[QGIS Commit] r11197 - in trunk/qgis: . ms-windows
ms-windows/osgeo4w python
svn_qgis at osgeo.org
Wed Jul 29 04:59:18 EDT 2009
Author: jef
Date: 2009-07-29 04:59:18 -0400 (Wed, 29 Jul 2009)
New Revision: 11197
Added:
trunk/qgis/ms-windows/osgeo4w/
trunk/qgis/ms-windows/osgeo4w/package.cmd
trunk/qgis/ms-windows/osgeo4w/postinstall.bat
trunk/qgis/ms-windows/osgeo4w/preremove.bat
trunk/qgis/ms-windows/osgeo4w/qgis-dev.bat.tmpl
trunk/qgis/CMakeLists.txt
trunk/qgis/python/CMakeLists.txt
include OSGeo4W build scripts
Modified: trunk/qgis/CMakeLists.txt
--- trunk/qgis/CMakeLists.txt 2009-07-29 08:58:16 UTC (rev 11196)
+++ trunk/qgis/CMakeLists.txt 2009-07-29 08:59:18 UTC (rev 11197)
@@ -201,9 +201,10 @@
ENDIF (MSVC)
ENDIF (PEDANTIC)
-IF (CMAKE_BUILD_TYPE MATCHES Debug OR CMAKE_BUILD_TYPE MATCHES RelWithDebInfo)
+IF (CMAKE_BUILD_TYPE MATCHES Debug OR CMAKE_CONFIGURATION_TYPE MATCHES RelWithDebInfo)
+ MESSAGE ("-- Debug output enabled")
ADD_DEFINITIONS(-DQGISDEBUG=1)
-ENDIF (CMAKE_BUILD_TYPE MATCHES Debug OR CMAKE_BUILD_TYPE MATCHES RelWithDebInfo)
+ENDIF (CMAKE_BUILD_TYPE MATCHES Debug OR CMAKE_CONFIGURATION_TYPE MATCHES RelWithDebInfo)
# platform specific stuff
@@ -215,11 +216,6 @@
SET (DEFAULT_INCLUDE_SUBDIR include)
IF (MSVC)
- # Python parts need to be build with nmake not vcexpress
- # if you dont add this clause, extra blank msvc projects
- # will pop up mid way through the build process and block
- # the build, plus the python bindings wont build correctly
- SET (CMAKE_MAKE_PROGRAM nmake)
SET (DEFAULT_BIN_SUBDIR bin)
# put all the build products into a single directory
# under build (doesnt affect install target) to make for
@@ -234,11 +230,14 @@
ADD_DEFINITIONS(-D_CRT_SECURE_NO_WARNINGS)
ADD_DEFINITIONS(-D_CRT_NONSTDC_NO_WARNINGS)
- IF (CMAKE_BUILD_TYPE MATCHES Debug OR CMAKE_BUILD_TYPE MATCHES RelWithDebInfo)
+ IF (CMAKE_BUILD_TYPE MATCHES Debug OR CMAKE_CONFIGURATION_TYPE MATCHES RelWithDebInfo)
+ MESSAGE ("-- Generating browse files")
ADD_DEFINITIONS( /FR )
- ENDIF (CMAKE_BUILD_TYPE MATCHES Debug OR CMAKE_BUILD_TYPE MATCHES RelWithDebInfo)
+ ENDIF (CMAKE_BUILD_TYPE MATCHES Debug OR CMAKE_CONFIGURATION_TYPE MATCHES RelWithDebInfo)
- INSTALL(DIRECTORY ${CMAKE_BINARY_DIR}/../vcdeps/. DESTINATION .)
+ IF (INSTALL_DEPS)
+ INSTALL(DIRECTORY ${INSTALL_DEPS} DESTINATION .)
+ ENDIF (INSTALL_DEPS)
ELSE(MSVC)
SET (DEFAULT_BIN_SUBDIR .)
ENDIF(MSVC)
Added: trunk/qgis/ms-windows/osgeo4w/package.cmd
--- trunk/qgis/ms-windows/osgeo4w/package.cmd (rev 0)
+++ trunk/qgis/ms-windows/osgeo4w/package.cmd 2009-07-29 08:59:18 UTC (rev 11197)
@@ -0,0 +1,127 @@
+ at echo off
+set GRASS_VERSION=6.4.0svn
+path %SYSTEMROOT%\system32;%SYSTEMROOT%;%SYSTEMROOT%\System32\Wbem;%PROGRAMFILES%\CMake 2.6\bin
+set PYTHONPATH=
+set VS90COMNTOOLS=%PROGRAMFILES%\Microsoft Visual Studio 9.0\Common7\Tools\
+call "%PROGRAMFILES%\Microsoft Visual Studio 9.0\VC\vcvarsall.bat" x86
+set OSGEO4W_ROOT=%PROGRAMFILES%\OSGeo4W
+call "%OSGEO4W_ROOT%\bin\o4w_env.bat"
+set LIB_DIR=%OSGEO4W_ROOT%
+set FLEX=%PROGRAMFILES%\GnuWin32\bin\flex.exe
+set BISON=%PROGRAMFILES%\GnuWin32\bin\bison.exe
+set VERSION=%1
+set PACKAGE=%2
+PROMPT qgis%VERSION%$g
+set BUILDCONF=RelWithDebInfo
+REM set BUILDCONF=Release
+if not exist build mkdir build
+if not exist build goto error
+if not exist build.log goto build
+REM
+REM try renaming the logfile to see if it's locked
+REM
+if exist build.tmp del build.tmp
+if exist build.tmp goto error
+ren build.log build.tmp
+if exist build.log goto locked
+if not exist build.tmp goto locked
+ren build.tmp build.log
+if exist build.tmp goto locked
+if not exist build.log goto locked
+goto build
+:locked
+echo Logfile locked
+goto error
+:build
+set LOG=%CD%\build.log
+cd build
+echo Logging to %LOG%
+echo BEGIN: %DATE% %TIME%>>%LOG% 2>&1
+if errorlevel 1 goto error
+set >buildenv.log
+if exist CMakeCache.txt goto skipcmake
+echo CMAKE: %DATE% %TIME%>>%LOG% 2>&1
+cmake -G "Visual Studio 9 2008" ^
+ -D PEDANTIC=TRUE ^
+ -D WITH_SPATIALITE=TRUE ^
+ -D WITH_INTERNAL_SPATIALITE=TRUE ^
+ -D CMAKE_CONFIGURATION_TYPE=%BUILDCONF% ^
+ -D CMAKE_BUILDCONFIGURATION_TYPES=%BUILDCONF% ^
+ -D FLEX_EXECUTABLE=%FLEX% ^
+ -D BISON_EXECUTABLE=%BISON% ^
+ -D GDAL_INCLUDE_DIR=%OSGEO4W_ROOT%\apps\gdal-16\include -D GDAL_LIBRARY=%OSGEO4W_ROOT%\apps\gdal-16\lib\gdal_i.lib ^
+ -D PYTHON_EXECUTABLE=%OSGEO4W_ROOT%\bin\python.exe ^
+ -D PYTHON_INCLUDE_DIR=%OSGEO4W_ROOT%\apps\Python25\include -D PYTHON_LIBRARY=%OSGEO4W_ROOT%\apps\Python25\libs\python25.lib ^
+ -D SIP_BINARY_PATH=%OSGEO4W_ROOT%\apps\Python25\sip.exe ^
+ -D GRASS_PREFIX=%OSGEO4W_ROOT%\apps\grass\grass-%GRASS_VERSION% ^
+ -D QT_BINARY_DIR=%OSGEO4W_ROOT%\bin -D QT_LIBRARY_DIR=%OSGEO4W_ROOT%\lib ^
+ -D QT_HEADERS_DIR=%OSGEO4W_ROOT%\include\qt4 ^
+ -D QT_ZLIB_LIBRARY=%OSGEO4W_ROOT%\lib\zlib.lib ^
+ -D QT_PNG_LIBRARY=%OSGEO4W_ROOT%\lib\libpng13.lib ^
+ -D CMAKE_INSTALL_PREFIX=%OSGEO4W_ROOT%\apps\qgis-dev ^
+ ../../..>>%LOG% 2>&1
+:skipcmake
+echo ZERO_CHECK: %DATE% %TIME%>>%LOG% 2>&1
+devenv qgis%VERSION%.sln /Project ZERO_CHECK /Build %BUILDCONF%>>%LOG% 2>&1
+echo ALL_BUILD: %DATE% %TIME%>>%LOG% 2>&1
+devenv qgis%VERSION%.sln /Project ALL_BUILD /Build %BUILDCONF%>>%LOG% 2>&1
+echo INSTALL: %DATE% %TIME%>>%LOG% 2>&1
+devenv qgis%VERSION%.sln /Project INSTALL /Build %BUILDCONF%>>%LOG% 2>&1
+echo PACKAGE: %DATE% %TIME%>>%LOG% 2>&1
+cd ..
+copy postinstall.bat %OSGEO4W_ROOT%\etc\postinstall\qgis-dev.bat
+copy preremove.bat %OSGEO4W_ROOT%\etc\preremove\qgis-dev.bat
+copy qgis-dev.bat.tmpl %OSGEO4W_ROOT%\bin\qgis-dev.bat.tmpl
+tar -C %OSGEO4W_ROOT% -cjf qgis-dev-%VERSION%-%PACKAGE%.tar.bz2 ^
+ --exclude "apps/qgis-dev/plugins/EDBSQuery.dll" ^
+ apps/qgis-dev ^
+ bin/qgis-dev.bat.tmpl ^
+ etc/postinstall/qgis-dev.bat ^
+ etc/preremove/qgis-dev.bat>>%LOG% 2>&1
+goto end
+:error
+echo BUILD ERROR %ERRORLEVEL%: %DATE% %TIME%
+echo BUILD ERROR %ERRORLEVEL%: %DATE% %TIME%>>%LOG% 2>&1
+if exist qgis-dev-%VERSION%-%PACKAGE%.tar.bz2 del qgis-dev-%VERSION%-%PACKAGE%.tar.bz2
+:end
+echo FINISHED: %DATE% %TIME% >>%LOG% 2>&1
Property changes on: trunk/qgis/ms-windows/osgeo4w/package.cmd
___________________________________________________________________
Added: svn:executable
Added: trunk/qgis/ms-windows/osgeo4w/postinstall.bat
--- trunk/qgis/ms-windows/osgeo4w/postinstall.bat (rev 0)
+++ trunk/qgis/ms-windows/osgeo4w/postinstall.bat 2009-07-29 08:59:18 UTC (rev 11197)
@@ -0,0 +1,5 @@
+textreplace -std -t bin\qgis-dev.bat
+mkdir "%OSGEO4W_STARTMENU%"
+xxmklink "%OSGEO4W_STARTMENU%\Quantum GIS (trunk).lnk" "%OSGEO4W_ROOT%\bin\qgis-dev.bat" " " \ "Quantum GIS - Desktop GIS (trunk)" 1 "%OSGEO4W_ROOT%\apps\qgis-dev\icons\QGIS.ico"
+xxmklink "%ALLUSERSPROFILE%\Desktop\Quantum GIS (trunk).lnk" "%OSGEO4W_ROOT%\bin\qgis-dev.bat" " " \ "Quantum GIS - Desktop GIS (trunk)" 1 "%OSGEO4W_ROOT%\apps\qgis-dev\icons\QGIS.ico"
Property changes on: trunk/qgis/ms-windows/osgeo4w/postinstall.bat
Added: trunk/qgis/ms-windows/osgeo4w/preremove.bat
--- trunk/qgis/ms-windows/osgeo4w/preremove.bat (rev 0)
+++ trunk/qgis/ms-windows/osgeo4w/preremove.bat 2009-07-29 08:59:18 UTC (rev 11197)
@@ -0,0 +1,3 @@
+del "%OSGEO4W_STARTMENU%\Quantum GIS (trunk).lnk"
+del "%ALLUSERSPROFILE%\Desktop\Quantum GIS (trunk).lnk"
+del "%OSGEO4W_ROOT%\bin\qgis-dev.bat
Property changes on: trunk/qgis/ms-windows/osgeo4w/preremove.bat
Added: trunk/qgis/ms-windows/osgeo4w/qgis-dev.bat.tmpl
--- trunk/qgis/ms-windows/osgeo4w/qgis-dev.bat.tmpl (rev 0)
+++ trunk/qgis/ms-windows/osgeo4w/qgis-dev.bat.tmpl 2009-07-29 08:59:18 UTC (rev 11197)
@@ -0,0 +1,8 @@
+ at echo off
+SET OSGEO4W_ROOT=@osgeo4w@
+call "%OSGEO4W_ROOT%"\bin\o4w_env.bat
+call "%OSGEO4W_ROOT%"\bin\gdal16.bat
+ at echo off
+path %PATH%;%GISBASE%\bin
+start "Quantum GIS" /B "%OSGEO4W_ROOT%"\apps\qgis-dev\bin\qgis.exe %*
Property changes on: trunk/qgis/ms-windows/osgeo4w/qgis-dev.bat.tmpl
Modified: trunk/qgis/python/CMakeLists.txt
--- trunk/qgis/python/CMakeLists.txt 2009-07-29 08:58:16 UTC (rev 11196)
+++ trunk/qgis/python/CMakeLists.txt 2009-07-29 08:59:18 UTC (rev 11197)
@@ -50,6 +50,7 @@
IF (MSVC)
SET(EXPORT "__declspec(dllimport)")
+ SET(CMAKE_MAKE_PROGRAM $ENV{VCINSTALLDIR}/bin/nmake.exe)
ELSE (MSVC)
SET(EXPORT "")
ENDIF (MSVC)
