[QGIS Commit] r11027 -
branches/symbology-ng-branch/src/plugins/labeling
svn_qgis at osgeo.org
Sun Jul 5 07:39:47 EDT 2009
Author: wonder
Date: 2009-07-05 07:39:47 -0400 (Sun, 05 Jul 2009)
New Revision: 11027
branches/symbology-ng-branch/src/plugins/labeling/labelinggui.cpp
branches/symbology-ng-branch/src/plugins/labeling/labelinggui.h
branches/symbology-ng-branch/src/plugins/labeling/labelingguibase.ui
branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp
branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h
reorganized labeling dialog in vision of new placement methods :)
Modified: branches/symbology-ng-branch/src/plugins/labeling/labelinggui.cpp
--- branches/symbology-ng-branch/src/plugins/labeling/labelinggui.cpp 2009-07-05 11:38:02 UTC (rev 11026)
+++ branches/symbology-ng-branch/src/plugins/labeling/labelinggui.cpp 2009-07-05 11:39:47 UTC (rev 11027)
@@ -44,19 +44,64 @@
connect(spinBufferSize, SIGNAL(valueChanged(int)), this, SLOT(updatePreview()) );
connect(btnEngineSettings, SIGNAL(clicked()), this, SLOT(showEngineConfigDialog()) );
- populatePlacementMethods();
+ // set placement methods page based on geometry type
+ switch (layer()->geometryType())
+ case QGis::Point:
+ stackedPlacement->setCurrentWidget(pagePoint);
+ break;
+ case QGis::Line:
+ stackedPlacement->setCurrentWidget(pageLine);
+ break;
+ case QGis::Polygon:
+ stackedPlacement->setCurrentWidget(pagePolygon);
+ break;
+ default:
+ Q_ASSERT(0 && "NOOOO!");
populateFieldNames();
const LayerSettings& lyr = lbl->layer(layerId);
if (!lyr.layerId.isEmpty())
// load the labeling settings
- cboPlacement->setCurrentIndex( cboPlacement->findData( QVariant( (int)lyr.placement ) ) );
+ // placement
+ switch (lyr.placement)
+ case LayerSettings::AroundPoint:
+ radAroundPoint->setChecked(true);
+ radAroundCentroid->setChecked(true);
+ spinDistPoint->setValue(lyr.dist);
+ //spinAngle->setValue(lyr.angle);
+ break;
+ case LayerSettings::AroundLine:
+ case LayerSettings::OnLine:
+ radLineParallel->setChecked(true);
+ radPolygonPerimeter->setChecked(true);
+ if ( lyr.placement == LayerSettings::AroundLine )
+ radAroundLine->setChecked(true);
+ spinDistLine->setValue(lyr.dist);
+ else
+ radOnLine->setChecked(true);
+ break;
+ case LayerSettings::Horizontal:
+ radPolygonHorizontal->setChecked(true);
+ break;
+ case LayerSettings::Free:
+ radPolygonFree->setChecked(true);
+ break;
+ default:
+ Q_ASSERT(0 && "NOOO!");
cboFieldName->setCurrentIndex( cboFieldName->findText(lyr.fieldName) );
chkEnableLabeling->setChecked( lyr.enabled );
sliderPriority->setValue( lyr.priority );
chkNoObstacle->setChecked( !lyr.obstacle );
- spinDist->setValue( lyr.dist );
bool scaleBased = (lyr.scaleMin != 0 && lyr.scaleMax != 0);
chkScaleBasedVisibility->setChecked(scaleBased);
@@ -78,19 +123,24 @@
- // feature distance available only for points and lines
- if (layer()->geometryType() == QGis::Polygon)
- spinDist->setEnabled( false );
btnTextColor->setColor( lyr.textColor );
btnBufferColor->setColor( lyr.bufferColor );
updateFont( lyr.textFont );
updateUi();
+ updateOptions();
connect(chkBuffer, SIGNAL(toggled(bool)), this, SLOT(updateUi()) );
connect(chkScaleBasedVisibility, SIGNAL(toggled(bool)), this, SLOT(updateUi()) );
+ // setup connection to changes in the placement
+ QRadioButton* placementRadios[] = {
+ radAroundPoint, radOverPoint, // point
+ radLineParallel, radLineHorizontal, // line
+ radAroundCentroid, radPolygonHorizontal, radPolygonFree, radPolygonPerimeter // polygon
+ for (int i = 0; i < sizeof(placementRadios)/sizeof(QRadioButton*); i++)
+ connect( placementRadios[i], SIGNAL(toggled(bool)), this, SLOT(updateOptions()) );
LabelingGui::~LabelingGui()
@@ -110,13 +160,44 @@
LayerSettings lyr;
lyr.layerId = mLayerId;
lyr.fieldName = cboFieldName->currentText();
- lyr.placement = (LayerSettings::Placement) cboPlacement->itemData(cboPlacement->currentIndex()).toInt();
+ lyr.dist = 0;
+ if ( (stackedPlacement->currentWidget() == pagePoint && radAroundPoint->isChecked())
+ || (stackedPlacement->currentWidget() == pagePolygon && radAroundCentroid->isChecked()) )
+ lyr.placement = LayerSettings::AroundPoint;
+ lyr.dist = spinDistPoint->value();
+ //lyr.angle = spinAngle->value();
+ else if ( (stackedPlacement->currentWidget() == pageLine && radLineParallel->isChecked())
+ || (stackedPlacement->currentWidget() == pagePolygon && radPolygonPerimeter->isChecked()) )
+ if (radAroundLine->isChecked())
+ lyr.placement = LayerSettings::AroundLine;
+ lyr.dist = spinDistLine->value();
+ else
+ lyr.placement = LayerSettings::OnLine;
+ else
+ // this must be polygon - horizontal / free
+ if (radPolygonHorizontal->isChecked())
+ lyr.placement = LayerSettings::Horizontal;
+ else if (radPolygonFree->isChecked())
+ lyr.placement = LayerSettings::Free;
+ else
lyr.textColor = btnTextColor->color();
lyr.textFont = lblFontPreview->font();
lyr.enabled = chkEnableLabeling->isChecked();
lyr.priority = sliderPriority->value();
lyr.obstacle = !chkNoObstacle->isChecked();
- lyr.dist = spinDist->value();
if (chkScaleBasedVisibility->isChecked())
lyr.scaleMin = spinScaleMin->value();
@@ -139,26 +220,6 @@
return lyr;
-void LabelingGui::populatePlacementMethods()
- switch (layer()->geometryType())
- case QGis::Point:
- cboPlacement->addItem(tr("Around the point"), QVariant(LayerSettings::AroundPoint));
- break;
- case QGis::Line:
- cboPlacement->addItem(tr("On the line"), QVariant(LayerSettings::OnLine));
- cboPlacement->addItem(tr("Around the line"), QVariant(LayerSettings::AroundLine));
- break;
- case QGis::Polygon:
- cboPlacement->addItem(tr("Horizontal"), QVariant(LayerSettings::Horizontal));
- cboPlacement->addItem(tr("Free"), QVariant(LayerSettings::Free));
- cboPlacement->addItem(tr("Around the centroid"), QVariant(LayerSettings::AroundPoint));
- cboPlacement->addItem(tr("On the perimeter"), QVariant(LayerSettings::OnLine));
- cboPlacement->addItem(tr("Around the perimeter"), QVariant(LayerSettings::AroundLine));
- break;
void LabelingGui::populateFieldNames()
@@ -231,3 +292,21 @@
btnBufferColor->setColor(color);
updatePreview();
+void LabelingGui::updateOptions()
+ stackedOptions->setCurrentWidget(pageOptionsPoint);
+ stackedOptions->setCurrentWidget(pageOptionsLine);
+ else
+ stackedOptions->setCurrentWidget(pageOptionsEmpty);
Modified: branches/symbology-ng-branch/src/plugins/labeling/labelinggui.h
--- branches/symbology-ng-branch/src/plugins/labeling/labelinggui.h 2009-07-05 11:38:02 UTC (rev 11026)
+++ branches/symbology-ng-branch/src/plugins/labeling/labelinggui.h 2009-07-05 11:39:47 UTC (rev 11027)
@@ -45,6 +45,7 @@
void updateUi();
void updatePreview();
+ void updateOptions();
protected:
void populatePlacementMethods();
Modified: branches/symbology-ng-branch/src/plugins/labeling/labelingguibase.ui
--- branches/symbology-ng-branch/src/plugins/labeling/labelingguibase.ui 2009-07-05 11:38:02 UTC (rev 11026)
+++ branches/symbology-ng-branch/src/plugins/labeling/labelingguibase.ui 2009-07-05 11:39:47 UTC (rev 11027)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>354</width>
- <height>608</height>
+ <width>454</width>
+ <height>474</height>
</rect>
</property>
<property name="windowTitle">
@@ -18,7 +18,7 @@
<normaloff/>
</iconset>
</property>
- <layout class="QVBoxLayout" name="verticalLayout_2">
+ <layout class="QVBoxLayout" name="verticalLayout">
<item>
<widget class="QCheckBox" name="chkEnableLabeling">
<property name="text">
@@ -27,34 +27,8 @@
</widget>
</item>
<item>
- <layout class="QGridLayout" name="gridLayout_2">
- <item row="0" column="0">
- <widget class="QLabel" name="label">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
- <horstretch>1</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="text">
- <string>Placement</string>
- </property>
- <property name="alignment">
- <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
- </property>
- </widget>
- </item>
- <item row="0" column="1">
- <widget class="QComboBox" name="cboPlacement">
- <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
- <horstretch>2</horstretch>
- </sizepolicy>
- </property>
- </widget>
- </item>
- <item row="1" column="0">
+ <layout class="QHBoxLayout" name="horizontalLayout_9">
+ <item>
<widget class="QLabel" name="label_6">
<string>Field with labels</string>
@@ -64,314 +38,526 @@
</property>
</widget>
</item>
- <item row="1" column="1">
+ <item>
<widget class="QComboBox" name="cboFieldName"/>
</item>
- <item row="2" column="0">
- <widget class="QLabel" name="label_8">
- <string>Label distance</string>
+ <item>
+ <spacer name="horizontalSpacer_4">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
</property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>40</width>
+ <height>20</height>
+ </size>
</property>
- </widget>
+ </spacer>
</item>
- <item row="2" column="1">
- <layout class="QHBoxLayout" name="horizontalLayout_3">
- <item>
- <widget class="QDoubleSpinBox" name="spinDist">
- <property name="decimals">
- <number>0</number>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QLabel" name="label_9">
- <string>pixels</string>
- </property>
- </widget>
- </item>
- </layout>
- </item>
</layout>
</item>
<item>
- <widget class="QGroupBox" name="groupBox">
+ <widget class="QGroupBox" name="groupBox_4">
<property name="title">
- <string>Text style</string>
+ <string>Placement</string>
</property>
- <layout class="QGridLayout" name="gridLayout">
- <widget class="QLabel" name="label_4">
- <horstretch>0</horstretch>
- </sizepolicy>
+ <layout class="QHBoxLayout" name="horizontalLayout_8">
+ <property name="leftMargin">
+ <number>0</number>
+ </property>
+ <property name="topMargin">
+ </property>
+ <property name="rightMargin">
+ </property>
+ <property name="bottomMargin">
+ <number>4</number>
+ </property>
+ <item>
+ <widget class="QStackedWidget" name="stackedPlacement">
+ <property name="currentIndex">
</property>
- <string>Font</string>
+ <widget class="QWidget" name="pagePoint">
+ <layout class="QVBoxLayout" name="verticalLayout_2">
+ <item>
+ <widget class="QRadioButton" name="radAroundPoint">
+ <property name="text">
+ <string>around point</string>
+ </property>
+ <property name="checked">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radOverPoint">
+ <property name="enabled">
+ <bool>false</bool>
+ </property>
+ <string>over point</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="pageLine">
+ <layout class="QVBoxLayout" name="verticalLayout_3">
+ <item>
+ <widget class="QRadioButton" name="radLineParallel">
+ <string>parallel</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radLineHorizontal">
+ </property>
+ <string>horizontal</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="pagePolygon">
+ <layout class="QVBoxLayout" name="verticalLayout_4">
+ <item>
+ <widget class="QRadioButton" name="radAroundCentroid">
+ <string>around centroid</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radPolygonHorizontal">
+ <string>horizontal (slow)</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radPolygonFree">
+ <string>free (slow)</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radPolygonPerimeter">
+ <string>using perimeter</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </widget>
+ </item>
+ <item>
+ <widget class="Line" name="line_2">
+ <enum>Qt::Vertical</enum>
</property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QStackedWidget" name="stackedOptions">
</property>
+ <widget class="QWidget" name="pageOptionsPoint">
+ <layout class="QGridLayout" name="gridLayout_2">
+ <item row="0" column="0">
+ <widget class="QLabel" name="label_8">
+ <string>Label distance</string>
+ </property>
+ <property name="alignment">
+ <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1">
+ <widget class="QDoubleSpinBox" name="spinDistPoint">
+ <property name="decimals">
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="2">
+ <widget class="QLabel" name="label_9">
+ <string>pixels</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0">
+ <widget class="QLabel" name="label_17">
+ <string>Rotation</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1">
+ <widget class="QSpinBox" name="spinAngle">
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="2">
+ <widget class="QLabel" name="label_18">
+ <string>degrees</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="pageOptionsLine">
+ <layout class="QVBoxLayout" name="verticalLayout_5">
+ <item>
+ <widget class="QRadioButton" name="radOnLine">
+ <string>on line</string>
+ </property>
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radAroundLine">
+ <string>around line</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <layout class="QHBoxLayout" name="horizontalLayout_3">
+ <item>
+ <widget class="QLabel" name="label_16">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDoubleSpinBox" name="spinDistLine">
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLabel" name="label_15">
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ </layout>
+ </widget>
+ <widget class="QWidget" name="pageOptionsEmpty"/>
</widget>
</item>
- <layout class="QHBoxLayout" name="horizontalLayout_5">
- <item>
- <widget class="QLabel" name="lblFontName">
+ </layout>
+ </widget>
+ </item>
+ <item>
+ <layout class="QGridLayout" name="gridLayout_4">
+ <item row="0" column="0" rowspan="2">
+ <widget class="QGroupBox" name="groupBox">
+ <property name="title">
+ <string>Text style</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout">
+ <widget class="QLabel" name="label_4">
- <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
+ <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
+ <horstretch>0</horstretch>
</sizepolicy>
</property>
- <string>TextLabel</string>
+ <string>Font</string>
</property>
+ </property>
</widget>
</item>
- <item>
- <spacer name="horizontalSpacer_2">
- <property name="orientation">
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeHint" stdset="0">
- <size>
- <width>40</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
+ <layout class="QHBoxLayout" name="horizontalLayout_5">
+ <item>
+ <widget class="QLabel" name="lblFontName">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
+ <horstretch>1</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <string>TextLabel</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer_2">
+ </property>
+ <size>
+ <width>40</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QToolButton" name="btnChangeFont">
+ <string>...</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
</item>
- <item>
- <widget class="QToolButton" name="btnChangeFont">
- <string>...</string>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <widget class="QLabel" name="label_3">
- </sizepolicy>
- </property>
- <string>Color</string>
- </property>
- </property>
- </widget>
- </item>
- <layout class="QHBoxLayout" name="horizontalLayout_6">
- <item>
- <widget class="QgsColorButton" name="btnTextColor">
+ <widget class="QLabel" name="label_3">
</sizepolicy>
</property>
- <string/>
+ <string>Color</string>
</property>
+ </property>
</widget>
</item>
- <item>
- <spacer name="horizontalSpacer">
+ <layout class="QHBoxLayout" name="horizontalLayout_6">
+ <item>
+ <widget class="QgsColorButton" name="btnTextColor">
+ <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
+ </sizepolicy>
+ </property>
+ <string/>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer">
+ </property>
+ <property name="sizeType">
+ <enum>QSizePolicy::Preferred</enum>
+ </property>
+ <size>
+ <width>142</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ </layout>
+ </item>
+ <item row="2" column="0">
+ <widget class="QLabel" name="label_10">
+ <string>Buffer</string>
</property>
- <property name="sizeType">
- <enum>QSizePolicy::Preferred</enum>
</property>
- <size>
- <width>142</width>
- </size>
- </property>
- </spacer>
+ </widget>
</item>
- </layout>
- </item>
- <widget class="QLabel" name="label_10">
- <string>Buffer</string>
- </property>
- </property>
- </widget>
- </item>
- <layout class="QHBoxLayout" name="horizontalLayout_4">
- <item>
- <widget class="QCheckBox" name="chkBuffer">
+ <item row="2" column="1">
+ <layout class="QHBoxLayout" name="horizontalLayout_4">
+ <item>
+ <widget class="QCheckBox" name="chkBuffer">
+ <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+ </sizepolicy>
+ </property>
+ <string/>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLabel" name="label_11">
+ <string>Size</string>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QSpinBox" name="spinBufferSize">
+ <property name="minimum">
+ <number>1</number>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QLabel" name="label_12">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QgsColorButton" name="btnBufferColor">
+ </sizepolicy>
+ </property>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="4" column="0">
+ <widget class="QLabel" name="label_7">
- <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
</sizepolicy>
</property>
- <string/>
+ <string>Sample</string>
</property>
+ </property>
</widget>
</item>
- <item>
- <widget class="QLabel" name="label_11">
+ <item row="4" column="1">
+ <widget class="LabelPreview" name="lblFontPreview">
+ <property name="minimumSize">
+ <size>
+ <width>30</width>
+ <height>30</height>
+ </size>
+ </property>
- <string>Size</string>
+ <string>Lorem Ipsum</string>
</property>
+ <set>Qt::AlignCenter</set>
</property>
</widget>
</item>
- <item>
- <widget class="QSpinBox" name="spinBufferSize">
- <property name="minimum">
- <number>1</number>
+ <item row="3" column="0" colspan="2">
+ <widget class="Line" name="line">
</property>
</widget>
</item>
+ </layout>
+ </widget>
+ </item>
+ <widget class="QGroupBox" name="groupBox_2">
+ <string>Priority</string>
+ </property>
+ <layout class="QHBoxLayout" name="horizontalLayout">
<item>
- <widget class="QLabel" name="label_12">
+ <widget class="QLabel" name="label_2">
+ <string>Low</string>
</property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QSlider" name="sliderPriority">
+ <property name="maximum">
+ <number>10</number>
</property>
+ <property name="value">
+ <number>5</number>
+ </property>
+ </property>
+ <property name="tickPosition">
+ <enum>QSlider::TicksBelow</enum>
+ </property>
+ <property name="tickInterval">
+ </property>
</widget>
</item>
<item>
- <widget class="QgsColorButton" name="btnBufferColor">
- </sizepolicy>
+ <widget class="QLabel" name="label_5">
+ <string>High</string>
</property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <widget class="QGroupBox" name="groupBox_3">
+ <string>Scale-based visibility</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_3">
+ <item row="0" column="0" colspan="2">
+ <widget class="QCheckBox" name="chkScaleBasedVisibility">
+ <string>Enabled</string>
</property>
</widget>
</item>
- </layout>
- </item>
- <item row="4" column="0">
- <widget class="QLabel" name="label_7">
- </sizepolicy>
- </property>
- <string>Sample</string>
- </property>
- </property>
- </widget>
- </item>
- <item row="4" column="1">
- <widget class="LabelPreview" name="lblFontPreview">
- <property name="minimumSize">
- <size>
- <width>30</width>
- <height>30</height>
- </size>
- </property>
- <string>Lorem Ipsum</string>
- </property>
- <set>Qt::AlignCenter</set>
- </property>
- </widget>
- </item>
- <item row="3" column="0" colspan="2">
- <widget class="Line" name="line">
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <item>
- <widget class="QGroupBox" name="groupBox_2">
- <property name="title">
- <string>Priority</string>
- </property>
- <layout class="QHBoxLayout" name="horizontalLayout">
- <item>
- <widget class="QLabel" name="label_2">
- <string>Low</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QSlider" name="sliderPriority">
- <property name="maximum">
- <number>10</number>
- </property>
- <property name="value">
- <number>5</number>
- </property>
- </property>
- <property name="tickPosition">
- <enum>QSlider::TicksBelow</enum>
- </property>
- <property name="tickInterval">
- </property>
- </widget>
- </item>
- <item>
- <widget class="QLabel" name="label_5">
- <string>High</string>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <item>
- <widget class="QGroupBox" name="groupBox_3">
- <string>Scale-based visibility</string>
- </property>
- <layout class="QVBoxLayout" name="verticalLayout">
- <item>
- <widget class="QCheckBox" name="chkScaleBasedVisibility">
- <string>Enabled</string>
- </property>
- </widget>
- </item>
- <item>
- <layout class="QHBoxLayout" name="horizontalLayout_7">
- <item>
<widget class="QLabel" name="label_13">
<string>Minimum</string>
@@ -381,7 +567,7 @@
</property>
</widget>
</item>
- <item>
<widget class="QSpinBox" name="spinScaleMin">
<number>1</number>
@@ -391,7 +577,7 @@
</property>
</widget>
</item>
- <item>
<widget class="QLabel" name="label_14">
<string>Maximum</string>
@@ -401,7 +587,7 @@
</property>
</widget>
</item>
- <item>
<widget class="QSpinBox" name="spinScaleMax">
<number>1</number>
@@ -415,42 +601,19 @@
</widget>
</item>
</layout>
- </item>
- </layout>
- </widget>
+ </widget>
+ </item>
+ </layout>
</item>
<item>
- <widget class="QCheckBox" name="chkNoObstacle">
- <property name="enabled">
- <bool>true</bool>
- </property>
- <string>not an obstacle</string>
- </property>
- </widget>
- </item>
- <item>
- <spacer name="verticalSpacer_2">
- <enum>Qt::Vertical</enum>
- </property>
- <size>
- <width>20</width>
- <height>40</height>
- </size>
- </property>
- </spacer>
- </item>
- <item>
<layout class="QHBoxLayout" name="horizontalLayout_2">
<item>
- <widget class="QPushButton" name="btnEngineSettings">
+ <widget class="QCheckBox" name="chkNoObstacle">
<bool>true</bool>
</property>
- <string>Engine settings</string>
+ <string>not an obstacle</string>
</property>
</widget>
</item>
@@ -467,9 +630,32 @@
</property>
</spacer>
</item>
+ <item>
+ <widget class="QPushButton" name="btnEngineSettings">
+ <bool>true</bool>
+ </property>
+ <string>Engine settings</string>
+ </property>
+ </widget>
+ </item>
</layout>
</item>
<item>
+ <spacer name="verticalSpacer_2">
+ </property>
+ <size>
+ <width>20</width>
+ <height>40</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
<widget class="QDialogButtonBox" name="buttonBox">
@@ -496,9 +682,19 @@
</customwidgets>
<tabstops>
<tabstop>chkEnableLabeling</tabstop>
- <tabstop>cboPlacement</tabstop>
<tabstop>cboFieldName</tabstop>
- <tabstop>spinDist</tabstop>
+ <tabstop>radAroundPoint</tabstop>
+ <tabstop>radOverPoint</tabstop>
+ <tabstop>radLineParallel</tabstop>
+ <tabstop>radLineHorizontal</tabstop>
+ <tabstop>radAroundCentroid</tabstop>
+ <tabstop>radPolygonHorizontal</tabstop>
+ <tabstop>radPolygonFree</tabstop>
+ <tabstop>spinDistPoint</tabstop>
+ <tabstop>spinAngle</tabstop>
+ <tabstop>radOnLine</tabstop>
+ <tabstop>radAroundLine</tabstop>
+ <tabstop>spinDistLine</tabstop>
<tabstop>btnChangeFont</tabstop>
<tabstop>btnTextColor</tabstop>
<tabstop>chkBuffer</tabstop>
Modified: branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp
--- branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp 2009-07-05 11:38:02 UTC (rev 11026)
+++ branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp 2009-07-05 11:39:47 UTC (rev 11027)
@@ -128,7 +128,8 @@
geometries.append(lbl);
// register feature to the layer
- palLayer->registerFeature(lbl->strId(), lbl, labelX, labelY);
+ if (!palLayer->registerFeature(lbl->strId(), lbl, labelX, labelY))
+ return;
// TODO: allow layer-wide feature dist in PAL...?
if (dist != 0)
Modified: branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h
--- branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h 2009-07-05 11:38:02 UTC (rev 11026)
+++ branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h 2009-07-05 11:39:47 UTC (rev 11027)
@@ -30,7 +30,7 @@
LayerSettings();
LayerSettings(const LayerSettings& s);
~LayerSettings();
enum Placement
AroundPoint, // Point / Polygon
