[QGIS Commit] r10968 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Jun 23 08:35:24 EDT 2009
Author: jef
Date: 2009-06-23 08:35:23 -0400 (Tue, 23 Jun 2009)
New Revision: 10968
   trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
reindent postgres provider
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2009-06-23 12:03:18 UTC (rev 10967)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2009-06-23 12:35:23 UTC (rev 10968)
@@ -1686,8 +1686,8 @@
   QString typeName;
   //find out type of index
-  QgsFieldMap::const_iterator f_it = attributeFields.find(index);
-  if(f_it != attributeFields.constEnd())
+  QgsFieldMap::const_iterator f_it = attributeFields.find( index );
+  if ( f_it != attributeFields.constEnd() )
     typeName = f_it.value().typeName();
@@ -1697,19 +1697,19 @@
   //is type an enum?
-  QString typeSql = QString("SELECT typtype FROM pg_type where typname = %1").arg(quotedValue(typeName));
+  QString typeSql = QString( "SELECT typtype FROM pg_type where typname = %1" ).arg( quotedValue( typeName ) );
   Result typeRes = connectionRO->PQexec( typeSql );
-  if ( PQresultStatus( typeRes ) != PGRES_TUPLES_OK || PQntuples(typeRes) < 1)
+  if ( PQresultStatus( typeRes ) != PGRES_TUPLES_OK || PQntuples( typeRes ) < 1 )
     return;
   QString typtype = PQgetvalue( typeRes, 0, 0 );
-  if(typtype.compare("e", Qt::CaseInsensitive) == 0)
+  if ( typtype.compare( "e", Qt::CaseInsensitive ) == 0 )
     //try to read enum_range of attribute
-    if(!parseEnumRange(enumList, f_it->name()))
+    if ( !parseEnumRange( enumList, f_it->name() ) )
       enumList.clear();
@@ -1717,37 +1717,37 @@
   else
     //is there a domain check constraint for the attribute?
-    if(!parseDomainCheckConstraint(enumList, f_it->name()))
+    if ( !parseDomainCheckConstraint( enumList, f_it->name() ) )
-       enumList.clear();
+      enumList.clear();
-bool QgsPostgresProvider::parseEnumRange(QStringList& enumValues, const QString& attributeName) const
+bool QgsPostgresProvider::parseEnumRange( QStringList& enumValues, const QString& attributeName ) const
   enumValues.clear();
-  QString enumRangeSql = QString("SELECT enum_range(%1) from %2 limit1").arg(quotedIdentifier(attributeName)).arg(mSchemaTableName);
-  Result enumRangeRes = connectionRO->PQexec(enumRangeSql);
-  if ( PQresultStatus( enumRangeRes ) == PGRES_TUPLES_OK && PQntuples(enumRangeRes) > 0)
+  QString enumRangeSql = QString( "SELECT enum_range(%1) from %2 limit1" ).arg( quotedIdentifier( attributeName ) ).arg( mSchemaTableName );
+  Result enumRangeRes = connectionRO->PQexec( enumRangeSql );
+  if ( PQresultStatus( enumRangeRes ) == PGRES_TUPLES_OK && PQntuples( enumRangeRes ) > 0 )
-    QString enumRangeString = PQgetvalue(enumRangeRes, 0, 0);
+    QString enumRangeString = PQgetvalue( enumRangeRes, 0, 0 );
     //strip away the brackets at begin and end
-    enumRangeString.chop(1);
-    enumRangeString.remove(0, 1);
-    QStringList rangeSplit = enumRangeString.split(",");
+    enumRangeString.chop( 1 );
+    enumRangeString.remove( 0, 1 );
+    QStringList rangeSplit = enumRangeString.split( "," );
     QStringList::const_iterator range_it = rangeSplit.constBegin();
-    for(; range_it != rangeSplit.constEnd(); ++range_it)
+    for ( ; range_it != rangeSplit.constEnd(); ++range_it )
       QString currentEnumValue = *range_it;
       //remove quotes from begin and end of the value
-      if(currentEnumValue.startsWith("'") || currentEnumValue.startsWith("\""))
+      if ( currentEnumValue.startsWith( "'" ) || currentEnumValue.startsWith( "\"" ) )
-        currentEnumValue.remove(0, 1);
+        currentEnumValue.remove( 0, 1 );
-      if(currentEnumValue.endsWith("'") || currentEnumValue.endsWith("\""))
+      if ( currentEnumValue.endsWith( "'" ) || currentEnumValue.endsWith( "\"" ) )
-        currentEnumValue.chop(1);
+        currentEnumValue.chop( 1 );
       enumValues << currentEnumValue;
@@ -1756,49 +1756,49 @@
   return false;
-bool QgsPostgresProvider::parseDomainCheckConstraint(QStringList& enumValues, const QString& attributeName) const
+bool QgsPostgresProvider::parseDomainCheckConstraint( QStringList& enumValues, const QString& attributeName ) const
   enumValues.clear();
   //is it a domain type with a check constraint?
-  QString domainSql = QString("SELECT domain_name from information_schema.columns where table_name = %1 and column_name = %2").arg(quotedValue(mTableName)).arg(quotedValue(attributeName));
-  Result domainResult = connectionRO->PQexec(domainSql);
-  if ( PQresultStatus( domainResult ) == PGRES_TUPLES_OK && PQntuples(domainResult) > 0)
+  QString domainSql = QString( "SELECT domain_name from information_schema.columns where table_name = %1 and column_name = %2" ).arg( quotedValue( mTableName ) ).arg( quotedValue( attributeName ) );
+  Result domainResult = connectionRO->PQexec( domainSql );
+  if ( PQresultStatus( domainResult ) == PGRES_TUPLES_OK && PQntuples( domainResult ) > 0 )
     //a domain type
-    QString domainCheckDefinitionSql = QString("SELECT consrc FROM pg_constraint where conname = (SELECT constraint_name FROM information_schema.domain_constraints WHERE domain_name = %1)").arg(quotedValue(PQgetvalue(domainResult, 0, 0)));
-    Result domainCheckRes = connectionRO->PQexec(domainCheckDefinitionSql);
-    if ( PQresultStatus(domainCheckRes) == PGRES_TUPLES_OK && PQntuples(domainCheckRes) > 0)
+    QString domainCheckDefinitionSql = QString( "SELECT consrc FROM pg_constraint where conname = (SELECT constraint_name FROM information_schema.domain_constraints WHERE domain_name = %1)" ).arg( quotedValue( PQgetvalue( domainResult, 0, 0 ) ) );
+    Result domainCheckRes = connectionRO->PQexec( domainCheckDefinitionSql );
+    if ( PQresultStatus( domainCheckRes ) == PGRES_TUPLES_OK && PQntuples( domainCheckRes ) > 0 )
-      QString checkDefinition = PQgetvalue(domainCheckRes, 0, 0);
+      QString checkDefinition = PQgetvalue( domainCheckRes, 0, 0 );
       //we assume that the constraint is of the following form:
       //(VALUE = ANY (ARRAY['a'::text, 'b'::text, 'c'::text, 'd'::text]))
       //normally, postgresql creates that if the contstraint has been specified as 'VALUE in ('a', 'b', 'c', 'd')
       //todo: ANY must occure before ARRAY
-      int anyPos = checkDefinition.indexOf("VALUE = ANY");
-      int arrayPosition = checkDefinition.lastIndexOf("ARRAY[");
-      int closingBracketPos = checkDefinition.indexOf("]", arrayPosition + 6);
+      int anyPos = checkDefinition.indexOf( "VALUE = ANY" );
+      int arrayPosition = checkDefinition.lastIndexOf( "ARRAY[" );
+      int closingBracketPos = checkDefinition.indexOf( "]", arrayPosition + 6 );
-      if(anyPos == -1 || anyPos >= arrayPosition)
+      if ( anyPos == -1 || anyPos >= arrayPosition )
         return false; //constraint has not the required format
-      if(arrayPosition != -1)
+      if ( arrayPosition != -1 )
-        QString valueList = checkDefinition.mid(arrayPosition + 6, closingBracketPos);
-        QStringList commaSeparation = valueList.split(",", QString::SkipEmptyParts);
+        QString valueList = checkDefinition.mid( arrayPosition + 6, closingBracketPos );
+        QStringList commaSeparation = valueList.split( ",", QString::SkipEmptyParts );
         QStringList::const_iterator cIt = commaSeparation.constBegin();
-        for(; cIt != commaSeparation.constEnd(); ++cIt)
+        for ( ; cIt != commaSeparation.constEnd(); ++cIt )
           //get string between ''
-          int beginQuotePos = cIt->indexOf("'");
-          int endQuotePos = cIt->lastIndexOf("'");
-          if(beginQuotePos != -1 && (endQuotePos - beginQuotePos) > 1)
+          int beginQuotePos = cIt->indexOf( "'" );
+          int endQuotePos = cIt->lastIndexOf( "'" );
+          if ( beginQuotePos != -1 && ( endQuotePos - beginQuotePos ) > 1 )
-            enumValues << cIt->mid(beginQuotePos + 1, endQuotePos - beginQuotePos - 1);
+            enumValues << cIt->mid( beginQuotePos + 1, endQuotePos - beginQuotePos - 1 );
More information about the QGIS-commit mailing list
