[QGIS Commit] r10288 - trunk/qgis/cmake
svn_qgis at osgeo.org
Tue Mar 17 07:42:51 EDT 2009
Author: timlinux
Date: 2009-03-17 07:42:50 -0400 (Tue, 17 Mar 2009)
New Revision: 10288
trunk/qgis/cmake/FindGDAL.cmake
trunk/qgis/cmake/FindGEOS.cmake
trunk/qgis/cmake/FindPostgres.cmake
trunk/qgis/cmake/FindSqlite3.cmake
Tweaks to make cmake find the sqlite3, pq, gdal and geos dependencies when using LIB_DIR and osgeo4w dependencies
Modified: trunk/qgis/cmake/FindGDAL.cmake
--- trunk/qgis/cmake/FindGDAL.cmake 2009-03-16 14:22:45 UTC (rev 10287)
+++ trunk/qgis/cmake/FindGDAL.cmake 2009-03-17 11:42:50 UTC (rev 10288)
@@ -22,10 +22,13 @@
"$ENV{LIB_DIR}/include/gdal"
CACHE STRING INTERNAL
- SET (
- GDAL_LIBRARY
- "$ENV{LIB_DIR}/lib/gdal.lib";odbc32;odbccp32
- CACHE STRING INTERNAL)
+ FIND_LIBRARY(GDAL_LIBRARY NAMES gdal gdal_i PATHS
+ "$ENV{LIB_DIR}/lib" /usr/lib c:/msys/local/lib)
+ IF (GDAL_LIBRARY)
+ SET (
+ GDAL_LIBRARY;odbc32;odbccp32
+ CACHE STRING INTERNAL)
+ ENDIF (GDAL_LIBRARY)
ENDIF (MSVC)
Modified: trunk/qgis/cmake/FindGEOS.cmake
--- trunk/qgis/cmake/FindGEOS.cmake 2009-03-16 14:22:45 UTC (rev 10287)
+++ trunk/qgis/cmake/FindGEOS.cmake 2009-03-17 11:42:50 UTC (rev 10288)
@@ -21,10 +21,18 @@
"$ENV{LIB_DIR}/include"
- SET (
- GEOS_LIBRARY
- "$ENV{LIB_DIR}/lib/geos_c.lib";odbc32;odbccp32
+ FIND_LIBRARY(GEOS_LIBRARY NAMES geos geos_c_i PATHS
+ #mingw
+ c:/msys/local/lib
+ NO_DEFAULT_PATH
+ IF (GEOS_LIBRARY)
+ SET (
+ GEOS_LIBRARY
+ GEOS_LIBRARY;odbc32;odbccp32
+ ENDIF (GEOS_LIBRARY)
ENDIF (MSVC)
ELSE(WIN32)
Modified: trunk/qgis/cmake/FindPostgres.cmake
--- trunk/qgis/cmake/FindPostgres.cmake 2009-03-16 14:22:45 UTC (rev 10287)
+++ trunk/qgis/cmake/FindPostgres.cmake 2009-03-17 11:42:50 UTC (rev 10288)
@@ -16,11 +16,12 @@
/usr/include
c:/msys/local/include
"$ENV{LIB_DIR}/include/postgresql"
+ "$ENV{LIB_DIR}/include"
ENDIF (NOT POSTGRES_INCLUDE_DIR)
IF (NOT POSTGRES_LIBRARY)
- FIND_LIBRARY(POSTGRES_LIBRARY NAMES pq libpq PATHS
+ FIND_LIBRARY(POSTGRES_LIBRARY NAMES pq libpq libpqdll PATHS
/usr/local/lib
/usr/lib
c:/msys/local/lib
@@ -61,13 +62,11 @@
IF (POSTGRES_INCLUDE_DIR AND POSTGRES_LIBRARY)
SET(POSTGRES_FOUND TRUE)
IF(EXISTS "${POSTGRES_INCLUDE_DIR}/pg_config.h")
SET(HAVE_PGCONFIG TRUE)
ELSE(EXISTS "${POSTGRES_INCLUDE_DIR}/pg_config.h")
SET(HAVE_PGCONFIG FALSE)
ENDIF(EXISTS "${POSTGRES_INCLUDE_DIR}/pg_config.h")
ENDIF (POSTGRES_INCLUDE_DIR AND POSTGRES_LIBRARY)
Modified: trunk/qgis/cmake/FindSqlite3.cmake
--- trunk/qgis/cmake/FindSqlite3.cmake 2009-03-16 14:22:45 UTC (rev 10287)
+++ trunk/qgis/cmake/FindSqlite3.cmake 2009-03-17 11:42:50 UTC (rev 10288)
@@ -22,7 +22,7 @@
FIND_PATH(SQLITE3_INCLUDE_DIR sqlite3.h)
-FIND_LIBRARY(SQLITE3_LIBRARY NAMES sqlite3 PATHS
+FIND_LIBRARY(SQLITE3_LIBRARY NAMES sqlite3 sqlite3_i PATHS
"$ENV{LIB_DIR}/lib"
#mingw
c:/msys/local/lib
