[QGIS Commit] r10339 - in branches/analysis_branch: python/core
src/analysis/vector src/core
svn_qgis at osgeo.org
Fri Mar 20 15:27:56 EDT 2009
Author: cfarmer
Date: 2009-03-20 15:27:55 -0400 (Fri, 20 Mar 2009)
New Revision: 10339
branches/analysis_branch/python/core/qgsgeometry.sip
branches/analysis_branch/src/analysis/vector/qgsgeometryanalyzer.cpp
branches/analysis_branch/src/analysis/vector/qgsgeometryanalyzer.h
branches/analysis_branch/src/core/qgsgeometry.cpp
branches/analysis_branch/src/core/qgsgeometry.h
changes to geometryanalyzer (passes tests) and added simplify to qgsgeometry
Modified: branches/analysis_branch/python/core/qgsgeometry.sip
--- branches/analysis_branch/python/core/qgsgeometry.sip 2009-03-20 18:55:30 UTC (rev 10338)
+++ branches/analysis_branch/python/core/qgsgeometry.sip 2009-03-20 19:27:55 UTC (rev 10339)
@@ -224,6 +224,9 @@
of segments used to approximate curves */
QgsGeometry* buffer(double distance, int segments) /Factory/;
+ /** Returns a simplified version of this geometry using a specified tolerance value */
+ QgsGeometry* simplify(double tolerance) /Factory/;
/** Returns the smallest convex polygon that contains all the points in the geometry. */
QgsGeometry* convexHull() /Factory/;
Modified: branches/analysis_branch/src/analysis/vector/qgsgeometryanalyzer.cpp
--- branches/analysis_branch/src/analysis/vector/qgsgeometryanalyzer.cpp 2009-03-20 18:55:30 UTC (rev 10338)
+++ branches/analysis_branch/src/analysis/vector/qgsgeometryanalyzer.cpp 2009-03-20 19:27:55 UTC (rev 10339)
@@ -21,7 +21,6 @@
#include "qgsapplication.h"
#include "qgsfield.h"
#include "qgsfeature.h"
-#include "qgsgeometry.h"
#include "qgslogger.h"
#include "qgscoordinatereferencesystem.h"
#include "qgsvectorfilewriter.h"
@@ -405,7 +404,7 @@
-bool QgsGeometryAnalyzer::simpleMeasure( QgsGeometry& geometry )
+QList<double> QgsGeometryAnalyzer::simpleMeasure( QgsGeometry& geometry )
if inGeom.wkbType() == QGis.WKBPoint:
@@ -424,7 +423,7 @@
-bool QgsGeometryAnalyzer::perimeterMeasure( QgsGeometry& geometry )
+double QgsGeometryAnalyzer::perimeterMeasure( QgsGeometry& geometry )
value = 0.00
@@ -442,7 +441,7 @@
-bool QgsGeometryAnalyzer::checkGeometryFields( QgsGeometry& geometry )
+QgsFieldMap QgsGeometryAnalyzer::checkGeometryFields( QgsGeometry& geometry, int index1, int index2 )
vprovider = vlayer.dataProvider()
@@ -486,10 +485,9 @@
fieldList[index2] = field
return (fieldList, index1, index2)
-bool QgsGeometryAnalyzer::extractAsLine( QgsGeometry& geometry )
+QgsPolyline QgsGeometryAnalyzer::extractAsLine( QgsGeometry& geometry )
multi_geom = QgsGeometry()
@@ -509,7 +507,7 @@
-bool QgsGeometryAnalyzer::extractAsSingle( QgsGeometry& geometry )
+QgsGeometry QgsGeometryAnalyzer::extractAsSingle( QgsGeometry& geometry )
@@ -540,7 +538,8 @@
-bool QgsGeometryAnalyzer::extractAsMulti( QgsGeometry& geometry )
+QgsGeometry QgsGeometryAnalyzer::extractAsMulti( QgsGeometry& geometry )
if ( geometry->mGeos == NULL )
@@ -592,7 +591,8 @@
-bool QgsGeometryAnalyzer::convertGeometry( QgsGeometry& geometry )
+QgsGeometry QgsGeometryAnalyzer::convertGeometry( QgsGeometry& geometry )
if vType == 0:
@@ -604,7 +604,7 @@
-bool QgsGeometryAnalyzer::extractPoints( QgsGeometry& geometry )
+QList<QPoint> QgsGeometryAnalyzer::extractPoints( QgsGeometry& geometry )
QList multi_geom;
Modified: branches/analysis_branch/src/analysis/vector/qgsgeometryanalyzer.h
--- branches/analysis_branch/src/analysis/vector/qgsgeometryanalyzer.h 2009-03-20 18:55:30 UTC (rev 10338)
+++ branches/analysis_branch/src/analysis/vector/qgsgeometryanalyzer.h 2009-03-20 19:27:55 UTC (rev 10339)
@@ -21,6 +21,9 @@
#include "qgsvectorlayer.h"
+#include "qgsfeature.h"
+#include "qgsgeometry.h"
+#include "qgsfield.h"
/** \ingroup analysis
@@ -65,7 +68,7 @@
bool polygonsToLines( QgsVectorLayer* layer,
const QString& shapefileName,
const QString& fileEncoding );
* Add vector layer geometry info to point (XCOORD, YCOORD), line (LENGTH),
* or polygon (AREA, PERIMETER) layer.
@@ -98,16 +101,17 @@
bool layerExtent( QgsVectorLayer* layer,
private:
- bool simpleMeasure( QgsGeometry& geometry );
- bool perimeterMeasure( QgsGeometry& geometry );
- bool checkGeometryFields( QgsGeometry& geometry );
- bool extractAsLine( QgsGeometry& geometry );
- bool extractAsSingle( QgsGeometry& geometry );
- bool extractAsMulti( QgsGeometry& geometry );
- bool convertGeometry( QgsGeometry& geometry );
- bool extractPoints( QgsGeometry& geometry );
+ QList<double> simpleMeasure( QgsGeometry& geometry );
+ double perimeterMeasure( QgsGeometry& geometry );
+ QgsFieldMap checkGeometryFields( QgsGeometry& geometry, int index1, int index2 );
+ QgsPolyline extractAsLine( QgsGeometry& geometry );
+ QgsGeometry extractAsSingle( QgsGeometry& geometry );
+ QgsGeometry extractAsMulti( QgsGeometry& geometry );
+ QgsGeometry convertGeometry( QgsGeometry& geometry );
+ QList<QPoint> extractPoints( QgsGeometry& geometry );
#endif //QGSVECTORANALYZER
Modified: branches/analysis_branch/src/core/qgsgeometry.cpp
--- branches/analysis_branch/src/core/qgsgeometry.cpp 2009-03-20 18:55:30 UTC (rev 10338)
+++ branches/analysis_branch/src/core/qgsgeometry.cpp 2009-03-20 19:27:55 UTC (rev 10339)
@@ -134,6 +134,7 @@
#define GEOSIntersection(g0,g1) GEOSIntersection( (GEOSGeometry*) g0, (GEOSGeometry*)g1 )
#define GEOSBuffer(g, d, s) GEOSBuffer( (GEOSGeometry*) g, d, s)
#define GEOSArea(g, a) GEOSArea( (GEOSGeometry*) g, a)
+#define GEOSSimplify(g, t) GEOSSimplify( (GEOSGeometry*) g, t)
#define GEOSCoordSeq_getSize(cs,n) GEOSCoordSeq_getSize( (GEOSCoordSequence *) cs, n )
#define GEOSCoordSeq_getX(cs,i,x) GEOSCoordSeq_getX( (GEOSCoordSequence *)cs, i, x )
@@ -5328,6 +5329,23 @@
CATCH_GEOS( 0 )
+QgsGeometry* QgsGeometry::simplify( double tolerance )
+ if ( mGeos == NULL )
+ exportWkbToGeos();
+ if ( !mGeos )
+ return 0;
+ try
+ return fromGeosGeom( GEOSSimplify( mGeos, tolerance ) );
+ CATCH_GEOS( 0 )
QgsGeometry* QgsGeometry::convexHull()
@@ -5450,7 +5468,6 @@
CATCH_GEOS( 0 )
QList<QgsGeometry*> QgsGeometry::asGeometryCollection()
Modified: branches/analysis_branch/src/core/qgsgeometry.h
--- branches/analysis_branch/src/core/qgsgeometry.h 2009-03-20 18:55:30 UTC (rev 10338)
+++ branches/analysis_branch/src/core/qgsgeometry.h 2009-03-20 19:27:55 UTC (rev 10339)
@@ -269,6 +269,9 @@
/** Returns a buffer region around this geometry having the given width and with a specified number
QgsGeometry* buffer( double distance, int segments );
+ QgsGeometry* simplify( double tolerance );
QgsGeometry* convexHull();
