[QGIS Commit] r11165 - in trunk/qgis: images/themes/classic images/themes/gis src/app/composer src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Jul 23 18:15:46 EDT 2009
Author: jef
Date: 2009-07-23 18:15:46 -0400 (Thu, 23 Jul 2009)
New Revision: 11165
Added:
   trunk/qgis/images/themes/classic/mActionSaveAsPDF.png
   trunk/qgis/images/themes/gis/mActionSaveAsPDF.png
   trunk/qgis/src/app/composer/qgscomposer.cpp
   trunk/qgis/src/app/composer/qgscomposer.h
   trunk/qgis/src/ui/qgscomposerbase.ui
add export to PDF to composer
Copied: trunk/qgis/images/themes/classic/mActionSaveAsPDF.png (from rev 11164, trunk/qgis/src/plugins/quick_print/quick_print.png)
(Binary files differ)
Copied: trunk/qgis/images/themes/gis/mActionSaveAsPDF.png (from rev 11164, trunk/qgis/images/themes/gis/plugins/quick_print.png)
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp	2009-07-23 20:15:50 UTC (rev 11164)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp	2009-07-23 22:15:46 UTC (rev 11165)
@@ -239,6 +239,7 @@
   mActionSaveAsTemplate->setIcon( QgisApp::getThemeIcon( "/mActionFileSaveAs.png" ) );
   mActionExportAsImage->setIcon( QgisApp::getThemeIcon( "/mActionExportMapServer.png" ) );
   mActionExportAsSVG->setIcon( QgisApp::getThemeIcon( "/mActionSaveAsSVG.png" ) );
+  mActionExportAsPDF->setIcon( QgisApp::getThemeIcon( "/mActionSaveAsPDF.png" ) );
   mActionPrint->setIcon( QgisApp::getThemeIcon( "/mActionFilePrint.png" ) );
   mActionZoomAll->setIcon( QgisApp::getThemeIcon( "/mActionZoomFullExtent.png" ) );
   mActionZoomIn->setIcon( QgisApp::getThemeIcon( "/mActionZoomIn.png" ) );
@@ -429,20 +430,55 @@
+void QgsComposer::on_mActionExportAsPDF_triggered()
+  QSettings myQSettings;  // where we keep last used filter in persistant state
+  QString myLastUsedFile = myQSettings.value( "/UI/lastSaveAsPdfFile", "qgis.pdf" ).toString();
+  QFileInfo file( myLastUsedFile );
+  QFileDialog *myQFileDialog = new QFileDialog( this, tr( "Choose a file name to save the map as" ),
+      file.path(), tr( "PDF Format" ) + " (*.pdf *PDF)" );
+  myQFileDialog->selectFile( file.fileName() );
+  myQFileDialog->setFileMode( QFileDialog::AnyFile );
+  myQFileDialog->setAcceptMode( QFileDialog::AcceptSave );
+  int result = myQFileDialog->exec();
+  raise();
+  if ( result != QDialog::Accepted ) return;
+  QString myOutputFileNameQString = myQFileDialog->selectedFiles().first();
+  if ( myOutputFileNameQString == "" ) return;
+  myQSettings.setValue( "/UI/lastSaveAsPdfFile", myOutputFileNameQString );
+  QPrinter printer;
+  printer.setOutputFormat( QPrinter::PdfFormat );
+  printer.setOutputFileName( myOutputFileNameQString );
+  print( printer );
 void QgsComposer::on_mActionPrint_triggered()
-  if ( !mComposition )
+  QPrinter printer;
+  QPrintDialog printDialog( &printer );
+  if ( printDialog.exec() != QDialog::Accepted )
     return;
+  print( printer );
+void QgsComposer::print( QPrinter &printer )
+  if( !mComposition )
+    return;
   if ( containsWMSLayer() )
     showWMSPrintingWarning();
-  QPrinter printer;
   //try to set most of the print dialog settings based on composer properties
   if ( mComposition->paperHeight() > mComposition->paperWidth() )
@@ -454,58 +490,50 @@
   //set resolution based on composer setting
   printer.setFullPage( true );
   printer.setColorMode( QPrinter::Color );
-  QPrintDialog printDialog( &printer );
-  if ( printDialog.exec() == QDialog::Accepted )
-    //set user-defined resolution
-    if ( mComposition )
-      printer.setResolution( mComposition->printResolution() );
-    QPainter p( &printer );
+  //set user-defined resolution
+  printer.setResolution( mComposition->printResolution() );
-    QgsComposition::PlotStyle savedPlotStyle = mComposition->plotStyle();
-    mComposition->setPlotStyle( QgsComposition::Print );
+  QPainter p( &printer );
-    QApplication::setOverrideCursor( Qt::BusyCursor );
+  QgsComposition::PlotStyle savedPlotStyle = mComposition->plotStyle();
+  mComposition->setPlotStyle( QgsComposition::Print );
-    if ( mComposition->printAsRaster() )
-      //print out via QImage, code copied from on_mActionExportAsImage_activated
-      int width = ( int )( mComposition->printResolution() * mComposition->paperWidth() / 25.4 );
-      int height = ( int )( mComposition-> printResolution() * mComposition->paperHeight() / 25.4 );
-      QImage image( QSize( width, height ), QImage::Format_ARGB32 );
-      image.setDotsPerMeterX( mComposition->printResolution() / 25.4 * 1000 );
-      image.setDotsPerMeterY( mComposition->printResolution() / 25.4 * 1000 );
-      image.fill( 0 );
-      QPainter imagePainter( &image );
-      QRectF sourceArea( 0, 0, mComposition->paperWidth(), mComposition->paperHeight() );
-      QRectF targetArea( 0, 0, width, height );
-      mComposition->render( &imagePainter, targetArea, sourceArea );
-      imagePainter.end();
-      p.drawImage( targetArea, image, targetArea );
-    else
+  QApplication::setOverrideCursor( Qt::BusyCursor );
+  if ( mComposition->printAsRaster() )
+    //print out via QImage, code copied from on_mActionExportAsImage_activated
+    int width = ( int )( mComposition->printResolution() * mComposition->paperWidth() / 25.4 );
+    int height = ( int )( mComposition-> printResolution() * mComposition->paperHeight() / 25.4 );
+    QImage image( QSize( width, height ), QImage::Format_ARGB32 );
+    image.setDotsPerMeterX( mComposition->printResolution() / 25.4 * 1000 );
+    image.setDotsPerMeterY( mComposition->printResolution() / 25.4 * 1000 );
+    image.fill( 0 );
+    QPainter imagePainter( &image );
+    QRectF sourceArea( 0, 0, mComposition->paperWidth(), mComposition->paperHeight() );
+    QRectF targetArea( 0, 0, width, height );
+    mComposition->render( &imagePainter, targetArea, sourceArea );
+    imagePainter.end();
+    p.drawImage( targetArea, image, targetArea );
+  else
 #if QT_VERSION < 0x040400
-      QRectF paperRect( 0, 0, mComposition->paperWidth(), mComposition->paperHeight() );
-      QRect pageRect = printer.pageRect();
-      mComposition->render( &p, pageRect, paperRect );
+    QRectF paperRect( 0, 0, mComposition->paperWidth(), mComposition->paperHeight() );
+    QRect pageRect = printer.pageRect();
+    mComposition->render( &p, pageRect, paperRect );
 #else
-      //better in case of custom page size, but only possible with Qt>=4.4.0
-      QRectF paperRectMM = printer.pageRect( QPrinter::Millimeter );
-      QRectF paperRectPixel = printer.pageRect( QPrinter::DevicePixel );
-      mComposition->render( &p, paperRectPixel, paperRectMM );
+    //better in case of custom page size, but only possible with Qt>=4.4.0
+    QRectF paperRectMM = printer.pageRect( QPrinter::Millimeter );
+    QRectF paperRectPixel = printer.pageRect( QPrinter::DevicePixel );
+    mComposition->render( &p, paperRectPixel, paperRectMM );
 #endif
-    mComposition->setPlotStyle( savedPlotStyle );
-    QApplication::restoreOverrideCursor();
+  mComposition->setPlotStyle( savedPlotStyle );
+  QApplication::restoreOverrideCursor();
 void QgsComposer::on_mActionExportAsImage_triggered()
Modified: trunk/qgis/src/app/composer/qgscomposer.h
--- trunk/qgis/src/app/composer/qgscomposer.h	2009-07-23 20:15:50 UTC (rev 11164)
+++ trunk/qgis/src/app/composer/qgscomposer.h	2009-07-23 22:15:46 UTC (rev 11165)
@@ -119,6 +119,9 @@
     //! Print as SVG
     void on_mActionExportAsSVG_triggered();
+    //! Print as PDF
+    void on_mActionExportAsPDF_triggered();
     //! Select item
     void on_mActionSelectMoveItem_triggered();
@@ -243,6 +246,9 @@
     //! Changes elements that are not suitable for this project
     void cleanupAfterTemplateRead();
+    //! Print to a printer object
+    void print( QPrinter &printer );
     //! Writes state under DOM element
     void writeXML( QDomNode& parentNode, QDomDocument& doc );
     //! Pointer to composer view
Modified: trunk/qgis/src/ui/qgscomposerbase.ui
--- trunk/qgis/src/ui/qgscomposerbase.ui	2009-07-23 20:15:50 UTC (rev 11164)
+++ trunk/qgis/src/ui/qgscomposerbase.ui	2009-07-23 22:15:46 UTC (rev 11165)
@@ -232,6 +232,7 @@
    <addaction name="mActionLoadFromTemplate" />
    <addaction name="mActionSaveAsTemplate" />
    <addaction name="mActionExportAsImage" />
+   <addaction name="mActionExportAsPDF" />
    <addaction name="mActionExportAsSVG" />
    <addaction name="mActionPrint" />
    <addaction name="separator" />
@@ -334,6 +335,14 @@
     <string>Export as Image...</string>
    </property>
   </action>
+  <action name="mActionExportAsPDF" >
+   <property name="icon" >
+    <iconset>../themes/default/mActionSaveAsPDF.png</iconset>
+   </property>
+   <property name="text" >
+    <string>Export as PDF...</string>
+   </property>
+  </action>
   <action name="mActionExportAsSVG" >
     <iconset>../themes/default/mActionSaveAsSVG.png</iconset>
More information about the QGIS-commit mailing list
