[QGIS Commit] r10886 - trunk/qgis/src/plugins/grass/scripts
svn_qgis at osgeo.org
Fri Jun 5 10:47:10 EDT 2009
Author: rblazek
Date: 2009-06-05 10:47:10 -0400 (Fri, 05 Jun 2009)
New Revision: 10886
trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py
fixed wrong port
Modified: trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py
--- trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py 2009-06-05 13:13:45 UTC (rev 10885)
+++ trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py 2009-06-05 14:47:10 UTC (rev 10886)
@@ -85,13 +85,10 @@
user = options['user']
password = options['password']
- #if not maptable:
- # grass.fatal("There is no table connected to this map. Cannot join any column.")
# Test connection
conn = "dbname=" + database
if host: conn += ",host=" + host
- if port: conn += ",port=" + host
+ if port: conn += ",port=" + port
# Unfortunately we cannot test untill user/password is set
if user or password:
