[QGIS Commit] r10992 - in trunk/qgis/src: app app/legend core core/composer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 1 06:11:34 EDT 2009
Author: mhugent
Date: 2009-07-01 06:11:33 -0400 (Wed, 01 Jul 2009)
New Revision: 10992
   trunk/qgis/src/app/legend/qgslegendlayer.cpp
   trunk/qgis/src/app/qgsattributedialog.cpp
   trunk/qgis/src/app/qgscontinuouscolordialog.cpp
   trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp
   trunk/qgis/src/app/qgsmaptoolidentify.cpp
   trunk/qgis/src/app/qgsuniquevaluedialog.cpp
   trunk/qgis/src/core/composer/qgslegendmodel.cpp
   trunk/qgis/src/core/qgsvectorlayer.cpp
   trunk/qgis/src/core/qgsvectorlayer.h
Added a convenience to retrieve the attribute display name from QgsVectorLayer. Use this function in renderer dialogs, info tool, attribute table and composer legend
Modified: trunk/qgis/src/app/legend/qgslegendlayer.cpp
--- trunk/qgis/src/app/legend/qgslegendlayer.cpp	2009-07-01 07:51:18 UTC (rev 10991)
+++ trunk/qgis/src/app/legend/qgslegendlayer.cpp	2009-07-01 10:11:33 UTC (rev 10992)
@@ -370,11 +370,14 @@
     if ( renderer->needsAttributes() )
       QgsAttributeList classfieldlist = renderer->classificationAttributes();
-      const QgsFieldMap& fields = layer->dataProvider()->fields();
+      const QgsFieldMap& fields = layer->pendingFields();
       for ( QgsAttributeList::iterator it = classfieldlist.begin(); it != classfieldlist.end(); ++it )
-        const QgsField& theField = fields[*it];
-        QString classfieldname = theField.name();
+        QString classfieldname = layer->attributeAlias(*it);
+        if(classfieldname.isEmpty())
+            classfieldname = fields[*it].name();
         itemList.push_front( std::make_pair( classfieldname, QPixmap() ) );
Modified: trunk/qgis/src/app/qgsattributedialog.cpp
--- trunk/qgis/src/app/qgsattributedialog.cpp	2009-07-01 07:51:18 UTC (rev 10991)
+++ trunk/qgis/src/app/qgsattributedialog.cpp	2009-07-01 10:11:33 UTC (rev 10992)
@@ -103,11 +103,7 @@
     const QgsField &field = theFieldMap[it.key()];
     //show attribute alias if available
-    QString myFieldName = vl->attributeAlias(it.key());
-    if(myFieldName.isEmpty())
-      myFieldName = field.name();
+    QString myFieldName = vl->attributeDisplayName(it.key());
     int myFieldType = field.type();
     QLabel * mypLabel = new QLabel();
     mypInnerLayout->addWidget( mypLabel, index, 0 );
Modified: trunk/qgis/src/app/qgscontinuouscolordialog.cpp
--- trunk/qgis/src/app/qgscontinuouscolordialog.cpp	2009-07-01 07:51:18 UTC (rev 10991)
+++ trunk/qgis/src/app/qgscontinuouscolordialog.cpp	2009-07-01 10:11:33 UTC (rev 10992)
@@ -41,13 +41,15 @@
   //find out the numerical fields of mVectorLayer
   const QgsFieldMap & fields = mVectorLayer->pendingFields();
+  QString displayName;
   for ( QgsFieldMap::const_iterator it = fields.begin(); it != fields.end(); ++it )
     QVariant::Type type = it->type();
     if ( type == QVariant::Int || type == QVariant::Double )
-      classificationComboBox->addItem( it->name(), it.key() );
+      displayName = mVectorLayer->attributeDisplayName(it.key());
+      classificationComboBox->addItem( displayName, it.key() );
@@ -144,7 +146,7 @@
   else
-    minimumString = QString::number( minimum );
+    minimumString = QString::number( minimum, 'f', 0 );
   QgsSymbol* minsymbol = new QgsSymbol( mVectorLayer->geometryType(), minimumString, "", "" );
   QPen minPen;
@@ -167,7 +169,7 @@
   else
-    maximumString = QString::number( maximum );
+    maximumString = QString::number( maximum, 'f', 0 );
   QgsSymbol* maxsymbol = new QgsSymbol( mVectorLayer->geometryType(), maximumString, "", "" );
   QPen maxPen;
Modified: trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp
--- trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp	2009-07-01 07:51:18 UTC (rev 10991)
+++ trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp	2009-07-01 10:11:33 UTC (rev 10992)
@@ -37,15 +37,16 @@
   const QgsFieldMap & fields = layer->pendingFields();
-  QString str;
       QVariant::Type type = ( *it ).type();
-        classificationComboBox->addItem( it->name() );
-        mFieldMap.insert( std::make_pair( it->name(), it.key() ) );
+        displayName = layer->attributeDisplayName(it.key());
+        classificationComboBox->addItem( displayName );
+        mFieldMap.insert( std::make_pair( displayName, it.key() ) );
@@ -350,7 +351,7 @@
         else
-          lowerString = QString::number(*last_it);
+          lowerString = QString::number(*last_it, 'f', 0);
         ( *symbol_it )->setLowerValue(lowerString);
@@ -360,7 +361,7 @@
         else
-          upperString = QString::number(*it);
+          upperString = QString::number(*it, 'f', 0);
         ( *symbol_it )->setUpperValue(upperString);
@@ -391,7 +392,7 @@
       else
-            lowerString = QString::number(lower);
+            lowerString = QString::number(lower, 'f', 0);
@@ -403,7 +404,7 @@
       else
-        upperString = QString::number(upper);
+        upperString = QString::number(upper, 'f', 0);
Modified: trunk/qgis/src/app/qgsmaptoolidentify.cpp
--- trunk/qgis/src/app/qgsmaptoolidentify.cpp	2009-07-01 07:51:18 UTC (rev 10991)
+++ trunk/qgis/src/app/qgsmaptoolidentify.cpp	2009-07-01 10:11:33 UTC (rev 10992)
@@ -337,11 +337,7 @@
         featureNode->setText( 1, it->toString() );
-      QString attributeName = layer->attributeAlias(it.key());
-      if(attributeName.isEmpty())
-        attributeName = fields[it.key()].name();
+      QString attributeName = layer->attributeDisplayName(it.key());
       mResults->addAttribute( featureNode, attributeName, it->isNull() ? "NULL" : it->toString() );
Modified: trunk/qgis/src/app/qgsuniquevaluedialog.cpp
--- trunk/qgis/src/app/qgsuniquevaluedialog.cpp	2009-07-01 07:51:18 UTC (rev 10991)
+++ trunk/qgis/src/app/qgsuniquevaluedialog.cpp	2009-07-01 10:11:33 UTC (rev 10992)
@@ -32,66 +32,65 @@
   setupUi( this );
   setOrientation( Qt::Vertical );
   //find out the fields of mVectorLayer
-  QgsVectorDataProvider *provider;
-  if (( provider = dynamic_cast<QgsVectorDataProvider *>( mVectorLayer->dataProvider() ) ) )
+  if(mVectorLayer)
-    const QgsFieldMap & fields = provider->fields();
-    QString str;
-    for ( QgsFieldMap::const_iterator it = fields.begin(); it != fields.end(); ++it )
+    //we cannot use unique values for not-commited fields because QgsVectorLayer has no 'unique values' method...
+    QgsVectorDataProvider* provider = mVectorLayer->dataProvider();
+    if(provider)
-      str = ( *it ).name();
-      mClassificationComboBox->addItem( str );
+      const QgsFieldMap & fields = provider->fields();
+      QString str;
+      for ( QgsFieldMap::const_iterator it = fields.begin(); it != fields.end(); ++it )
+        str = ( *it ).name();
+        str = mVectorLayer->attributeDisplayName(it.key());
+        mClassificationComboBox->addItem( str, it.key() );
-  else
-    QgsDebugMsg( "data provider is null" );
-    return;
   mClassListWidget->setSelectionMode( QAbstractItemView::ExtendedSelection );
   mClassListWidget->setEditTriggers( QAbstractItemView::DoubleClicked | QAbstractItemView::EditKeyPressed | QAbstractItemView::AnyKeyPressed );
   mClassListWidget->setSortingEnabled( true );
-  const QgsUniqueValueRenderer* renderer = dynamic_cast < const QgsUniqueValueRenderer * >( mVectorLayer->renderer() );
-  if ( renderer )
+  if(mVectorLayer)
-    mClassListWidget->clear();
+    const QgsUniqueValueRenderer* renderer = dynamic_cast < const QgsUniqueValueRenderer * >( mVectorLayer->renderer() );
-    // XXX - mloskot - fix for Ticket #31 (bug)
-    //QgsAttributeList attributes = renderer->classificationAttributes();
-    //QgsAttributeList::iterator iter = attributes.begin();
-    //int classattr = *iter;
-    //QString field = provider->fields()[ classattr ].name();
-    QString field = provider->fields()[ renderer->classificationField()].name();
-    mOldClassificationAttribute = field;
-    mClassificationComboBox->setCurrentIndex( mClassificationComboBox->findText( field ) );
-    const QList<QgsSymbol*> list = renderer->symbols();
-    //fill the items of the renderer into mValues
-    for ( QList<QgsSymbol*>::const_iterator iter = list.begin(); iter != list.end(); ++iter )
+    if ( renderer )
-      QgsSymbol* symbol = ( *iter );
-      QString symbolvalue = symbol->lowerValue();
-      QgsSymbol* sym = new QgsSymbol( mVectorLayer->geometryType(), symbol->lowerValue(), symbol->upperValue(), symbol->label() );
-      sym->setPen( symbol->pen() );
-      sym->setCustomTexture( symbol->customTexture() );
-      sym->setBrush( symbol->brush() );
-      sym->setNamedPointSymbol( symbol->pointSymbolName() );
-      sym->setPointSize( symbol->pointSize() );
-      sym->setScaleClassificationField( symbol->scaleClassificationField() );
-      sym->setRotationClassificationField( symbol->rotationClassificationField() );
-      mValues.insert( symbolvalue, sym );
+      mClassListWidget->clear();
+      QString field = mVectorLayer->attributeDisplayName(renderer->classificationField());
+      mOldClassificationAttribute = field;
+      mClassificationComboBox->setCurrentIndex( mClassificationComboBox->findText( field ) );
-      QListWidgetItem *item = new QListWidgetItem( symbolvalue );
-      mClassListWidget->addItem( item );
-      updateEntryIcon( symbol, item );
-      item->setFlags( Qt::ItemIsSelectable | Qt::ItemIsEditable | Qt::ItemIsEnabled );
-      item->setData( Qt::UserRole, symbol->lowerValue() );
-      item->setToolTip( symbol->label() );
+      const QList<QgsSymbol*> list = renderer->symbols();
+      //fill the items of the renderer into mValues
+      for ( QList<QgsSymbol*>::const_iterator iter = list.begin(); iter != list.end(); ++iter )
+        QgsSymbol* symbol = ( *iter );
+        QString symbolvalue = symbol->lowerValue();
+        QgsSymbol* sym = new QgsSymbol( mVectorLayer->geometryType(), symbol->lowerValue(), symbol->upperValue(), symbol->label() );
+        sym->setPen( symbol->pen() );
+        sym->setCustomTexture( symbol->customTexture() );
+        sym->setBrush( symbol->brush() );
+        sym->setNamedPointSymbol( symbol->pointSymbolName() );
+        sym->setPointSize( symbol->pointSize() );
+        sym->setScaleClassificationField( symbol->scaleClassificationField() );
+        sym->setRotationClassificationField( symbol->rotationClassificationField() );
+        mValues.insert( symbolvalue, sym );
+        QListWidgetItem *item = new QListWidgetItem( symbolvalue );
+        mClassListWidget->addItem( item );
+        updateEntryIcon( symbol, item );
+        item->setFlags( Qt::ItemIsSelectable | Qt::ItemIsEditable | Qt::ItemIsEnabled );
+        item->setData( Qt::UserRole, symbol->lowerValue() );
+        item->setToolTip( symbol->label() );
@@ -149,7 +148,7 @@
   QgsVectorDataProvider *provider = dynamic_cast<QgsVectorDataProvider *>( mVectorLayer->dataProvider() );
   if ( provider )
-    int fieldIndex = provider->fieldNameIndex( mClassificationComboBox->currentText() );
+    int fieldIndex = mClassificationComboBox->itemData( mClassificationComboBox->currentIndex() ).toInt();
     if ( fieldIndex != -1 )
       renderer->setClassificationField( fieldIndex );
@@ -292,7 +291,7 @@
   if ( provider )
-    int nr = provider->fieldNameIndex( attributeName );
+    int nr = mClassificationComboBox->itemData(mClassificationComboBox->currentIndex()).toInt();
     if ( nr == -1 )
       return;
Modified: trunk/qgis/src/core/composer/qgslegendmodel.cpp
--- trunk/qgis/src/core/composer/qgslegendmodel.cpp	2009-07-01 07:51:18 UTC (rev 10991)
+++ trunk/qgis/src/core/composer/qgslegendmodel.cpp	2009-07-01 10:11:33 UTC (rev 10992)
@@ -102,22 +102,17 @@
   QSettings settings;
   if ( settings.value( "/qgis/showLegendClassifiers", false ).toBool() )
-    QgsVectorDataProvider* provider = vectorLayer->dataProvider();
-    if ( provider )
+    QgsFieldMap layerFields = vectorLayer->pendingFields();
+    QgsAttributeList attributes = vectorRenderer->classificationAttributes();
+    QgsAttributeList::const_iterator att_it = attributes.constBegin();
+    for ( ; att_it != attributes.constEnd(); ++att_it )
-      QgsFieldMap providerFields = provider->fields();
-      QgsAttributeList attributes = vectorRenderer->classificationAttributes();
-      QgsAttributeList::const_iterator att_it = attributes.constBegin();
-      for ( ; att_it != attributes.constEnd(); ++att_it )
+      QgsFieldMap::const_iterator fieldIt = layerFields.find( *att_it );
+      if ( fieldIt != layerFields.constEnd() )
-        QgsFieldMap::const_iterator fieldIt = providerFields.find( *att_it );
-        if ( fieldIt != providerFields.constEnd() )
-          QString attributeName = fieldIt.value().name();
-          QStandardItem* attributeItem = new QStandardItem( attributeName );
-          layerItem->setChild( layerItem->rowCount(), 0, attributeItem );
+        QString attributeName = vectorLayer->attributeDisplayName(fieldIt.key());
+        QStandardItem* attributeItem = new QStandardItem( attributeName );
+        layerItem->setChild( layerItem->rowCount(), 0, attributeItem );
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2009-07-01 07:51:18 UTC (rev 10991)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2009-07-01 10:11:33 UTC (rev 10992)
@@ -2732,6 +2732,21 @@
+QString QgsVectorLayer::attributeDisplayName(int attributeIndex) const
+  QString displayName = attributeAlias(attributeIndex);
+  if(displayName.isEmpty())
+    const QgsFieldMap& fields = pendingFields();
+    QgsFieldMap::const_iterator fieldIt = fields.find( attributeIndex );
+    if ( fieldIt != fields.constEnd() )
+      displayName = fieldIt->name();
+  return displayName;
 bool QgsVectorLayer::deleteAttribute( int index )
   if ( !isEditable() )
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h	2009-07-01 07:51:18 UTC (rev 10991)
+++ trunk/qgis/src/core/qgsvectorlayer.h	2009-07-01 10:11:33 UTC (rev 10992)
@@ -409,6 +409,10 @@
       @note added in version 1.2*/
     QString attributeAlias(int attributeIndex) const;
+    /**Convenience function that returns the attribute alias if defined or the field name else
+      @note added in version 1.2*/
+    QString attributeDisplayName(int attributeIndex) const;
     /** delete an attribute field (but does not commit it) */
     bool deleteAttribute( int attr );
More information about the QGIS-commit mailing list
