[QGIS Commit] r11204 - in trunk/qgis/src/plugins/grass: modules-6.3
modules-6.4
svn_qgis at osgeo.org
Wed Jul 29 11:36:00 EDT 2009
Author: rugginoso
Date: 2009-07-29 11:35:59 -0400 (Wed, 29 Jul 2009)
New Revision: 11204
trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
Moved db.in.ogr grass module into under "Import" section.
Modified: trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.3/default.qgc 2009-07-29 14:05:16 UTC (rev 11203)
+++ trunk/qgis/src/plugins/grass/modules-6.3/default.qgc 2009-07-29 15:35:59 UTC (rev 11204)
@@ -38,6 +38,9 @@
<grass name="v.in.garmin"/>
<grass name="v.in.gpsbabel"/>
</section>
+ <section label="Database">
+ <grass name="db.in.ogr"/>
+ </section>
</section>
<section label="Export">
<section label="Export raster">
@@ -429,7 +432,6 @@
<grass name="db.connect.schema"/>
<grass name="v.db.reconnect.all"/>
<grass name="db.login"/>
- <grass name="db.in.ogr"/>
</section>
<section label="Tables management">
<grass name="db.copy"/>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc 2009-07-29 14:05:16 UTC (rev 11203)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc 2009-07-29 15:35:59 UTC (rev 11204)
@@ -43,6 +43,9 @@
<grass name="v.in.geonames"/>
<grass name="v.in.gns"/>
</section>
+ </section>
</section>
@@ -441,7 +444,6 @@
<grass name="db.connect-login.pg"/>
</section>
