[QGIS Commit] r10970 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Jun 23 09:21:02 EDT 2009
Author: wonder
Date: 2009-06-23 09:21:02 -0400 (Tue, 23 Jun 2009)
New Revision: 10970
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgsmaptoolnodetool.cpp
   trunk/qgis/src/app/qgsmaptoolnodetool.h
Node tool now works also with on the fly projections turned on.
Contributed by Richard Kostecky.
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2009-06-23 12:36:33 UTC (rev 10969)
+++ trunk/qgis/src/app/qgisapp.cpp	2009-06-23 13:21:02 UTC (rev 10970)
@@ -1659,6 +1659,8 @@
            this, SLOT( activateDeactivateLayerRelatedActions( QgsMapLayer* ) ) );
   connect( mMapLegend, SIGNAL( currentLayerChanged( QgsMapLayer* ) ),
            mUndoWidget, SLOT( layerChanged( QgsMapLayer* ) ) );
+  connect( mMapLegend, SIGNAL( currentLayerChanged( QgsMapLayer* ) ),
+           mMapTools.mNodeTool, SLOT( currentLayerChanged( QgsMapLayer* ) ) );
   //signal when mouse moved over window (coords display in status bar)
Modified: trunk/qgis/src/app/qgsmaptoolnodetool.cpp
--- trunk/qgis/src/app/qgsmaptoolnodetool.cpp	2009-06-23 12:36:33 UTC (rev 10969)
+++ trunk/qgis/src/app/qgsmaptoolnodetool.cpp	2009-06-23 13:21:02 UTC (rev 10970)
@@ -31,7 +31,7 @@
   marker->setWidth(2);
   double movement = 4;
   double s = QgsTolerance::toleranceInMapUnits(movement, vlayer, mCanvas->mapRenderer(), QgsTolerance::Pixels);
-  QgsPoint pom = center;
+  QgsPoint pom = toMapCoordinates( vlayer, center );
   pom.setX(pom.x() - s);
   pom.setY(pom.y() - s);
   marker->addPoint(pom);
@@ -58,7 +58,8 @@
   mClicked = false;
   mChangingGeometry = false;
   mIsPoint = false;
-  connect( canvas, SIGNAL(layersChanged()), this, SLOT(layersChanged() ) );
+  connect( canvas, SIGNAL(layersChanged()), this, SLOT( layersChanged() ) );
+  connect( canvas->mapRenderer(), SIGNAL(destinationSrsChanged()), this, SLOT( coordinatesChanged() ) );
 QgsMapToolNodeTool::~QgsMapToolNodeTool()
@@ -76,7 +77,17 @@
+void QgsMapToolNodeTool::currentLayerChanged( QgsMapLayer* layer)
+  QgsVectorLayer* vlayer = vlayer = dynamic_cast<QgsVectorLayer*>( layer );
+  if (mSelectionFeature!= NULL && mSelectionFeature->vlayer() != vlayer)
+    delete mSelectionFeature;
+    mSelectionFeature = NULL;
 void QgsMapToolNodeTool::featureDeleted( int featureId )
   if (mSelectionFeature != NULL && featureId == mSelectionFeature->featureId())
@@ -136,14 +147,14 @@
       int index = 0;
       if (beforeVertex != -1) //adding first point which is not moving
-        rb->addPoint(vertexMap[beforeVertex].point, false );
+        rb->addPoint( toMapCoordinates( mCanvas->currentLayer(), vertexMap[beforeVertex].point ), false );
         mSelectionFeature->setRubberBandValues(beforeVertex, true, lastRubberBand, index );
         vertexMap[beforeVertex].inRubberBand = true;
         index ++;
       while (vertex != -1 && vertexMap[vertex].selected && !vertexMap[vertex].inRubberBand)
-        rb->addPoint(vertexMap[vertex].point, false);
+        rb->addPoint(toMapCoordinates( mCanvas->currentLayer(), vertexMap[vertex].point), false);
         mSelectionFeature->setRubberBandValues(vertex, true, lastRubberBand, index );
         vertexMap[vertex].inRubberBand = true;
         index ++;
@@ -151,7 +162,7 @@
       if (vertex != -1 && !vertexMap[vertex].selected) //add last point if exists
-        rb->addPoint(vertexMap[vertex].point, true);
+        rb->addPoint(toMapCoordinates( mCanvas->currentLayer(), vertexMap[vertex].point), true);
         index ++;
@@ -160,8 +171,15 @@
       lastRubberBand ++;
+void QgsMapToolNodeTool::coordinatesChanged()
+  if (mSelectionFeature != NULL)
+    mSelectionFeature->updateVertexMarkersPosition( mCanvas );
@@ -197,11 +215,9 @@
               QgsRubberBand* rb = createRubberBandMarker( vertexMap[i].point, vlayer );
               mQgsRubberBands.append(rb);
         createMovingRubberBands();
       else
@@ -214,7 +230,7 @@
         QgsPoint posMapCoord = snapPointFromResults( snapResults, e->pos() );
         if (snapResults.size() > 0)
-          firstCoords = mClosestVertex;
+          firstCoords = toMapCoordinates( vlayer, mClosestVertex );
         //special handling of points
@@ -236,8 +252,10 @@
           if (vertexMap[i].selected)
-            double x = vertexMap[i].point.x() + posMapCoord.x() - firstCoords.x();
-            double y = vertexMap[i].point.y() + posMapCoord.y() - firstCoords.y();
+            QgsPoint mapCoords = toMapCoordinates( vlayer, vertexMap[i].point );
+            double x = mapCoords.x() + posMapCoord.x() - firstCoords.x();
+            double y = mapCoords.y() + posMapCoord.y() - firstCoords.y();
+            //QgsPoint pom = toLayerCoordinates(
             mQgsRubberBands[vertexMap[i].rubberBandNr]->movePoint( vertexMap[i].index + 1, QgsPoint(x, y));
             if (vertexMap[i].index == 0)
@@ -337,7 +355,7 @@
     QgsGeometry* g = f.geometry();
     int atVertex, beforeVertex, afterVertex;
     double dist;
-    g->closestVertex(mapCoordPoint, atVertex, beforeVertex, afterVertex, dist);
+    g->closestVertex(toLayerCoordinates(vlayer, mapCoordPoint), atVertex, beforeVertex, afterVertex, dist);
     dist = sqrt(dist);
     mSnapper.snapToCurrentLayer(e->pos(), snapResults, QgsSnapper::SnapToVertex, tol);
@@ -374,7 +392,7 @@
           mMoving = true;
           QgsPoint point = mCanvas->getCoordinateTransform()->toMapPoint(e->pos().x(), e->pos().y());
-          mClosestVertex = getClosestVertex( point );
+          mClosestVertex = getClosestVertex( toLayerCoordinates( vlayer, point) );
           if ( !mSelectionFeature->isSelected( snapResult.beforeVertexNr ) || !mSelectionFeature->isSelected( snapResult.afterVertexNr ))
             mSelectionFeature->deselectAllVertexes();
@@ -396,7 +414,7 @@
       //some vertex selected
       mMoving = true;
       if (mMoving)
         if (mCtrl)
@@ -441,7 +459,9 @@
   mClicked = false;
   mSelectionRectangle = false;
-  QgsPoint coords = mCanvas->getCoordinateTransform()->toMapPoint( e->pos().x(),  e->pos().y() );
+  QgsPoint coords = toMapCoordinates( e->pos() );
+  //QgsPoint coords = mCanvas->getCoordinateTransform()->toMapPoint( e->pos().x(),  e->pos().y() );
+  //QgsPoint firstCoords = toMapCoordinates( *mLastCoordinates );
   QgsPoint firstCoords = mCanvas->getCoordinateTransform()->toMapPoint( mLastCoordinates->x(), mLastCoordinates->y() );
   if (mQRubberBand != NULL)
@@ -461,30 +481,34 @@
   else
-    //got correct coordinates
+    // coordinates has to be coordinates from layer not canvas
+    QgsPoint layerCoords = toLayerCoordinates(vlayer, coords);
+    QgsPoint layerFirstCoords = toLayerCoordinates(vlayer, firstCoords);
+    //got correct coordinates
     double topX;
     double bottomX;
-    if (coords.x() > firstCoords.x())
+    if (layerCoords.x() > layerFirstCoords.x())
-      topX = firstCoords.x();
-      bottomX = coords.x();
+      topX = layerFirstCoords.x();
+      bottomX = layerCoords.x();
     else
-      topX = coords.x();
-      bottomX = firstCoords.x();
+      topX = layerCoords.x();
+      bottomX = layerFirstCoords.x();
     double leftY;
     double rightY;
-    if (coords.y() > firstCoords.y())
+    if (layerCoords.y() > layerFirstCoords.y())
-      leftY = firstCoords.y();
-      rightY = coords.y();
+      leftY = layerFirstCoords.y();
+      rightY = layerCoords.y();
     else
-      leftY = coords.y();
-      rightY = firstCoords.y();
+      leftY = layerCoords.y();
+      rightY = layerFirstCoords.y();
     if (mMoving)
@@ -498,11 +522,12 @@
       //coords = mCanvas->getCoordinateTransform()->toMapPoint( e->pos().x(), e->pos().y() );
-      double changeX = coords.x() - firstCoords.x();
-      double changeY = coords.y() - firstCoords.y();
+      double changeX = layerCoords.x() - layerFirstCoords.x();
+      double changeY = layerCoords.y() - layerFirstCoords.y();
       mChangingGeometry = true;
       mSelectionFeature->moveSelectedVertexes( changeX, changeY );
       mCanvas->refresh();
@@ -541,7 +566,7 @@
   disconnect( mCanvas->currentLayer(), SIGNAL( featureDeleted(int) ) );
-  disconnect(mCanvas->currentLayer(), SIGNAL( layerModified(bool) )  );
+  disconnect( mCanvas->currentLayer(), SIGNAL( layerModified(bool) )  );
   mQRubberBand = NULL;
   mSelectAnother = false;
@@ -592,11 +617,12 @@
       if (snapResults.first().snappedVertexNr == -1)
         QgsPoint coords = snapResults.first().snappedVertex;
+        QgsPoint layerCoords = toLayerCoordinates( vlayer, coords );
         //add vertex
         vlayer->beginEditCommand( tr("Inserted vertex") );
-        vlayer->insertVertex(coords.x(), coords.y(), mSelectionFeature->featureId(), snapResults.first().afterVertexNr );
+        vlayer->insertVertex(layerCoords.x(), layerCoords.y(), mSelectionFeature->featureId(), snapResults.first().afterVertexNr );
         vlayer->endEditCommand();
         mSelectionFeature->updateFromFeature();
@@ -736,13 +762,16 @@
       mVlayer->moveVertex( mVertexMap[i].point.x() + changeX, mVertexMap[i].point.y() + changeY, mFeatureId, i);
       mVertexMap[i].point = QgsPoint(mVertexMap[i].point.x() + changeX, mVertexMap[i].point.y() + changeY);
-      mVertexMap[i].vertexMarker->setCenter(mVertexMap[i].point);
+      QgsPoint point = mVertexMap[i].point;
+      point = mCanvas->mapRenderer()->layerToMapCoordinates( mVlayer, mVertexMap[i].point );
+      mVertexMap[i].vertexMarker->setCenter(point);
       mVertexMap[i].vertexMarker->update();
       if (mVertexMap[i].equals != -1 && !mVertexMap[mVertexMap[i].equals].selected)
         int index = mVertexMap[i].equals;
         mVertexMap[index].point = QgsPoint(mVertexMap[index].point.x() + changeX, mVertexMap[index].point.y() + changeY);
         //for polygon delete both
@@ -755,7 +784,8 @@
 QgsVertexMarker* SelectionFeature::createVertexMarker(QgsPoint center)
   QgsVertexMarker* marker = new QgsVertexMarker(mCanvas);
-  marker->setCenter( center );
+  QgsPoint newCenter = mCanvas->mapRenderer()->layerToMapCoordinates( mVlayer, center );
+  marker->setCenter( newCenter );
   marker->setIconType( QgsVertexMarker::ICON_BOX );
@@ -1028,7 +1058,7 @@
   for (int i=0; i< mVertexMap.size() ;i++)
+    mVertexMap[i].vertexMarker->setCenter( mCanvas->mapRenderer()->layerToMapCoordinates( mVlayer, mVertexMap[i].point ) );
Modified: trunk/qgis/src/app/qgsmaptoolnodetool.h
--- trunk/qgis/src/app/qgsmaptoolnodetool.h	2009-06-23 12:36:33 UTC (rev 10969)
+++ trunk/qgis/src/app/qgsmaptoolnodetool.h	2009-06-23 13:21:02 UTC (rev 10970)
@@ -228,6 +228,13 @@
     QgsPoint getClosestVertex(QgsPoint point);
+  public slots:
+     * Slot to count with layer change
+     * @param layer layer to which selection changed
+    void currentLayerChanged( QgsMapLayer* layer);
   protected slots:
      * Processing incomming signal of deleted feature (for deletion of selected feature)
@@ -246,6 +253,11 @@
     void layersChanged();
+     * Changed coordinates to markers need to be redrawn to correct position
+    void coordinatesChanged();
   private:
     void connectSignals(QgsVectorLayer* vlayer);
More information about the QGIS-commit mailing list
