[QGIS Commit] r10874 - in trunk/qgis/src: app core ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jun 1 17:21:51 EDT 2009
Author: jef
Date: 2009-06-01 17:21:51 -0400 (Mon, 01 Jun 2009)
New Revision: 10874
   trunk/qgis/src/app/qgsprojectproperties.cpp
   trunk/qgis/src/core/qgsmaplayer.cpp
   trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
make saving of relative pathes of file data sources optional
Modified: trunk/qgis/src/app/qgsprojectproperties.cpp
--- trunk/qgis/src/app/qgsprojectproperties.cpp	2009-06-01 21:20:14 UTC (rev 10873)
+++ trunk/qgis/src/app/qgsprojectproperties.cpp	2009-06-01 21:21:51 UTC (rev 10874)
@@ -80,6 +80,8 @@
     radManual->setChecked( true );
+  cbxAbsolutePath->setChecked( QgsProject::instance()->readBoolEntry( "Paths", "/Absolute", true ) );
   int dp = QgsProject::instance()->readNumEntry( "PositionPrecision", "/DecimalPlaces" );
   spinBoxDP->setValue( dp );
@@ -274,14 +276,13 @@
   // number of decimal places for the manual option
   // Note. Qt 3.2.3 and greater have a function selectedId() that
   // can be used instead of the two part technique here
-  if ( radAutomatic->isChecked() )
-    QgsProject::instance()->writeEntry( "PositionPrecision", "/Automatic", true );
-  else
-    QgsProject::instance()->writeEntry( "PositionPrecision", "/Automatic", false );
+  QgsProject::instance()->writeEntry( "PositionPrecision", "/Automatic", radAutomatic->isChecked() );
   QgsProject::instance()->writeEntry( "PositionPrecision", "/DecimalPlaces", spinBoxDP->value() );
   // Announce that we may have a new display precision setting
   emit displayPrecisionChanged();
+  QgsProject::instance()->writeEntry( "Paths", "/Absolute", cbxAbsolutePath->isChecked() );
   //set the colour for selections
   QColor myColour = pbnSelectionColour->color();
   QgsProject::instance()->writeEntry( "Gui", "/SelectionColorRedPart", myColour.red() );
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp	2009-06-01 21:20:14 UTC (rev 10873)
+++ trunk/qgis/src/core/qgsmaplayer.cpp	2009-06-01 21:21:51 UTC (rev 10874)
@@ -282,7 +282,8 @@
   QString src = source();
   QFileInfo srcInfo( src );
-  if ( srcInfo.exists() )
+  bool absolutePath = QgsProject::instance()->readBoolEntry( "Paths", "/Absolute", true );
+  if ( !absolutePath && srcInfo.exists() )
     QFileInfo pfi( QgsProject::instance()->fileName() );
     QgsDebugMsg( "project path: " + pfi.canonicalPath() );
Modified: trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
--- trunk/qgis/src/ui/qgsprojectpropertiesbase.ui	2009-06-01 21:20:14 UTC (rev 10873)
+++ trunk/qgis/src/ui/qgsprojectpropertiesbase.ui	2009-06-01 21:21:51 UTC (rev 10874)
@@ -1,7 +1,8 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>QgsProjectPropertiesBase</class>
- <widget class="QDialog" name="QgsProjectPropertiesBase" >
-  <property name="geometry" >
+ <widget class="QDialog" name="QgsProjectPropertiesBase">
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
@@ -9,71 +10,73 @@
     <height>713</height>
    </rect>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>Project Properties</string>
   </property>
-  <property name="windowIcon" >
-   <iconset/>
+  <property name="windowIcon">
+   <iconset>
+    <normaloff/>
+   </iconset>
   </property>
-  <property name="sizeGripEnabled" >
+  <property name="sizeGripEnabled">
    <bool>true</bool>
   </property>
-  <property name="modal" >
+  <property name="modal">
    <bool>true</bool>
   </property>
-  <layout class="QGridLayout" >
-   <item row="0" column="0" >
-    <widget class="QTabWidget" name="tabWidget" >
-     <property name="currentIndex" >
+  <layout class="QGridLayout">
+   <item row="0" column="0">
+    <widget class="QTabWidget" name="tabWidget">
+     <property name="currentIndex">
       <number>0</number>
      </property>
-     <widget class="QWidget" name="tab1" >
-      <attribute name="title" >
+     <widget class="QWidget" name="tab1">
+      <attribute name="title">
        <string>General</string>
       </attribute>
-        <widget class="QGroupBox" name="titleBox" >
-         <property name="title" >
+        <widget class="QGroupBox" name="titleBox">
+         <property name="title">
           <string>Title and colors</string>
          </property>
-           <widget class="QLabel" name="label_2" >
-            <property name="text" >
+           <widget class="QLabel" name="label_2">
+            <property name="text">
              <string>Project title</string>
             </property>
            </widget>
           </item>
-          <item row="0" column="1" colspan="3" >
-           <widget class="QLineEdit" name="titleEdit" >
-            <property name="toolTip" >
+          <item row="0" column="1" colspan="3">
+           <widget class="QLineEdit" name="titleEdit">
+            <property name="toolTip">
              <string>Descriptive project name</string>
             </property>
              <string>Default project title</string>
             </property>
            </widget>
           </item>
-          <item row="1" column="0" >
-           <widget class="QLabel" name="textLabel1" >
+          <item row="1" column="0">
+           <widget class="QLabel" name="textLabel1">
              <string>Selection color</string>
             </property>
-            <property name="buddy" >
+            <property name="buddy">
              <cstring>pbnSelectionColour</cstring>
             </property>
            </widget>
           </item>
-          <item row="1" column="2" >
+          <item row="1" column="2">
            <spacer>
-            <property name="orientation" >
+            <property name="orientation">
              <enum>Qt::Horizontal</enum>
             </property>
-            <property name="sizeType" >
+            <property name="sizeType">
              <enum>QSizePolicy::Expanding</enum>
             </property>
-            <property name="sizeHint" >
+            <property name="sizeHint" stdset="0">
              <size>
               <width>40</width>
               <height>20</height>
@@ -81,35 +84,35 @@
             </property>
            </spacer>
           </item>
-          <item row="1" column="3" >
-           <widget class="QgsColorButton" name="pbnSelectionColour" >
-            <property name="minimumSize" >
+          <item row="1" column="3">
+           <widget class="QgsColorButton" name="pbnSelectionColour">
+            <property name="minimumSize">
              <size>
               <width>100</width>
               <height>0</height>
              </size>
             </property>
              <string/>
             </property>
            </widget>
           </item>
-          <item row="2" column="0" colspan="2" >
-           <widget class="QLabel" name="label" >
+          <item row="2" column="0" colspan="2">
+           <widget class="QLabel" name="label">
              <string>Background color</string>
             </property>
              <cstring>pbnCanvasColor</cstring>
             </property>
            </widget>
           </item>
-          <item row="2" column="2" >
+          <item row="2" column="2">
            <spacer>
             </property>
              <size>
               <width>40</width>
               <height>20</height>
@@ -117,15 +120,15 @@
             </property>
            </spacer>
           </item>
-          <item row="2" column="3" >
-           <widget class="QgsColorButton" name="pbnCanvasColor" >
+          <item row="2" column="3">
+           <widget class="QgsColorButton" name="pbnCanvasColor">
              <size>
               <width>100</width>
               <height>0</height>
              </size>
             </property>
              <string/>
             </property>
            </widget>
@@ -133,44 +136,35 @@
          </layout>
         </widget>
        </item>
-        <widget class="QGroupBox" name="btnGrpMapUnits" >
+        <widget class="QGroupBox" name="btnGrpMapUnits">
           <string>Map units</string>
          </property>
-         <layout class="QHBoxLayout" >
-          <property name="leftMargin" >
+         <layout class="QHBoxLayout">
+          <property name="margin">
            <number>11</number>
           </property>
-          <property name="topMargin" >
-           <number>11</number>
-          </property>
-          <property name="rightMargin" >
-          </property>
-          <property name="bottomMargin" >
-          </property>
           <item>
-           <widget class="QRadioButton" name="radMeters" >
+           <widget class="QRadioButton" name="radMeters">
              <string>Meters</string>
             </property>
-            <property name="checked" >
+            <property name="checked">
              <bool>true</bool>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QRadioButton" name="radFeet" >
+           <widget class="QRadioButton" name="radFeet">
              <string>Feet</string>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QRadioButton" name="radDecimalDegrees" >
+           <widget class="QRadioButton" name="radDecimalDegrees">
              <string>Decimal degrees</string>
             </property>
            </widget>
@@ -178,60 +172,60 @@
          </layout>
         </widget>
        </item>
-       <item row="2" column="0" >
-        <widget class="QGroupBox" name="btnGrpPrecision" >
+       <item row="2" column="0">
+        <widget class="QGroupBox" name="btnGrpPrecision">
           <string>Precision</string>
          </property>
-           <widget class="QRadioButton" name="radAutomatic" >
+           <widget class="QRadioButton" name="radAutomatic">
              <string>Automatically sets the number of decimal places in the mouse position display</string>
             </property>
-            <property name="whatsThis" >
+            <property name="whatsThis">
              <string>The number of decimal places that are used when displaying the mouse position is automatically set to be enough so that moving the mouse by one pixel gives a change in the position display</string>
             </property>
              <string>Automatic</string>
             </property>
              <bool>true</bool>
             </property>
            </widget>
           </item>
-          <item row="0" column="1" >
-           <widget class="QRadioButton" name="radManual" >
+          <item row="0" column="1">
+           <widget class="QRadioButton" name="radManual">
              <string>Sets the number of decimal places to use for the mouse position display</string>
             </property>
             </property>
              <string>Manual</string>
             </property>
            </widget>
           </item>
-          <item row="0" column="2" >
-           <widget class="QSpinBox" name="spinBoxDP" >
+          <item row="0" column="2">
+           <widget class="QSpinBox" name="spinBoxDP">
              <string>The number of decimal places for the manual option</string>
             </property>
             </property>
            </widget>
           </item>
-          <item row="0" column="3" >
-           <widget class="QLabel" name="textLabel3" >
-            <property name="sizePolicy" >
-             <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
+          <item row="0" column="3">
+           <widget class="QLabel" name="textLabel3">
+            <property name="sizePolicy">
+             <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
               <horstretch>0</horstretch>
               <verstretch>0</verstretch>
              </sizepolicy>
             </property>
              <string>decimal places</string>
             </property>
            </widget>
@@ -239,35 +233,35 @@
          </layout>
         </widget>
        </item>
-       <item row="3" column="0" >
-        <widget class="QGroupBox" name="grpDigitizing" >
-          <sizepolicy vsizetype="Expanding" hsizetype="Preferred" >
+       <item row="3" column="0">
+        <widget class="QGroupBox" name="grpDigitizing">
+          <sizepolicy hsizetype="Preferred" vsizetype="Expanding">
           </sizepolicy>
          </property>
           <string>Digitizing</string>
          </property>
-           <widget class="QCheckBox" name="mEnableTopologicalEditingCheckBox" >
+           <widget class="QCheckBox" name="mEnableTopologicalEditingCheckBox">
              <string>Enable topological editing</string>
             </property>
            </widget>
           </item>
-           <widget class="QCheckBox" name="mAvoidIntersectionsCheckBox" >
+           <widget class="QCheckBox" name="mAvoidIntersectionsCheckBox">
              <string>Avoid intersections of new polygons</string>
             </property>
            </widget>
           </item>
-           <widget class="QPushButton" name="mSnappingOptionsPushButton" >
+           <widget class="QPushButton" name="mSnappingOptionsPushButton">
              <string>Snapping options...</string>
             </property>
            </widget>
@@ -275,52 +269,59 @@
          </layout>
         </widget>
        </item>
+       <item row="4" column="0">
+        <widget class="QCheckBox" name="cbxAbsolutePath">
+          <string>save absolute paths</string>
+         </property>
+        </widget>
+       </item>
       </layout>
      </widget>
-     <widget class="QWidget" name="tab2" >
+     <widget class="QWidget" name="tab2">
        <string>Coordinate Reference System (CRS)</string>
       </attribute>
+       <property name="leftMargin">
         <number>3</number>
        </property>
+       <property name="topMargin">
         <number>11</number>
        </property>
+       <property name="rightMargin">
         <number>3</number>
        </property>
+       <property name="bottomMargin">
         <number>11</number>
        </property>
-        <widget class="QCheckBox" name="cbxProjectionEnabled" >
+        <widget class="QCheckBox" name="cbxProjectionEnabled">
           <string>Enable 'on the fly' CRS transformation</string>
          </property>
         </widget>
        </item>
-        <widget class="QgsProjectionSelector" native="1" name="projectionSelector" />
+        <widget class="QgsProjectionSelector" name="projectionSelector" native="true"/>
        </item>
       </layout>
      </widget>
     </widget>
    </item>
-    <widget class="QDialogButtonBox" name="buttonBox" >
+    <widget class="QDialogButtonBox" name="buttonBox">
      </property>
-     <property name="standardButtons" >
-      <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
+     <property name="standardButtons">
+      <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
      </property>
     </widget>
    </item>
   </layout>
  </widget>
- <layoutdefault spacing="6" margin="11" />
+ <layoutdefault spacing="6" margin="11"/>
  <customwidgets>
   <customwidget>
    <class>QgsColorButton</class>
@@ -359,11 +360,11 @@
    <receiver>spinBoxDP</receiver>
    <slot>setEnabled(bool)</slot>
    <hints>
-    <hint type="sourcelabel" >
+    <hint type="sourcelabel">
      <x>229</x>
      <y>280</y>
     </hint>
-    <hint type="destinationlabel" >
+    <hint type="destinationlabel">
      <x>416</x>
      <y>286</y>
     </hint>
@@ -375,11 +376,11 @@
    <receiver>textLabel3</receiver>
    <hints>
      <x>240</x>
      <y>281</y>
     </hint>
      <x>583</x>
      <y>290</y>
     </hint>
@@ -391,11 +392,11 @@
    <slot>setDisabled(bool)</slot>
    <hints>
      <x>100</x>
      <y>290</y>
     </hint>
      <x>395</x>
      <y>285</y>
     </hint>
@@ -407,11 +408,11 @@
    <hints>
      <x>87</x>
      <y>284</y>
     </hint>
      <x>589</x>
      <y>285</y>
     </hint>
More information about the QGIS-commit mailing list
