[QGIS Commit] r10978 - trunk/qgis/src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Jun 25 10:50:32 EDT 2009
Author: mhugent
Date: 2009-06-25 10:50:31 -0400 (Thu, 25 Jun 2009)
New Revision: 10978
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgsmaptoolidentify.cpp
   trunk/qgis/src/app/qgsmaptoolidentify.h
Applied patch to fix bug #1747. Thanks to gcarrillo!
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2009-06-25 09:33:10 UTC (rev 10977)
+++ trunk/qgis/src/app/qgisapp.cpp	2009-06-25 14:50:31 UTC (rev 10978)
@@ -1662,6 +1662,9 @@
   connect( mMapLegend, SIGNAL( currentLayerChanged( QgsMapLayer* ) ),
            mMapTools.mNodeTool, SLOT( currentLayerChanged( QgsMapLayer* ) ) );
+  // connect map layer registry signal to identify
+  connect( QgsMapLayerRegistry::instance(), SIGNAL( layerWillBeRemoved( QString ) ),
+           mMapTools.mIdentify, SLOT( removeLayer( QString ) ) );
   //signal when mouse moved over window (coords display in status bar)
   connect( mMapCanvas, SIGNAL( xyCoordinates( QgsPoint & ) ), this, SLOT( showMouseCoordinate( QgsPoint & ) ) );
Modified: trunk/qgis/src/app/qgsmaptoolidentify.cpp
--- trunk/qgis/src/app/qgsmaptoolidentify.cpp	2009-06-25 09:33:10 UTC (rev 10977)
+++ trunk/qgis/src/app/qgsmaptoolidentify.cpp	2009-06-25 14:50:31 UTC (rev 10978)
@@ -46,6 +46,8 @@
   // set cursor
   QPixmap myIdentifyQPixmap = QPixmap(( const char ** ) identify_cursor );
   mCursor = QCursor( myIdentifyQPixmap, 1, 1 );
+  mLayer = 0; // Initialize mLayer, useful in removeLayer SLOT
 QgsMapToolIdentify::~QgsMapToolIdentify()
@@ -511,3 +513,22 @@
   delete ad;
   mCanvas->refresh();
+void QgsMapToolIdentify::removeLayer( QString layerID )
+  if ( mLayer )
+    if ( mLayer->type() == QgsMapLayer::VectorLayer )
+      if ( mLayer->getLayerID() == layerID )
+        if ( mResults )
+          mResults->clear();
+          delete mRubberBand;
+          mRubberBand = 0;
\ No newline at end of file
Modified: trunk/qgis/src/app/qgsmaptoolidentify.h
--- trunk/qgis/src/app/qgsmaptoolidentify.h	2009-06-25 09:33:10 UTC (rev 10977)
+++ trunk/qgis/src/app/qgsmaptoolidentify.h	2009-06-25 14:50:31 UTC (rev 10978)
@@ -112,6 +112,8 @@
     // Let us know when the QgsIdentifyResults dialog box has been closed
     void resultsDialogGone();
+    // Check if the mLayer is removing from canvas to clear the results dialog
+    void removeLayer( QString );
More information about the QGIS-commit mailing list
