[QGIS Commit] r11073 - in trunk/qgis/src/plugins/grass: modules-6.4 modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 15 02:33:53 EDT 2009
Author: pcav
Date: 2009-07-15 02:33:43 -0400 (Wed, 15 Jul 2009)
New Revision: 11073
   trunk/qgis/src/plugins/grass/modules-6.4/r.grow.distance.qgm
   trunk/qgis/src/plugins/grass/modules-6.4/v.in.gns.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.cost.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.in.bin.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.in.poly.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.in.wms.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.in.xyz.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.out.ascii.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.out.mpeg.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.out.vtk.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.out.xyz.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.reclass.area.greater.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.reclass.area.lesser.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.surf.contour.qgm
   trunk/qgis/src/plugins/grass/modules-common/v.net.path.qgm
   trunk/qgis/src/plugins/grass/modules-common/v.out.pov.qgm
   trunk/qgis/src/plugins/grass/modules-common/v.out.svg.qgm
   trunk/qgis/src/plugins/grass/modules-common/v.out.vtk.qgm
More consistency in GRASS module descriptions
Modified: trunk/qgis/src/plugins/grass/modules-6.4/r.grow.distance.qgm
--- trunk/qgis/src/plugins/grass/modules-6.4/r.grow.distance.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-6.4/r.grow.distance.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,9 +1,9 @@
 <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Generates a raster map layer of distance to features in input layer" module="r.grow.distance">
+<qgisgrassmodule label="Create raster of distance to features in input layer" module="r.grow.distance">
 	<option key="input" />
 	<option key="distance" />
 	<option key="value" />
 	<option key="metric" />
-</qgisgrassmodule>
\ No newline at end of file
+</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/v.in.gns.qgm
--- trunk/qgis/src/plugins/grass/modules-6.4/v.in.gns.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-6.4/v.in.gns.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import US-NGA GEOnet Names Server (GNS)country files" module="r.in.gns">
+<qgisgrassmodule label="Import US-NGA GEOnet Names Server (GNS) country file" module="r.in.gns">
 	<file key="file" type="old" filter="TXT (*.txt)" />
 	<option key="vect" />
-</qgisgrassmodule>
+</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules-common/r.cost.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.cost.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.cost.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Output raster showing the cumulative cost of moving between different geographic locations based on cost input raster" module="r.cost">
+<qgisgrassmodule label="Generate raster of cumulative cost of moving between locations based on cost input raster" module="r.cost">
 	<option key="input"/>
 	<option key="output"/>
 	<option key="start_rast"/>
Modified: trunk/qgis/src/plugins/grass/modules-common/r.in.bin.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.in.bin.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.in.bin.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Import a binary raster file" module="r.in.bin">
+<qgisgrassmodule label="Import binary raster" module="r.in.bin">
 	<file key="input" type="old" filters="Binary (*.bin)" />
 	<option key="bytes" />
 	<option key="anull" />
Modified: trunk/qgis/src/plugins/grass/modules-common/r.in.poly.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.in.poly.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.in.poly.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Create rasters from ASCII polygon/line data in current directory" module="r.in.poly">
+<qgisgrassmodule label="Import raster from ASCII polygon/line" module="r.in.poly">
 	<file key="input" type="old" />
 	<option key="output" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules-common/r.in.wms.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.in.wms.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.in.wms.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Download and imports data from WMS servers" module="r.in.wms">
+<qgisgrassmodule label="Download and import data from WMS server" module="r.in.wms">
 	<option key="mapserver" />
 	<option key="layers" />
 	<option key="srs" />
Modified: trunk/qgis/src/plugins/grass/modules-common/r.in.xyz.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.in.xyz.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.in.xyz.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Create a raster map from an assemblage of many coordinates using univariate statistics" module="r.in.xyz">
+<qgisgrassmodule label="Import raster from coordinates using univariate statistics" module="r.in.xyz">
 	<file key="input" type="old" filters="TXT (*.txt), CSV (*.csv)"/>
 	<option key="method" />
 	<option key="type" />
Modified: trunk/qgis/src/plugins/grass/modules-common/r.out.ascii.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.out.ascii.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.out.ascii.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Converts a raster map layer into an ASCII text file" module="r.out.ascii">
+<qgisgrassmodule label="Export raster to ASCII text file" module="r.out.ascii">
 	<option key="dp" answer="2"/>
 	<option key="null" />
Modified: trunk/qgis/src/plugins/grass/modules-common/r.out.mpeg.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.out.mpeg.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.out.mpeg.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export raster series to MPGEG Conversion Program" module="r.out.mpeg">
+<qgisgrassmodule label="Export raster series to MPEG movie" module="r.out.mpeg">
 	<file key="view1" label="Type in map names separated by a comma" />
 	<option key="qual" />
 	<flag key="c" />
Modified: trunk/qgis/src/plugins/grass/modules-common/r.out.vtk.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.out.vtk.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.out.vtk.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert raster maps in VTK-Ascii format" module="r.out.vtk">
+<qgisgrassmodule label="Export raster to VTK-ASCII" module="r.out.vtk">
 	<option key="elevation" />
 	<flag key="p" answer="off" />
Modified: trunk/qgis/src/plugins/grass/modules-common/r.out.xyz.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.out.xyz.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.out.xyz.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export raster to a text files as x,y,z values based on cell centers" module="r.out.xyz">
+<qgisgrassmodule label="Export raster to text file as x,y,z values based on cell centers" module="r.out.xyz">
 	<option key="fs" />
 	<file key="output" type="new" />
Modified: trunk/qgis/src/plugins/grass/modules-common/r.reclass.area.greater.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.reclass.area.greater.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.reclass.area.greater.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reclassify raster with patches larger than user-defined area size (in hectares)" module="r.reclass.area">
+<qgisgrassmodule label="Reclass raster with patches larger than user-defined area size (in hectares)" module="r.reclass.area">
 	<option key="greater" />
Modified: trunk/qgis/src/plugins/grass/modules-common/r.reclass.area.lesser.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.reclass.area.lesser.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.reclass.area.lesser.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Reclassify raster with patches smaller than user-defined area size (in hectares)" module="r.reclass.area">
+<qgisgrassmodule label="Reclass raster with patches smaller than user-defined area size (in hectares)" module="r.reclass.area">
 	<option key="lesser" />
Modified: trunk/qgis/src/plugins/grass/modules-common/r.surf.contour.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.surf.contour.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/r.surf.contour.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Genearate surface from rasterized contours" module="r.surf.contour">
+<qgisgrassmodule label="Create surface from rasterized contours" module="r.surf.contour">
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules-common/v.net.path.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.net.path.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/v.net.path.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Finds shortest path on vector network" module="v.net.path">
+<qgisgrassmodule label="Find shortest path on vector network" module="v.net.path">
 	<option key="alayer" answer="1" />
 	<option key="nlayer" answer="2" />
Modified: trunk/qgis/src/plugins/grass/modules-common/v.out.pov.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.out.pov.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/v.out.pov.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Convert to POV-Ray format" module="v.out.pov">
+<qgisgrassmodule label="Export vector to POV-Ray" module="v.out.pov">
 	<option key="input" typeoption="type" />
 	<option key="size" />
 	<file key="output" filters="POV (*.pov)"/>
Modified: trunk/qgis/src/plugins/grass/modules-common/v.out.svg.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.out.svg.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/v.out.svg.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="Export a GRASS vector map to SVG" module="v.out.svg">
+<qgisgrassmodule label="Export vector to SVG" module="v.out.svg">
 	<option key="input" layeroption="layer" />
 	<option key="precision" />
Modified: trunk/qgis/src/plugins/grass/modules-common/v.out.vtk.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.out.vtk.qgm	2009-07-15 05:06:11 UTC (rev 11072)
+++ trunk/qgis/src/plugins/grass/modules-common/v.out.vtk.qgm	2009-07-15 06:33:43 UTC (rev 11073)
@@ -1,8 +1,8 @@
-<qgisgrassmodule label="Convert a GRASS binary vector map to VTK Ascii outpt" module="v.out.vtk">
+<qgisgrassmodule label="Export vector to VTK-ASCII" module="v.out.vtk">
 	<option key="input" layeroption="layer" typeoption="type" />
 	<option key="scale" />
 	<file key="output" filters="VTK (*.vtk)"/>
-</qgisgrassmodule>
+</qgisgrassmodule>
More information about the QGIS-commit mailing list
