
// We get the layer which was requested by the uri. The layername
// has precedence over the layerid if both are given.
if ( theLayerName.isNull() )
@@ -151,7 +151,7 @@
else
- ogrLayer = OGR_DS_GetLayerByName( ogrDataSource, (char*)(theLayerName.toLocal8Bit().data()) );
+ ogrLayer = OGR_DS_GetLayerByName( ogrDataSource, ( char* )( theLayerName.toLocal8Bit().data() ) );
// get the extent_ (envelope) of the layer
@@ -204,19 +204,19 @@
QStringList QgsOgrProvider::subLayers() const
QStringList theList = QStringList();
- if (! valid )
+ if ( ! valid )
return theList;
for ( int i = 0; i < layerCount() ; i++ )
- QString theLayerName = QString(OGR_FD_GetName(OGR_L_GetLayerDefn(OGR_DS_GetLayer( ogrDataSource, i ))));
- OGRwkbGeometryType layerGeomType = OGR_FD_GetGeomType(OGR_L_GetLayerDefn(OGR_DS_GetLayer( ogrDataSource, i )));
+ QString theLayerName = QString( OGR_FD_GetName( OGR_L_GetLayerDefn( OGR_DS_GetLayer( ogrDataSource, i ) ) ) );
+ OGRwkbGeometryType layerGeomType = OGR_FD_GetGeomType( OGR_L_GetLayerDefn( OGR_DS_GetLayer( ogrDataSource, i ) ) );
- int theLayerFeatureCount=OGR_L_GetFeatureCount(OGR_DS_GetLayer( ogrDataSource, i ),1) ;
+ int theLayerFeatureCount = OGR_L_GetFeatureCount( OGR_DS_GetLayer( ogrDataSource, i ), 1 ) ;
QString geom;
- switch (layerGeomType)
+ switch ( layerGeomType )
case wkbUnknown: geom = "Unknown"; break;
case wkbPoint: geom="Point"; break;
@@ -232,9 +232,9 @@
case wkbMultiPoint25D: geom="MultiPoint25D"; break;
case wkbMultiLineString25D: geom="MultiLineString25D"; break;
case wkbMultiPolygon25D: geom="MultiPolygon25D"; break;
- default: geom="Unknown WKB: " + QString::number(layerGeomType);
+ default: geom="Unknown WKB: " + QString::number( layerGeomType );
- theList.append(QString::number(i)+":"+ theLayerName+":"+QString::number(theLayerFeatureCount)+":"+geom);
+ theList.append( QString::number( i ) + ":" + theLayerName + ":" + QString::number( theLayerFeatureCount ) + ":" + geom );
return theList;
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.h
--- trunk/qgis/src/providers/ogr/qgsogrprovider.h 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.h 2009-01-31 16:26:56 UTC (rev 10066)
@@ -47,7 +47,7 @@
virtual QgsCoordinateReferenceSystem crs();
* Sub-layers handled by this provider, in order from bottom to top
* Sub-layers are used when the provider's source can combine layers
@@ -188,7 +188,7 @@
* @param index the index of the attribute
* @param values reference to the list of unique values */
virtual void uniqueValues( int index, QList<QVariant> &uniqueValues );
/** return a provider name
Essentially just returns the provider key. Should be used to build file
Modified: trunk/qgis/src/python/qgspythonutilsimpl.cpp
--- trunk/qgis/src/python/qgspythonutilsimpl.cpp 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/python/qgspythonutilsimpl.cpp 2009-01-31 16:26:56 UTC (rev 10066)
@@ -305,7 +305,7 @@
if ( !PyErr_Occurred() )
return false;
PyObject* obj_str;
PyObject* err_type;
PyObject* err_value;
@@ -341,13 +341,13 @@
QString QgsPythonUtilsImpl::PyObjectToQString( PyObject* obj )
QString result;
// is it None?
if ( obj == Py_None )
return QString();
// check whether the object is already a unicode string
if ( PyUnicode_Check( obj ) )
@@ -359,31 +359,31 @@
Py_XDECREF( utf8 );
return result;
// check whether the object is a classical (8-bit) string
if ( PyString_Check( obj ) )
return QString::fromUtf8( PyString_AS_STRING( obj ) );
// it's some other type of object:
// convert object to unicode string (equivalent to calling unicode(obj) )
PyObject* obj_uni = PyObject_Unicode( obj ); // obj_uni is new reference
if ( obj_uni )
// get utf-8 representation of unicode string (new reference)
- PyObject* obj_utf8 = PyUnicode_AsUTF8String(obj_uni);
+ PyObject* obj_utf8 = PyUnicode_AsUTF8String( obj_uni );
// convert from utf-8 to QString
if ( obj_utf8 )
- result = QString::fromUtf8(PyString_AsString( obj_utf8 ));
+ result = QString::fromUtf8( PyString_AsString( obj_utf8 ) );
else
result = "(qgis error)";
Py_XDECREF( obj_utf8 );
Py_XDECREF( obj_uni );
return result;
// if conversion to unicode failed, try to convert it to classic string, i.e. str(obj)
PyObject* obj_str = PyObject_Str( obj ); // new reference
if ( obj_str )
@@ -392,9 +392,9 @@
Py_XDECREF( obj_str );
return result;
// some problem with conversion to unicode string
- QgsDebugMsg("unable to convert PyObject to a QString!");
+ QgsDebugMsg( "unable to convert PyObject to a QString!" );
return "(qgis error)";
Modified: trunk/qgis/src/python/qgspythonutilsimpl.h
--- trunk/qgis/src/python/qgspythonutilsimpl.h 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/src/python/qgspythonutilsimpl.h 2009-01-31 16:26:56 UTC (rev 10066)
@@ -118,7 +118,7 @@
//! convert python object to QString. If the object isn't unicode/str, it will be converted
QString PyObjectToQString( PyObject* obj );
//! reference to module __main__
PyObject* mMainModule;
Modified: trunk/qgis/tests/src/core/testqgsrenderers.cpp
--- trunk/qgis/tests/src/core/testqgsrenderers.cpp 2009-01-31 16:04:02 UTC (rev 10065)
+++ trunk/qgis/tests/src/core/testqgsrenderers.cpp 2009-01-31 16:26:56 UTC (rev 10066)
@@ -196,7 +196,7 @@
QString error = mpPointsLayer->loadNamedStyle( myFileName, myStyleFlag );
if ( !myStyleFlag )
- qDebug(error.toLocal8Bit().data());
+ qDebug( error.toLocal8Bit().data() );
return false;
else
