[QGIS Commit] r10282 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Mar 16 06:37:33 EDT 2009
Author: pcav
Date: 2009-03-16 06:37:33 -0400 (Mon, 16 Mar 2009)
New Revision: 10282
Added:
   trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.1.png
   trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.2.png
   trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.loc.1.png
   trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.loc.2.png
   trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.loc.qgm
   trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.qgm
   trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.1.svg
   trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.2.png
   trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.loc.1.svg
   trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.loc.2.png
   trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.loc.qgm
   trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.qgm
New GRASS modules to convert loaded rasters and vectors - thanks John C. Tull
Added: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.1.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.1.png
___________________________________________________________________
   + application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.2.png
Added: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.loc.1.png
Property changes on: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.loc.1.png
Added: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.loc.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.loc.2.png
Added: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.loc.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.loc.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.loc.qgm	2009-03-16 10:37:33 UTC (rev 10282)
@@ -0,0 +1,10 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Import loaded raster and create a fitted location" module="r.in.gdal">
+	<flag key="o" answer="off" hidden="yes" />
+	<flag key="e" answer="on" hidden="yes" />
+    <gdal key="input" label="GDAL raster layer" />
+    <option key="output" />
+	<option key="location" />
+</qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules/r.in.gdal.qgis.qgm	2009-03-16 10:37:33 UTC (rev 10282)
@@ -0,0 +1,9 @@
+<qgisgrassmodule label="Import loaded raster" module="r.in.gdal">
+	<flag key="o" answer="on" hidden="yes" />
+	<flag key="e" answer="off" hidden="yes" />
+</qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.1.svg
--- trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.1.svg	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.1.svg	2009-03-16 10:37:33 UTC (rev 10282)
@@ -0,0 +1,8 @@
+<?xml version="1.0" standalone="no"?>
+<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 20001102//EN" "http://www.w3.org/TR/2000/CR-SVG-20001102/DTD/svg-20001102.dtd">
+<svg xmlns="http://www.w3.org/2000/svg" width="500" x="0" y="0" height="500" id="/hardmnt/janacek0/ssi/blazek/inst/qgis/cvs/plugins/grass/modules/r.to.vect.line.2" >
+ <rect width="500" x="0" y="0" height="500" style="stroke:rgb(0,0,0);stroke-width:0;fill:rgb(255,255,255);" />
+ <g style="stroke:rgb(0,0,0);stroke-width:0.9;fill:none;" >
+  <line transform="translate(0.331263 0.331263)" style="stroke:rgb(0,0,0);stroke-width:15;fill:rgb(220,220,220);" y1="401" y2="96" x1="94" x2="399" />
+ </g>
+</svg>
Added: trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.2.png
Added: trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.loc.1.svg
--- trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.loc.1.svg	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.loc.1.svg	2009-03-16 10:37:33 UTC (rev 10282)
@@ -0,0 +1,8 @@
+ </g>
+</svg>
Added: trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.loc.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.loc.2.png
Added: trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.loc.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.loc.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.loc.qgm	2009-03-16 10:37:33 UTC (rev 10282)
@@ -0,0 +1,11 @@
+<qgisgrassmodule label="Import loaded vector and create a fitted location" module="v.in.ogr">
+	<flag key="z" answer="off" hidden="no" />
+    <ogr key="dsn" layeroption="layer" whereoption="where" label="OGR vector layer" />
+	<option key="type" />
+</qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.qgm
--- trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules/v.in.ogr.qgis.qgm	2009-03-16 10:37:33 UTC (rev 10282)
@@ -0,0 +1,11 @@
+<qgisgrassmodule label="Import loaded vector" module="v.in.ogr">
+	<flag key="e" answer="off" hidden="no" />
+</qgisgrassmodule>
More information about the QGIS-commit mailing list
