[QGIS Commit] r10918 - trunk/qgis/src/core/raster
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jun 12 20:06:08 EDT 2009
Author: ersts
Date: 2009-06-12 20:06:08 -0400 (Fri, 12 Jun 2009)
New Revision: 10918
   trunk/qgis/src/core/raster/qgsrasterlayer.cpp
-removed the use of setPixel() in the rendering routines, thanks Yan for the suggestion
-swapped all of the myColumns and myRows in the rendering routines, as they were reversed
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2009-06-12 22:27:58 UTC (rev 10917)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2009-06-13 00:06:08 UTC (rev 10918)
@@ -1555,12 +1555,13 @@
       int newTransparency;
       for ( int myHeightRunner = 0; myHeightRunner < myHeight; myHeightRunner++ )
+        QRgb* myLineBuffer = ( QRgb* ) transparentImageCopy->scanLine( myHeightRunner );
         for ( int myWidthRunner = 0; myWidthRunner < myWidth; myWidthRunner++ )
           myRgb = image->pixel( myWidthRunner, myHeightRunner );
           //combine transparency from WMS and layer transparency
           newTransparency = ( double ) mTransparencyLevel / 255.0 * ( double )( qAlpha( myRgb ) );
-          image->setPixel( myWidthRunner, myHeightRunner, qRgba( qRed( myRgb ), qGreen( myRgb ), qBlue( myRgb ), newTransparency ) );
+          myLineBuffer[ myWidthRunner ] = qRgba( qRed( myRgb ), qGreen( myRgb ), qBlue( myRgb ), newTransparency );
@@ -2864,13 +2865,13 @@
       double myValue = 0.0;
       for ( int myRow = 0; myRow < mySize; myRow++ )
+        QRgb* myLineBuffer = ( QRgb* )myQImage.scanLine( myRow );
         for ( int myCol = 0; myCol < mySize; myCol++ )
           myValue = myStep * ( double )( myCol + myRow * mySize );
           int c1, c2, c3;
           myShader.shade( myValue, &c1, &c2, &c3 );
-          myQImage.setPixel( myCol, myRow, qRgb( c1, c2, c3 ) );
+          myLineBuffer[ myCol ] = qRgb( c1, c2, c3 );
@@ -4261,7 +4262,7 @@
   QImage myQImage = QImage( theRasterViewPort->drawableAreaXDim, theRasterViewPort->drawableAreaYDim, QImage::Format_ARGB32 );
-  myQImage.fill( qRgba( 255, 255, 255, 0 ) ); // fill transparent
+  QRgb myDefaultColor = qRgba( 255, 255, 255, 0 );
   QgsRasterBandStats myRedBandStats;
   QgsRasterBandStats myGreenBandStats;
@@ -4318,30 +4319,34 @@
   QgsContrastEnhancement* myBlueContrastEnhancement = contrastEnhancement( myBlueBandNo );
   QgsDebugMsg( "Starting main render loop" );
-  for ( int myColumn = 0; myColumn < theRasterViewPort->drawableAreaYDim; ++myColumn )
+  for ( int myRow = 0; myRow < theRasterViewPort->drawableAreaYDim; ++myRow )
-    for ( int myRow = 0; myRow < theRasterViewPort->drawableAreaXDim; ++myRow )
+    for ( int myColumn = 0; myColumn < theRasterViewPort->drawableAreaXDim; ++myColumn )
       myRedValue   = readValue( myGdalRedData, ( GDALDataType )myRedType,
-                                myColumn * theRasterViewPort->drawableAreaXDim + myRow );
+                                myRow * theRasterViewPort->drawableAreaXDim + myColumn );
       myGreenValue = readValue( myGdalGreenData, ( GDALDataType )myGreenType,
       myBlueValue  = readValue( myGdalBlueData, ( GDALDataType )myBlueType,
       if ( mValidNoDataValue && (( myRedValue == mNoDataValue || myRedValue != myRedValue ) || ( myGreenValue == mNoDataValue || myGreenValue != myGreenValue ) || ( myBlueValue == mNoDataValue || myBlueValue != myBlueValue ) ) )
+        myLineBuffer[ myColumn ] = myDefaultColor;
         continue;
       if ( !myRedContrastEnhancement->isValueInDisplayableRange( myRedValue ) || !myGreenContrastEnhancement->isValueInDisplayableRange( myGreenValue ) || !myBlueContrastEnhancement->isValueInDisplayableRange( myBlueValue ) )
         continue;
       myAlphaValue = mRasterTransparency.alphaValue( myRedValue, myGreenValue, myBlueValue, mTransparencyLevel );
       if ( 0 == myAlphaValue )
         continue;
@@ -4356,7 +4361,7 @@
         myStretchedBlueValue = 255 - myStretchedBlueValue;
-      myQImage.setPixel( myRow, myColumn, qRgba( myStretchedRedValue, myStretchedGreenValue, myStretchedBlueValue, myAlphaValue ) );
+      myLineBuffer[ myColumn ] = qRgba( myStretchedRedValue, myStretchedGreenValue, myStretchedBlueValue, myAlphaValue );
   //free the scanline memory
@@ -4432,7 +4437,7 @@
   double myPixelValue = 0.0;
   int myRedValue = 0;
@@ -4441,41 +4446,45 @@
   int myAlphaValue = 0;
       myRedValue = 0;
       myGreenValue = 0;
       myBlueValue = 0;
       myPixelValue = readValue( myGdalScanData, ( GDALDataType )myDataType,
       if ( mValidNoDataValue && ( myPixelValue == mNoDataValue || myPixelValue != myPixelValue ) )
         continue;
       myAlphaValue = mRasterTransparency.alphaValue( myPixelValue, mTransparencyLevel );
         continue;
       if ( !mRasterShader->shade( myPixelValue, &myRedValue, &myGreenValue, &myBlueValue ) )
         continue;
       if ( mInvertColor )
         //Invert flag, flip blue and read
-        myQImage.setPixel( myRow, myColumn, qRgba( myBlueValue, myGreenValue, myRedValue, myAlphaValue ) );
+        myLineBuffer[ myColumn ] = qRgba( myBlueValue, myGreenValue, myRedValue, myAlphaValue );
       else
         //Normal
-        myQImage.setPixel( myRow, myColumn, qRgba( myRedValue, myGreenValue, myBlueValue, myAlphaValue ) );
+        myLineBuffer[ myColumn ] = qRgba( myRedValue, myGreenValue, myBlueValue, myAlphaValue );
@@ -4516,7 +4525,7 @@
   int myRedValue = 0;
@@ -4525,29 +4534,33 @@
       myRedValue = 0;
       myGreenValue = 0;
       myBlueValue = 0;
         continue;
         continue;
         continue;
@@ -4555,13 +4568,13 @@
         double myGrayValue = ( 0.3 * ( double )myRedValue ) + ( 0.59 * ( double )myGreenValue ) + ( 0.11 * ( double )myBlueValue );
-        myQImage.setPixel( myRow, myColumn, qRgba(( int )myGrayValue, ( int )myGrayValue, ( int )myGrayValue, myAlphaValue ) );
+        myLineBuffer[ myColumn ] = qRgba(( int )myGrayValue, ( int )myGrayValue, ( int )myGrayValue, myAlphaValue );
       else
         //Normal
         double myGrayValue = ( 0.3 * ( double )myBlueValue ) + ( 0.59 * ( double )myGreenValue ) + ( 0.11 * ( double )myRedValue );
@@ -4600,7 +4613,7 @@
   if ( NULL == mRasterShader )
@@ -4631,41 +4644,45 @@
       myRedValue = 0;
       myGreenValue = 0;
       myBlueValue = 0;
         continue;
         continue;
         continue;
       if ( mInvertColor )
       else
         //Normal
@@ -4706,7 +4723,7 @@
   QgsRasterBandStats myGrayBandStats;
@@ -4735,12 +4752,13 @@
   int myGrayVal = 0;
   QgsContrastEnhancement* myContrastEnhancement = contrastEnhancement( theBandNo );
       myGrayValue = readValue( myGdalScanData, myDataType,
       // If mNoDataValue is 'nan', the comparison
       // against myGrayVal will always fail ( nan==nan always
@@ -4748,17 +4766,20 @@
       // of myGrayVal against itself.
       if ( mValidNoDataValue && ( myGrayValue == mNoDataValue || myGrayValue != myGrayValue ) )
         continue;
       if ( !myContrastEnhancement->isValueInDisplayableRange( myGrayValue ) )
         continue;
       myAlphaValue = mRasterTransparency.alphaValue( myGrayValue, mTransparencyLevel );
         continue;
@@ -4770,8 +4791,7 @@
         myGrayVal = 255 - myGrayVal;
-      myQImage.setPixel( myRow, myColumn, qRgba( myGrayVal, myGrayVal, myGrayVal, myAlphaValue ) );
+      myLineBuffer[ myColumn ] = qRgba( myGrayVal, myGrayVal, myGrayVal, myAlphaValue );
@@ -4807,7 +4827,7 @@
@@ -4839,38 +4859,42 @@
       myPixelValue = readValue( myGdalScanData, myDataType,
         continue;
         continue;
         continue;
       if ( mInvertColor )
       else
         //Normal
     }                       //end of columnwise loop
   }                           //end of rowwise loop
More information about the QGIS-commit mailing list
