[QGIS Commit] r10318 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Fri Mar 20 10:05:51 EDT 2009
Author: jef
Date: 2009-03-20 10:05:51 -0400 (Fri, 20 Mar 2009)
New Revision: 10318
trunk/qgis/src/ui/qgsopenvectorlayerdialogbase.ui
fix layout of add vector dialog
Modified: trunk/qgis/src/ui/qgsopenvectorlayerdialogbase.ui
--- trunk/qgis/src/ui/qgsopenvectorlayerdialogbase.ui 2009-03-20 14:05:19 UTC (rev 10317)
+++ trunk/qgis/src/ui/qgsopenvectorlayerdialogbase.ui 2009-03-20 14:05:51 UTC (rev 10318)
@@ -8,8 +8,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>500</width>
- <height>569</height>
+ <width>930</width>
+ <height>635</height>
</rect>
</property>
<property name="sizePolicy" >
@@ -29,10 +29,11 @@
</property>
<property name="windowIcon" >
<iconset>
- <normaloff>../../../../../Documents and Settings/freddy/.designer/plugins/ogr_converter</normaloff>../../../../../Documents and Settings/freddy/.designer/plugins/ogr_converter</iconset>
+ <normaloff/>
+ </iconset>
</property>
- <layout class="QVBoxLayout" name="verticalLayout_3" >
- <item>
+ <layout class="QGridLayout" name="gridLayout_5" >
+ <item row="0" column="0" >
<widget class="QGroupBox" name="srcGroupBox_2" >
<sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
@@ -40,312 +41,286 @@
<verstretch>0</verstretch>
</sizepolicy>
</property>
- <property name="minimumSize" >
- <size>
- <width>482</width>
- <height>80</height>
- </size>
- </property>
- <property name="maximumSize" >
- <size>
- <width>16777215</width>
- <height>70</height>
- </size>
- </property>
<property name="title" >
<string>Source type</string>
</property>
- <layout class="QVBoxLayout" name="verticalLayout_4" >
- <item>
- <layout class="QHBoxLayout" name="horizontalLayout_3" >
+ <layout class="QGridLayout" name="gridLayout" >
+ <widget class="QRadioButton" name="radioSrcFile" >
+ <property name="text" >
+ <string>File</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1" >
+ <widget class="QRadioButton" name="radioSrcDirectory" >
+ <string>Directory</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="2" >
+ <widget class="QRadioButton" name="radioSrcDatabase" >
+ <string>Database</string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="3" >
+ <widget class="QRadioButton" name="radioSrcProtocol" >
+ <string>Protocol</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0" >
+ <widget class="QLabel" name="label_3" >
+ <string>Encoding :</string>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1" colspan="3" >
+ <widget class="QComboBox" name="cmbEncodings" >
+ <property name="minimumSize" >
+ <size>
+ <width>380</width>
+ <height>0</height>
+ </size>
+ </property>
<item>
- <widget class="QRadioButton" name="radioSrcFile" >
- <property name="text" >
- <string>File</string>
- </property>
- </widget>
+ <string>BIG5</string>
+ </property>
</item>
<item>
- <widget class="QRadioButton" name="radioSrcDirectory" >
- <string>Directory</string>
- </property>
- </widget>
+ <string>BIG5-HKSCS</string>
+ </property>
</item>
<item>
- <widget class="QRadioButton" name="radioSrcDatabase" >
- <string>Database</string>
- </property>
- </widget>
+ <string>EUCJP</string>
+ </property>
</item>
<item>
- <widget class="QRadioButton" name="radioSrcProtocol" >
- <string>Protocol</string>
- </property>
- </widget>
+ <string>EUCKR</string>
+ </property>
</item>
- </layout>
- </item>
- <item>
- <layout class="QHBoxLayout" name="horizontalLayout_4" >
<item>
- <widget class="QLabel" name="label_3" >
- <string>Encoding :</string>
- </property>
- </widget>
+ <string>GB2312</string>
+ </property>
</item>
<item>
- <widget class="QComboBox" name="cmbEncodings" >
- <size>
- <width>380</width>
- <height>0</height>
- </size>
- </property>
- <item>
- <string>BIG5</string>
- </property>
- </item>
- <item>
- <string>BIG5-HKSCS</string>
- </property>
- </item>
- <item>
- <string>EUCJP</string>
- </property>
- </item>
- <item>
- <string>EUCKR</string>
- </property>
- </item>
- <item>
- <string>GB2312</string>
- </property>
- </item>
- <item>
- <string>GBK</string>
- </property>
- </item>
- <item>
- <string>GB18030</string>
- </property>
- </item>
- <item>
- <string>JIS7</string>
- </property>
- </item>
- <item>
- <string>SHIFT-JIS</string>
- </property>
- </item>
- <item>
- <string>TSCII</string>
- </property>
- </item>
- <item>
- <string>UTF-8</string>
- </property>
- </item>
- <item>
- <string>UTF-16</string>
- </property>
- </item>
- <item>
- <string>KOI8-R</string>
- </property>
- </item>
- <item>
- <string>KOI8-U</string>
- </property>
- </item>
- <item>
- <string>ISO8859-1</string>
- </property>
- </item>
- <item>
- <string>ISO8859-2</string>
- </property>
- </item>
- <item>
- <string>ISO8859-3</string>
- </property>
- </item>
- <item>
- <string>ISO8859-4</string>
- </property>
- </item>
- <item>
- <string>ISO8859-5</string>
- </property>
- </item>
- <item>
- <string>ISO8859-6</string>
- </property>
- </item>
- <item>
- <string>ISO8859-7</string>
- </property>
- </item>
- <item>
- <string>ISO8859-8</string>
- </property>
- </item>
- <item>
- <string>ISO8859-8-I</string>
- </property>
- </item>
- <item>
- <string>ISO8859-9</string>
- </property>
- </item>
- <item>
- <string>ISO8859-10</string>
- </property>
- </item>
- <item>
- <string>ISO8859-11</string>
- </property>
- </item>
- <item>
- <string>ISO8859-12</string>
- </property>
- </item>
- <item>
- <string>ISO8859-13</string>
- </property>
- </item>
- <item>
- <string>ISO8859-14</string>
- </property>
- </item>
- <item>
- <string>ISO8859-15</string>
- </property>
- </item>
- <item>
- <string>IBM 850</string>
- </property>
- </item>
- <item>
- <string>IBM 866</string>
- </property>
- </item>
- <item>
- <string>CP874</string>
- </property>
- </item>
- <item>
- <string>CP1250</string>
- </property>
- </item>
- <item>
- <string>CP1251</string>
- </property>
- </item>
- <item>
- <string>CP1252</string>
- </property>
- </item>
- <item>
- <string>CP1253</string>
- </property>
- </item>
- <item>
- <string>CP1254</string>
- </property>
- </item>
- <item>
- <string>CP1255</string>
- </property>
- </item>
- <item>
- <string>CP1256</string>
- </property>
- </item>
- <item>
- <string>CP1257</string>
- </property>
- </item>
- <item>
- <string>CP1258</string>
- </property>
- </item>
- <item>
- <string>Apple Roman</string>
- </property>
- </item>
- <item>
- <string>TIS-620</string>
- </property>
- </item>
- </widget>
+ <string>GBK</string>
+ </property>
</item>
- </layout>
+ <item>
+ <string>GB18030</string>
+ </property>
+ </item>
+ <item>
+ <string>JIS7</string>
+ </property>
+ </item>
+ <item>
+ <string>SHIFT-JIS</string>
+ </property>
+ </item>
+ <item>
+ <string>TSCII</string>
+ </property>
+ </item>
+ <item>
+ <string>UTF-8</string>
+ </property>
+ </item>
+ <item>
+ <string>UTF-16</string>
+ </property>
+ </item>
+ <item>
+ <string>KOI8-R</string>
+ </property>
+ </item>
+ <item>
+ <string>KOI8-U</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-1</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-2</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-3</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-4</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-5</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-6</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-7</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-8</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-8-I</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-9</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-10</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-11</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-12</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-13</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-14</string>
+ </property>
+ </item>
+ <item>
+ <string>ISO8859-15</string>
+ </property>
+ </item>
+ <item>
+ <string>IBM 850</string>
+ </property>
+ </item>
+ <item>
+ <string>IBM 866</string>
+ </property>
+ </item>
+ <item>
+ <string>CP874</string>
+ </property>
+ </item>
+ <item>
+ <string>CP1250</string>
+ </property>
+ </item>
+ <item>
+ <string>CP1251</string>
+ </property>
+ </item>
+ <item>
+ <string>CP1252</string>
+ </property>
+ </item>
+ <item>
+ <string>CP1253</string>
+ </property>
+ </item>
+ <item>
+ <string>CP1254</string>
+ </property>
+ </item>
+ <item>
+ <string>CP1255</string>
+ </property>
+ </item>
+ <item>
+ <string>CP1256</string>
+ </property>
+ </item>
+ <item>
+ <string>CP1257</string>
+ </property>
+ </item>
+ <item>
+ <string>CP1258</string>
+ </property>
+ </item>
+ <item>
+ <string>Apple Roman</string>
+ </property>
+ </item>
+ <item>
+ <string>TIS-620</string>
+ </property>
+ </item>
+ </widget>
</item>
</layout>
</widget>
</item>
- <item>
<widget class="QGroupBox" name="protocolGroupBox" >
<size>
- <height>90</height>
+ <width>0</width>
</size>
</property>
- <size>
- </size>
- </property>
</property>
@@ -373,7 +348,7 @@
</layout>
</widget>
</item>
- <item>
+ <item row="2" column="0" >
<widget class="QGroupBox" name="fileGroupBox" >
@@ -383,16 +358,10 @@
</property>
<size>
+ <width>0</width>
</size>
</property>
- <size>
- </size>
- </property>
<string>Source</string>
</property>
@@ -437,7 +406,14 @@
</layout>
</widget>
</item>
- <item>
+ <item row="4" column="0" >
+ <widget class="QDialogButtonBox" name="buttonBox" >
+ <property name="standardButtons" >
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="0" >
<widget class="QGroupBox" name="dbGroupBox" >
@@ -447,113 +423,77 @@
</property>
<size>
- <height>240</height>
+ <width>0</width>
</size>
</property>
- <size>
- </size>
- </property>
</property>
- <widget class="QGroupBox" name="groupBox_2" >
- <property name="geometry" >
- <rect>
- <x>10</x>
- <y>30</y>
- <width>454</width>
- <height>61</height>
- </rect>
- </property>
- <property name="title" >
- <string>Type</string>
- </property>
- <layout class="QVBoxLayout" name="verticalLayout_2" >
- <item>
- <widget class="QComboBox" name="cmbDatabaseTypes" />
- </item>
- </layout>
- </widget>
- <widget class="QGroupBox" name="groupBox" >
- <rect>
- <x>10</x>
- <y>90</y>
- <height>126</height>
- </rect>
- </property>
- <string>Connections</string>
- </property>
- <layout class="QVBoxLayout" name="verticalLayout" >
- <item>
- <widget class="QComboBox" name="cmbConnections" />
- </item>
- <item>
- <layout class="QHBoxLayout" name="horizontalLayout" >
- <item>
+ <layout class="QGridLayout" name="gridLayout_6" >
+ <widget class="QLabel" name="label_4" >
+ <string>Type</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QComboBox" name="cmbDatabaseTypes" >
+ <property name="sizePolicy" >
+ <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="0" colspan="2" >
+ <widget class="QGroupBox" name="groupBox" >
+ <sizepolicy vsizetype="Preferred" hsizetype="Minimum" >
+ </sizepolicy>
+ </property>
+ <property name="title" >
+ <string>Connections</string>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_4" >
<widget class="QPushButton" name="btnNew" >
<string>New</string>
</property>
</widget>
</item>
- <item>
+ <item row="1" column="1" >
<widget class="QPushButton" name="btnEdit" >
<string>Edit</string>
</property>
</widget>
</item>
- <item>
+ <item row="1" column="2" >
<widget class="QPushButton" name="btnDelete" >
<string>Delete</string>
</property>
</widget>
</item>
+ <item row="0" column="0" colspan="3" >
+ <widget class="QComboBox" name="cmbConnections" />
+ </item>
</layout>
- </item>
- </layout>
- </widget>
+ <zorder>btnNew</zorder>
+ <zorder>btnEdit</zorder>
+ <zorder>btnDelete</zorder>
+ <zorder>cmbConnections</zorder>
+ </widget>
+ </item>
+ </layout>
</widget>
</item>
- <item>
- <layout class="QHBoxLayout" name="horizontalLayout_2" >
- <item>
- <widget class="QPushButton" name="btnHelp" >
- <string>Help</string>
- </property>
- </widget>
- </item>
- <item>
- <spacer name="horizontalSpacer" >
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="sizeHint" stdset="0" >
- <size>
- <width>228</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- <item>
- <widget class="QDialogButtonBox" name="buttonBox" >
- <property name="standardButtons" >
- <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
- </property>
- </widget>
- </item>
- </layout>
- </item>
</layout>
</widget>
<layoutdefault spacing="6" margin="11" />
