[QGIS Commit] r10872 - in trunk/qgis/src: core/composer gui plugins/diagram_overlay
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jun 1 17:18:16 EDT 2009
Author: jef
Date: 2009-06-01 17:18:16 -0400 (Mon, 01 Jun 2009)
New Revision: 10872
   trunk/qgis/src/core/composer/qgscomposeritem.cpp
   trunk/qgis/src/gui/qgscomposerview.cpp
   trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
indentation update
Modified: trunk/qgis/src/core/composer/qgscomposeritem.cpp
--- trunk/qgis/src/core/composer/qgscomposeritem.cpp	2009-06-01 14:17:54 UTC (rev 10871)
+++ trunk/qgis/src/core/composer/qgscomposeritem.cpp	2009-06-01 21:18:16 UTC (rev 10872)
@@ -34,7 +34,7 @@
 #define FONT_WORKAROUND_SCALE 10 //scale factor for upscaling fontsize and downscaling painter
 QgsComposerItem::QgsComposerItem( QgsComposition* composition, bool manageZValue ): QGraphicsRectItem( 0 ), mComposition( composition ), mBoundingResizeRectangle( 0 ), \
-        mFrame( true ), mItemPositionLocked(false)
+    mFrame( true ), mItemPositionLocked( false )
   setFlag( QGraphicsItem::ItemIsSelectable, true );
   setAcceptsHoverEvents( true );
@@ -125,13 +125,13 @@
   composerItemElem.setAttribute( "outlineWidth", QString::number( pen().widthF() ) );
   //position lock for mouse moves/resizes
-  if(mItemPositionLocked)
+  if ( mItemPositionLocked )
-    composerItemElem.setAttribute( "positionLock", "true");
+    composerItemElem.setAttribute( "positionLock", "true" );
   else
-    composerItemElem.setAttribute( "positionLock", "false");
+    composerItemElem.setAttribute( "positionLock", "false" );
@@ -177,14 +177,14 @@
-  QString positionLock = itemElem.attribute("positionLock");
-  if(positionLock.compare("true", Qt::CaseInsensitive) == 0)
+  QString positionLock = itemElem.attribute( "positionLock" );
+  if ( positionLock.compare( "true", Qt::CaseInsensitive ) == 0 )
-      mItemPositionLocked = true;
+    mItemPositionLocked = true;
   else
-      mItemPositionLocked = false;
+    mItemPositionLocked = false;
   //position
@@ -246,10 +246,10 @@
 void QgsComposerItem::mouseMoveEvent( QGraphicsSceneMouseEvent * event )
-        return;
+    return;
   if ( mBoundingResizeRectangle )
@@ -263,10 +263,10 @@
 void QgsComposerItem::mousePressEvent( QGraphicsSceneMouseEvent * event )
-        return;
+    return;
   //set current position and type of mouse move action
   mMouseMoveStartPos = event->lastScenePos();
@@ -297,10 +297,10 @@
 void QgsComposerItem::mouseReleaseEvent( QGraphicsSceneMouseEvent * event )
-        return;
+    return;
   //delete frame rectangle
@@ -331,9 +331,9 @@
   QgsComposerItem::MouseMoveAction mouseAction = mouseMoveActionForPosition( itemCoordPos );
-  if( mouseAction == QgsComposerItem::NoAction)
+  if ( mouseAction == QgsComposerItem::NoAction )
-      return Qt::ForbiddenCursor;
+    return Qt::ForbiddenCursor;
   if ( mouseAction == QgsComposerItem::MoveItem )
@@ -361,9 +361,9 @@
   //no action at all if item position is locked for mouse
-      return QgsComposerItem::NoAction;
+    return QgsComposerItem::NoAction;
   bool nearLeftBorder = false;
@@ -434,7 +434,7 @@
   //test if change item is a composer item. If so, prefer call to  setSceneRect() instead of setTransform() and setRect()
-  QgsComposerItem* changeComposerItem = dynamic_cast<QgsComposerItem*>(changeItem);
+  QgsComposerItem* changeComposerItem = dynamic_cast<QgsComposerItem*>( changeItem );
   double mx = 0.0, my = 0.0, rx = 0.0, ry = 0.0;
   QPointF snappedPosition = mComposition->snapPointToGrid( currentPosition );
@@ -504,7 +504,7 @@
       double moveRectX = snappedLeftPoint.x() - originalItem->transform().dx();
       double moveRectY = snappedLeftPoint.y() - originalItem->transform().dy();
-      if(!changeComposerItem)
+      if ( !changeComposerItem )
         QTransform moveTransform;
         moveTransform.translate( originalItem->transform().dx() + moveRectX, originalItem->transform().dy() + moveRectY );
@@ -512,14 +512,14 @@
       else  //for composer items, we prefer setSceneRect as subclasses can implement custom behaviour (e.g. item group)
-        changeComposerItem->setSceneRect(QRectF(originalItem->transform().dx() + moveRectX, \
-                                                originalItem->transform().dy() + moveRectY, \
-                                                originalItem->rect().width(), originalItem->rect().height()));
+        changeComposerItem->setSceneRect( QRectF( originalItem->transform().dx() + moveRectX, \
+                                          originalItem->transform().dy() + moveRectY, \
+                                          originalItem->rect().width(), originalItem->rect().height() ) );
       return;
     QTransform itemTransform;
     itemTransform.translate( originalItem->transform().dx() + mx, originalItem->transform().dy() + my );
@@ -529,8 +529,8 @@
-    changeComposerItem->setSceneRect( QRectF(originalItem->transform().dx() + mx, originalItem->transform().dy() + my, \
-      originalItem->rect().width() + rx, originalItem->rect().height() + ry) );
+    changeComposerItem->setSceneRect( QRectF( originalItem->transform().dx() + mx, originalItem->transform().dy() + my, \
+                                      originalItem->rect().width() + rx, originalItem->rect().height() + ry ) );
@@ -548,29 +548,29 @@
     double rectHandlerSize = rectHandlerBorderTolerance();
     double sizeLockSymbol = lockSymbolSize();
-        //draw lock symbol at upper left edge. Use QImage to be independant of the graphic system
-        QString lockIconPath = QgsApplication::activeThemePath() + "/mIconLock.png";
-        if(!QFile::exists(lockIconPath))
-            lockIconPath = QgsApplication::defaultThemePath() + "/mIconLock.png";
+      //draw lock symbol at upper left edge. Use QImage to be independant of the graphic system
+      QString lockIconPath = QgsApplication::activeThemePath() + "/mIconLock.png";
+      if ( !QFile::exists( lockIconPath ) )
+        lockIconPath = QgsApplication::defaultThemePath() + "/mIconLock.png";
-        QImage lockImage(lockIconPath);
-        if(!lockImage.isNull())
-            p->drawImage(QRectF(0, 0, sizeLockSymbol, sizeLockSymbol), lockImage, QRectF(0, 0, lockImage.width(), lockImage.height()));
+      QImage lockImage( lockIconPath );
+      if ( !lockImage.isNull() )
+        p->drawImage( QRectF( 0, 0, sizeLockSymbol, sizeLockSymbol ), lockImage, QRectF( 0, 0, lockImage.width(), lockImage.height() ) );
     else //draw blue squares
-        p->setPen( QPen( QColor( 0, 0, 255 ) ) );
-        p->setBrush( QBrush( QColor( 0, 0, 255 ) ) );
-        p->drawRect( QRectF( 0, 0, rectHandlerSize, rectHandlerSize ) );
-        p->drawRect( QRectF( rect().width() - rectHandlerSize, 0, rectHandlerSize, rectHandlerSize ) );
-        p->drawRect( QRectF( rect().width() - rectHandlerSize, rect().height() - rectHandlerSize, rectHandlerSize, rectHandlerSize ) );
-        p->drawRect( QRectF( 0, rect().height() - rectHandlerSize, rectHandlerSize, rectHandlerSize ) );
+      p->setPen( QPen( QColor( 0, 0, 255 ) ) );
+      p->setBrush( QBrush( QColor( 0, 0, 255 ) ) );
+      p->drawRect( QRectF( 0, 0, rectHandlerSize, rectHandlerSize ) );
+      p->drawRect( QRectF( rect().width() - rectHandlerSize, 0, rectHandlerSize, rectHandlerSize ) );
+      p->drawRect( QRectF( rect().width() - rectHandlerSize, rect().height() - rectHandlerSize, rectHandlerSize, rectHandlerSize ) );
+      p->drawRect( QRectF( 0, rect().height() - rectHandlerSize, rectHandlerSize, rectHandlerSize ) );
@@ -749,38 +749,38 @@
 double QgsComposerItem::rectHandlerBorderTolerance() const
-     //size of symbol boxes depends on zoom level in composer view
-    double viewScaleFactor = horizontalViewScaleFactor();
-    double rectHandlerSize = 10.0 / viewScaleFactor;
+  //size of symbol boxes depends on zoom level in composer view
+  double viewScaleFactor = horizontalViewScaleFactor();
+  double rectHandlerSize = 10.0 / viewScaleFactor;
-    //make sure the boxes don't get too large
-    if(rectHandlerSize > (rect().width() / 3))
-        rectHandlerSize = rect().width() / 3;
-    if(rectHandlerSize > (rect().height() / 3))
-        rectHandlerSize = rect().height() / 3;
-    return rectHandlerSize;
+  //make sure the boxes don't get too large
+  if ( rectHandlerSize > ( rect().width() / 3 ) )
+    rectHandlerSize = rect().width() / 3;
+  if ( rectHandlerSize > ( rect().height() / 3 ) )
+    rectHandlerSize = rect().height() / 3;
+  return rectHandlerSize;
 double QgsComposerItem::lockSymbolSize() const
   double lockSymbolSize = 20.0 / horizontalViewScaleFactor();
-  if(lockSymbolSize > (rect().width() / 3))
+  if ( lockSymbolSize > ( rect().width() / 3 ) )
     lockSymbolSize = rect().width() / 3;
-  if(lockSymbolSize > (rect().height() / 3))
+  if ( lockSymbolSize > ( rect().height() / 3 ) )
     lockSymbolSize = rect().height() / 3;
   return lockSymbolSize;
-void QgsComposerItem::updateCursor(const QPointF& itemPos)
+void QgsComposerItem::updateCursor( const QPointF& itemPos )
-    setCursor( cursorForPosition(itemPos) );
+  setCursor( cursorForPosition( itemPos ) );
Modified: trunk/qgis/src/gui/qgscomposerview.cpp
--- trunk/qgis/src/gui/qgscomposerview.cpp	2009-06-01 14:17:54 UTC (rev 10871)
+++ trunk/qgis/src/gui/qgscomposerview.cpp	2009-06-01 21:18:16 UTC (rev 10872)
@@ -46,19 +46,19 @@
   QPointF snappedScenePoint = composition()->snapPointToGrid( scenePoint );
   //lock/unlock position of item with right click
-  if(e->button() == Qt::RightButton)
+  if ( e->button() == Qt::RightButton )
-     QgsComposerItem* selectedItem = composition()->composerItemAt( scenePoint );
-     if(selectedItem)
-         bool lock = selectedItem->positionLock() ? false : true;
-         selectedItem->setPositionLock(lock);
-         selectedItem->update();
-         //make sure the new cursor is correct
-         QPointF itemPoint = selectedItem->mapFromScene( scenePoint );
-         selectedItem->updateCursor(itemPoint);
-     return;
+    QgsComposerItem* selectedItem = composition()->composerItemAt( scenePoint );
+    if ( selectedItem )
+      bool lock = selectedItem->positionLock() ? false : true;
+      selectedItem->setPositionLock( lock );
+      selectedItem->update();
+      //make sure the new cursor is correct
+      QPointF itemPoint = selectedItem->mapFromScene( scenePoint );
+      selectedItem->updateCursor( itemPoint );
+    return;
   switch ( mCurrentTool )
@@ -101,7 +101,7 @@
       QTransform t;
       mRubberBandItem = new QGraphicsRectItem( 0, 0, 0, 0 );
-      mRubberBandStartPos = QPointF(snappedScenePoint.x(), snappedScenePoint.y());
+      mRubberBandStartPos = QPointF( snappedScenePoint.x(), snappedScenePoint.y() );
       t.translate( snappedScenePoint.x(), snappedScenePoint.y() );
       mRubberBandItem->setTransform( t );
       mRubberBandItem->setZValue( 100 );
@@ -236,44 +236,44 @@
       case AddMap:
         //adjust rubber band item
-          double x = 0;
-          double y = 0;
-          double width = 0;
-          double height = 0;
+        double x = 0;
+        double y = 0;
+        double width = 0;
+        double height = 0;
-          double dx = scenePoint.x() - mRubberBandStartPos.x();
-          double dy = scenePoint.y() - mRubberBandStartPos.y();
+        double dx = scenePoint.x() - mRubberBandStartPos.x();
+        double dy = scenePoint.y() - mRubberBandStartPos.y();
-          if(dx < 0)
-            x = scenePoint.x();
-            width = -dx;
-          else
-            x = mRubberBandStartPos.x();
-            width = dx;
+        if ( dx < 0 )
+          x = scenePoint.x();
+          width = -dx;
+        else
+          x = mRubberBandStartPos.x();
+          width = dx;
-          if(dy < 0)
-            y = scenePoint.y();
-            height = -dy;
-          else
-            y = mRubberBandStartPos.y();
-            height = dy;
-          mRubberBandItem->setRect( 0, 0, width, height );
-          QTransform t;
-          t.translate(x, y);
-          mRubberBandItem->setTransform(t);
-          break;
+        if ( dy < 0 )
+          y = scenePoint.y();
+          height = -dy;
+        else
+          y = mRubberBandStartPos.y();
+          height = dy;
+        mRubberBandItem->setRect( 0, 0, width, height );
+        QTransform t;
+        t.translate( x, y );
+        mRubberBandItem->setTransform( t );
+        break;
       case MoveItemContent:
         //update map preview if composer map
Modified: trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
--- trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp	2009-06-01 14:17:54 UTC (rev 10871)
+++ trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp	2009-06-01 21:18:16 UTC (rev 10872)
@@ -104,9 +104,9 @@
         currentGeometry = currentFeature.geometryAndOwnership();
         //overlay objects needs the geometry in map coordinates
-        if(currentGeometry && renderContext.coordinateTransform())
+        if ( currentGeometry && renderContext.coordinateTransform() )
-          currentGeometry->transform(*(renderContext.coordinateTransform()));
+          currentGeometry->transform( *( renderContext.coordinateTransform() ) );
         mOverlayObjects.insert( currentFeature.id(), new QgsOverlayObject( width, height, 0, currentGeometry ) );
@@ -152,21 +152,21 @@
             const QgsCoordinateTransform* ct = context.coordinateTransform();
             QList<QgsPoint>::const_iterator positionIt = positionList.constBegin();
-            for(; positionIt != positionList.constEnd(); ++positionIt)
+            for ( ; positionIt != positionList.constEnd(); ++positionIt )
-                QgsPoint overlayPosition = *positionIt;
-                context.mapToPixel().transform( &overlayPosition );
-                int shiftX = currentDiagramImage->width() / 2;
-                int shiftY = currentDiagramImage->height() / 2;
+              QgsPoint overlayPosition = *positionIt;
+              context.mapToPixel().transform( &overlayPosition );
+              int shiftX = currentDiagramImage->width() / 2;
+              int shiftY = currentDiagramImage->height() / 2;
-                if ( painter )
-                    painter->save();
-                    painter->scale( 1.0 / context.rasterScaleFactor(), 1.0 / context.rasterScaleFactor() );
-                    //painter->drawRect(( int )( overlayPosition.x() * context.rasterScaleFactor() ) - shiftX, ( int )( overlayPosition.y() * context.rasterScaleFactor() ) - shiftY, it.value()->width(), it.value()->height());
-                    painter->drawImage(( int )( overlayPosition.x() * context.rasterScaleFactor() ) - shiftX, ( int )( overlayPosition.y() * context.rasterScaleFactor() ) - shiftY, *currentDiagramImage );
-                    painter->restore();
+              if ( painter )
+                painter->save();
+                painter->scale( 1.0 / context.rasterScaleFactor(), 1.0 / context.rasterScaleFactor() );
+                //painter->drawRect(( int )( overlayPosition.x() * context.rasterScaleFactor() ) - shiftX, ( int )( overlayPosition.y() * context.rasterScaleFactor() ) - shiftY, it.value()->width(), it.value()->height());
+                painter->drawImage(( int )( overlayPosition.x() * context.rasterScaleFactor() ) - shiftX, ( int )( overlayPosition.y() * context.rasterScaleFactor() ) - shiftY, *currentDiagramImage );
+                painter->restore();
More information about the QGIS-commit mailing list
