[QGIS Commit] r10311 - in branches/analysis_branch/tests/src: . analysis
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Mar 19 14:58:17 EDT 2009
Author: timlinux
Date: 2009-03-19 14:58:17 -0400 (Thu, 19 Mar 2009)
New Revision: 10311
Added:
   branches/analysis_branch/tests/src/analysis/
   branches/analysis_branch/tests/src/analysis/CMakeLists.txt
   branches/analysis_branch/tests/src/analysis/testqgsvectoranalyzer.cpp
   branches/analysis_branch/tests/src/CMakeLists.txt
Added stub unit test for vector analysis
Modified: branches/analysis_branch/tests/src/CMakeLists.txt
--- branches/analysis_branch/tests/src/CMakeLists.txt	2009-03-19 18:35:46 UTC (rev 10310)
+++ branches/analysis_branch/tests/src/CMakeLists.txt	2009-03-19 18:58:17 UTC (rev 10311)
@@ -1,4 +1,5 @@
 IF (ENABLE_TESTS)
   SUBDIRS(core)
   SUBDIRS(gui)
+  SUBDIRS(analysis)
 ENDIF (ENABLE_TESTS)
Added: branches/analysis_branch/tests/src/analysis/CMakeLists.txt
--- branches/analysis_branch/tests/src/analysis/CMakeLists.txt	                        (rev 0)
+++ branches/analysis_branch/tests/src/analysis/CMakeLists.txt	2009-03-19 18:58:17 UTC (rev 10311)
@@ -0,0 +1,110 @@
+# Standard includes and utils to compile into all tests.
+SET (util_SRCS ../core/qgsrenderchecker.cpp)
+# Don't forget to include output directory, otherwise
+# the UI file won't be wrapped!
+INCLUDE_DIRECTORIES(${CMAKE_CURRENT_SOURCE_DIR}
+  ${CMAKE_CURRENT_BINARY_DIR}
+  ${CMAKE_CURRENT_SOURCE_DIR}/../../../src/analysis/vector
+  ${QT_INCLUDE_DIR}
+  ${GDAL_INCLUDE_DIR}
+  ${PROJ_INCLUDE_DIR}
+  ${GEOS_INCLUDE_DIR}
+# Compiler defines
+# expect that classes are being IMPORTED for the tests
+IF (WIN32)
+  # expect that classes are being imported
+  # Note: MSVC doesn't like when the macros are quotes
+  # and MSYS doesn't like them unqouted (bacause of braces)
+  IF (MSVC)
+    ADD_DEFINITIONS("-DCORE_EXPORT=__declspec(dllimport)")
+    ADD_DEFINITIONS("-DANALYzer_EXPORT=__declspec(dllimport)")
+    #ADD_DEFINITIONS("-DPLUGIN_EXPORT=__declspec(dllimport)")
+    #next needed for qgis gui includes
+    ADD_DEFINITIONS("-DGUI_EXPORT=__declspec(dllexport)")
+  ELSE (MSVC)
+    ADD_DEFINITIONS("-UCORE_EXPORT \"-DCORE_EXPORT=__declspec(dllimport)\"")
+    ADD_DEFINITIONS("-UANALYzer_EXPORT \"-DCORE_EXPORT=__declspec(dllimport)\"")
+    #ADD_DEFINITIONS("\"-DPLUGIN_EXPORT=__declspec(dllimport)\"")
+    ADD_DEFINITIONS("-UGUI_EXPORT \"-DGUI_EXPORT=__declspec(dllexport)\"")
+  ENDIF (MSVC)
+ENDIF (WIN32)
+# This define is used for tests that need to locate the test
+# data under tests/testdata in the qgis source tree.
+# the TEST_DATA_DIR variable is set in the top level CMakeLists.txt
+ADD_DEFINITIONS(-DTEST_DATA_DIR="\\"${TEST_DATA_DIR}\\"")
+ADD_DEFINITIONS(-DINSTALL_PREFIX="\\"${CMAKE_INSTALL_PREFIX}\\"")
+# libraries
+# because of htonl
+IF (WIN32)
+  SET(PLATFORM_LIBRARIES wsock32)
+ENDIF (WIN32)
+# Since the tests are not actually installed, but rather
+# run directly from the build/src/tests dir we need to
+# ensure the omg libs can be found.
+IF (APPLE)
+  # For Mac OS X, the executable must be at the root of the bundle's executable folder
+  SET (CMAKE_INSTALL_NAME_DIR @executable_path/../../../src/analyzer)
+ENDIF (APPLE)
+#note for tests we should not include the moc of our
+#qtests in the executable file list as the moc is
+#directly included in the sources
+#and should not be compiled twice. Trying to include
+#them in will cause an error at build time
+# Tests:
+# QgsVectorAnalyzer test
+SET(qgis_vectoranalyzertest_SRCS testqgsvectoranalyzer.cpp ${util_SRCS})
+SET(qgis_vectoranalyzertest_MOC_CPPS testqgsvectoranalyzer.cpp)
+QT4_WRAP_CPP(qgis_vectoranalyzertest_MOC_SRCS ${qgis_vectoranalyzertest_MOC_CPPS})
+ADD_CUSTOM_TARGET(qgis_vectoranalyzertestmoc ALL DEPENDS ${qgis_vectoranalyzertest_MOC_SRCS})
+ADD_EXECUTABLE(qgis_vectoranalyzertest ${qgis_vectoranalyzertest_SRCS})
+ADD_DEPENDENCIES(qgis_vectoranalyzertest qgis_vectoranalyzertestmoc)
+TARGET_LINK_LIBRARIES(qgis_vectoranalyzertest ${QT_LIBRARIES} qgis_core)
+  #No relinking and full RPATH for the install tree
+  #See: http://www.cmake.org/Wiki/CMake_RPATH_handling#No_relinking_and_full_RPATH_for_the_install_tree
+SET_TARGET_PROPERTIES(qgis_vectoranalyzertest
+  # skip the full RPATH for the build tree
+  PROPERTIES SKIP_BUILD_RPATH  TRUE
+  # when building, use the install RPATH already
+  # (so it doesn't need to relink when installing)
+  PROPERTIES BUILD_WITH_INSTALL_RPATH TRUE
+  # the RPATH to be used when installing
+  PROPERTIES INSTALL_RPATH ${QGIS_LIB_DIR}
+  # add the automatically determined parts of the RPATH
+  # which point to directories outside the build tree to the install RPATH
+  PROPERTIES INSTALL_RPATH_USE_LINK_PATH TRUE
+IF (APPLE)
+  INSTALL(TARGETS qgis_vectoranalyzertest RUNTIME DESTINATION ${CMAKE_INSTALL_PREFIX})
+  ADD_TEST(qgis_vectoranalyzertest ${CMAKE_INSTALL_PREFIX}/qgis_vectoranalyzertest)
+ELSE (APPLE)
+  INSTALL(TARGETS qgis_vectoranalyzertest RUNTIME DESTINATION ${CMAKE_INSTALL_PREFIX}/bin)
+  ADD_TEST(qgis_vectoranalyzertest ${CMAKE_INSTALL_PREFIX}/bin/qgis_vectoranalyzertest)
+ENDIF (APPLE)
Added: branches/analysis_branch/tests/src/analysis/testqgsvectoranalyzer.cpp
--- branches/analysis_branch/tests/src/analysis/testqgsvectoranalyzer.cpp	                        (rev 0)
+++ branches/analysis_branch/tests/src/analysis/testqgsvectoranalyzer.cpp	2009-03-19 18:58:17 UTC (rev 10311)
@@ -0,0 +1,36 @@
+  testqgsvectoranalyzer.cpp
+Date                 : Sun Sep 16 12:22:49 AKDT 2007
+Copyright            : (C) 2007 by Gary E. Sherman
+Email                : sherman at mrcc dot com
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+#include <QtTest>
+//header for class being tested
+#include <qgsgeometryanalyzer.h>
+class TestQgsVectorAnalyzer: public QObject
+    Q_OBJECT;
+  private slots:
+    void initTestCase();
+  private:
+void TestQgsVectorAnalyzer::initTestCase()
+QTEST_MAIN( TestQgsVectorAnalyzer )
+#include "moc_testqgsvectoranalyzer.cxx"
More information about the QGIS-commit mailing list
