[QGIS Commit] r11224 - docs/branches/1.0.0/italian/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jul 31 06:58:17 EDT 2009
Author: santini
Date: 2009-07-31 06:58:17 -0400 (Fri, 31 Jul 2009)
New Revision: 11224
   docs/branches/1.0.0/italian/user_guide/core_plugins.tex
IT for core_revised
Modified: docs/branches/1.0.0/italian/user_guide/core_plugins.tex
--- docs/branches/1.0.0/italian/user_guide/core_plugins.tex	2009-07-31 10:42:51 UTC (rev 11223)
+++ docs/branches/1.0.0/italian/user_guide/core_plugins.tex	2009-07-31 10:58:17 UTC (rev 11224)
@@ -25,66 +25,57 @@
 \hline \textbf{Icon} & \textbf{Plugin} & \textbf{Description}\\
 \hline
 \includegraphics[width=0.6cm]{delimited_text}
- & Aggiungi layer testo delimitato \index{plugins!delimited text} & Carica e mostra files di testo delimitato contenenti coordinate x,y\\
+ & Aggiungi layer testo delimitato \index{plugins!Testo delimitato} & Carica e mostra files di testo delimitato contenenti coordinate x,y\\
 \hline
 \includegraphics[width=0.6cm]{coordinate_capture}
- & Cattura Coordinate \index{plugins!coordinate capture}& Cattura le coordinate del mouse
+ & Cattura Coordinate \index{plugins!Cattura coordinate}& Cattura le coordinate del mouse
 usando SRS diverso\\
 \hline
 \includegraphics[width=0.6cm]{copyright_label}
- & Copyright Label \index{plugins!copyright}& Draws a copyright label with
-information\\
+ & Etichetta di copyright \index{plugins!Etichetta di copyright}& Disegna una Etichetta di copyrightcon informazioni\\
 \hline
 \includegraphics[width=0.6cm]{dxf2shp_converter}
- & DXF2Shape Converter \index{plugins!DXF2Shape}& Converts from DXF to SHP file
-format\\
+ & DXF2Shape Convertitore \index{plugins!Convertitore DXF2Shape}& Converte da formato DXF a SHP\\
 \hline
 \includegraphics[width=0.6cm]{gps_importer}
- & GPS Tools \index{plugins!gps}& Tools for loading and importing GPS data\\
+ & Strumenti GPS \index{plugins!gps}& Strumenti per caricare e importare dati GPS\\
 \hline
 \includegraphics[width=0.6cm]{grass}
- & GRASS \index{plugin!grass toolbox} & Activates the mighty GRASS Toolbox\\
+ & GRASS \index{plugin!strumenti grass} & Attiva il potente strumentario GRASS\\
 \hline
 \includegraphics[width=0.6cm]{georeferencer}
- & Georeferencer \index{plugin!georeferencer} & Adding projection info to
-Rasterfiles\\
+ & Georeferenziatore \index{plugin!georeferenziatore} & Aggiunge proiezioni ai file raster\\
 \hline
 \includegraphics[width=0.6cm]{grid_maker}
- & Graticule Creator \index{plugins!graticule}& Create a latitude/longitude grid
-and save as a shapefile\\
+ & Creatore di Griglia \index{plugins!Creatore di Griglia}& Crea una griglia latitudine/longitudine e la salva come  shape\\
 \hline
 \includegraphics[width=0.6cm]{interpolation}
-& Interpolation plugin \index{plugins!Interpolation}& Interpolation on base of
-vertices of a vector layer\\
+& Plugin di Interpolazione  \index{plugins!Interpolazione}& Interpolazione basata sui vertici di un layer vettoriale\\
 \hline
 \includegraphics[width=0.6cm]{mapserver_export}
-& MapServer Export Plugin \index{plugins!MapServer Export}& Export a saved QGIS
-project file to a MapServer map file \\
+& Plugin MapServer Export \index{plugins!MapServer Export}& Esporta un progetto salvato QGIS
+in un file mappa MapServer \\
 \hline
 \includegraphics[width=0.6cm]{north_arrow}
-& North Arrow \index{plugins!north arrow}& Displays a north arrow overlayed onto
-the map\\
+& Freccia Nord \index{plugins!Freccia Nord}& Mostra una freccia che indica il nord sovrapposta alla mappa\\
 \hline
 \includegraphics[width=0.6cm]{ogr_converter}
- & OGR Layer Converter \index{plugins!OGR converter} & Translate vector
-layers between OGR suported formats\\
+ & Convertitore di layer OGR \index{plugins!Convertitore OGR} & Traduce i layer vettoriali tra formati supportati OGR\\
 \hline
 \includegraphics[width=0.6cm]{plugin_installer}
- & Plugin Installer \index{plugins!Plugin Installer} & Downloads and installs
-QGIS python plugins\\
+ & Istallatore di Plugin  \index{plugins!Istallatore di Plugin} & Scarica e istallai plugin QGIS python\\
 \hline
 \includegraphics[width=0.6cm]{spiticon}
- & SPIT \index{plugins!spit}& Shapefile to PostgreSQL/PostGIS Import Tool \\
+ & SPIT \index{plugins!spit}& Strumento di importazione di file shape in PostgreSQL/PostGIS \\
 \hline
 \includegraphics[width=0.6cm]{quick_print}
- & Qucik Print \index{plugins!quick print}& Quickly print a map with minimal
-effort \\
+ & Stampa veloce \index{plugins!Stampa veloce}& Stampa rapidamente una mappa con sforzo minimo \\
 \hline
 \includegraphics[width=0.6cm]{scale_bar}
- & Scalebar \index{plugins!scalebar}& Draws a scale bar\\
+ & Barra di Scala \index{plugins!barra di scala}& Disegna una barra di scala\\
 \hline
 \includegraphics[width=0.6cm]{mIconAddWfsLayer}
- & WFS & Load and display WFS layer \\
+ & WFS & Carica e mostra un layer WFS\\
 \hline
 \end{tabular}
 \end{table}
@@ -92,9 +83,6 @@
 \normalsize
-\begin{Tip}\caption{\textsc{Plugins Settings Saved to Project}}\index{plugins
-settings}
-\qgistip{When you save a .qgs project, any changes you have made to NorthArrow,
-ScaleBar and Copyright plugins will be saved in the project and restored next
-time you load the project.}
+\begin{Tip}\caption{\textsc{Impostazioni dei plugin salvate nel progetto}}\index{Impostazione dei plugins}
+\qgistip{Quando si salva un progetto .qgs, qualsiasi cambiamento fatto ai plugin  Freccia Nord, Barra di Scala e Etichetta di Copyright saranno salvate nel progetto e ripristinate la prossima volta che si apre il progetto.}
 \end{Tip}
More information about the QGIS-commit mailing list
