[QGIS Commit] r11092 - trunk/qgis/src/plugins/grass/modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Jul 16 06:46:21 EDT 2009
Author: rugginoso
Date: 2009-07-16 06:46:20 -0400 (Thu, 16 Jul 2009)
New Revision: 11092
   trunk/qgis/src/plugins/grass/modules-common/db.connect.schema.qgm
Forced the driver to be "pg" for db.connect.schema module of grass plug-in.
Modified: trunk/qgis/src/plugins/grass/modules-common/db.connect.schema.qgm
--- trunk/qgis/src/plugins/grass/modules-common/db.connect.schema.qgm	2009-07-16 09:36:52 UTC (rev 11091)
+++ trunk/qgis/src/plugins/grass/modules-common/db.connect.schema.qgm	2009-07-16 10:46:20 UTC (rev 11092)
@@ -2,7 +2,7 @@
 <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
 <qgisgrassmodule label="Set general DB connection with a schema (PostgreSQL only)" module="db.connect">
-	<option key="driver" answer="dbf" hidden="no"/>
+	<option key="driver" answer="pg" hidden="yes"/>
 	<option key="database" answer="$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/" hidden="no"/>
 	<option key="schema" answer=" " hidden="no"/>
 </qgisgrassmodule>
More information about the QGIS-commit mailing list
