[QGIS Commit] r10266 - in branches/vector_overlay_branch/src: core core/pal plugins/interpolation
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Mar 9 06:29:24 EDT 2009
Author: mhugent
Date: 2009-03-09 06:29:23 -0400 (Mon, 09 Mar 2009)
New Revision: 10266
   branches/vector_overlay_branch/src/core/pal/feature.cpp
   branches/vector_overlay_branch/src/core/pal/feature.h
   branches/vector_overlay_branch/src/core/pal/geomfunction.cpp
   branches/vector_overlay_branch/src/core/pal/labelposition.cpp
   branches/vector_overlay_branch/src/core/pal/layer.cpp
   branches/vector_overlay_branch/src/core/pal/layer.h
   branches/vector_overlay_branch/src/core/pal/pal.cpp
   branches/vector_overlay_branch/src/core/pal/pal.h
   branches/vector_overlay_branch/src/core/pal/palgeometry.h
   branches/vector_overlay_branch/src/core/pal/pointset.h
   branches/vector_overlay_branch/src/core/pal/problem.cpp
   branches/vector_overlay_branch/src/core/pal/util.cpp
   branches/vector_overlay_branch/src/core/pal/util.h
   branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.cpp
   branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.h
   branches/vector_overlay_branch/src/core/qgsmaprenderer.cpp
   branches/vector_overlay_branch/src/core/qgsoverlayobjectpositionmanager.h
   branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.cpp
   branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.h
   branches/vector_overlay_branch/src/plugins/interpolation/qgsinterpolator.cpp
   branches/vector_overlay_branch/src/plugins/interpolation/qgstininterpolator.cpp
Update of the pal classes
Modified: branches/vector_overlay_branch/src/core/pal/feature.cpp
--- branches/vector_overlay_branch/src/core/pal/feature.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/feature.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -139,7 +139,7 @@
         return uid;
-    int Feature::setPositionForPoint (double x, double y, double scale, LabelPosition ***lPos) {
+    int Feature::setPositionForPoint (double x, double y, double scale, LabelPosition ***lPos, double delta_width) {
 #ifdef _DEBUG_
         std::cout << "SetPosition (point) : " << layer->name << "/" << uid << std::endl;
@@ -151,14 +151,16 @@
         double xrm;
         double yrm;
-        if (layer->label_unit == PIXEL) {
-            xrm = px2meters (label_x, dpi, scale);
-            yrm = px2meters (label_y, dpi, scale);
-        } else {
-            xrm = label_x;
-            yrm = label_y;
+        xrm = unit_convert(label_x,
+                layer->label_unit,
+                layer->pal->map_unit,
+                dpi, scale, delta_width);
+        yrm = unit_convert(label_y,
         int nbp = layer->pal->point_p;
         //std::cout << "Nbp : " << nbp << std::endl;
@@ -174,7 +176,10 @@
         //if (nbp==2)
         //   beta = M_PI/2;
-        double distlabel = px2meters (double (this->distlabel), layer->pal->dpi, scale);
+        double distlabel = unit_convert(this->distlabel,
+                pal::PIXEL,
         double lx, ly; /* label pos */
@@ -274,22 +279,31 @@
 // TODO work with squared distance by remonving call to sqrt or dist_euc2d
-    int Feature::setPositionForLine (double scale, LabelPosition ***lPos, PointSet *mapShape) {
+    int Feature::setPositionForLine (double scale, LabelPosition ***lPos, PointSet *mapShape, double delta_width) {
 #ifdef _DEBUG_
         std::cout << "SetPosition (line) : " << layer->name << "/" << uid << std::endl;
 #endif
         int i;
         int dpi = layer->pal->dpi;
         double xrm, yrm;
-        } else {
-            xrm = label_x;
-            yrm = label_y;
+                pal::PIXEL,
         double *d; // segments lengths distance bw pt[i] && pt[i+1]
         double *ad;  // absolute distance bw pt[0] and pt[i] along the line
         double ll; // line length
@@ -311,7 +325,7 @@
         PointSet * line = mapShape;
 #ifdef _DEBUG_FULL_
-        std::cout << "New line of " << line->nbPoints << " points" << std::endl;
+        std::cout << "New line of " << line->nbPoints << " points with label " << xrm << "x" << yrm << std::endl;
 #endif
         nbPoints = line->nbPoints;
@@ -447,7 +461,7 @@
-    int Feature::setPositionForPolygon (double scale, LabelPosition ***lPos, PointSet *mapShape) {
+    int Feature::setPositionForPolygon (double scale, LabelPosition ***lPos, PointSet *mapShape, double delta_width) {
 #ifdef _DEBUG_
         std::cout << "SetPosition (polygon) : " << layer->name << "/" << uid << std::endl;
@@ -459,14 +473,16 @@
         double xrm;
         double yrm;
-            xrm = px2meters (label_x, layer->pal->dpi, scale);
-            yrm = px2meters (label_y, layer->pal->dpi, scale);
-        } else {
-            xrm = label_x;
-            yrm = label_y;
+                layer->pal->dpi, scale, delta_width);
         //print();
         //LinkedList<PointSet*> *shapes_toCut;
@@ -687,20 +703,23 @@
         bbox[1] = bbox_min[1];
         bbox[2] = bbox_max[0];
         bbox[3] = bbox_max[1];
+        double delta = bbox_max[0] - bbox_min[0];
         switch (type) {
         case GEOS_POINT:
             fetchCoordinates ();
-            nbp = setPositionForPoint (x[0], y[0], scale, lPos);
+            nbp = setPositionForPoint (x[0], y[0], scale, lPos, delta);
 #ifdef _EXPORT_MAP_
             toSVGPath (nbPoints, type, x, y, dpi , scale,
-                       convert (bbox_min[0], scale, dpi),
-                       convert (bbox_max[1], scale, dpi),
+                       convert2pt (bbox_min[0], scale, dpi),
+                       convert2pt (bbox_max[1], scale, dpi),
                        layer->name, uid, svgmap);
 #endif
             releaseCoordinates();
             break;
         case GEOS_LINESTRING:
-            nbp = setPositionForLine (scale, lPos, mapShape);
+            nbp = setPositionForLine (scale, lPos, mapShape, delta);
             break;
         case GEOS_POLYGON:
@@ -708,14 +727,14 @@
             case P_POINT:
                 double cx, cy;
                 mapShape->getCentroid (cx, cy);
-                nbp = setPositionForPoint (cx, cy, scale, lPos);
+                nbp = setPositionForPoint (cx, cy, scale, lPos, delta);
                 break;
             case P_LINE:
             case P_LINE_AROUND:
                 break;
             default:
-                nbp = setPositionForPolygon (scale, lPos, mapShape);
+                nbp = setPositionForPolygon (scale, lPos, mapShape, delta);
                 break;
Modified: branches/vector_overlay_branch/src/core/pal/feature.h
--- branches/vector_overlay_branch/src/core/pal/feature.h	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/feature.h	2009-03-09 10:29:23 UTC (rev 10266)
@@ -103,7 +103,7 @@
          * \param lPos pointer to an array of candidates, will be filled by generated candidates
          * \return the number of generated cadidates
-        int setPositionForPoint (double x, double y, double scale, LabelPosition ***lPos);
+        int setPositionForPoint (double x, double y, double scale, LabelPosition ***lPos, double delta_width);
          * \brief generate candidates for line feature
@@ -113,7 +113,7 @@
          * \param mapShape a pointer to the line
-        int setPositionForLine (double scale, LabelPosition ***lPos, PointSet *mapShape);
+        int setPositionForLine (double scale, LabelPosition ***lPos, PointSet *mapShape, double delta_width);
          * \brief generate candidates for point feature
@@ -123,7 +123,7 @@
          * \param mapShape a pointer to the polygon
-        int setPositionForPolygon (double scale, LabelPosition ***lPos, PointSet *mapShape);
+        int setPositionForPolygon (double scale, LabelPosition ***lPos, PointSet *mapShape, double delta_width);
Modified: branches/vector_overlay_branch/src/core/pal/geomfunction.cpp
--- branches/vector_overlay_branch/src/core/pal/geomfunction.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/geomfunction.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -522,9 +522,9 @@
         int i;
         if (nbPoints > 1) {
-            out << "  <path style=\"fill:none;fill-opacity:1;fill-rule:evenodd;stroke:#000000;stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke-opacity:1\" d=\"M " << convert (x[0], scale, dpi) - xmin << "," << ymax - convert (y[0], scale, dpi) << " ";
+            out << "  <path style=\"fill:none;fill-opacity:1;fill-rule:evenodd;stroke:#000000;stroke-width:1;stroke-linecap:round;stroke-linejoin:round;stroke-opacity:1\" d=\"M " << convert2pt (x[0], scale, dpi) - xmin << "," << ymax - convert2pt (y[0], scale, dpi) << " ";
             for (i = 1;i < nbPoints;i++) {
-                out << "L " << convert (x[i], scale, dpi) - xmin  << ", " << ymax - convert (y[i], scale, dpi) << " ";
+                out << "L " << convert2pt (x[i], scale, dpi) - xmin  << ", " << ymax - convert2pt (y[i], scale, dpi) << " ";
             if (geomType == GEOS_POLYGON) {
@@ -535,8 +535,8 @@
             out << "id=\"" << layername << "-" << objectID << "\" ";
             out << "inkscape:label=\"#path-" << layername << "-" << objectID << "\"/>\n";
         } else {
-            int cx = convert (x[0], scale, dpi) - xmin;
-            int cy = ymax - convert (y[0], scale, dpi);
+            int cx = convert2pt (x[0], scale, dpi) - xmin;
+            int cy = ymax - convert2pt (y[0], scale, dpi);
             out << "   <path ";
             out << "      sodipodi:type=\"arc\" ";
             out << "      style=\"opacity:1;fill:#bcbcbc;fill-opacity:l;stroke:#000000;stroke-opacity:1;stroke-width:0.5;stroke-linejoin:miter;stroke-dasharray:none;display:inline\"";
Modified: branches/vector_overlay_branch/src/core/pal/labelposition.cpp
--- branches/vector_overlay_branch/src/core/pal/labelposition.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/labelposition.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -250,10 +250,8 @@
     bool obstacleCallback (PointSet *feat, void *ctx) {
         LabelPosition::PolygonCostCalculator *pCost = (LabelPosition::PolygonCostCalculator*) ctx;
         LabelPosition *lp = pCost->getLabel();
         if ( (feat == lp->feature) || (feat->holeOf && feat->holeOf != lp->feature)) {
             return true;
@@ -261,8 +259,6 @@
         // if the feature is not a hole we have to fetch corrdinates
         // otherwise holes coordinates are still in memory (feature->selfObs)
-        // If the feature is not a hole, we have to fetch its coordinates
-        // Otherwise the feat is ahole of this polygone, oordinates have already been fetched
         if (feat->holeOf == NULL) {
             ( (Feature*) feat)->fetchCoordinates();
@@ -293,7 +289,6 @@
         feature->fetchCoordinates();
         pCost->update(feature);
-        // TODO Make a constructor
         PointSet *extent = new PointSet(4, bbx, bby);
         pCost->update(extent);
@@ -301,18 +296,18 @@
         delete extent;
         // TODO Comment
-        if (cost > (w*w + h*h) / 4.0) {
+        /*if (cost > (w*w + h*h) / 4.0) {
             double dist = sqrt (cost);
             amin[0] = (x[0] + x[2]) / 2.0 - dist;
             amin[1] = (y[0] + y[2]) / 2.0 - dist;
             amax[0] = amin[0] + 2 * dist;
             amax[1] = amin[1] + 2 * dist;
-        } else {
+        } else {*/
             amin[0] = feature->xmin;
             amin[1] = feature->ymin;
             amax[0] = feature->xmax;
             amax[1] = feature->ymax;
         //std::cout << amin[0] << " " << amin[1] << " " << amax[0] << " " <<  amax[1] << std::endl;
         obstacles->Search (amin, amax, obstacleCallback, pCost);
Modified: branches/vector_overlay_branch/src/core/pal/layer.cpp
--- branches/vector_overlay_branch/src/core/pal/layer.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/layer.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -491,7 +491,7 @@
     void Layer::setLabelUnit (Units label_unit) {
-        if (label_unit == PIXEL || label_unit == METERS)
+        if (label_unit == PIXEL || label_unit == METER)
             this->label_unit = label_unit;
Modified: branches/vector_overlay_branch/src/core/pal/layer.h
--- branches/vector_overlay_branch/src/core/pal/layer.h	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/layer.h	2009-03-09 10:29:23 UTC (rev 10266)
@@ -174,6 +174,7 @@
          * \brief set unit for label size
         void setLabelUnit (Units label_unit);
Modified: branches/vector_overlay_branch/src/core/pal/pal.cpp
--- branches/vector_overlay_branch/src/core/pal/pal.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/pal.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -62,8 +62,9 @@
     typedef struct {
         //LabelPosition *lp;
+        double scale;
+        Pal* pal;
         PointSet *obstacle;
-        double scale;
     } PruneCtx;
     void geosError (const char *fmt, ...) {
@@ -78,12 +79,9 @@
         vfprintf (stdout, fmt, list);
     Pal::Pal() {
+        initGEOS (geosNotice, geosError);
-        initGEOS (geosNotice, geosError);
         layers = new std::list<Layer*>();
         lyrsMutex = new SimpleMutex();
@@ -106,6 +104,8 @@
         line_p = 8;
         poly_p = 8;
+        this->map_unit = pal::METER;
         std::cout.precision (12);
         std::cerr.precision (12);
@@ -303,8 +303,8 @@
                         if (!svged) {
                             toSVGPath (shape->nbPoints, shape->type, shape->x, shape->y,
                                        dpi , context->scale,
-                                       convert (context->bbox_min[0], context->scale, dpi),
-                                       convert (context->bbox_max[1], context->scale, dpi),
+                                       convert2pt (context->bbox_min[0], context->scale, dpi),
+                                       convert2pt (context->bbox_max[1], context->scale, dpi),
                                        context->layer->name, ft_ptr->uid, *context->svgmap);
 #endif
@@ -322,6 +322,9 @@
                 while (feats->size() > 0) {
                     Feats *ft = feats->pop_front();
+#ifdef _DEBUG_
+                    std::cout << "Compute candidates for feat " <<  ft->feature->layer->name << "/" << ft->feature->uid << std::endl;
+#endif
                     ft->nblp = ft->feature->setPosition (context->scale, & (ft->lPos), context->bbox_min, context->bbox_max, ft->shape, context->candidates
 #ifdef _EXPORT_MAP_
                                                          , *context->svgmap
@@ -335,9 +338,12 @@
                         // valid features are added to fFeats
                         ft->priority = context->priority;
                         context->fFeats->push_back (ft);
+#ifdef _DEBUG_
+                        std::cout << ft->nblp << " labelPositions for feature : " << ft->feature->layer->name << "/" << ft->feature->uid << std::endl;
+#endif
                     } else {
                         // Others are deleted
-#ifndef _VERBOSE_
+#ifdef _VERBOSE_
                         std::cout << "Unable to generate labelPosition for feature : " << ft->feature->layer->name << "/" << ft->feature->uid << std::endl;
 #endif
                         delete[] ft->lPos;
@@ -410,6 +416,7 @@
         PointSet *feat = ( (PruneCtx*) ctx)->obstacle;
         double scale = ( (PruneCtx*) ctx)->scale;
+        Pal* pal = ( (PruneCtx*) ctx)->pal;
             return true;
@@ -426,9 +433,14 @@
         //((Feature*)feat)->fetchCoordinates();
         double dist;
-        double distlabel = px2meters (double (lp->feature->distlabel), lp->feature->layer->pal->dpi, scale);
+        double distlabel = unit_convert(double(lp->feature->distlabel),
+                pal::PIXEL,
+                pal->map_unit,
+                pal->dpi, scale, 1);
         switch (feat->type) {
             //case geos::geom::GEOS_POINT:
         case GEOS_POINT:
@@ -528,12 +540,14 @@
     typedef struct _filterContext {
         RTree<LabelPosition*, double, 2, double> *cdtsIndex;
         double scale;
+        Pal* pal;
     } FilterContext;
     bool filteringCallback (PointSet *pset, void *ctx) {
         RTree<LabelPosition*, double, 2, double> *cdtsIndex = ( (FilterContext*) ctx)->cdtsIndex;
         double scale = ( (FilterContext*) ctx)->scale;
+        Pal* pal = ((FilterContext*)ctx)->pal;
         if (pset->holeOf == NULL) {
             ( (Feature*) pset)->fetchCoordinates();
@@ -552,6 +566,7 @@
         pruneContext.scale = scale;
         pruneContext.obstacle = pset;
+        pruneContext.pal = pal;
         cdtsIndex->Search (amin, amax, pruneLabelPositionCallback, (void*) &pruneContext);
@@ -727,6 +742,7 @@
         FilterContext filterCtx;
         filterCtx.cdtsIndex = prob->candidates;
         filterCtx.scale = prob->scale;
+        filterCtx.pal = this;
         obstacles->Search (amin, amax, filteringCallback, (void*) &filterCtx);
@@ -960,8 +976,8 @@
         << "xmlns=\"http://www.w3.org/2000/svg\"" << std::endl
         << "xmlns:sodipodi=\"http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd\"" << std::endl
         << "xmlns:inkscape=\"http://www.inkscape.org/namespaces/inkscape\"" << std::endl
-        << "width=\"" << convert (bbox[2] - bbox[0], scale, dpi)  << "\"" << std::endl
-        << "height=\"" << convert (bbox[3] - bbox[1], scale, dpi)  << "\">" << std::endl; // TODO xmax ymax
+        << "width=\"" << convert2pt (bbox[2] - bbox[0], scale, dpi)  << "\"" << std::endl
+        << "height=\"" << convert2pt (bbox[3] - bbox[1], scale, dpi)  << "\">" << std::endl; // TODO xmax ymax
 #endif
         // First, extract the problem
@@ -1153,5 +1169,25 @@
+     * \brief get current map unit
+    Units Pal::getMapUnit(){
+       return map_unit;
+     * \brief set map unit
+    void Pal::setMapUnit(Units map_unit){
+       if (map_unit == pal::PIXEL || map_unit == pal::METER
+            || map_unit == pal::FOOT || map_unit == pal::DEGREE){
+          this->map_unit = map_unit;
 } // namespace pal
Modified: branches/vector_overlay_branch/src/core/pal/pal.h
--- branches/vector_overlay_branch/src/core/pal/pal.h	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/pal.h	2009-03-09 10:29:23 UTC (rev 10266)
@@ -64,8 +64,10 @@
     /** Units for label sizes and distlabel */
     enum _Units {
-        PIXEL = 0, /**< pixel*/
-        METERS = 1 /**< meters [m]*/
+        PIXEL = 0, /**< pixel [px]*/
+        METER, /**< meter [m]*/
+        FOOT, /**< foot [ft]*/
+        DEGREE /**< degree [°] */
     /** Typedef for _Units enumeration */
@@ -121,6 +123,8 @@
         // TODO remove after tests !!!
         clock_t tmpTime;
+        Units map_unit;
          * \brief maximum # candidates for a point
@@ -236,7 +240,6 @@
         ~Pal();
          * \brief add a new layer
@@ -374,8 +377,17 @@
         int getPolyP ();
+        Units getMapUnit();
+        void setMapUnit(Units map_unit);
          * \brief Select the search method to use.
          * For interactive mapping using CHAIN is a good
Modified: branches/vector_overlay_branch/src/core/pal/palgeometry.h
--- branches/vector_overlay_branch/src/core/pal/palgeometry.h	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/palgeometry.h	2009-03-09 10:29:23 UTC (rev 10266)
@@ -5,23 +5,23 @@
  *                      University of Applied Sciences, Western Switzerland
  *                      http://www.hes-so.ch
- *   Contact:
+ *   Contact:
  *      maxence.laurent <at> heig-vd <dot> ch
  *    or
  *      eric.taillard <at> heig-vd <dot> ch
  * This file is part of libpal.
  * libpal is free software: you can redistribute it and/or modify
  * it under the terms of the GNU General Public License as published by
  * the Free Software Foundation, either version 3 of the License, or
  * (at your option) any later version.
  * libpal is distributed in the hope that it will be useful,
  * but WITHOUT ANY WARRANTY; without even the implied warranty of
  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  * GNU General Public License for more details.
  * You should have received a copy of the GNU General Public License
  * along with libpal.  If not, see <http://www.gnu.org/licenses/>.
@@ -34,54 +34,54 @@
 #include <pal/label.h>
 #include <geos_c.h>
-namespace pal{
+namespace pal {
- * \brief Interface that allow Pal to acces user's geometries
-class PalGeometry {
-public:
-    * \brief get the geometry in WKB hexa format
-    * This method is called by Pal each time it needs a geom's coordinates
-    * @return WKB Hex buffer
-   //virtual char * getWkbHexBuffer() = 0;
-    * \brief get the GEOSGeometry of the feature
-    * @return GEOSGeometry * a pointer the the geos geom
-   virtual GEOSGeometry* getGeosGeometry() = 0;
+     * \brief Interface that allow Pal to acces user's geometries
+    class PalGeometry {
+    public:
+         * \brief get the geometry in WKB hexa format
+         * This method is called by Pal each time it needs a geom's coordinates
+         * @return WKB Hex buffer
+        //virtual char * getWkbHexBuffer() = 0;
+         * \brief get the GEOSGeometry of the feature
+         * @return GEOSGeometry * a pointer the the geos geom
+        virtual GEOSGeometry* getGeosGeometry() = 0;
-    * \brief Called by Pal when it doesn't need the coordinates anymore
-    * @param the_geom is the geoms geom  from PalGeometry::getfeomGeometry()
-   virtual void releaseGeosGeometry(GEOSGeometry *the_geom) = 0;
-    * @param wkbBuffer is the WkbBuffer from PalGeometry::getWkbHexBuffer()
-   //virtual void releaseWkbHexBuffer(char *wkbBuffer) = 0;
+         * \brief Called by Pal when it doesn't need the coordinates anymore
+         * @param the_geom is the geoms geom  from PalGeometry::getfeomGeometry()
+        virtual void releaseGeosGeometry (GEOSGeometry *the_geom) = 0;
-    * \brief Give back a label to display
-    * Pal call this method when label will no move anymore.
-    * @param label the label to disploy
-   //virtual void addLabel(Label *label) = 0;
-   virtual ~PalGeometry(){}
+         * @param wkbBuffer is the WkbBuffer from PalGeometry::getWkbHexBuffer()
+        //virtual void releaseWkbHexBuffer(char *wkbBuffer) = 0;
+         * \brief Give back a label to display
+         * Pal call this method when label will no move anymore.
+         * @param label the label to disploy
+        //virtual void addLabel(Label *label) = 0;
+        virtual ~PalGeometry() {}
 } // end namespace pal
 #endif
Modified: branches/vector_overlay_branch/src/core/pal/pointset.h
--- branches/vector_overlay_branch/src/core/pal/pointset.h	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/pointset.h	2009-03-09 10:29:23 UTC (rev 10266)
@@ -90,6 +90,7 @@
         friend class Pal;
         friend class Layer;
         friend class LabelPosition;
+        friend class PolygonCostCalculator;
         friend class Problem;
         friend bool pruneLabelPositionCallback (LabelPosition *lp, void *ctx);
         //friend Feat *splitButterflyPolygon (Feat *f, int pt_a, int pt_b, double cx, double cy);
@@ -100,30 +101,28 @@
         friend void releaseAllInIndex (RTree<PointSet*, double, 2, double> *obstacles);
         friend bool releaseCallback (PointSet *pset, void *ctx);
         friend bool filteringCallback (PointSet*, void*);
-    public:
+    protected:
         int nbPoints;
         double *x;
         double *y;   // points order is counterclockwise
-		int type;
-	protected:
         int *status;   // -1 means inside the bbox, +1 means outside and 0 is either in either out
         int *cHull;
         int cHullSize;
+        int type;
         //PointSet *parent;
         PointSet* holeOf;
         PointSet* parent;
-public:
         PointSet (double x, double y);
         PointSet (PointSet &ps);
+//public:
         double xmin;
         double xmax;
         double ymin;
Modified: branches/vector_overlay_branch/src/core/pal/problem.cpp
--- branches/vector_overlay_branch/src/core/pal/problem.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/problem.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -43,6 +43,7 @@
 #include <cfloat>
 #include <ctime>
 #include <list>
+#include <limits.h> //for INT_MAX
 #include <pal/pal.h>
 #include <pal/palstat.h>
@@ -58,8 +59,8 @@
 #include "util.h"
 #include "priorityqueue.h"
-#include <limits.h>
 namespace pal {
     inline void delete_chain (Chain *chain) {
@@ -3044,7 +3045,7 @@
         for (i = 0;i < nbft;i++) {
             if (sol->s[i] >= 0) {
                 LabelPosition *lp = labelpositions[sol->s[i]];
-                toSVGPath (4, 3, lp->x, lp->y, pal->getDpi(), scale, convert (bbox[0], scale, pal->getDpi()), convert (bbox[3], scale, pal->getDpi()), "label", lp->feature->uid, svgmap);
+                toSVGPath (4, 3, lp->x, lp->y, pal->getDpi(), scale, convert2pt (bbox[0], scale, pal->getDpi()), convert2pt (bbox[3], scale, pal->getDpi()), "label", lp->feature->uid, svgmap);
Modified: branches/vector_overlay_branch/src/core/pal/util.cpp
--- branches/vector_overlay_branch/src/core/pal/util.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/util.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -352,6 +352,7 @@
         f->minmax[3] = ymax;
+        // TODO make a function with that and add simplify() process
         int new_nbPoints = f->nbPoints;
         bool *ok = new bool[new_nbPoints];
Modified: branches/vector_overlay_branch/src/core/pal/util.h
--- branches/vector_overlay_branch/src/core/pal/util.h	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/pal/util.h	2009-03-09 10:29:23 UTC (rev 10266)
@@ -39,6 +39,8 @@
 #include <stddef.h>
 #include <geos_c.h>
+#include <pal/pal.h>
 #include "rtree.hpp"
 #include "pointset.h"
@@ -78,9 +80,6 @@
     LinkedList<Feat*> * splitGeom (GEOSGeometry *the_geom, const char *geom_id);
     typedef struct _feats {
         Feature *feature;
         PointSet *shape;
@@ -116,18 +115,91 @@
     inline double vabs (double x)
     { return x >= 0 ? x : -x; }
-    inline double px2meters (double x, int dpi, double scale)
-    { return ( (x / double (dpi)) * 0.0254) * scale; }
+    inline double degree2meter (double delta_deg){
+        double lat = delta_deg*0.5;
+        const static double rads = (4.0*atan(1.0))/180.0;
+        double a = cos(lat*rads);
+        a = a*a;
+        double c = 2.0*atan2(sqrt(a), sqrt(1.0 - a));
+        const static double ra = 6378000; // [m]
+        const static double e = 0.0810820288;
+        double radius = ra*(1.0 - e*e) / pow(1.0 - e*e*sin(lat*rads)*sin(lat*rads ), 1.5 );
+        double meters = (delta_deg) / 180.0 * radius * c; // [m]
+        return meters;
+    inline double unit_convert (double x, Units from, Units to, int dpi, double scale, double delta_canvas_width)
+        /* nothing to convert */
+        if (from == to){
+            return x;
+        switch (from){
+            case pal::PIXEL:
+                switch (to){
+                    case pal::METER:
+                        return ((x / double (dpi)) * 0.0254) * scale;
+                    case pal::FOOT:
+                        return ((x / double (dpi))*12) * scale;
+                    case pal::DEGREE:
+                        double iw = degree2meter(delta_canvas_width)*39.3700787;
+                        return (x * delta_canvas_width * scale) / (iw * dpi);
+                break;
+            case pal::METER:
+                switch (to){
+                    case pal::PIXEL:
+                        return (x*dpi)/(2.54*scale);
+                    case pal::FOOT:
+                        return x/0.3048;
+                    case pal::DEGREE:
+                        double mw = degree2meter(delta_canvas_width);
+                        return (x * delta_canvas_width) / mw;
+                break;
+            case pal::FOOT:
+                switch (to){
+                    case pal::PIXEL:
+                        return (x*dpi)/(12*scale);
+                    case pal::METER:
+                        return x*0.3048;
+                    case pal::DEGREE:
+                        return (x * delta_canvas_width) / iw;
+                break;
+            case pal::DEGREE:
+                switch (to){
+                    case pal::PIXEL:
+                        fprintf (stderr, "Degree to pixel not yet implemented");
+                        break;
+                    case pal::METER:
+                        fprintf (stderr, "Degree to meter not yet implemented");
+                        break;
+                    case pal::FOOT:
+                        fprintf (stderr, "Degree to foot not yet implemented");
+                        break;
+                break;
+        fprintf (stderr, "Unable to convert. Unknown units");
+        return 0.0;
     /* From meters to PostScript Point */
-    inline void convert (int *x, double scale, int dpi) {
+    inline void convert2pt (int *x, double scale, int dpi) {
         *x = (int) ( ( (double) * x / scale) * 39.3700787402 * dpi + 0.5);
-    inline int convert (double x, double scale, int dpi) {
+    inline int convert2pt (double x, double scale, int dpi) {
         return (int) ( (x / scale) * 39.3700787402 * dpi + 0.5);
Modified: branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.cpp
--- branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -41,7 +41,7 @@
   mOverlays.clear();
-void QgsCentralPointPositionManager::findObjectPositions(const QgsRenderContext& context)
+void QgsCentralPointPositionManager::findObjectPositions(const QgsRenderContext& context, QGis::UnitType unitType)
   QList<QgsVectorOverlay*>::iterator overlay_it = mOverlays.begin();
   QgsVectorOverlay* currentOverlay = 0;
Modified: branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.h
--- branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.h	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/qgscentralpointpositionmanager.h	2009-03-09 10:29:23 UTC (rev 10266)
@@ -33,7 +33,7 @@
   void addLayer(QgsVectorLayer* vl, QList<QgsVectorOverlay*>& overlays);
   /**Removes all the overlays*/
   void removeLayers();
-  void findObjectPositions(const QgsRenderContext& context);
+  void findObjectPositions(const QgsRenderContext& context, QGis::UnitType unitType);
  private:
   /**Calculates the central point for points/lines/polygons. Returns 0 in case of success*/
Modified: branches/vector_overlay_branch/src/core/qgsmaprenderer.cpp
--- branches/vector_overlay_branch/src/core/qgsmaprenderer.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/qgsmaprenderer.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -461,7 +461,7 @@
   //find overlay positions and draw the vector overlays
   if(overlayManager && allOverlayList.size() > 0)
-    overlayManager->findObjectPositions(mRenderContext);
+    overlayManager->findObjectPositions(mRenderContext, mScaleCalculator->mapUnits());
     //draw all the overlays
     QList<QgsVectorOverlay*>::iterator allOverlayIt = allOverlayList.begin();
     for(; allOverlayIt != allOverlayList.end(); ++allOverlayIt)
Modified: branches/vector_overlay_branch/src/core/qgsoverlayobjectpositionmanager.h
--- branches/vector_overlay_branch/src/core/qgsoverlayobjectpositionmanager.h	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/qgsoverlayobjectpositionmanager.h	2009-03-09 10:29:23 UTC (rev 10266)
@@ -19,6 +19,7 @@
 #define QGSOVERLAYOBJECTPOSITIONMANAGER_H
 #include <QList>
+#include "qgis.h"
 class QgsRenderContext;
 class QgsVectorLayer;
@@ -34,8 +35,10 @@
   virtual void addLayer(QgsVectorLayer* vl, QList<QgsVectorOverlay*>& overlays) = 0;
   /**Removes all the layers*/
   virtual void removeLayers() = 0;
-  /**Calculate positions for the overlay objects*/
-  virtual void findObjectPositions(const QgsRenderContext& context) = 0;
+  /**Calculate positions for the overlay objects
+    @param context Context of rendering operation (Painter, scale factor)
+    @param unitType meters, feet, degrees*/
+  virtual void findObjectPositions(const QgsRenderContext& context, QGis::UnitType unitType) = 0;
 #endif
Modified: branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.cpp
--- branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -92,12 +92,31 @@
-void QgsPALObjectPositionManager::findObjectPositions(const QgsRenderContext& renderContext)
+void QgsPALObjectPositionManager::findObjectPositions(const QgsRenderContext& renderContext, QGis::UnitType unitType)
   //trigger label placement
   QgsRectangle viewExtent = renderContext.extent();
   double bbox[4]; bbox[0] = viewExtent.xMinimum(); bbox[1] = viewExtent.yMinimum(); bbox[2] = viewExtent.xMaximum(); bbox[3] = viewExtent.yMaximum();
   pal::PalStat* stat = 0;
+  //set map units
+  pal::Units mapUnits;
+  switch (unitType)
+    case QGis::Meters:
+      mapUnits = pal::METER;
+      break;
+    case QGis::Feet:
+      mapUnits = pal::FOOT;
+      break;
+    case QGis::Degrees:
+      mapUnits = pal::DEGREE;
+      break;
+  mPositionEngine.setMapUnit(mapUnits);
   qWarning("**********************************starting calculation of overlay positions*****************************");
   std::list<pal::Label*>* resultLabelList = mPositionEngine.labeller(renderContext.rendererScale(), bbox, &stat, true);
   qWarning("**********************************calculation of overlay positions finished*****************************");
Modified: branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.h
--- branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.h	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/core/qgspalobjectpositionmanager.h	2009-03-09 10:29:23 UTC (rev 10266)
@@ -27,7 +27,7 @@
     QgsPALObjectPositionManager();
     ~QgsPALObjectPositionManager();
-    void findObjectPositions(const QgsRenderContext& renderContext);
+    void findObjectPositions(const QgsRenderContext& renderContext, QGis::UnitType unitType);
     /**Sets algorithm used for object placements. Possibilities are:
Modified: branches/vector_overlay_branch/src/plugins/interpolation/qgsinterpolator.cpp
--- branches/vector_overlay_branch/src/plugins/interpolation/qgsinterpolator.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/plugins/interpolation/qgsinterpolator.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -18,6 +18,7 @@
 #include "qgsinterpolator.h"
 #include "qgsvectordataprovider.h"
 #include "qgsgeometry.h"
+#include <cmath>
 QgsInterpolator::QgsInterpolator( const QList<QgsVectorLayer*>& vlayers ): mDataIsCached( false ), mVectorLayers( vlayers ), zCoordInterpolation( false ), mValueAttribute( -1 )
@@ -76,6 +77,7 @@
     QgsFeature theFeature;
     double attributeValue = 0.0;
+    bool attributeConversionOk = false;
     while ( provider->nextFeature( theFeature ) )
       if ( !zCoordInterpolation )
@@ -86,7 +88,11 @@
           return 3;
-        attributeValue = att_it.value().toDouble();
+        attributeValue = att_it.value().toDouble(&attributeConversionOk);
+	if(!attributeConversionOk || isnan(attributeValue)) //don't consider vertices with attributes like 'nan' for the interpolation
+          continue;
       if ( addVerticesToCache( theFeature.geometry(), attributeValue ) != 0 )
Modified: branches/vector_overlay_branch/src/plugins/interpolation/qgstininterpolator.cpp
--- branches/vector_overlay_branch/src/plugins/interpolation/qgstininterpolator.cpp	2009-03-09 00:20:39 UTC (rev 10265)
+++ branches/vector_overlay_branch/src/plugins/interpolation/qgstininterpolator.cpp	2009-03-09 10:29:23 UTC (rev 10266)
@@ -65,6 +65,20 @@
   DualEdgeTriangulation* theDualEdgeTriangulation = new DualEdgeTriangulation( mCachedBaseData.size(), 0 );
   mTriangulation = theDualEdgeTriangulation;
+   //do some randomisation on the base data to have better results with regular structures
+    vertexData vertex1, vertex2;
+    for(int i = 0; i <= mCachedBaseData.size() / 2; ++i)
+        vertex1 = mCachedBaseData[i];
+        Point3D* thePoint1 = new Point3D( vertex1.x, vertex1.y, vertex1.z );
+        mTriangulation->addPoint( thePoint1 );
+        vertex2 = mCachedBaseData[mCachedBaseData.size() - 1 - i];
+        Point3D* thePoint2 = new Point3D( vertex2.x, vertex2.y, vertex2.z );
+        mTriangulation->addPoint( thePoint2 );
+#if 0
   //add all the vertices to the triangulation
   QVector<vertexData>::const_iterator vertex_it = mCachedBaseData.constBegin();
   for ( ; vertex_it != mCachedBaseData.constEnd(); ++vertex_it )
@@ -72,6 +86,7 @@
     Point3D* thePoint = new Point3D( vertex_it->x, vertex_it->y, vertex_it->z );
     mTriangulation->addPoint( thePoint );
+#endif //0
   mTriangleInterpolator = new LinTriangleInterpolator( theDualEdgeTriangulation );
More information about the QGIS-commit mailing list
