[QGIS Commit] r10271 - trunk/qgis/src/core/raster
    svn_qgis at osgeo.org
    Wed Mar 11 18:32:49 EDT 2009
Author: ersts
Date: 2009-03-11 18:32:49 -0400 (Wed, 11 Mar 2009)
New Revision: 10271
   trunk/qgis/src/core/raster/qgscolorrampshader.cpp
-Fixed issue with color ramp shader and doubles
-Closes ticket #1497
Modified: trunk/qgis/src/core/raster/qgscolorrampshader.cpp
--- trunk/qgis/src/core/raster/qgscolorrampshader.cpp	2009-03-11 11:30:27 UTC (rev 10270)
+++ trunk/qgis/src/core/raster/qgscolorrampshader.cpp	2009-03-11 22:32:49 UTC (rev 10271)
@@ -17,11 +17,14 @@
  *   (at your option) any later version.                                   *
+#define REALLY_SMALL 0.0000001
 #include "qgslogger.h"
 #include "qgscolorrampshader.h"
+#include <math.h>
 QgsColorRampShader::QgsColorRampShader( double theMinimumValue, double theMaximumValue ) : QgsRasterShaderFunction( theMinimumValue, theMaximumValue )
   QgsDebugMsg( "called." );
@@ -54,17 +57,19 @@
     return false;
+  double myTinyDiff = 0.0;
   QgsColorRampShader::ColorRampItem myColorRampItem;
   while ( mCurrentColorRampItemIndex >= 0 && mCurrentColorRampItemIndex < myColorRampItemCount )
     //Start searching from the last index - assumtion is that neighboring pixels tend to be similar values
     myColorRampItem = mColorRampItemList.value( mCurrentColorRampItemIndex );
+    myTinyDiff = fabs( theValue - myColorRampItem.value );
     //If the previous entry is less, then search closer to the top of the list (assumes mColorRampItemList is sorted)
     if ( mCurrentColorRampItemIndex != 0 && theValue <= mColorRampItemList.at( mCurrentColorRampItemIndex - 1 ).value )
       mCurrentColorRampItemIndex--;
-    else if ( theValue <= myColorRampItem.value )
+    else if ( theValue <= myColorRampItem.value || myTinyDiff <= REALLY_SMALL )
       *theReturnRedValue = myColorRampItem.color.red();
       *theReturnGreenValue = myColorRampItem.color.green();
@@ -94,12 +99,14 @@
     return false;
-    if ( theValue == myColorRampItem.value )
+    if ( theValue == myColorRampItem.value || myTinyDiff <= REALLY_SMALL )
@@ -133,13 +140,13 @@
 bool QgsColorRampShader::interpolatedColor( double theValue, int* theReturnRedValue, int* theReturnGreenValue, int* theReturnBlueValue )
   int myColorRampItemCount = mColorRampItemList.count();
   if ( myColorRampItemCount <= 0 )
     return false;
   double myCurrentRampRange; //difference between two consecutive entry values
   double myOffsetInRange; //difference between the previous entry value and value
@@ -147,12 +154,13 @@
-    else if ( mCurrentColorRampItemIndex != 0 && theValue <= myColorRampItem.value )
+    else if ( mCurrentColorRampItemIndex != 0 && ( theValue <= myColorRampItem.value || myTinyDiff <= REALLY_SMALL ) )
       QgsColorRampShader::ColorRampItem myPreviousColorRampItem = mColorRampItemList.value( mCurrentColorRampItemIndex - 1 );
       myCurrentRampRange = myColorRampItem.value - myPreviousColorRampItem.value;
