[QGIS Commit] r11181 - trunk/qgis/src/plugins/georeferencer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jul 27 09:24:44 EDT 2009
Author: homann
Date: 2009-07-27 09:24:43 -0400 (Mon, 27 Jul 2009)
New Revision: 11181
   trunk/qgis/src/plugins/georeferencer/CMakeLists.txt
   trunk/qgis/src/plugins/georeferencer/qgsgeorefdescriptiondialog.cpp
   trunk/qgis/src/plugins/georeferencer/qgsgeorefdescriptiondialogbase.ui
   trunk/qgis/src/plugins/georeferencer/qgsleastsquares.cpp
   trunk/qgis/src/plugins/georeferencer/qgspointdialog.h
   trunk/qgis/src/plugins/georeferencer/qgspointdialogbase.ui
Text string made easier to translate in georeferencer.
Modified: trunk/qgis/src/plugins/georeferencer/CMakeLists.txt
--- trunk/qgis/src/plugins/georeferencer/CMakeLists.txt	2009-07-26 15:57:31 UTC (rev 11180)
+++ trunk/qgis/src/plugins/georeferencer/CMakeLists.txt	2009-07-27 13:24:43 UTC (rev 11181)
@@ -2,7 +2,7 @@
 # Files
 SET (GEOREF_SRCS
-     plugin.cpp
+     qgsgeorefplugin.cpp
      qgsgeorefdatapoint.cpp
      qgsimagewarper.cpp
      qgsleastsquares.cpp
@@ -20,7 +20,7 @@
 SET (GEOREF_MOC_HDRS
-     plugin.h
+     qgsgeorefplugin.h
      qgspointdialog.h
      mapcoordsdialog.h
      qgsgeorefwarpoptionsdialog.h
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefdescriptiondialog.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefdescriptiondialog.cpp	2009-07-26 15:57:31 UTC (rev 11180)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefdescriptiondialog.cpp	2009-07-27 13:24:43 UTC (rev 11181)
@@ -20,4 +20,13 @@
 QgsGeorefDescriptionDialog::QgsGeorefDescriptionDialog( QWidget* parent ): QDialog( parent )
   setupUi( this );
+  textEdit->setText("<h2>Description</h2>"
+          "<p>This plugin can generate world files "
+          "for rasters. You select points on the "
+          "raster and give their world "
+          "coordinates, and the plugin will "
+          "compute the world file parameters. "
+          "The more coordinates you can "
+          "provide the better the result will be.</p>");
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefdescriptiondialogbase.ui
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefdescriptiondialogbase.ui	2009-07-26 15:57:31 UTC (rev 11180)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefdescriptiondialogbase.ui	2009-07-27 13:24:43 UTC (rev 11181)
@@ -13,7 +13,6 @@
    <string>Description georeferencer</string>
   </property>
   <property name="windowIcon" >
-	  <iconset resource="georeferencer.qrc" >:/georeferencer.png</iconset>
   </property>
   <property name="modal" >
    <bool>true</bool>
@@ -40,13 +39,6 @@
      <property name="readOnly" >
       <bool>true</bool>
      </property>
-     <property name="html" >
-      <string>&lt;html>&lt;head>&lt;meta name="qrichtext" content="1" />&lt;style type="text/css">
-p, li { white-space: pre-wrap; }
-&lt;/style>&lt;/head>&lt;body style=" font-family:'Sans Serif'; font-size:12pt; font-weight:400; font-style:normal; text-decoration:none;">
-&lt;p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;">&lt;span style=" font-size:11pt; font-weight:600;">Description&lt;/span>&lt;/p>
-&lt;p style=" margin-top:12px; margin-bottom:12px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-size:9pt;">This plugin can generate world files for rasters. You select points on the raster and give their world coordinates, and the plugin will compute the world file parameters. The more coordinates you can provide the better the result will be.&lt;/p>&lt;/body>&lt;/html></string>
-     </property>
     </widget>
    </item>
    <item row="0" column="0" >
Modified: trunk/qgis/src/plugins/georeferencer/qgsleastsquares.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsleastsquares.cpp	2009-07-26 15:57:31 UTC (rev 11180)
+++ trunk/qgis/src/plugins/georeferencer/qgsleastsquares.cpp	2009-07-27 13:24:43 UTC (rev 11181)
@@ -30,8 +30,7 @@
   int n = mapCoords.size();
   if ( n < 2 )
-    throw std::domain_error( QObject::tr( "Fit to a linear transform requires at "
-                                          "least 2 points." ).toLocal8Bit().constData() );
+    throw std::domain_error( QObject::tr( "Fit to a linear transform requires at least 2 points." ).toLocal8Bit().constData() );
   double sumPx( 0 ), sumPy( 0 ), sumPx2( 0 ), sumPy2( 0 ), sumPxMx( 0 ), sumPyMy( 0 ),
@@ -72,8 +71,7 @@
   if ( n < 2 )
-    throw std::domain_error( QObject::tr( "Fit to a Helmert transform requires at "
+    throw std::domain_error( QObject::tr( "Fit to a Helmert transform requires at least 2 points." ).toLocal8Bit().constData() );
   double A = 0, B = 0, C = 0, D = 0, E = 0, F = 0, G = 0, H = 0, I = 0, J = 0;
@@ -128,8 +126,7 @@
   if ( n < 4 )
-    throw std::domain_error( QObject::tr( "Fit to an affine transform requires at "
-                                          "least 4 points." ).toLocal8Bit().constData() );
+    throw std::domain_error( QObject::tr( "Fit to an affine transform requires at least 4 points." ).toLocal8Bit().constData() );
Modified: trunk/qgis/src/plugins/georeferencer/qgspointdialog.h
--- trunk/qgis/src/plugins/georeferencer/qgspointdialog.h	2009-07-26 15:57:31 UTC (rev 11180)
+++ trunk/qgis/src/plugins/georeferencer/qgspointdialog.h	2009-07-27 13:24:43 UTC (rev 11181)
@@ -76,6 +76,7 @@
     QString guessWorldFileName( const QString& raster );
     void enableModifiedRasterControls( bool state );
+    void enableControls(bool state);
     QIcon getThemeIcon( const QString theName );
     QActionGroup* mMapToolGroup;
Modified: trunk/qgis/src/plugins/georeferencer/qgspointdialogbase.ui
--- trunk/qgis/src/plugins/georeferencer/qgspointdialogbase.ui	2009-07-26 15:57:31 UTC (rev 11180)
+++ trunk/qgis/src/plugins/georeferencer/qgspointdialogbase.ui	2009-07-27 13:24:43 UTC (rev 11181)
@@ -312,7 +312,7 @@
         </widget>
        </item>
        <item row="3" column="0" >
-        <widget class="QLabel" name="textLabel1" >
+        <widget class="QLabel" name="lblSelectWorldFile" >
          <property name="text" >
           <string>World file:</string>
          </property>
More information about the QGIS-commit mailing list
