[QGIS Commit] r10903 - in trunk/qgis: cmake src/plugins/grass
src/plugins/grass/modules src/plugins/grass/modules-old
svn_qgis at osgeo.org
Thu Jun 11 07:54:44 EDT 2009
Author: rugginoso
Date: 2009-06-11 07:54:43 -0400 (Thu, 11 Jun 2009)
New Revision: 10903
Added:
trunk/qgis/src/plugins/grass/modules-old/
trunk/qgis/src/plugins/grass/modules-old/CMakeLists.txt
trunk/qgis/src/plugins/grass/modules-old/r.surf.fractal.1.png
trunk/qgis/src/plugins/grass/modules-old/r.surf.fractal.2.png
trunk/qgis/src/plugins/grass/modules-old/r.surf.fractal.qgm
trunk/qgis/src/plugins/grass/modules-old/v.buffer.1.svg
trunk/qgis/src/plugins/grass/modules-old/v.buffer.2.svg
trunk/qgis/src/plugins/grass/modules-old/v.buffer.qgm
trunk/qgis/src/plugins/grass/modules-old/v.db.select.1.png
trunk/qgis/src/plugins/grass/modules-old/v.db.select.2.png
trunk/qgis/src/plugins/grass/modules-old/v.db.select.qgm
trunk/qgis/src/plugins/grass/modules-old/v.db.select.where.1.png
trunk/qgis/src/plugins/grass/modules-old/v.db.select.where.2.png
trunk/qgis/src/plugins/grass/modules-old/v.db.select.where.qgm
trunk/qgis/src/plugins/grass/modules-old/v.to.db.1.png
trunk/qgis/src/plugins/grass/modules-old/v.to.db.2.png
trunk/qgis/src/plugins/grass/modules-old/v.to.db.qgm
trunk/qgis/cmake/FindGRASS.cmake
trunk/qgis/src/plugins/grass/CMakeLists.txt
trunk/qgis/src/plugins/grass/modules/r.surf.fractal.qgm
trunk/qgis/src/plugins/grass/modules/v.buffer.qgm
trunk/qgis/src/plugins/grass/modules/v.db.select.qgm
trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm
trunk/qgis/src/plugins/grass/modules/v.to.db.qgm
Changed some grass modules to work with grass 6.4 and guarantee the compatibility with previous versions. Fixed #1629.
Modified: trunk/qgis/cmake/FindGRASS.cmake
--- trunk/qgis/cmake/FindGRASS.cmake 2009-06-11 07:23:31 UTC (rev 10902)
+++ trunk/qgis/cmake/FindGRASS.cmake 2009-06-11 11:54:43 UTC (rev 10903)
@@ -66,7 +66,15 @@
IF (GRASS_FOUND)
FILE(READ ${GRASS_INCLUDE_DIR}/grass/version.h VERSIONFILE)
+ # We can avoid the following block using version_less version_equal and
+ # version_greater. Are there compatibility problems?
STRING(REGEX MATCH "[0-9]+\\.[0-9]+\\.[^ ]+" GRASS_VERSION ${VERSIONFILE})
+ STRING(REGEX REPLACE "^([0-9]*)\\.[0-9]*\\..*$" "\\1" GRASS_MAJOR_VERSION ${GRASS_VERSION})
+ STRING(REGEX REPLACE "^[0-9]*\\.([0-9]*)\\..*$" "\\1" GRASS_MINOR_VERSION ${GRASS_VERSION})
+ STRING(REGEX REPLACE "^[0-9]*\\.[0-9]*\\.(.*)$" "\\1" GRASS_MICRO_VERSION ${GRASS_VERSION})
+ # Add micro version too?
+ # How to numerize RC versions?
+ MATH( EXPR GRASS_NUM_VERSION "${GRASS_MAJOR_VERSION}*10000 + ${GRASS_MINOR_VERSION}*100")
IF (NOT GRASS_FIND_QUIETLY)
MESSAGE(STATUS "Found GRASS: ${GRASS_PREFIX} (${GRASS_VERSION})")
Modified: trunk/qgis/src/plugins/grass/CMakeLists.txt
--- trunk/qgis/src/plugins/grass/CMakeLists.txt 2009-06-11 07:23:31 UTC (rev 10902)
+++ trunk/qgis/src/plugins/grass/CMakeLists.txt 2009-06-11 11:54:43 UTC (rev 10903)
@@ -1,5 +1,5 @@
-SUBDIRS(config modules scripts themes)
+SUBDIRS(config modules modules-old scripts themes)
ADD_DEFINITIONS(-DGRASS_BASE=\\\"${GRASS_PREFIX}\\\")
ADD_DEFINITIONS(-DHAVE_OPENPTY=${HAVE_OPENPTY})
Modified: trunk/qgis/src/plugins/grass/modules/r.surf.fractal.qgm
--- trunk/qgis/src/plugins/grass/modules/r.surf.fractal.qgm 2009-06-11 07:23:31 UTC (rev 10902)
+++ trunk/qgis/src/plugins/grass/modules/r.surf.fractal.qgm 2009-06-11 11:54:43 UTC (rev 10903)
@@ -2,7 +2,7 @@
<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
<qgisgrassmodule label="Create fractal surface of given fractal dimension" module="r.surf.fractal">
- <option key="d" />
- <option key="n" />
- <option key="out" />
+ <option key="dimension" />
+ <option key="number" />
+ <option key="output" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.buffer.qgm
--- trunk/qgis/src/plugins/grass/modules/v.buffer.qgm 2009-06-11 07:23:31 UTC (rev 10902)
+++ trunk/qgis/src/plugins/grass/modules/v.buffer.qgm 2009-06-11 11:54:43 UTC (rev 10903)
@@ -3,6 +3,6 @@
<qgisgrassmodule label="Vector buffer" module="v.buffer">
<option key="input" typeoption="type" layeroption="layer" />
- <option key="buffer"/>
+ <option key="distance"/>
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.select.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.select.qgm 2009-06-11 07:23:31 UTC (rev 10902)
+++ trunk/qgis/src/plugins/grass/modules/v.db.select.qgm 2009-06-11 11:54:43 UTC (rev 10903)
@@ -3,6 +3,6 @@
<qgisgrassmodule label="Display vector attributes" module="v.db.select">
<option key="map" layeroption="layer" />
- <field key="column" layer="map" type="integer,double,varchar"/>
+ <field key="columns" layer="map" type="integer,double,varchar"/>
<option key="fs" answer="|" hidden="yes" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm 2009-06-11 07:23:31 UTC (rev 10902)
+++ trunk/qgis/src/plugins/grass/modules/v.db.select.where.qgm 2009-06-11 11:54:43 UTC (rev 10903)
@@ -3,7 +3,7 @@
<qgisgrassmodule label="Display vector map attributes with SQL" module="v.db.select">
<option key="where" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/v.to.db.qgm
--- trunk/qgis/src/plugins/grass/modules/v.to.db.qgm 2009-06-11 07:23:31 UTC (rev 10902)
+++ trunk/qgis/src/plugins/grass/modules/v.to.db.qgm 2009-06-11 11:54:43 UTC (rev 10903)
@@ -5,5 +5,5 @@
<option key="map" layeroption="layer"/>
<option key="option"/>
<option key="units"/>
- <field key="column" layer="map" type="integer,double" label="Attribute field" />
+ <field key="columns" layer="map" type="integer,double" label="Attribute field" />
</qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/modules-old/CMakeLists.txt
--- trunk/qgis/src/plugins/grass/modules-old/CMakeLists.txt (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-old/CMakeLists.txt 2009-06-11 11:54:43 UTC (rev 10903)
@@ -0,0 +1,6 @@
+IF ( GRASS_NUM_VERSION LESS 60400 )
+ FILE (GLOB MODULE_FILES *.qgm *.svg *.png)
+ INSTALL (FILES ${MODULE_FILES}
+ DESTINATION ${QGIS_DATA_DIR}/grass/modules)
+ENDIF ( GRASS_NUM_VERSION LESS 60400 )
Added: trunk/qgis/src/plugins/grass/modules-old/r.surf.fractal.1.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/modules-old/r.surf.fractal.1.png
___________________________________________________________________
+ application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules-old/r.surf.fractal.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-old/r.surf.fractal.2.png
Added: trunk/qgis/src/plugins/grass/modules-old/r.surf.fractal.qgm
--- trunk/qgis/src/plugins/grass/modules-old/r.surf.fractal.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-old/r.surf.fractal.qgm 2009-06-11 11:54:43 UTC (rev 10903)
@@ -0,0 +1,8 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Create fractal surface of given fractal dimension" module="r.surf.fractal">
+ <option key="d" />
+ <option key="n" />
+ <option key="out" />
+</qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/modules-old/v.buffer.1.svg
--- trunk/qgis/src/plugins/grass/modules-old/v.buffer.1.svg (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-old/v.buffer.1.svg 2009-06-11 11:54:43 UTC (rev 10903)
@@ -0,0 +1,13 @@
+<?xml version="1.0" standalone="no"?>
+<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 20001102//EN" "http://www.w3.org/TR/2000/CR-SVG-20001102/DTD/svg-20001102.dtd">
+<svg xmlns="http://www.w3.org/2000/svg" width="500" x="0" y="0" height="500" id="/putrela0/mpasol/blazek/inst/qgiscvs07/plugins/grass/modules/v.buffer.1" >
+ <rect width="500" x="0" y="0" height="500" style="stroke:rgb(0,0,0);stroke-width:0;fill:rgb(255,255,255);" />
+ <g style="stroke:rgb(0,0,0);stroke-width:0.9;fill:none;" >
+ <clipPath id="clip1" >
+ <rect width="500" x="0" y="0" height="500" />
+ </clipPath>
+ <g style="clip-path:url(#clip1)" >
+ <polyline points="80 416 94 381 110 352 130 322 161 298 213 281 276 264 323 245 353 217 399 168 418 125 431 95 438 77" style="stroke:rgb(0,0,255);stroke-width:15;fill:none;" />
+ </g>
+ </g>
+</svg>
Added: trunk/qgis/src/plugins/grass/modules-old/v.buffer.2.svg
--- trunk/qgis/src/plugins/grass/modules-old/v.buffer.2.svg (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-old/v.buffer.2.svg 2009-06-11 11:54:43 UTC (rev 10903)
@@ -0,0 +1,14 @@
+<svg xmlns="http://www.w3.org/2000/svg" width="500" x="0" y="0" height="500" id="/putrela0/mpasol/blazek/inst/qgiscvs07/plugins/grass/modules/v.buffer.2" >
+ </clipPath>
+ <polygon points="125 435 125 436 118 447 107 457 95 463 81 465 68 463 55 458 44 449 36 438 32 424 32 411 35 397 49 363 51 359 66 329 70 324 90 295 94 289 100 284 130 260 137 255 145 251 197 234 200 233 260 218 297 203 318 183 358 140 374 105 386 76 393 59 393 58 401 46 411 37 423 31 437 28 450 30 463 35 474 43 482 54 486 68 487 81 484 95 477 113 476 115 463 145 463 145 443 188 440 194 435 201 389 250 386 253 357 281 350 286 342 290 294 310 288 312 226 327 184 341 166 356 152 377 139 402 125 435" style="stroke:rgb(0,0,0);stroke-width:0;fill:rgb(170,255,255);" />
+ <polygon points="125 435 125 436 118 447 107 457 95 463 81 465 68 463 55 458 44 449 36 438 32 424 32 411 35 397 49 363 51 359 66 329 70 324 90 295 94 289 100 284 130 260 137 255 145 251 197 234 200 233 260 218 297 203 318 183 358 140 374 105 386 76 393 59 393 58 401 46 411 37 423 31 437 28 450 30 463 35 474 43 482 54 486 68 487 81 484 95 477 113 476 115 463 145 463 145 443 188 440 194 435 201 389 250 386 253 357 281 350 286 342 290 294 310 288 312 226 327 184 341 166 356 152 377 139 402 125 435" style="stroke:rgb(0,0,255);stroke-width:15;fill:none;" />
+ </g>
+ </g>
+</svg>
Added: trunk/qgis/src/plugins/grass/modules-old/v.buffer.qgm
--- trunk/qgis/src/plugins/grass/modules-old/v.buffer.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-old/v.buffer.qgm 2009-06-11 11:54:43 UTC (rev 10903)
@@ -0,0 +1,8 @@
+<qgisgrassmodule label="Vector buffer" module="v.buffer">
+ <option key="input" typeoption="type" layeroption="layer" />
+ <option key="buffer"/>
+</qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/modules-old/v.db.select.1.png
Property changes on: trunk/qgis/src/plugins/grass/modules-old/v.db.select.1.png
Added: trunk/qgis/src/plugins/grass/modules-old/v.db.select.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-old/v.db.select.2.png
Added: trunk/qgis/src/plugins/grass/modules-old/v.db.select.qgm
--- trunk/qgis/src/plugins/grass/modules-old/v.db.select.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-old/v.db.select.qgm 2009-06-11 11:54:43 UTC (rev 10903)
@@ -0,0 +1,8 @@
+<qgisgrassmodule label="Display vector attributes" module="v.db.select">
+ <option key="map" layeroption="layer" />
+ <field key="column" layer="map" type="integer,double,varchar"/>
+ <option key="fs" answer="|" hidden="yes" />
+</qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/modules-old/v.db.select.where.1.png
Property changes on: trunk/qgis/src/plugins/grass/modules-old/v.db.select.where.1.png
Added: trunk/qgis/src/plugins/grass/modules-old/v.db.select.where.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-old/v.db.select.where.2.png
Added: trunk/qgis/src/plugins/grass/modules-old/v.db.select.where.qgm
--- trunk/qgis/src/plugins/grass/modules-old/v.db.select.where.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-old/v.db.select.where.qgm 2009-06-11 11:54:43 UTC (rev 10903)
@@ -0,0 +1,9 @@
+<qgisgrassmodule label="Display vector map attributes with SQL" module="v.db.select">
+ <option key="where" />
+</qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/modules-old/v.to.db.1.png
Property changes on: trunk/qgis/src/plugins/grass/modules-old/v.to.db.1.png
Added: trunk/qgis/src/plugins/grass/modules-old/v.to.db.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-old/v.to.db.2.png
Added: trunk/qgis/src/plugins/grass/modules-old/v.to.db.qgm
--- trunk/qgis/src/plugins/grass/modules-old/v.to.db.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-old/v.to.db.qgm 2009-06-11 11:54:43 UTC (rev 10903)
@@ -0,0 +1,9 @@
+<qgisgrassmodule label="Put geometry variables in database" module="v.to.db">
+ <option key="map" layeroption="layer"/>
+ <option key="option"/>
+ <option key="units"/>
+ <field key="column" layer="map" type="integer,double" label="Attribute field" />
+</qgisgrassmodule>
