[QGIS Commit] r11141 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 22 07:31:26 EDT 2009
Author: wonder
Date: 2009-07-22 07:31:25 -0400 (Wed, 22 Jul 2009)
New Revision: 11141
   trunk/qgis/src/app/qgsmaptoolnodetool.cpp
   trunk/qgis/src/app/qgsmaptoolnodetool.h
Added support for topology editing in node tool. Contributed by Richard Kostecky.
Modified: trunk/qgis/src/app/qgsmaptoolnodetool.cpp
--- trunk/qgis/src/app/qgsmaptoolnodetool.cpp	2009-07-21 22:58:36 UTC (rev 11140)
+++ trunk/qgis/src/app/qgsmaptoolnodetool.cpp	2009-07-22 11:31:25 UTC (rev 11141)
@@ -20,12 +20,15 @@
 #include "qgsvectorlayer.h"
 #include "qgsvectordataprovider.h"
 #include "qgstolerance.h"
+#include "qgsgeometry.h"
 #include <math.h>
 #include <QMouseEvent>
 #include <QMessageBox>
 QgsRubberBand* QgsMapToolNodeTool::createRubberBandMarker( QgsPoint center, QgsVectorLayer* vlayer )
+  //create rubber band marker for moving points
   QgsRubberBand* marker = new QgsRubberBand( mCanvas, true );
   marker->setColor( Qt::red );
   marker->setWidth( 2 );
@@ -58,8 +61,12 @@
   mClicked = false;
   mChangingGeometry = false;
   mIsPoint = false;
+  //signal handling change of layer structure
   connect( canvas, SIGNAL( layersChanged() ), this, SLOT( layersChanged() ) );
+  //signal when destination srs changed to repaint coordinates
   connect( canvas->mapRenderer(), SIGNAL( destinationSrsChanged() ), this, SLOT( coordinatesChanged() ) );
+  //signal changing of coordinate renderer changed to repaint markers
+  connect( canvas->mapRenderer(), SIGNAL( hasCrsTransformEnabled( bool ) ), this, SLOT( coordinatesChanged( ) ) );
 QgsMapToolNodeTool::~QgsMapToolNodeTool()
@@ -69,6 +76,7 @@
 void QgsMapToolNodeTool::layersChanged()
+  //deselection of feature when layer has changed
   QgsVectorLayer* vlayer = dynamic_cast<QgsVectorLayer*>( mCanvas->currentLayer() );
   if ( mSelectionFeature != NULL && mSelectionFeature->vlayer() != vlayer )
@@ -79,6 +87,7 @@
 void QgsMapToolNodeTool::currentLayerChanged( QgsMapLayer* layer )
+  //deselection of feature when current layer has changed
   QgsVectorLayer* vlayer = dynamic_cast<QgsVectorLayer*>( layer );
@@ -90,8 +99,10 @@
 void QgsMapToolNodeTool::featureDeleted( int featureId )
+  //check if deleted feature is the one selected
   if ( mSelectionFeature != NULL && featureId == mSelectionFeature->featureId() )
+    //if it's delete selection and disconnect signals since tool is not used anymore
     delete mSelectionFeature;
     mSelectionFeature = NULL;
     disconnect( mCanvas->currentLayer(), SIGNAL( featureDeleted( int ) ) );
@@ -101,21 +112,34 @@
 void QgsMapToolNodeTool::layerModified( bool onlyGeometry )
+  //handling modification of
   QgsFeature feat;
   if ( mSelectionFeature != NULL && !mChangingGeometry && ( vlayer->featureAtId( mSelectionFeature->featureId(), feat, true, false ) ) )
-    if ( !GEOSEquals( feat.geometry()->asGeos(), mSelectionFeature->feature()->geometry()->asGeos() ) )
+    try
-      qDebug( "update from feature" );
+      if ( !GEOSEquals( feat.geometry()->asGeos(), mSelectionFeature->feature()->geometry()->asGeos() ) )
+        mSelectionFeature->updateFromFeature();
+        //throw error
+    catch (...)
+      //GEOS is throwing exception when polygon is not valid to be able to edit it
+      //Only possibility to fix this operation sice node tool doesn't allow to strore invalid geometry after editing
-      //throw error
+      //if it does update markers just to be sure of correctness
 void QgsMapToolNodeTool::createMovingRubberBands()
+  int topologicalEditing = QgsProject::instance()->readNumEntry( "Digitizing", "/TopologicalEditing", 0 );
+  QgsVectorLayer* vlayer = dynamic_cast<QgsVectorLayer*>( mCanvas->currentLayer() );
   QList<VertexEntry> vertexMap = mSelectionFeature->vertexMap();
   QgsGeometry* geometry = mSelectionFeature->feature()->geometry();
   int beforeVertex, afterVertex;
@@ -136,11 +160,12 @@
           geometry->adjacentVertices( vertex, beforeVertex, afterVertex );
         else
-        { //break
+        { //break if cycle is found
           break;
       //we have first vertex of moving part
+      //create rubber band and set default paramaters
       QgsRubberBand* rb = new QgsRubberBand( mCanvas, false );
       rb->setWidth( 2 );
       rb->setColor( Qt::blue );
@@ -154,13 +179,20 @@
       while ( vertex != -1 && vertexMap[vertex].selected && !vertexMap[vertex].inRubberBand )
+        //topology rubber band creation if needed
+        if ( topologicalEditing )
+          createTopologyRubbedBands( vlayer, vertexMap, vertex );
+        //adding point which will be moved
         rb->addPoint( toMapCoordinates( mCanvas->currentLayer(), vertexMap[vertex].point ), false );
+        //setting values about added vertex
         mSelectionFeature->setRubberBandValues( vertex, true, lastRubberBand, index );
         vertexMap[vertex].inRubberBand = true;
         index ++;
         geometry->adjacentVertices( vertex, beforeVertex, vertex );
-      if ( vertex != -1 && !vertexMap[vertex].selected ) //add last point if exists
+      if ( vertex != -1 && !vertexMap[vertex].selected ) //add last point not moving if exists
         rb->addPoint( toMapCoordinates( mCanvas->currentLayer(), vertexMap[vertex].point ), true );
@@ -173,17 +205,121 @@
+void QgsMapToolNodeTool::createTopologyRubbedBands(QgsVectorLayer* vlayer, QList<VertexEntry> vertexMap, int vertex)
+  QMultiMap<double, QgsSnappingResult> currentResultList;
+  QgsGeometry* geometry = mSelectionFeature->feature()->geometry();
+  //snapp from current vertex
+  currentResultList.clear();
+  vlayer->snapWithContext( vertexMap[vertex].point, ZERO_TOLERANCE, currentResultList, QgsSnapper::SnapToVertex );
+  QMultiMap<double, QgsSnappingResult>::iterator resultIt =  currentResultList.begin();
+  for ( ; resultIt != currentResultList.end(); ++resultIt )
+    //move all other
+    if (mSelectionFeature->featureId() != resultIt.value().snappedAtGeometry)
+      if ( mTopologyMovingVertexes.contains( resultIt.value().snappedAtGeometry) )
+        if ( mTopologyMovingVertexes[resultIt.value().snappedAtGeometry]->contains( resultIt.value().snappedVertexNr ) )
+          //skip vertex already exists in some rubberband
+          continue;
+      QgsRubberBand* trb = new QgsRubberBand( mCanvas, false );
+      mTopologyRubberBand.append( trb );
+      int rbId = mTopologyRubberBand.size() - 1;
+      trb->setWidth( 1 );
+      trb->setColor( Qt::red );
+      int tVertex = resultIt.value().snappedVertexNr;
+      int tVertexBackup, tVertexAfter;
+      int tVertexFirst = tVertex;//vertex number to check for cycling
+      QgsFeature topolFeature;
+      vlayer->featureAtId( resultIt.value().snappedAtGeometry, topolFeature, true, false );
+      QgsGeometry* topolGeometry = topolFeature.geometry();
+      while (tVertex != -1) //looking for first vertex to rubber band
+        tVertexBackup = tVertex;
+        topolGeometry->adjacentVertices( tVertex, tVertex, tVertexAfter );
+        if ( tVertex == -1 || tVertex == tVertexFirst )
+           break;//chceck if this is not first vertex of the feature or cycling error
+        //if closest vertex is not from selected feature or is not selected end
+        double dist;
+        QgsPoint point = topolGeometry->vertexAt(tVertex);
+        int at, before, after;
+        geometry->closestVertex( point, at, before, after, dist );
+        if ( dist > ZERO_TOLERANCE || !vertexMap[at].selected) //problem with double precision
+          break; //found first vertex
+      int movingPointIndex = 0;
+      Vertexes* movingPoints = new Vertexes();
+      Vertexes* addedPoints = new Vertexes();
+        addedPoints = mTopologyMovingVertexes[ resultIt.value().snappedAtGeometry ];
+      if (tVertex == -1) //adding first point if needed
+        tVertex = tVertexBackup;
+      else
+        trb->addPoint( topolGeometry->vertexAt( tVertex ) );
+        if (tVertex == tVertexFirst) //cycle first vertex need to be added also
+          movingPoints->insert( movingPointIndex );
+        movingPointIndex = 1;
+        topolGeometry->adjacentVertices( tVertex, tVertexAfter, tVertex );
+        double dist;
+        // find first no matching vertex
+        if ( dist > ZERO_TOLERANCE || !vertexMap[at].selected ) //problem with double precision
+        else //add moving point to rubber band
+          if ( addedPoints->contains( tVertex ) )
+            break; //just preventing to circle
+          movingPointIndex++;
+          addedPoints->insert( tVertex );
+      mTopologyMovingVertexes.insert ( resultIt.value().snappedAtGeometry, addedPoints );
+      mTopologyRubberBandVertexes.insert ( rbId, movingPoints );
 void QgsMapToolNodeTool::coordinatesChanged()
+  //need to update vertex markers since coordinate systems have changed
   if ( mSelectionFeature != NULL )
     mSelectionFeature->updateVertexMarkersPosition( mCanvas );
 void QgsMapToolNodeTool::canvasMoveEvent( QMouseEvent * e )
   QgsMapLayer* currentLayer = mCanvas->currentLayer();
@@ -202,8 +338,7 @@
     mSelectAnother = false;
     if ( mMoving )
-      //create rubberband
+      //create rubberband if none exists
       if ( mQgsRubberBands.empty() )
         if ( mIsPoint )
@@ -219,14 +354,19 @@
         createMovingRubberBands();
+        QList<QgsSnappingResult> snapResults;
+        QgsPoint posMapCoord = snapPointFromResults( snapResults, e->pos() );
+        mPosMapCoordBackup = posMapCoord;
       else
+        //move rubber band
         QgsPoint firstCoords = mCanvas->getCoordinateTransform()->toMapPoint( mLastCoordinates->x(), mLastCoordinates->y() );
         QList<QgsPoint> excludePoints;
         excludePoints.append( mClosestVertex );
         mSnapper.snapToBackgroundLayers( e->pos(), snapResults, excludePoints );
+        //get correct coordinates to move
         if ( snapResults.size() > 0 )
@@ -255,7 +395,7 @@
             QgsPoint mapCoords = toMapCoordinates( vlayer, vertexMap[i].point );
             double x = mapCoords.x() + posMapCoord.x() - firstCoords.x();
             double y = mapCoords.y() + posMapCoord.y() - firstCoords.y();
-            //QgsPoint pom = toLayerCoordinates(
             mQgsRubberBands[vertexMap[i].rubberBandNr]->movePoint( vertexMap[i].index + 1, QgsPoint( x, y ) );
             if ( vertexMap[i].index == 0 )
@@ -263,6 +403,30 @@
+        //topological editing
+        double offsetX = posMapCoord.x() - mPosMapCoordBackup.x();
+        double offsetY = posMapCoord.y() - mPosMapCoordBackup.y();
+        for (int i = 0; i < mTopologyRubberBand.size(); i++)
+          for (int pointIndex = 0; pointIndex < mTopologyRubberBand[i]->numberOfVertices() -1; pointIndex ++ )
+            if (mTopologyRubberBandVertexes[i]->contains( pointIndex ))
+              const QgsPoint* point = mTopologyRubberBand[i]->getPoint( 0, pointIndex +1 );
+              if (point == 0)
+                  break;
+              mTopologyRubberBand[i]->movePoint( pointIndex +1, QgsPoint( point->x() + offsetX, point->y() + offsetY ) );
+              if ( pointIndex == 0 )
+                mTopologyRubberBand[i]->movePoint( pointIndex , QgsPoint( point->x() + offsetX, point->y() + offsetY ) );
     else
@@ -280,6 +444,7 @@
       mQRubberBand->show();
 void QgsMapToolNodeTool::connectSignals( QgsVectorLayer* vlayer )
@@ -303,11 +468,19 @@
     return false;
+  try
-    //update markers
-    mSelectionFeature->updateFromFeature();
+      //update markers when geometries are not valid
+  catch (...)
+    // for cases when geos throws an exception for example for invalid polygon
+    return true;
   return true;
@@ -419,7 +592,6 @@
         if ( mCtrl )
-          //mSelectionFeature->invertVertexSelection( snapResult.snappedVertexNr);
           mSelectionFeature->invertVertexSelection( atVertex );
         else
@@ -520,9 +692,14 @@
       coords = snapPointFromResults( snapResults, e->pos() );
       //coords = mCanvas->getCoordinateTransform()->toMapPoint( e->pos().x(), e->pos().y() );
         firstCoords = toMapCoordinates( vlayer, mClosestVertex );
+          insertSegmentVerticesForSnap( snapResults, vlayer );
       QgsPoint layerCoords = toLayerCoordinates( vlayer, coords );
       QgsPoint layerFirstCoords = toLayerCoordinates( vlayer, firstCoords );
@@ -586,6 +763,16 @@
   mQgsRubberBands.clear();
+  rb_it = mTopologyRubberBand.begin();
+  for ( ;rb_it != mTopologyRubberBand.end(); ++rb_it )
+    delete *rb_it;
+  mTopologyRubberBand.clear();
+  mTopologyMovingVertexes.clear();
+  mTopologyRubberBandVertexes.clear();
   //remove all data from selected feature (no change to rubber bands itself
     mSelectionFeature->cleanRubberBandsData();
@@ -729,25 +916,64 @@
 void SelectionFeature::deleteSelectedVertexes()
   mVlayer->beginEditCommand( QObject::tr( "Deleted vertices" ) );
   int count = 0;
   for ( int i = mVertexMap.size() - 1; i > -1 ; i-- )
     if ( mVertexMap[i].selected )
-      mVlayer->deleteVertex( mFeatureId, i );
+      if ( mVertexMap[i].equals != -1 )
+      { //to avoid try to delete some vertex twice
+        mVertexMap[mVertexMap[i].equals].selected = false;
+        mVlayer->snapWithContext( mVertexMap[i].point, ZERO_TOLERANCE, currentResultList, QgsSnapper::SnapToVertex );
+      if (!mVlayer->deleteVertex( mFeatureId, i ))
+        count = 0;
+        qDebug("Setting count 0 and calling break;");
+        break;
       count++;
-      if ( mVertexMap[i].equals != -1 && !mVertexMap[mVertexMap[i].equals].selected )
-        //for polygon delete both
+          //move all other
+          if (mFeatureId !=  resultIt.value().snappedAtGeometry)
+            mVlayer->deleteVertex( resultIt.value().snappedAtGeometry, resultIt.value().snappedVertexNr );
-  if ( count )
+  QgsFeature f;
+  mVlayer->featureAtId( mFeatureId, f, true, false);
+  if ( !GEOSisValid( f.geometry()->asGeos() ) )
+    QMessageBox::warning( NULL,
+                          tr( "Node tool" ),
+                          tr( "Result geometry is invalid. Reverting last changes.\n" ),
+                          QMessageBox::Ok ,
+                          QMessageBox::Ok );
+  if ( count != 0 && GEOSisValid( f.geometry()->asGeos() ))
     mVlayer->endEditCommand();
   else
-    mVlayer->destroyEditCommand(); // no changes...
+    mVlayer->destroyEditCommand(); // no changes... or invalid changes
@@ -756,13 +982,36 @@
 void SelectionFeature::moveSelectedVertexes( double changeX, double changeY )
   mVlayer->beginEditCommand( QObject::tr( "Moved vertices" ) );
       mVlayer->moveVertex( mVertexMap[i].point.x() + changeX, mVertexMap[i].point.y() + changeY, mFeatureId, i );
       mVertexMap[i].point = QgsPoint( mVertexMap[i].point.x() + changeX, mVertexMap[i].point.y() + changeY );
       QgsPoint point = mVertexMap[i].point;
+          //move all other
+            mVlayer->moveVertex( mVertexMap[i].point.x(), mVertexMap[i].point.y(),
+                                 resultIt.value().snappedAtGeometry, resultIt.value().snappedVertexNr );
       point = mCanvas->mapRenderer()->layerToMapCoordinates( mVlayer, mVertexMap[i].point );
       mVertexMap[i].vertexMarker->setCenter( point );
@@ -777,7 +1026,23 @@
-  mVlayer->endEditCommand();
+  QgsFeature f;
+                          QMessageBox::Ok ,
+    //redo last operations
+    updateFromFeature();
+  else
+    mVlayer->endEditCommand();
   updateFeature();
@@ -853,15 +1118,13 @@
   else //multipolygon
-    //print("Number of polygons: " + str(len(feature.geometry().asMultiPolygon())))
     for ( int i2 = 0 ; i2 < mFeature->geometry()->asMultiPolygon().size(); i2++ )
+    { //iterating through polygons
       QgsPolygon poly2 = mFeature->geometry()->asMultiPolygon()[i2];
       for ( int i3 = 0; i3 < poly2.size(); i3++ )
+      { //iterating through polygon rings
         QgsPolyline poly = poly2[i3];
         int i;
-        //print("Number of vertexes:" + str(len(poly)))
         for ( i = 0; i < poly.size(); i++ )
           VertexEntry entry;
@@ -892,6 +1155,7 @@
     QgsMultiPolyline mLine = mFeature->geometry()->asMultiPolyline();
     for ( int i2 = 0; i2 < mLine.size(); i2++ )
+      //iterating through polylines
       QgsPolyline poly = mLine[i2];
       int i;
@@ -969,7 +1233,7 @@
 void SelectionFeature::createVertexMap()
   mVlayer->featureAtId( mFeatureId, *mFeature );
-  //createvertexmap
+  //createvertexmap for correct geometry type
   if ( mFeature->geometry()->type() == QGis::Polygon )
     createVertexMapPolygon();
@@ -997,7 +1261,7 @@
   mVertexMap[vertexNr].vertexMarker->setColor( Qt::blue );
   mVertexMap[vertexNr].vertexMarker->update();
   if ( mVertexMap[vertexNr].equals != -1 )
+  { // select both vertexes if this is first/last vertex
     mVertexMap[mVertexMap[vertexNr].equals].selected = true;
     mVertexMap[mVertexMap[vertexNr].equals].vertexMarker->setColor( Qt::blue );
     mVertexMap[mVertexMap[vertexNr].equals].vertexMarker->update();
@@ -1027,8 +1291,10 @@
 void SelectionFeature::invertVertexSelection( int vertexNr, bool invert )
+  //inverting of selection of vertex
   if ( mVertexMap[vertexNr].selected == false )
+    //case vertex is not selected
     mVertexMap[vertexNr].selected = true;
@@ -1056,6 +1322,7 @@
 void SelectionFeature::updateVertexMarkersPosition( QgsMapCanvas* canvas )
+  //function for on-line updating vertex markers without refresh of canvas
   for ( int i = 0; i < mVertexMap.size() ;i++ )
     mVertexMap[i].vertexMarker->setCenter( mCanvas->mapRenderer()->layerToMapCoordinates( mVlayer, mVertexMap[i].point ) );
@@ -1080,5 +1347,3 @@
   return mVlayer;
Modified: trunk/qgis/src/app/qgsmaptoolnodetool.h
--- trunk/qgis/src/app/qgsmaptoolnodetool.h	2009-07-21 22:58:36 UTC (rev 11140)
+++ trunk/qgis/src/app/qgsmaptoolnodetool.h	2009-07-22 11:31:25 UTC (rev 11141)
@@ -32,7 +32,6 @@
   bool selected;
   QgsPoint point;
   int equals;
-  //QgsRubberBand *vertexMarker;
   QgsVertexMarker* vertexMarker;
   bool inRubberBand;
   int rubberBandNr;
@@ -41,10 +40,21 @@
+ * Set representing set of vertex numbers
+typedef QSet<int> Vertexes;
+ * Constant representing zero value for distance. It's 0 because of error in double counting.
+const static double ZERO_TOLERANCE = 0.000000001;
  * Class that supports feature which is selected/
-class SelectionFeature
+class SelectionFeature: public QObject
+  Q_OBJECT
   public:
     SelectionFeature();
@@ -92,6 +102,7 @@
      * Inverts selection of vertex with number
      * @param vertexNr number of vertex which is to be inverted
+     * @param invert flag if vertex selection should be inverted or not
     void invertVertexSelection( int vertexNr, bool invert = true );
@@ -200,7 +211,7 @@
     QgsMapCanvas* mCanvas;
-/**A maptool to move/deletes/adds vertices of line or polygon fetures*/
+/**A maptool to move/deletes/adds vertices of line or polygon features*/
 class QgsMapToolNodeTool: public QgsMapToolVertexEdit
     Q_OBJECT
@@ -260,22 +271,30 @@
   private:
+     * Connects signal which are required for correct work with bakground changes
+     * @param vlayer vector layer which is emiting these signals
     void connectSignals( QgsVectorLayer* vlayer );
-    /** Deletes the rubber band pointers
-     and clears mRubberBands*/
+     * Deletes the rubber band pointers and clears mRubberBands
     void removeRubberBands();
      * Creating rubber band marker for movin of point
      * @param center coordinates of point to be moved
      * @param vlayer vector layer on which we are working
+     * @return rubber band marker
     QgsRubberBand* createRubberBandMarker( QgsPoint center, QgsVectorLayer* vlayer );
      * Function to check if selected feature exists and is same with original one
+     * stored in internal structures
      * @param vlayer vector layer for checking
+     * @return if feature is same as one in internal structures
     bool checkCorrectnessOfFeature( QgsVectorLayer* vlayer );
@@ -284,12 +303,29 @@
     void createMovingRubberBands();
+     * Creates rubber bands for ther features when topology editing is enabled
+     * @param vlayer vector layer for ehich rubber bands are created
+     * @param vertexMap map of vertexes
+     * @param vertex currently processed vertex
+    void createTopologyRubbedBands(QgsVectorLayer* vlayer, QList<VertexEntry> vertexMap, int vertex);
     /** The position of the vertex to move (in map coordinates) to exclude later from snapping*/
     QList<QgsPoint> mExcludePoint;
     /** rubber bands */
     QList<QgsRubberBand*> mQgsRubberBands;
+    /** list of topology rubber bands */
+    QList<QgsRubberBand*> mTopologyRubberBand;
+    /** vertexes of rubberbands which are to be moved */
+    QMap<int, Vertexes*> mTopologyMovingVertexes;
+    /** vertexes of features with int id which were already added tu rubber bands */
+    QMap<int, Vertexes*> mTopologyRubberBandVertexes;
     /** object containing selected feature and it's vertexes */
     SelectionFeature* mSelectionFeature;
@@ -317,6 +353,9 @@
     /** closest vertex to click */
     QgsPoint mClosestVertex;
+    /** backup of map coordinates to be able to count change between moves */
+    QgsPoint mPosMapCoordBackup;
     /** active rubberband for selecting vertexes */
     QRubberBand* mQRubberBand;
More information about the QGIS-commit mailing list
