[QGIS Commit] r10334 - trunk/qgis/src/plugins/grass/config
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Mar 20 13:28:52 EDT 2009
Author: jef
Date: 2009-03-20 13:28:51 -0400 (Fri, 20 Mar 2009)
New Revision: 10334
   trunk/qgis/src/plugins/grass/config/default.qgc
fix identation in default.qgc
Modified: trunk/qgis/src/plugins/grass/config/default.qgc
--- trunk/qgis/src/plugins/grass/config/default.qgc	2009-03-20 16:42:52 UTC (rev 10333)
+++ trunk/qgis/src/plugins/grass/config/default.qgc	2009-03-20 17:28:51 UTC (rev 10334)
@@ -81,14 +81,16 @@
                                 <grass name="g.region.save"/>
                                 <grass name="g.region.zoom"/>
                                 <grass name="g.region.multiple.raster"/>
-                                <grass name="g.region.multiple.vector"/> 			</section>
+                                <grass name="g.region.multiple.vector"/>
+                        </section>
 			<section label="Projection management">
-                                <section label="Print projection information of the current location"> 					<grass name="g.proj.print"/>
-				</section>
+                                <section label="Print projection information of the current location">
+                                        <grass name="g.proj.print"/>
+			        </section>
                                 <section label="Print projection information from a georeferenced file">
-					<grass name="g.proj.geo"/>
+			                <grass name="g.proj.geo"/>
                                         <grass name="g.proj.ascii"/>
-					<grass name="g.proj.proj"/>
+				        <grass name="g.proj.proj"/>
 				</section>
                                 <section label="Print projection information from a georeferenced file and create a new location based on it">
                                         <grass name="g.proj.geo.new"/>
More information about the QGIS-commit mailing list
