[QGIS Commit] r11050 - in branches/symbology-ng-branch/src:
core/pal plugins/labeling
svn_qgis at osgeo.org
Sun Jul 12 09:38:43 EDT 2009
Author: wonder
Date: 2009-07-12 09:38:42 -0400 (Sun, 12 Jul 2009)
New Revision: 11050
branches/symbology-ng-branch/src/core/pal/feature.cpp
branches/symbology-ng-branch/src/core/pal/layer.cpp
branches/symbology-ng-branch/src/core/pal/layer.h
branches/symbology-ng-branch/src/core/pal/pal.h
branches/symbology-ng-branch/src/plugins/labeling/labelinggui.cpp
branches/symbology-ng-branch/src/plugins/labeling/labelingguibase.ui
branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp
branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h
Added support to put labels above, below or on the line (or any combination).
The orientation above/below is determined from the map orientation or line direction (left/right side).
Modified: branches/symbology-ng-branch/src/core/pal/feature.cpp
--- branches/symbology-ng-branch/src/core/pal/feature.cpp 2009-07-12 12:15:01 UTC (rev 11049)
+++ branches/symbology-ng-branch/src/core/pal/feature.cpp 2009-07-12 13:38:42 UTC (rev 11050)
@@ -372,6 +372,11 @@
double alpha;
double cost;
+ unsigned long flags = layer->getArrangementFlags();
+ if ( flags == 0 )
+ flags = FLAG_ON_LINE; // default flag
+ bool reversed = false;
//LinkedList<PointSet*> *shapes_final;
//shapes_final = new LinkedList<PointSet*>(ptrPSetCompare);
@@ -476,10 +481,18 @@
#ifdef _DEBUG_FULL_
std::cout << " Create new label" << std::endl;
#endif
- if ( layer->arrangement == P_LINE_AROUND )
+ if ( layer->arrangement == P_LINE )
- positions->push_back( new LabelPosition( i, bx + cos( beta ) *distlabel , by + sin( beta ) *distlabel, xrm, yrm, alpha, cost, this ) ); // Line
- positions->push_back( new LabelPosition( i, bx - cos( beta ) * ( distlabel + yrm ) , by - sin( beta ) * ( distlabel + yrm ), xrm, yrm, alpha, cost, this ) ); // Line
+ std::cout << alpha*180/M_PI << std::endl;
+ if ( flags & FLAG_MAP_ORIENTATION )
+ reversed = ( alpha >= M_PI/2 || alpha < -M_PI/2 );
+ if ( (!reversed && (flags & FLAG_ABOVE_LINE)) || (reversed && (flags & FLAG_BELOW_LINE)) )
+ positions->push_back( new LabelPosition( i, bx + cos( beta ) *distlabel , by + sin( beta ) *distlabel, xrm, yrm, alpha, cost, this ) ); // Line
+ if ( (!reversed && (flags & FLAG_BELOW_LINE)) || (reversed && (flags & FLAG_ABOVE_LINE)) )
+ positions->push_back( new LabelPosition( i, bx - cos( beta ) * ( distlabel + yrm ) , by - sin( beta ) * ( distlabel + yrm ), xrm, yrm, alpha, cost, this ) ); // Line
+ if ( flags & FLAG_ON_LINE )
+ positions->push_back( new LabelPosition( i, bx - yrm*cos( beta ) / 2, by - yrm*sin( beta ) / 2, xrm, yrm, alpha, cost, this ) ); // Line
else if (layer->arrangement == P_HORIZ)
@@ -488,7 +501,7 @@
else
- positions->push_back( new LabelPosition( i, bx - yrm*cos( beta ) / 2, by - yrm*sin( beta ) / 2, xrm, yrm, alpha, cost, this ) ); // Line
+ // an invalid arrangement?
l += dist;
@@ -846,7 +859,6 @@
nbp = setPositionForPoint( cx, cy, scale, lPos, delta );
break;
case P_LINE:
- case P_LINE_AROUND:
nbp = setPositionForLine( scale, lPos, mapShape, delta );
break;
default:
Modified: branches/symbology-ng-branch/src/core/pal/layer.cpp
--- branches/symbology-ng-branch/src/core/pal/layer.cpp 2009-07-12 12:15:01 UTC (rev 11049)
+++ branches/symbology-ng-branch/src/core/pal/layer.cpp 2009-07-12 13:38:42 UTC (rev 11050)
@@ -57,7 +57,11 @@
namespace pal
- Layer::Layer( const char *lyrName, double min_scale, double max_scale, Arrangement arrangement, Units label_unit, double defaultPriority, bool obstacle, bool active, bool toLabel, Pal *pal ) : pal( pal ), obstacle( obstacle ), active( active ), toLabel( toLabel ), label_unit( label_unit ), min_scale( min_scale ), max_scale( max_scale ), arrangement( arrangement )
+ Layer::Layer( const char *lyrName, double min_scale, double max_scale, Arrangement arrangement, Units label_unit, double defaultPriority, bool obstacle, bool active, bool toLabel, Pal *pal )
+ : pal( pal ), obstacle( obstacle ), active( active ),
+ toLabel( toLabel ), label_unit( label_unit ),
+ min_scale( min_scale ), max_scale( max_scale ),
+ arrangement( arrangement ), arrangementFlags( 0 )
this->name = new char[strlen( lyrName ) +1];
Modified: branches/symbology-ng-branch/src/core/pal/layer.h
--- branches/symbology-ng-branch/src/core/pal/layer.h 2009-07-12 12:15:01 UTC (rev 11049)
+++ branches/symbology-ng-branch/src/core/pal/layer.h 2009-07-12 13:38:42 UTC (rev 11050)
@@ -95,6 +95,9 @@
Arrangement arrangement;
+ /** optional flags used for some placement methods */
+ unsigned long arrangementFlags;
// indexes (spatial and id)
RTree<Feature*, double, 2, double, 8, 4> *rtree;
HashTable<Cell<Feature*>*> *hashtable;
@@ -166,6 +169,9 @@
void setArrangement( Arrangement arrangement );
+ unsigned long getArrangementFlags() const { return arrangementFlags; }
+ void setArrangementFlags( unsigned long flags ) { arrangementFlags = flags; }
* \brief get units for label size
Modified: branches/symbology-ng-branch/src/core/pal/pal.h
--- branches/symbology-ng-branch/src/core/pal/pal.h 2009-07-12 12:15:01 UTC (rev 11049)
+++ branches/symbology-ng-branch/src/core/pal/pal.h 2009-07-12 13:38:42 UTC (rev 11050)
@@ -101,13 +101,20 @@
P_POINT_OVER, /** arranges candidates over a point (centroid for polygon)*/
P_LINE, /**< Only for lines and polygons, arranges candidates over the line or the polygon perimeter */
P_HORIZ, /**< Only for polygon, arranges candidates horizontaly */
- P_FREE, /**< Only for polygon, arranges candidates with respect of polygon orientation */
- P_LINE_AROUND /**< Only for lines and polygons, arranges candidates above and below the line or the polygon perimeter */
+ P_FREE /**< Only for polygon, arranges candidates with respect of polygon orientation */
/** typedef for _arrangement enumeration */
typedef enum _arrangement Arrangement;
+ /** enumeration line arrangement flags. Flags can be combined. */
+ enum LineArrangementFlags
+ FLAG_ON_LINE = 1,
+ FLAG_ABOVE_LINE = 2,
+ FLAG_BELOW_LINE = 4,
+ FLAG_MAP_ORIENTATION = 8
* \brief Pal main class.
Modified: branches/symbology-ng-branch/src/plugins/labeling/labelinggui.cpp
--- branches/symbology-ng-branch/src/plugins/labeling/labelinggui.cpp 2009-07-12 12:15:01 UTC (rev 11049)
+++ branches/symbology-ng-branch/src/plugins/labeling/labelinggui.cpp 2009-07-12 13:38:42 UTC (rev 11050)
@@ -80,17 +80,18 @@
radOverPoint->setChecked(true);
radOverCentroid->setChecked(true);
break;
- case LayerSettings::AroundLine:
- case LayerSettings::OnLine:
+ case LayerSettings::Line:
radLineParallel->setChecked(true);
radPolygonPerimeter->setChecked(true);
- if ( lyr.placement == LayerSettings::AroundLine )
- radAroundLine->setChecked(true);
- spinDistLine->setValue(lyr.dist);
+ spinDistLine->setValue(lyr.dist);
+ chkLineAbove->setChecked( lyr.placementFlags & LayerSettings::AboveLine );
+ chkLineBelow->setChecked( lyr.placementFlags & LayerSettings::BelowLine );
+ chkLineOn->setChecked( lyr.placementFlags & LayerSettings::OnLine );
+ if ( lyr.placementFlags & LayerSettings::MapOrientation )
+ radOrientationMap->setChecked(true);
else
- radOnLine->setChecked(true);
+ radOrientationLine->setChecked(true);
break;
case LayerSettings::Horizontal:
radPolygonHorizontal->setChecked(true);
@@ -167,6 +168,7 @@
lyr.fieldName = cboFieldName->currentText();
lyr.dist = 0;
+ lyr.placementFlags = 0;
if ( (stackedPlacement->currentWidget() == pagePoint && radAroundPoint->isChecked())
|| (stackedPlacement->currentWidget() == pagePolygon && radAroundCentroid->isChecked()) )
@@ -183,13 +185,17 @@
else if ( (stackedPlacement->currentWidget() == pageLine && radLineParallel->isChecked())
|| (stackedPlacement->currentWidget() == pagePolygon && radPolygonPerimeter->isChecked()) )
- if (radAroundLine->isChecked())
- lyr.placement = LayerSettings::AroundLine;
- lyr.dist = spinDistLine->value();
- else
- lyr.placement = LayerSettings::OnLine;
+ lyr.placement = LayerSettings::Line;
+ lyr.dist = spinDistLine->value();
+ if (chkLineAbove->isChecked())
+ lyr.placementFlags |= LayerSettings::AboveLine;
+ if (chkLineBelow->isChecked())
+ lyr.placementFlags |= LayerSettings::BelowLine;
+ if (chkLineOn->isChecked())
+ lyr.placementFlags |= LayerSettings::OnLine;
+ if (radOrientationMap->isChecked())
+ lyr.placementFlags |= LayerSettings::MapOrientation;
else if ( (stackedPlacement->currentWidget() == pageLine && radLineHorizontal->isChecked())
|| (stackedPlacement->currentWidget() == pagePolygon && radPolygonHorizontal->isChecked()) )
Modified: branches/symbology-ng-branch/src/plugins/labeling/labelingguibase.ui
--- branches/symbology-ng-branch/src/plugins/labeling/labelingguibase.ui 2009-07-12 12:15:01 UTC (rev 11049)
+++ branches/symbology-ng-branch/src/plugins/labeling/labelingguibase.ui 2009-07-12 13:38:42 UTC (rev 11050)
@@ -7,7 +7,7 @@
<x>0</x>
<y>0</y>
<width>454</width>
- <height>514</height>
+ <height>526</height>
</rect>
</property>
<property name="windowTitle">
@@ -175,7 +175,7 @@
<item>
<widget class="QStackedWidget" name="stackedOptions">
<property name="currentIndex">
- <number>0</number>
+ <number>1</number>
</property>
<widget class="QWidget" name="pageOptionsPoint">
<layout class="QGridLayout" name="gridLayout_2">
@@ -232,9 +232,9 @@
<widget class="QWidget" name="pageOptionsLine">
<layout class="QVBoxLayout" name="verticalLayout_5">
<item>
- <widget class="QRadioButton" name="radOnLine">
+ <widget class="QCheckBox" name="chkLineAbove">
<property name="text">
- <string>on line</string>
+ <string>above line</string>
</property>
<property name="checked">
<bool>true</bool>
@@ -242,13 +242,48 @@
</widget>
</item>
<item>
- <widget class="QRadioButton" name="radAroundLine">
+ <widget class="QCheckBox" name="chkLineOn">
- <string>around line</string>
+ <string>on line</string>
</property>
</widget>
</item>
<item>
+ <widget class="QCheckBox" name="chkLineBelow">
+ <property name="text">
+ <string>below line</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <layout class="QHBoxLayout" name="horizontalLayout_7">
+ <item>
+ <widget class="QLabel" name="label">
+ <string>Orientation</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radOrientationMap">
+ <string>map</string>
+ </property>
+ <property name="checked">
+ <bool>true</bool>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QRadioButton" name="radOrientationLine">
+ <string>line</string>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item>
<layout class="QHBoxLayout" name="horizontalLayout_3">
<item>
<widget class="QLabel" name="label_16">
@@ -693,8 +728,6 @@
<tabstop>radPolygonFree</tabstop>
<tabstop>spinDistPoint</tabstop>
<tabstop>spinAngle</tabstop>
- <tabstop>radOnLine</tabstop>
- <tabstop>radAroundLine</tabstop>
<tabstop>spinDistLine</tabstop>
<tabstop>btnChangeFont</tabstop>
<tabstop>btnTextColor</tabstop>
Modified: branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp
--- branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp 2009-07-12 12:15:01 UTC (rev 11049)
+++ branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp 2009-07-12 13:38:42 UTC (rev 11050)
@@ -77,6 +77,7 @@
layerId = s.layerId;
fieldName = s.fieldName;
placement = s.placement;
+ placementFlags = s.placementFlags;
textFont = s.textFont;
textColor = s.textColor;
enabled = s.enabled;
@@ -239,9 +240,8 @@
switch (lyr->placement)
case LayerSettings::AroundPoint: arrangement = P_POINT; break;
- case LayerSettings::OverPoint: arrangement = P_POINT_OVER; break;
- case LayerSettings::OnLine: arrangement = P_LINE; break;
- case LayerSettings::AroundLine: arrangement = P_LINE_AROUND; break;
+ case LayerSettings::OverPoint: arrangement = P_POINT_OVER; break;
+ case LayerSettings::Line: arrangement = P_LINE; break;
case LayerSettings::Horizontal: arrangement = P_HORIZ; break;
case LayerSettings::Free: arrangement = P_FREE; break;
@@ -257,6 +257,9 @@
Layer* l = thisClass->mPal->addLayer(lyr->layerId.toLocal8Bit().data(), min_scale, max_scale, arrangement, METER, priority, lyr->obstacle, true, true);
+ if ( lyr->placementFlags )
+ l->setArrangementFlags( lyr->placementFlags );
// save the pal layer to our layer context (with some additional info)
lyr->palLayer = l;
lyr->fieldIndex = fldIndex;
Modified: branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h
--- branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h 2009-07-12 12:15:01 UTC (rev 11049)
+++ branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h 2009-07-12 13:38:42 UTC (rev 11050)
@@ -35,15 +35,23 @@
AroundPoint, // Point / Polygon
OverPoint, // Point / Polygon
- OnLine, // Line / Polygon
- AroundLine, // Line / Polygon
+ Line, // Line / Polygon
Horizontal, // Polygon
Free // Polygon
+ enum LinePlacementFlags
+ OnLine = 1,
+ AboveLine = 2,
+ BelowLine = 4,
+ MapOrientation = 8
QString layerId;
QString fieldName;
Placement placement;
+ unsigned long placementFlags;
QFont textFont;
QColor textColor;
bool enabled;
