[QGIS Commit] r10966 - trunk/qgis/src/plugins/grass
svn_qgis at osgeo.org
Mon Jun 22 11:33:53 EDT 2009
Author: rugginoso
Date: 2009-06-22 11:33:52 -0400 (Mon, 22 Jun 2009)
New Revision: 10966
trunk/qgis/src/plugins/grass/qgsgrassmodel.cpp
Added the possibility to view informations about regions into the browser of the GRASS plug-in to fix ticket #1624.
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodel.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassmodel.cpp 2009-06-21 22:13:57 UTC (rev 10965)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodel.cpp 2009-06-22 15:33:52 UTC (rev 10966)
@@ -118,6 +118,7 @@
break;
case QgsGrassModel::Vectors:
case QgsGrassModel::Rasters:
+ case QgsGrassModel::Regions:
return QObject::tr( "Location: %1<br>Mapset: %2" ).arg( mLocation ).arg( mMapset );
break;
case QgsGrassModel::Raster:
@@ -367,6 +368,60 @@
return str;
break;
+ case QgsGrassModel::Region:
+ QString str = tblStart;
+ str += htmlTableRow( QObject::tr( "<b>Region</b>" ), QString( "<b>%1</b>" ).arg( mMap ) );
+ struct Cell_head window;
+ QgsGrass::setLocation( mGisbase, mLocation );
+ if ( G__get_window( &window, "windows", mMap.toLocal8Bit().data(), mMapset.toLocal8Bit().data()) != NULL)
+ str += "<tr><td colspan=2>" + QObject::tr( "Cannot open region header" ) + "</td></tr>";
+ else
+ QString proj;
+ switch (window.proj){
+ case PROJECTION_XY:
+ proj = QObject::tr("XY");
+ break;
+ case PROJECTION_UTM:
+ proj = QObject::tr("UTM");
+ break;
+ case PROJECTION_SP:
+ proj = QObject::tr("SP");
+ break;
+ case PROJECTION_LL:
+ proj = QObject::tr("LL");
+ break;
+ default:
+ proj = QObject::tr("Other");
+ str += htmlTableRow( QObject::tr( "Projection Type" ), proj );
+ if ( window.proj == PROJECTION_UTM)
+ str += htmlTableRow( QObject::tr( "Zone" ), QString::number( window.zone ) );
+ str += htmlTableRow( QObject::tr( "North" ), QString::number( window.north, 'f', 8 ) );
+ str += htmlTableRow( QObject::tr( "South" ), QString::number( window.south, 'f', 8 ) );
+ str += htmlTableRow( QObject::tr( "East" ), QString::number( window.east, 'f', 8 ) );
+ str += htmlTableRow( QObject::tr( "West" ), QString::number( window.west, 'f', 8 ) );
+ str += htmlTableRow( QObject::tr( "Columns" ), QString::number( window.cols ) );
+ str += htmlTableRow( QObject::tr( "Rows" ), QString::number( window.rows ) );
+ str += htmlTableRow( QObject::tr( "E-W resolution" ), QString::number( window.ew_res, 'f', 8 ) );
+ str += htmlTableRow( QObject::tr( "N-S resolution" ), QString::number( window.ns_res, 'f', 8 ) );
+ str += htmlTableRow( QObject::tr( "Top" ), QString::number( window.top ) );
+ str += htmlTableRow( QObject::tr( "Bottom" ), QString::number( window.bottom ) );
+ str += htmlTableRow( QObject::tr( "3D Cols" ), QString::number( window.cols3 ) );
+ str += htmlTableRow( QObject::tr( "3D Rows" ), QString::number( window.rows3 ) );
+ str += htmlTableRow( QObject::tr( "Depths" ), QString::number( window.depths ) );
+ str += htmlTableRow( QObject::tr( "E-W 3D resolution"), QString::number( window.ew_res3, 'f', 8 ) );
+ str += htmlTableRow( QObject::tr( "N-S 3D resolution"), QString::number( window.ns_res3, 'f', 8 ) );
+ str += "</table>";
+ return str;
+ break;
return QString();
