[QGIS Commit] r10972 - trunk/qgis/src/providers/ogr
svn_qgis at osgeo.org
Wed Jun 24 05:17:08 EDT 2009
Author: jef
Date: 2009-06-24 05:17:07 -0400 (Wed, 24 Jun 2009)
New Revision: 10972
trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
OGR provider update (fixes #1746)
- use OGR and not the filename to deduce the layername
- fall back to QgsVectorDataProvider methods if OGR SQL doesn't work
- check error code of OGR_L_SetFeature
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2009-06-23 13:56:22 UTC (rev 10971)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp 2009-06-24 09:17:07 UTC (rev 10972)
@@ -53,8 +53,6 @@
+ GDALVersionInfo( "RELEASE_NAME" )
QgsOgrProvider::QgsOgrProvider( QString const & uri )
: QgsVectorDataProvider( uri ),
ogrDataSource( 0 ),
@@ -768,7 +766,11 @@
- OGR_L_SetFeature( ogrLayer, of );
+ OGRErr res;
+ if (( res = OGR_L_SetFeature( ogrLayer, of ) ) != OGRERR_NONE )
+ QgsLogger::warning( "QgsOgrProvider::changeAttributeValues, setting the feature failed: " + QString::number( res ) );
OGR_L_SyncToDisk( ogrLayer );
@@ -778,6 +780,7 @@
bool QgsOgrProvider::changeGeometryValues( QgsGeometryMap & geometry_map )
+ OGRErr res;
OGRFeatureH theOGRFeature = 0;
OGRGeometryH theNewGeometry = 0;
@@ -809,15 +812,23 @@
//set the new geometry
- if ( OGR_F_SetGeometryDirectly( theOGRFeature, theNewGeometry ) != OGRERR_NONE )
+ if (( res = OGR_F_SetGeometryDirectly( theOGRFeature, theNewGeometry ) ) != OGRERR_NONE )
- QgsLogger::warning( "QgsOgrProvider::changeGeometryValues, error while replacing geometry" );
+ QgsLogger::warning( "QgsOgrProvider::changeGeometryValues, error while replacing geometry: " + QString::number( res ) );
OGR_G_DestroyGeometry( theNewGeometry );
theNewGeometry = 0;
continue;
- OGR_L_SetFeature( ogrLayer, theOGRFeature );
+ if (( res = OGR_L_SetFeature( ogrLayer, theOGRFeature ) ) != OGRERR_NONE )
+ QgsLogger::warning( "QgsOgrProvider::changeGeometryValues, error while setting feature: " + QString::number( res ) );
+ OGR_G_DestroyGeometry( theNewGeometry );
+ theNewGeometry = 0;
+ continue;
OGR_F_Destroy( theOGRFeature );
@@ -914,7 +925,7 @@
// TODO And test appropriately.
ability |= ChangeAttributeValues;
- ability |= QgsVectorDataProvider::ChangeGeometries;
+ ability |= ChangeGeometries;
if ( OGR_L_TestCapability( ogrLayer, "FastSpatialFilter" ) )
@@ -1505,48 +1516,42 @@
void QgsOgrProvider::uniqueValues( int index, QList<QVariant> &uniqueValues )
QgsField fld = mAttributeFields[index];
- QFileInfo fi( dataSourceUri() );
- if ( !fi.exists() )
- return;
+ QString theLayerName = OGR_FD_GetName( OGR_L_GetLayerDefn( ogrLayer ) );
QString sql = QString( "SELECT DISTINCT %1 FROM %2 ORDER BY %1" )
.arg( quotedIdentifier( fld.name() ) )
- .arg( quotedIdentifier( fi.completeBaseName() ) );
+ .arg( quotedIdentifier( theLayerName ) );
uniqueValues.clear();
QgsDebugMsg( QString( "SQL: %1" ).arg( sql ) );
- OGRLayerH lyr = OGR_DS_ExecuteSQL( ogrDataSource, mEncoding->fromUnicode( sql ).data(), NULL, "SQL" );
- if ( 0 == lyr )
- return;
+ OGRLayerH l = OGR_DS_ExecuteSQL( ogrDataSource, mEncoding->fromUnicode( sql ).data(), NULL, "SQL" );
+ if ( l == 0 )
+ return QgsVectorDataProvider::uniqueValues( index, uniqueValues );
OGRFeatureH f;
- while ( 0 != ( f = OGR_L_GetNextFeature( lyr ) ) )
+ while ( 0 != ( f = OGR_L_GetNextFeature( l ) ) )
uniqueValues << convertValue( fld.type(), mEncoding->toUnicode( OGR_F_GetFieldAsString( f, 0 ) ) );
OGR_F_Destroy( f );
- OGR_DS_ReleaseResultSet( ogrDataSource, lyr );
+ OGR_DS_ReleaseResultSet( ogrDataSource, l );
QVariant QgsOgrProvider::minimumValue( int index )
- return QVariant();
QString sql = QString( "SELECT MIN(%1) FROM %2" )
if ( l == 0 )
+ return QgsVectorDataProvider::minimumValue( index );
OGRFeatureH f = OGR_L_GetNextFeature( l );
if ( f == 0 )
@@ -1566,17 +1571,15 @@
QVariant QgsOgrProvider::maximumValue( int index )
QString sql = QString( "SELECT MAX(%1) FROM %2" )
if ( l == 0 )
+ return QgsVectorDataProvider::maximumValue( index );
if ( f == 0 )
