[QGIS Commit] r11074 - in trunk/qgis/src/plugins/grass: modules-6.3 modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 15 02:41:06 EDT 2009
Author: pcav
Date: 2009-07-15 02:41:03 -0400 (Wed, 15 Jul 2009)
New Revision: 11074
Added:
   trunk/qgis/src/plugins/grass/modules-6.3/v.out.ogr.postgis.1.png
   trunk/qgis/src/plugins/grass/modules-6.3/v.out.ogr.postgis.2.png
   trunk/qgis/src/plugins/grass/modules-6.3/v.out.ogr.postgis.qgm
Removed:
   trunk/qgis/src/plugins/grass/modules-common/v.out.ogr.postgis.1.png
   trunk/qgis/src/plugins/grass/modules-common/v.out.ogr.postgis.2.png
   trunk/qgis/src/plugins/grass/modules-common/v.out.ogr.postgis.qgm
Moved v.out.ogr.postgis to 6.3 modules
Copied: trunk/qgis/src/plugins/grass/modules-6.3/v.out.ogr.postgis.1.png (from rev 11071, trunk/qgis/src/plugins/grass/modules-common/v.out.ogr.postgis.1.png)
(Binary files differ)
Copied: trunk/qgis/src/plugins/grass/modules-6.3/v.out.ogr.postgis.2.png (from rev 11071, trunk/qgis/src/plugins/grass/modules-common/v.out.ogr.postgis.2.png)
Copied: trunk/qgis/src/plugins/grass/modules-6.3/v.out.ogr.postgis.qgm (from rev 11071, trunk/qgis/src/plugins/grass/modules-common/v.out.ogr.postgis.qgm)
--- trunk/qgis/src/plugins/grass/modules-6.3/v.out.ogr.postgis.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-6.3/v.out.ogr.postgis.qgm	2009-07-15 06:41:03 UTC (rev 11074)
@@ -0,0 +1,10 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Export vector to PostGIS" module="v.out.ogr">
+	<option key="input" layeroption="layer" typeoption="type" />
+	<option key="format" answer="PostgreSQL" hidden="yes"/>
+	<option key="dsn" label="Database parameters" />
+	<option key="olayer" label="Name of the table to create" />
+	<flag key="c" answer="on" hidden="no" label="Write only features link to a record"/>
+</qgisgrassmodule>
Deleted: trunk/qgis/src/plugins/grass/modules-common/v.out.ogr.postgis.1.png
Deleted: trunk/qgis/src/plugins/grass/modules-common/v.out.ogr.postgis.2.png
Deleted: trunk/qgis/src/plugins/grass/modules-common/v.out.ogr.postgis.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.out.ogr.postgis.qgm	2009-07-15 06:33:43 UTC (rev 11073)
+++ trunk/qgis/src/plugins/grass/modules-common/v.out.ogr.postgis.qgm	2009-07-15 06:41:03 UTC (rev 11074)
@@ -1,10 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Export vector to PostGIS" module="v.out.ogr">
-	<option key="input" layeroption="layer" typeoption="type" />
-	<option key="format" answer="PostgreSQL" hidden="yes"/>
-	<option key="dsn" label="Database parameters" />
-	<option key="olayer" label="Name of the table to create" />
-	<flag key="c" answer="on" hidden="no" label="Write only features link to a record"/>
-</qgisgrassmodule>
More information about the QGIS-commit mailing list
