[QGIS Commit] r11150 - trunk/qgis/src/app/attributetable
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 22 16:58:32 EDT 2009
Author: wonder
Date: 2009-07-22 16:58:32 -0400 (Wed, 22 Jul 2009)
New Revision: 11150
   trunk/qgis/src/app/attributetable/qgsattributetabledelegate.cpp
   trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h
   trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
[FEATURE] Honour the edit widgets settings also in attribute table.
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledelegate.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetabledelegate.cpp	2009-07-22 20:56:14 UTC (rev 11149)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledelegate.cpp	2009-07-22 20:58:32 UTC (rev 11150)
@@ -15,38 +15,183 @@
 #include <QItemDelegate>
 #include <QLineEdit>
+#include <QComboBox>
 #include <QPainter>
+#include <QCompleter>
+#include <QSpinBox>
+#include <QDoubleSpinBox>
 #include "qgsattributetableview.h"
 #include "qgsattributetablemodel.h"
+#include "qgsattributetablefiltermodel.h"
 #include "qgsattributetabledelegate.h"
 #include "qgsvectordataprovider.h"
+#include "qgsvectorlayer.h"
+#include "qgsuniquevaluerenderer.h"
+#include "qgssymbol.h"
 QWidget * QgsAttributeTableDelegate::createEditor(
   QWidget *parent,
   const QStyleOptionViewItem &option,
   const QModelIndex &index ) const
-  QWidget *editor = QItemDelegate::createEditor( parent, option, index );
+  QWidget *editor;
-  QLineEdit *le = dynamic_cast<QLineEdit*>( editor );
-  if ( !le ) return editor;
+  const QgsAttributeTableFilterModel* fm = dynamic_cast<const QgsAttributeTableFilterModel*>( index.model() );
+  if ( !fm )
+      return editor;
+  const QgsAttributeTableModel* m = dynamic_cast<const QgsAttributeTableModel*>( fm->sourceModel() );
+  if ( !m )
+      return editor;
-  const QgsAttributeTableModel* m = dynamic_cast<const QgsAttributeTableModel*>( index.model() );
-  if ( !m ) return editor;
   int col = index.column();
   QVariant::Type type = m->layer()->dataProvider()->fields()[col].type();
+  QgsVectorLayer::EditType editType = m->layer()->editType(col);
-  if ( type == QVariant::Int )
+  //need to created correct edit widget according to edit type of value
+  //and fill with data from correct source
+  if (editType == QgsVectorLayer::LineEdit ||
+      editType == QgsVectorLayer::UniqueValuesEditable ||
+      editType == QgsVectorLayer::FileName ||
+      editType == QgsVectorLayer::Immutable)
+  { //these are all siple edits
+    editor = new QLineEdit(parent);
+    QLineEdit* le = dynamic_cast<QLineEdit*> ( editor );
+    le-> setReadOnly ( false );
+    if ( editType == QgsVectorLayer::UniqueValuesEditable )
+    { //just this value has completer
+      QList<QVariant> values;
+      m->layer()->dataProvider()->uniqueValues( col, values );
+      QStringList svalues;
+      for ( QList<QVariant>::const_iterator it = values.begin(); it != values.end(); it++ )
+        svalues << it->toString();
+      QCompleter *c = new QCompleter( svalues );
+      c->setCompletionMode( QCompleter::PopupCompletion );
+      le->setCompleter( c );
+    if (editType == QgsVectorLayer::Immutable)
+      le->setReadOnly(true);
+    //validators if value needs it
+    if ( type == QVariant::Int )
+      le->setValidator( new QIntValidator( le ) );
+    else if ( type == QVariant::Double )
+      le->setValidator( new QDoubleValidator( le ) );
+  else if (editType == QgsVectorLayer::ValueMap)
+  { //simple combobox from data from vector layer
+    editor = new QComboBox(parent);
+    QComboBox* cb = dynamic_cast<QComboBox*>( editor );
+    QMap<QString, QVariant> &map = m->layer()->valueMap(col);
+    QMap<QString, QVariant>::iterator it = map.begin();
+    for ( ; it != map.end(); it ++)
+      cb->addItem( it.key() ,it.value());
+  else if (editType == QgsVectorLayer::SliderRange)
+  { //horizontal slider
+    editor = new QSlider(Qt::Horizontal, parent);
+    QSlider* s = dynamic_cast<QSlider*>(editor );
+    QgsVectorLayer::RangeData &range = m->layer()->range(col);
+    s->setMinimum( range.mMin.toInt() );
+    s->setMaximum( range.mMax.toInt() );
+    s->setPageStep( range.mStep.toInt() );
+  else if (editType == QgsVectorLayer::Classification)
-    le->setValidator( new QIntValidator( le ) );
+    // should be prepared probably to not change it always
+    int classificationField = -1;
+    QMap<QString, QString> classes;
+    const QgsUniqueValueRenderer *uvr = dynamic_cast<const QgsUniqueValueRenderer *>( m->layer()->renderer() );
+    if ( uvr )
+      classificationField = uvr->classificationField();
+      const QList<QgsSymbol *> symbols = uvr->symbols();
+      for ( int i = 0; i < symbols.size(); i++ )
+        QString label = symbols[i]->label();
+        QString name = symbols[i]->lowerValue();
+        if ( label == "" )
+          label = name;
+        classes.insert( name, label );
+    for ( QMap<QString, QString>::const_iterator it = classes.begin(); it != classes.end(); it++ )
+      cb->addItem( it.value(), it.key() );
-  else if ( type == QVariant::Double )
+  else if (editType == QgsVectorLayer::UniqueValues)
-    le->setValidator( new QDoubleValidator( le ) );
+    cb->setEditable( true );
+    for ( QList<QVariant>::iterator it = values.begin(); it != values.end(); it++ )
+      cb->addItem( it->toString() );
+  else if (editType == QgsVectorLayer::Enumeration)
+    QStringList enumValues;
+    m->layer()->dataProvider()->enumValues( col, enumValues );
+    QStringList::const_iterator s_it = enumValues.constBegin();
+    for ( ; s_it != enumValues.constEnd(); ++s_it )
+      cb->addItem( *s_it );
+  else if (editType == QgsVectorLayer::EditRange)
+      int min = m->layer()->range( col ).mMin.toInt();
+      int max = m->layer()->range( col ).mMax.toInt();
+      int step = m->layer()->range( col ).mStep.toInt();
+      editor = new QSpinBox(parent);
+      QSpinBox* sb = dynamic_cast<QSpinBox*>( editor );
+      sb->setRange( min, max );
+      sb->setSingleStep( step );
+      double min = m->layer()->range( col ).mMin.toDouble();
+      double max = m->layer()->range( col ).mMax.toDouble();
+      double step = m->layer()->range( col ).mStep.toDouble();
+      editor = new QDoubleSpinBox(parent);
+      QDoubleSpinBox* dsb = dynamic_cast<QDoubleSpinBox*>( editor );
+      dsb->setRange( min, max );
+      dsb->setSingleStep( step );
   return editor;
@@ -68,3 +213,129 @@
+void QgsAttributeTableDelegate::setEditorData(QWidget *editor, const QModelIndex &index) const
+  if ( !fm )
+      return;
+  if ( !m )
+      return;
+  int col = index.column();
+  QVariant::Type type = m->layer()->dataProvider()->fields()[col].type();
+    QString qs = index.model()->data(index, Qt::DisplayRole).toString();
+    le->setText( qs );
+  else if (editType == QgsVectorLayer::ValueMap ||
+           editType == QgsVectorLayer::Classification ||
+           editType == QgsVectorLayer::UniqueValues ||
+           editType == QgsVectorLayer::Enumeration)
+    QVariant qs = index.model()->data(index, Qt::EditRole);
+    int cbIndex = cb->findData(qs);
+    if (cbIndex > -1)
+      cb->setCurrentIndex(cbIndex);
+     int value = index.model()->data(index, Qt::EditRole).toInt();
+     QSlider* s = dynamic_cast<QSlider*>( editor );
+     s->setValue( value );
+      sb->setValue( value );
+      QDoubleSpinBox* sb = dynamic_cast<QDoubleSpinBox*>( editor );
+      double value = index.model()->data(index, Qt::EditRole).toDouble();
+void QgsAttributeTableDelegate::setModelData(QWidget *editor, QAbstractItemModel *model, const QModelIndex &index) const
+  if ( !fm )
+      return;
+  if ( !m )
+      return;
+    QString text = le->text();
+    QVariant value = QVariant (text);
+    model->setData( index, value );
+    model->setData(index, cb->itemData(cb->currentIndex()));
+    model->setData( index, s->value() );
+      model->setData( index, sb->value() );
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h
--- trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h	2009-07-22 20:56:14 UTC (rev 11149)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h	2009-07-22 20:58:32 UTC (rev 11150)
@@ -17,6 +17,7 @@
 #define QGSATTRIBUTETABLEDELEGATE_H
 class QPainter;
 /** \ingroup app
  * A delegate item class for QgsAttributeTable (see Qt documentation for
@@ -43,6 +44,22 @@
       QPainter * painter,
       const QStyleOptionViewItem & option,
       const QModelIndex & index ) const;
+     * Sets data to editor widget. Overloads default metod
+     * @param editor editor which was created by create editor function in this class
+     * @param index index of field which is to be modified
+    void setEditorData(QWidget *editor, const QModelIndex &index) const;
+     * Sets data from editor backk to model. Overloads default metod
+     * @param model model where data should be updated
+    void setModelData(QWidget *editor, QAbstractItemModel *model, const QModelIndex &index) const;
 #endif //QGSATTRIBUTETABLEDELEGATE_H
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp	2009-07-22 20:56:14 UTC (rev 11149)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp	2009-07-22 20:58:32 UTC (rev 11150)
@@ -144,7 +144,7 @@
   loadLayer();
   emit modelChanged();
-  emit headerDataChanged( Qt::Horizontal, 0, columnCount() );
+  emit headerDataChanged ( Qt::Horizontal, 0, columnCount() - 1);
 void QgsAttributeTableModel::loadLayer()
More information about the QGIS-commit mailing list
