[QGIS Commit] r11076 - trunk/qgis/src/plugins/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 15 02:58:32 EDT 2009
Author: rugginoso
Date: 2009-07-15 02:58:32 -0400 (Wed, 15 Jul 2009)
New Revision: 11076
   trunk/qgis/src/plugins/grass/qgsgrasstoolsbase.ui
Removed "Help" button from the GRASS plug-in window to fix #1778.
Modified: trunk/qgis/src/plugins/grass/qgsgrasstoolsbase.ui
--- trunk/qgis/src/plugins/grass/qgsgrasstoolsbase.ui	2009-07-15 06:58:06 UTC (rev 11075)
+++ trunk/qgis/src/plugins/grass/qgsgrasstoolsbase.ui	2009-07-15 06:58:32 UTC (rev 11076)
@@ -1,7 +1,8 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>QgsGrassToolsBase</class>
- <widget class="QDialog" name="QgsGrassToolsBase" >
-  <property name="geometry" >
+ <widget class="QDialog" name="QgsGrassToolsBase">
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
@@ -9,36 +10,36 @@
     <height>300</height>
    </rect>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>Grass Tools</string>
   </property>
-  <layout class="QGridLayout" >
-   <item row="0" column="0" >
-    <widget class="QTabWidget" name="mTabWidget" >
-     <property name="currentIndex" >
+  <layout class="QGridLayout">
+   <item row="0" column="0">
+    <widget class="QTabWidget" name="mTabWidget">
+     <property name="currentIndex">
       <number>0</number>
      </property>
-     <widget class="QWidget" name="modulesTree" >
-      <attribute name="title" >
+     <widget class="QWidget" name="modulesTree">
+      <attribute name="title">
        <string>Modules Tree</string>
       </attribute>
-        <widget class="QTreeWidget" name="mModulesTree" >
-         <property name="indentation" >
+        <widget class="QTreeWidget" name="mModulesTree">
+         <property name="indentation">
           <number>8</number>
          </property>
-         <property name="rootIsDecorated" >
+         <property name="rootIsDecorated">
           <bool>false</bool>
          </property>
-         <property name="wordWrap" >
+         <property name="wordWrap">
           <bool>true</bool>
          </property>
-         <property name="headerHidden" stdset="0" >
+         <property name="headerHidden">
           <bool>true</bool>
          </property>
          <column>
-          <property name="text" >
+          <property name="text">
            <string>1</string>
           </property>
          </column>
@@ -46,35 +47,35 @@
        </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="modulesList" >
+     <widget class="QWidget" name="modulesList">
        <string>Modules List</string>
       </attribute>
-        <widget class="QListView" name="mListView" >
-         <property name="alternatingRowColors" >
+        <widget class="QListView" name="mListView">
+         <property name="alternatingRowColors">
           <bool>true</bool>
          </property>
           <bool>true</bool>
          </property>
         </widget>
        </item>
-       <item row="1" column="0" >
-        <widget class="QLineEdit" name="mFilterInput" />
+       <item row="1" column="0">
+        <widget class="QLineEdit" name="mFilterInput"/>
        </item>
       </layout>
      </widget>
     </widget>
    </item>
-    <widget class="QDialogButtonBox" name="buttonBox" >
-     <property name="orientation" >
+    <widget class="QDialogButtonBox" name="buttonBox">
+     <property name="orientation">
       <enum>Qt::Horizontal</enum>
      </property>
-     <property name="standardButtons" >
-      <set>QDialogButtonBox::Close|QDialogButtonBox::Help|QDialogButtonBox::NoButton</set>
+     <property name="standardButtons">
+      <set>QDialogButtonBox::Close</set>
      </property>
     </widget>
    </item>
@@ -88,11 +89,11 @@
    <receiver>QgsGrassToolsBase</receiver>
    <slot>accept()</slot>
    <hints>
-    <hint type="sourcelabel" >
+    <hint type="sourcelabel">
      <x>252</x>
      <y>295</y>
     </hint>
-    <hint type="destinationlabel" >
+    <hint type="destinationlabel">
      <x>157</x>
      <y>274</y>
     </hint>
@@ -104,11 +105,11 @@
    <slot>reject()</slot>
    <hints>
      <x>320</x>
      <y>295</y>
     </hint>
      <x>286</x>
      <y>274</y>
     </hint>
More information about the QGIS-commit mailing list
