[QGIS Commit] r11008 - branches/symbology-ng-branch/src/core/pal
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Jul 2 11:22:36 EDT 2009
Author: wonder
Date: 2009-07-02 11:22:36 -0400 (Thu, 02 Jul 2009)
New Revision: 11008
   branches/symbology-ng-branch/src/core/pal/feature.cpp
   branches/symbology-ng-branch/src/core/pal/layer.cpp
   branches/symbology-ng-branch/src/core/pal/pointset.h
   branches/symbology-ng-branch/src/core/pal/util.cpp
   branches/symbology-ng-branch/src/core/pal/util.h
pal: replace polygon validity check with check from GEOS. Much faster. And don't check it twice, that's not necessary.
Modified: branches/symbology-ng-branch/src/core/pal/feature.cpp
--- branches/symbology-ng-branch/src/core/pal/feature.cpp	2009-07-02 15:14:33 UTC (rev 11007)
+++ branches/symbology-ng-branch/src/core/pal/feature.cpp	2009-07-02 15:22:36 UTC (rev 11008)
@@ -859,7 +859,7 @@
       //std::cout << "fetch feat " << layer->name << "/" << uid << std::endl;
       the_geom = userGeom->getGeosGeometry();
-      LinkedList<Feat*> *feats = splitGeom( the_geom, this->uid );
+      LinkedList<Feat*> *feats = splitGeom( the_geom, this->uid, false );
       int id = 0;
       while ( feats->size() > 0 )
Modified: branches/symbology-ng-branch/src/core/pal/layer.cpp
--- branches/symbology-ng-branch/src/core/pal/layer.cpp	2009-07-02 15:14:33 UTC (rev 11007)
+++ branches/symbology-ng-branch/src/core/pal/layer.cpp	2009-07-02 15:22:36 UTC (rev 11008)
@@ -324,7 +324,8 @@
     /* Split MULTI GEOM and Collection in simple geometries*/
     GEOSGeometry *the_geom = userGeom->getGeosGeometry();
-    LinkedList<Feat*> *finalQueue = splitGeom( the_geom, geom_id );
+    // also check whether the geometry is valid
+    LinkedList<Feat*> *finalQueue = splitGeom( the_geom, geom_id, true );
     int nGeom = finalQueue->size();
     int part = 0;
Modified: branches/symbology-ng-branch/src/core/pal/pointset.h
--- branches/symbology-ng-branch/src/core/pal/pointset.h	2009-07-02 15:14:33 UTC (rev 11007)
+++ branches/symbology-ng-branch/src/core/pal/pointset.h	2009-07-02 15:22:36 UTC (rev 11008)
@@ -103,7 +103,7 @@
       friend bool obstacleCallback( PointSet *feat, void *ctx );
       friend bool extractFeatCallback( Feature*, void* );
       friend void extractXYCoord( Feat *f );
-      friend LinkedList<Feat*> * splitGeom( GEOSGeometry *the_geom, const char *geom_id );
+      friend LinkedList<Feat*> * splitGeom( GEOSGeometry *the_geom, const char *geom_id, bool check_valid );
       friend void releaseAllInIndex( RTree<PointSet*, double, 2, double> *obstacles );
       friend bool releaseCallback( PointSet *pset, void *ctx );
       friend bool filteringCallback( PointSet*, void* );
Modified: branches/symbology-ng-branch/src/core/pal/util.cpp
--- branches/symbology-ng-branch/src/core/pal/util.cpp	2009-07-02 15:14:33 UTC (rev 11007)
+++ branches/symbology-ng-branch/src/core/pal/util.cpp	2009-07-02 15:22:36 UTC (rev 11008)
@@ -443,10 +443,9 @@
-  LinkedList<Feat*> * splitGeom( GEOSGeometry *the_geom, const char *geom_id )
+  LinkedList<Feat*> * splitGeom( GEOSGeometry *the_geom, const char *geom_id, bool check_valid )
     LinkedList <Feat*> *fCoordQueue = new LinkedList<Feat*> ( ptrFeatCompare );
-    LinkedList <Feat*> *finalQueue = new LinkedList<Feat*> ( ptrFeatCompare );
     LinkedList <const GEOSGeometry*> *simpleGeometries = unmulti( the_geom );
@@ -464,6 +463,13 @@
     while ( simpleGeometries->size() > 0 )
       geom = simpleGeometries->pop_front();
+      // ignore invalid geometries (e.g. polygons with self-intersecting rings)
+      if (check_valid && GEOSisValid( geom ) != 1) // 0=invalid, 1=valid, 2=exception
+        continue;
       //std::cout << "    split->typeid : " << geom->getGeometryTypeId() << std::endl;
       switch ( GEOSGeomTypeId( geom ) )
@@ -538,92 +544,7 @@
     delete simpleGeometries;
-    cX = 0.0;
-    cY = 0.0;
-    while ( fCoordQueue->size() > 0 )
-      f = fCoordQueue->pop_front();
-      if ( f->type == GEOS_POLYGON )
-#ifdef _DEBUG_FULL_
-        std::cout << "New feature coordinates:" << std::endl;
-        for ( i = 0;i < f->nbPoints;i++ )
-          std::cout << f->x[i] << ";" << f->y[i] << std::endl;
-#endif
-        // Butterfly detector
-        //   3____0
-        //     \/  <--- not allowed
-        //   1/__\2
-        //   1____0
-        //    2\/5  <--- allowed
-        //   3/__\4
-        pt_a = -1;
-        pt_b = -1;
-        for ( i = 0;i < f->nbPoints - 2;i++ )
-          j = i + 1;
-          j2 = ( j + 1 ) % f->nbPoints;
-          for ( k = i + 2;k < f->nbPoints - ( i == 0 );k++ )
-            l = ( k + 1 ) % f->nbPoints;
-            l2 = ( l + 1 ) % f->nbPoints;
-            //std::cout << "   " << i << "->" << j << "     " << k << "->" << l << std::endl;
-            if ( computeSegIntersectionExt( f->x[i], f->y[i],
-                                            f->x[j], f->y[j],
-                                            f->x[j2], f->y[j2],
-                                            f->x[k], f->y[k],
-                                            f->x[l], f->y[l],
-                                            f->x[l2], f->y[l2],
-                                            &tmpX, &tmpY ) )
-              std::cout << i << "->" << j << "  intersect " << k << "->" << l << std::endl;
-#endif
-              pt_a = i;
-              pt_b = k;
-              cX = tmpX;
-              cY = tmpY;
-              i = k = f->nbPoints;
-        if ( pt_a == -1 && pt_b == -1 )
-          finalQueue->push_back( f );
-        else
-          //fCoordQueue->push_back(splitButterflyPolygon (f, (pt_a+1)%f->nbPoints, (pt_b+1)%f->nbPoints, cX, cY));
-          //fCoordQueue->push_back(splitButterflyPolygon (f, (pt_b+1)%f->nbPoints, (pt_a+1)%f->nbPoints, cX, cY));
-          for ( i = 0;i < f->nbHoles;i++ )
-            delete f->holes[i];
-          delete f->holes;
-          delete[] f->x;
-          delete[] f->y;
-          delete f;
-      else
-    delete fCoordQueue;
-    //delete the_geom;
-    return finalQueue;
+    return fCoordQueue;
 } // namespace
Modified: branches/symbology-ng-branch/src/core/pal/util.h
--- branches/symbology-ng-branch/src/core/pal/util.h	2009-07-02 15:14:33 UTC (rev 11007)
+++ branches/symbology-ng-branch/src/core/pal/util.h	2009-07-02 15:22:36 UTC (rev 11008)
@@ -82,7 +82,7 @@
    * \brief split GEOS geom (multilinestring, multipoint, multipolygon) => (point, linestring, polygone)
-  LinkedList<Feat*> * splitGeom( GEOSGeometry *the_geom, const char *geom_id );
+  LinkedList<Feat*> * splitGeom( GEOSGeometry *the_geom, const char *geom_id, bool check_valid );
   typedef struct _feats
More information about the QGIS-commit mailing list
