[QGIS Commit] r10364 - branches/Version-1_0/i18n
svn_qgis at osgeo.org
Sat Mar 21 12:15:36 EDT 2009
Author: macho
Date: 2009-03-21 12:15:36 -0400 (Sat, 21 Mar 2009)
New Revision: 10364
branches/Version-1_0/i18n/qgis_de.ts
again found some german translation bugs
Modified: branches/Version-1_0/i18n/qgis_de.ts
--- branches/Version-1_0/i18n/qgis_de.ts 2009-03-21 16:11:29 UTC (rev 10363)
+++ branches/Version-1_0/i18n/qgis_de.ts 2009-03-21 16:15:36 UTC (rev 10364)
@@ -1,5 +1,6 @@
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE TS><TS version="1.1" language="de">
+<defaultcodec></defaultcodec>
<context>
<name>CoordinateCapture</name>
<message>
@@ -157,143 +158,115 @@
<context>
<name>Dialog</name>
<message>
- <location filename="" line="0"/>
<source>QGIS Plugin Installer</source>
<translation type="obsolete">QGIS Plugin Installation</translation>
</message>
<message>
<source>Name of plugin to install</source>
<translation type="obsolete">Name des zu installierenden Plugins</translation>
</message>
<message>
<source>Get List</source>
<translation type="obsolete">Hole Liste</translation>
</message>
<message>
<source>Done</source>
<translation type="obsolete">Fertig</translation>
</message>
<message>
<source>Install Plugin</source>
<translation type="obsolete">Plugin-Installation</translation>
</message>
<message>
<source>The plugin will be installed to ~/.qgis/python/plugins</source>
<translation type="obsolete">Das Plugin wird unter ~/.qgis/python/plugins installiert</translation>
</message>
<message>
<source>Name</source>
<translation type="obsolete">Name</translation>
</message>
<message>
<source>Version</source>
<translation type="obsolete">Version</translation>
</message>
<message>
<source>Description</source>
<translation type="obsolete">Beschreibung</translation>
</message>
<message>
<source>Author</source>
<translation type="obsolete">Autor</translation>
</message>
<message>
<source>Select repository, retrieve the list of available plugins, select one and install it</source>
<translation type="obsolete">Wähle ein Repository, empfange die Liste mit vorhandenen Plugins und installiere eines davon.</translation>
</message>
<message>
<source>Repository</source>
<translation type="obsolete">Repository</translation>
</message>
<message>
<source>Active repository:</source>
<translation type="obsolete">Aktives Repository:</translation>
</message>
<message>
<source>Add</source>
<translation type="obsolete">Hinzufügen</translation>
</message>
<message>
<source>Edit</source>
<translation type="obsolete">Bearbeiten</translation>
</message>
<message>
<source>Delete</source>
<translation type="obsolete">Löschen</translation>
</message>
<message>
<source>Dialog</source>
<translation type="obsolete">Dialog</translation>
</message>
<message>
<source>Point Symbol</source>
<translation type="obsolete">Punktsymbol </translation>
</message>
<message>
<source>Size</source>
<translation type="obsolete">Grösse</translation>
</message>
<message>
<source>Area scale field</source>
<translation type="obsolete">Flächenmaßstabsfeld</translation>
</message>
<message>
<source>Rotation field</source>
<translation type="obsolete">Rotationsfeld</translation>
</message>
<message>
<source>Style Options</source>
<translation type="obsolete">Stiloption</translation>
</message>
<message>
<source>Outline style</source>
<translation type="obsolete">Umrandungsstil</translation>
</message>
<message>
<source>Outline color</source>
<translation type="obsolete">Umrandungsfarbe
</translation>
</message>
<message>
<source>Outline width</source>
<translation type="obsolete">Umrandungsbreite</translation>
</message>
<message>
<source>Fill color</source>
<translation type="obsolete">Füllfarbe</translation>
</message>
<message>
<source>Fill style</source>
<translation type="obsolete">Füllstil</translation>
</message>
<message>
<source>...</source>
<translation type="obsolete">...</translation>
</message>
@@ -575,7 +548,6 @@
<translation>OGR-Layer-Konverter starten</translation>
</message>
<message>
<source>Replace this with a short description of the what the plugin does</source>
<translation type="obsolete">Diese Notiz mit einer kurzen Beschreibung, was das Plugin macht, ersetzen</translation>
</message>
@@ -1610,7 +1582,6 @@
<translation>Quick Print ist ein Plugin, um mal eben schnell und ohne großen Aufwandt eine Karte zu drucken.</translation>
</message>
<message>
<source>Loaded default style file from </source>
<translation type="obsolete">Standard Style geladen von </translation>
</message>
@@ -1869,12 +1840,10 @@
<translation>%1 ist ein ungültiger Layer und kann nicht geladen werden.</translation>
</message>
<message>
<source>Error Loading Plugin</source>
<translation type="obsolete">Fehler beim Laden des Plugins</translation>
</message>
<message>
<source>There was an error loading %1.</source>
<translation type="obsolete">Es trat ein Fehler auf beim Laden von %1.</translation>
</message>
@@ -1884,7 +1853,6 @@
<translation>Kartenbild gespeichert in</translation>
</message>
<message>
<source>Choose a filename to save the map image as</source>
<translation type="obsolete">Dateinamen zum Speichern des Kartenbildes wählen</translation>
</message>
@@ -2092,7 +2060,6 @@
<translation>Projekt speichern &als...</translation>
</message>
<message>
<source>Ctrl+A</source>
<comment>Save Project under a new name</comment>
<translation type="obsolete">Ctrl+A</translation>
@@ -2103,18 +2070,15 @@
<translation>Projekt unter einem neuen Namen abspeichern.</translation>
</message>
<message>
<source>&Print...</source>
<translation type="obsolete">&Drucken...</translation>
</message>
<message>
<source>Ctrl+P</source>
<comment>Print</comment>
<translation type="obsolete">Ctrl+P</translation>
</message>
<message>
<source>Print</source>
<translation type="obsolete">Drucken</translation>
</message>
@@ -2124,7 +2088,6 @@
<translation>Bild speichern als...</translation>
</message>
<message>
<source>Ctrl+I</source>
<comment>Save map as image</comment>
<translation type="obsolete">Ctrl+I</translation>
@@ -2151,7 +2114,6 @@
<translation>Beende QGIS</translation>
</message>
<message>
<source>Add a Vector Layer...</source>
<translation type="obsolete">Vektorlayer hinzufügen...</translation>
</message>
@@ -2167,7 +2129,6 @@
<translation>Vektorlayer hinzufügen</translation>
</message>
<message>
<source>Add a Raster Layer...</source>
<translation type="obsolete">Rasterlayer hinzufügen...</translation>
</message>
@@ -2183,7 +2144,6 @@
<translation>Rasterlayer hinzufügen</translation>
</message>
<message>
<source>Add a PostGIS Layer...</source>
<translation type="obsolete">PostGIS-Layer hinzufügen...</translation>
</message>
@@ -2231,7 +2191,6 @@
<translation>Lösche einen Layer</translation>
</message>
<message>
<source>Add All To Overview</source>
<translation type="obsolete">Alle zur Übersicht hinzufügen</translation>
</message>
@@ -2337,7 +2296,6 @@
<translation>Hilfe</translation>
</message>
<message>
<source>Qgis Home Page</source>
<translation type="obsolete">QGIS-Homepage</translation>
</message>
@@ -2427,18 +2385,15 @@
<translation>Auf die volle Ausdehnung herauszoomen</translation>
</message>
<message>
<source>Zoom To Selection</source>
<translation type="obsolete">Auf die Auswahl zoomen</translation>
</message>
<message>
<source>Ctrl+F</source>
<comment>Zoom to selection</comment>
<translation type="obsolete">Ctrl+F</translation>
</message>
<message>
<source>Zoom to selection</source>
</message>
@@ -2463,7 +2418,6 @@
<translation>Zur vorherigen Zoomeinstellung zurückkehren</translation>
</message>
<message>
<source>Zoom To Layer</source>
<translation type="obsolete">Auf den Layer zoomen</translation>
</message>
@@ -2494,7 +2448,6 @@
<translation>Wähle Objekte aus</translation>
</message>
<message>
<source>Open Table</source>
<translation type="obsolete">Attributtabelle öffnen</translation>
</message>
@@ -2504,7 +2457,6 @@
<translation>Linie messen</translation>
</message>
<message>
<source>Ctrl+M</source>
<comment>Measure a Line</comment>
<translation type="obsolete">Ctrl+M</translation>
@@ -2520,7 +2472,6 @@
<translation>Fläche messen</translation>
</message>
<message>
<source>Ctrl+J</source>
<comment>Measure an Area</comment>
<translation type="obsolete">Ctrl+J</translation>
@@ -2563,18 +2514,15 @@
<translation>WMS-Layer hinzufügen...</translation>
</message>
<message>
<source>W</source>
<comment>Add Web Mapping Server Layer</comment>
<translation type="obsolete">W</translation>
</message>
<message>
<source>Add Web Mapping Server Layer</source>
<translation type="obsolete">WMS-Layer hinzufügen</translation>
</message>
<message>
<source>In Overview</source>
<translation type="obsolete">In Übersicht anzeigen</translation>
</message>
@@ -2590,7 +2538,6 @@
<translation>Aktuellen Layer zur Übersicht hinzufügen</translation>
</message>
<message>
<source>Plugin Manager...</source>
<translation type="obsolete">Plugin Manager...</translation>
</message>
@@ -2753,7 +2700,6 @@
<translation>Kann das Projekt nicht speichern </translation>
</message>
<message>
<source>Choose a filename to save the QGIS project file as</source>
<translation type="obsolete">Bitte wählen Sie einen Dateinamen, unter dem Sie das Projekt speichern wollen.</translation>
</message>
@@ -2854,12 +2800,10 @@
<translation>Strg+?</translation>
</message>
<message>
<source>Show most toolbars</source>
<translation type="obsolete">Die meisten Werkzeugleisten anzeigen</translation>
</message>
<message>
<source>Hide most toolbars</source>
<translation type="obsolete">Die meisten Werkzeugleisten ausblenden</translation>
</message>
@@ -2889,12 +2833,10 @@
<translation>Python wird gestartet</translation>
</message>
<message>
<source>Python error</source>
<translation type="obsolete">Python-Fehler</translation>
</message>
<message>
<source>Error when reading metadata of plugin </source>
<translation type="obsolete">Fehler beim Lesen der Plugin-Metadaten</translation>
</message>
@@ -2944,7 +2886,6 @@
<translation>Insel in Multipolygon einfügen</translation>
</message>
<message>
<source>Toolbar Visibility...</source>
<translation type="obsolete">Werkzeugleistenanzeige...</translation>
</message>
@@ -2974,7 +2915,6 @@
<translation>Wollen Sie das aktuelle Projekt speichern?</translation>
</message>
<message>
<source>Python console</source>
<translation type="obsolete">Python-Konsole</translation>
</message>
@@ -3055,7 +2995,6 @@
<translation>Warne mich beim Öffnen einer Projektdatei, die mit einer älteren QGIS Version erstellt wurde</translation>
</message>
<message>
<source>Toggle full screen mode</source>
<translation type="obsolete">Vollbildmodus umschalten</translation>
</message>
@@ -3110,7 +3049,6 @@
<translation>Diese QGIS wurde mit Qt %1 kompiliert und läuft gerade mit Qt %2</translation>
</message>
<message>
<source>T</source>
<comment>
@@ -3118,7 +3056,6 @@
<translation type="obsolete">Die meisten Werkzeugleisten einblenden</translation>
</message>
<message>
<source>Ctrl+T</source>
<comment>
@@ -3136,7 +3073,6 @@
<translation>Zeigt die Kartenkoordinate der aktuellen Cursorposition. Die Anzeige wird während der Mausbewegung laufend aktualisiert.</translation>
</message>
<message>
<source>Ctrl-F</source>
<comment>
@@ -3179,52 +3115,42 @@
<translation>KBS-Status - Klicken um den Dialog zum Koordinatenbezugssystem zu öffnen</translation>
</message>
<message>
<source>This release candidate includes over 60 bug fixes and enchancements over the QGIS 0.10.0 release. In addition we have added the following new features:</source>
<translation type="obsolete">Dieser Release-Kandidate beinhalted über 60 Fehlerkorrekutren und Erweiterung gegenüber der Version 0.10.0. Zusätzlich haben wir folgende Funktionen ergänzt:</translation>
</message>
<message>
<source>Revision of all dialogs for user interface consistancy</source>
<translation type="obsolete">Überarbeitung aller Dialog zur Vereinheitlichung der Benutzeroberfläche.</translation>
</message>
<message>
<source>Improvements to unique value renderer vector dialog</source>
<translation type="obsolete">Verbesserungen am Dialog zur Darstellung nach eindeutigen Werten.</translation>
</message>
<message>
<source>Symbol previews when defining vector classes</source>
<translation type="obsolete">Symbolvorschau beim Anlegen von Vektorklassen</translation>
</message>
<message>
<source>Separation of python support into its own library</source>
<translation type="obsolete">Ausgliederung der Python-Unterstützung in eine separate Bibliothek.</translation>
</message>
<message>
<source>List view and filter for GRASS toolbox to find tools more quickly</source>
<translation type="obsolete">Filterbare Liste für den GRASS-Werkzeugkasten, um das Auffinden von Werkzeugen zu beschleunigen.</translation>
</message>
<message>
<source>List view and filter for Plugin Manager to find plugins more easily</source>
<translation type="obsolete">Filterbare Liste um das Auffinden von Plugins im Plugin-Manager zu vereinfachen.</translation>
</message>
<message>
<source>Updated Spatial Reference System definitions</source>
<translation type="obsolete">Definition der Definitionen der räumlichen Bezugssystem aktualisiert.</translation>
</message>
<message>
<source>QML Style support for rasters and database layers</source>
<translation type="obsolete">Unterstützung für QML-Stile für Raster- und Datenbanklayer.</translation>
</message>
<message>
<source>There was an error loading a plugin.The following diagnostic information may help the QGIS developers resolve the issue:
%1.</source>
<translation type="obsolete">Beim Laden eines Plugins trat ein Fehler auf. Die folgenden Informationen könnten den QGIS-Entwicklern bei der Lösung des Problem helfen: %1.</translation>
@@ -3675,17 +3601,14 @@
<context>
<name>QgisAppBase</name>
<message>
<source>MainWindow</source>
<translation type="obsolete">Hauptfenster</translation>
</message>
<message>
<source>Legend</source>
<translation type="obsolete">Legende</translation>
</message>
<message>
<source>Map View</source>
<translation type="obsolete">Kartenansicht</translation>
</message>
@@ -3825,7 +3748,6 @@
<context>
<name>QgsAttributeActionDialog</name>
<message>
<source>Select an action</source>
<comment>
@@ -4054,7 +3976,6 @@
<translation>Attributtabelle</translation>
</message>
<message>
<source>Ctrl+N</source>
<translation type="obsolete">Ctrl+N</translation>
</message>
@@ -4119,17 +4040,14 @@
<translation>Alt+N</translation>
</message>
<message>
<source>New column</source>
<translation type="obsolete">Neue Attributspalte</translation>
</message>
<message>
<source>Delete column</source>
<translation type="obsolete">Lösche Attributspalte</translation>
</message>
<message>
<source>Zoom map to the selected rows (Ctrl-F)</source>
<translation type="obsolete">Zoome Karte zum ausgewählten Spalteneintrag (Ctrl-F)</translation>
</message>
@@ -4139,7 +4057,6 @@
<translation>Zoome Karte zu den ausgewählten Spalteneinträgen</translation>
</message>
<message>
</message>
@@ -4212,47 +4129,38 @@
<translation>Keine Treffer gefunden.</translation>
</message>
<message>
<source>Name conflict</source>
<translation type="obsolete">Namenskonflikt</translation>
</message>
<message>
<source>Stop editing</source>
<translation type="obsolete">Bearbeitung beenden</translation>
</message>
<message>
<source>Do you want to save the changes?</source>
<translation type="obsolete">Sollen die Änderungen gespeichert werden?</translation>
</message>
<message>
<source>Error</source>
<translation type="obsolete">Fehler</translation>
</message>
<message>
<source>The attribute could not be inserted. The name already exists in the table.</source>
<translation type="obsolete">Das Attribut konnte nicht eingefügt werden, da der Name bereits vorhanden ist.</translation>
</message>
<message>
<source>Could not commit changes - changes are still pending</source>
<translation type="obsolete">Konnten Änderungen nicht speichern - sie stehen weiter an.</translation>
</message>
<message>
<source>Editing not permitted</source>
<translation type="obsolete">Bearbeitung nicht erlaubt</translation>
</message>
<message>
<source>The data provider is read only, editing is not allowed.</source>
<translation type="obsolete">Bearbeitung nicht möglich, da der Datenlieferant nur lesbar ist.</translation>
</message>
<message>
<source>Start editing</source>
<translation type="obsolete">Bearbeitun&g starten</translation>
</message>
@@ -4377,7 +4285,6 @@
<translation>Das Auffüllen der Attributtabelle wurde beendet, da kein virtueller Speicher mehr zur Verfügung steht</translation>
</message>
<message>
<source>Found %d matching features.</source>
@@ -4468,62 +4375,50 @@
<context>
<name>QgsComposer</name>
<message>
</message>
<message>
<source>Choose a filename to save the map as</source>
<translation type="obsolete">Dateinamen zum Speichern der Karte wählen</translation>
</message>
<message>
<source> for read/write</source>
<translation type="obsolete">um zu lesen/ schreiben</translation>
</message>
<message>
<source>Error in Print</source>
<translation type="obsolete">Fehler beim Drucken</translation>
</message>
<message>
<source>Cannot seek</source>
<translation type="obsolete">Kann nicht suchen</translation>
</message>
<message>
<source>Cannot overwrite BoundingBox</source>
<translation type="obsolete">Kann die Umgrenzung nicht überschreiben</translation>
</message>
<message>
<source>Cannot find BoundingBox</source>
<translation type="obsolete">Kann die Umgrenzung nicht finden.</translation>
</message>
<message>
<source>Cannot overwrite translate</source>
<translation type="obsolete">Kann Übersetzung nicht überschreiben.</translation>
</message>
<message>
<source>Cannot find translate</source>
<translation type="obsolete">Kann Übersetzung nicht finden.</translation>
</message>
<message>
<source>File IO Error</source>
<translation type="obsolete">Dateifehler</translation>
</message>
<message>
<source>Paper does not match</source>
<translation type="obsolete">Papier passt nicht</translation>
</message>
<message>
<source>The selected paper size does not match the composition size</source>
<translation type="obsolete">Die ausgewählte Papiergröße passt nicht zur Auswahl.</translation>
</message>
@@ -4558,7 +4453,6 @@
<translation>Karte 1</translation>
</message>
<message>
<source>Couldn't open </source>
<translation type="obsolete">Kann nicht öffnen </translation>
</message>
@@ -4583,72 +4477,58 @@
<translation>SVG-Format</translation>
</message>
<message>
<source>Move Content</source>
<translation type="obsolete">Inhalt verschieben</translation>
</message>
<message>
<source>Move item content</source>
<translation type="obsolete">Den Elementinhalt verschieben</translation>
</message>
<message>
<source>&Group</source>
<translation type="obsolete">&Gruppe</translation>
</message>
<message>
<source>Group items</source>
<translation type="obsolete">Gruppenelemente</translation>
</message>
<message>
<source>&Ungroup</source>
<translation type="obsolete">&Gruppe auflösen</translation>
</message>
<message>
<source>Ungroup items</source>
<translation type="obsolete">Die Gruppe auflösen</translation>
</message>
<message>
<source>Raise</source>
<translation type="obsolete">Hervorholen</translation>
</message>
<message>
<source>Raise selected items</source>
<translation type="obsolete">Ausgewählte Elemente in den Vordergrund bringen</translation>
</message>
<message>
<source>Lower</source>
<translation type="obsolete">Versenken</translation>
</message>
<message>
<source>Lower selected items</source>
<translation type="obsolete">Gewählte Elemente in den Hintergrund bringen</translation>
</message>
<message>
<source>Bring to Front</source>
<translation type="obsolete">In den Vordergrund holen</translation>
</message>
<message>
<source>Move selected items to top</source>
<translation type="obsolete">Gewählte Objekte in den Vordergrund verschieben</translation>
</message>
<message>
<source>Send to Back</source>
<translation type="obsolete">In den Hintergrund schicken</translation>
</message>
<message>
<source>Move selected items to bottom</source>
<translation type="obsolete">Die ausgewählten Elemente in den Hintergrund stellen</translation>
</message>
@@ -4791,12 +4671,10 @@
<translation>Eintrag</translation>
</message>
<message>
<source>&Open Template ...</source>
<translation type="obsolete">&Schablone öffnen...</translation>
</message>
<message>
<source>Save Template &As...</source>
<translation type="obsolete">Schablone speichern &als... </translation>
</message>
@@ -4826,12 +4704,10 @@
<translation>Eintrag wählen/verschieben</translation>
</message>
<message>
<source>Export as image</source>
<translation type="obsolete">Exportiere als Bild</translation>
</message>
<message>
<source>Export as SVG</source>
<translation type="obsolete">Exportiere als SVG</translation>
</message>
@@ -4851,7 +4727,6 @@
<translation>MainWindow</translation>
</message>
<message>
<source>Zoom All</source>
<translation type="obsolete">Auf Alles zoomen</translation>
</message>
@@ -4881,7 +4756,6 @@
</message>
<message>
<source>&Open Template...</source>
<translation type="obsolete">&Vorlage öffnen</translation>
</message>
@@ -5047,17 +4921,14 @@
<context>
<name>QgsComposerLabelBase</name>
<message>
<source>Label Options</source>
<translation type="obsolete">Beschriftungsoption</translation>
</message>
<message>
<source>Font</source>
<translation type="obsolete">Schrift</translation>
</message>
<message>
<source>Box</source>
<translation type="obsolete">Box</translation>
</message>
@@ -5199,32 +5070,26 @@
<context>
<name>QgsComposerMap</name>
<message>
<source>Extent (calculate scale)</source>
<translation type="obsolete">Ausdehnung (Massstabsberechnung)</translation>
</message>
<message>
<source>Scale (calculate extent)</source>
<translation type="obsolete">Massstab (Ausdenungsberechnung)</translation>
</message>
<message>
<source>Map %1</source>
<translation type="obsolete">Karte %1</translation>
</message>
<message>
<source>Cache</source>
<translation type="obsolete">Cache</translation>
</message>
<message>
<source>Render</source>
<translation type="obsolete">Zeichnen</translation>
</message>
<message>
<source>Rectangle</source>
<translation type="obsolete">Rechteck</translation>
</message>
@@ -5242,77 +5107,62 @@
<context>
<name>QgsComposerMapBase</name>
<message>
<source>Map options</source>
<translation type="obsolete">Kartenoptionen</translation>
</message>
<message>
<source><b>Map</b></source>
<translation type="obsolete"><b>Karte</b></translation>
</message>
<message>
<source>Set</source>
<translation type="obsolete">Setzen</translation>
</message>
<message>
<source>Width</source>
<translation type="obsolete">Breite</translation>
</message>
<message>
<source>Height</source>
<translation type="obsolete">Höhe</translation>
</message>
<message>
<source>Set Extent</source>
<translation type="obsolete">Ausdehnung setzen</translation>
</message>
<message>
<source>Set map extent to current extent in QGIS map canvas</source>
<translation type="obsolete">Ausdehnung auf die Ausmasse des QGIS Kartenausschnitts setzen</translation>
</message>
<message>
<source>Line width scale</source>
<translation type="obsolete">Linienbreitemassstab</translation>
</message>
<message>
<source>Width of one unit in millimeters</source>
<translation type="obsolete">Breite einer Einheit in Millimeter</translation>
</message>
<message>
<source>Symbol scale</source>
<translation type="obsolete">Symbol Massstab</translation>
</message>
<message>
<source>Font size scale</source>
<translation type="obsolete">Massstab der Schriftgrösse</translation>
</message>
<message>
<source>Frame</source>
<translation type="obsolete">Rahmen</translation>
</message>
<message>
<source>Preview</source>
<translation type="obsolete">Vorschau</translation>
</message>
<message>
<source>1:</source>
<translation type="obsolete">1:</translation>
</message>
<message>
<source>Scale:</source>
<translation type="obsolete">Massstab:</translation>
</message>
@@ -5411,22 +5261,18 @@
<context>
<name>QgsComposerPicture</name>
<message>
<source>Warning</source>
<translation type="obsolete">Warnung</translation>
</message>
<message>
<source>Cannot load picture.</source>
<translation type="obsolete">Kann das Bild nicht laden.</translation>
</message>
<message>
<source>Choose a file</source>
<translation type="obsolete">Wählen Sie eine Datei</translation>
</message>
<message>
<source>Pictures (</source>
<translation type="obsolete">Bilder (</translation>
</message>
@@ -5434,32 +5280,26 @@
<context>
<name>QgsComposerPictureBase</name>
<message>
<source>Picture Options</source>
<translation type="obsolete">Bild-Optionen</translation>
</message>
<message>
</message>
<message>
<source>Angle</source>
<translation type="obsolete">Winkel</translation>
</message>
<message>
</message>
<message>
</message>
<message>
<source>Browse</source>
<translation type="obsolete">Durchsuchen</translation>
</message>
@@ -5503,32 +5343,26 @@
<context>
<name>QgsComposerScaleBar</name>
<message>
<source>Single Box</source>
<translation type="obsolete">Einfachrahmen</translation>
</message>
<message>
<source>Double Box</source>
<translation type="obsolete">Doppelrahmen</translation>
</message>
<message>
<source>Line Ticks Middle</source>
<translation type="obsolete">Mittige Linieneinteilung</translation>
</message>
<message>
<source>Line Ticks Down</source>
<translation type="obsolete">Linieneinteilung unten</translation>
</message>
<message>
<source>Line Ticks Up</source>
<translation type="obsolete">Linieneinteilung oben</translation>
</message>
<message>
<source>Numeric</source>
<translation type="obsolete">Numerisch</translation>
</message>
@@ -5652,42 +5486,34 @@
<context>
<name>QgsComposerScalebarBase</name>
<message>
<source>Barscale Options</source>
<translation type="obsolete">Optionen für Massstabsbalken</translation>
</message>
<message>
<source>Segment size</source>
<translation type="obsolete">Segmentgrösse</translation>
</message>
<message>
<source>Number of segments</source>
<translation type="obsolete">Anzahl Segmente</translation>
</message>
<message>
<source>Map units per scalebar unit</source>
<translation type="obsolete">Karteneinheiten pro Massstabsbalkeneinheit</translation>
</message>
<message>
<source>Unit label</source>
<translation type="obsolete">Beschriftung der Einheit</translation>
</message>
<message>
<source>Map</source>
<translation type="obsolete">Karte</translation>
</message>
<message>
</message>
<message>
<source>Line width</source>
<translation type="obsolete">Linienbreite</translation>
</message>
@@ -5695,27 +5521,22 @@
<context>
<name>QgsComposerVectorLegend</name>
<message>
<source>Combine selected layers</source>
<translation type="obsolete">Kombiniere die ausgewählten Layer.</translation>
</message>
<message>
</message>
<message>
</message>
<message>
</message>
<message>
</message>
@@ -5771,114 +5592,92 @@
<context>
<name>QgsComposition</name>
<message>
<source>Custom</source>
<translation type="obsolete">Benutzerdefiniert</translation>
</message>
<message>
<source>A5 (148x210 mm)</source>
<translation type="obsolete">A5 (148x210 mm)</translation>
</message>
<message>
<source>A4 (210x297 mm)</source>
<translation type="obsolete">A4 (210x297 mm)</translation>
</message>
<message>
<source>A3 (297x420 mm)</source>
<translation type="obsolete">A3 (297x420 mm)</translation>
</message>
<message>
<source>A2 (420x594 mm)</source>
<translation type="obsolete">A2 (420x594 mm)</translation>
</message>
<message>
<source>A1 (594x841 mm)</source>
<translation type="obsolete">A1 (594x841 mm)</translation>
</message>
<message>
<source>A0 (841x1189 mm)</source>
<translation type="obsolete">A0 (841x1189 mm)</translation>
</message>
<message>
<source>B5 (176 x 250 mm)</source>
<translation type="obsolete">B5 (176 x 250 mm)</translation>
</message>
<message>
<source>B4 (250 x 353 mm)</source>
<translation type="obsolete">B4 (250 x 353 mm)</translation>
</message>
<message>
<source>B3 (353 x 500 mm)</source>
<translation type="obsolete">B3 (353 x 500 mm)</translation>
</message>
<message>
<source>B2 (500 x 707 mm)</source>
<translation type="obsolete">B2 (500 x 707 mm)</translation>
</message>
<message>
<source>B1 (707 x 1000 mm)</source>
<translation type="obsolete">B1 (707 x 1000 mm)</translation>
</message>
<message>
<source>B0 (1000 x 1414 mm)</source>
<translation type="obsolete">B0 (1000 x 1414 mm)</translation>
</message>
<message>
<source>Letter (8.5x11 inches)</source>
<translation type="obsolete">Letter (8.5x11 inches)</translation>
</message>
<message>
<source>Legal (8.5x14 inches)</source>
<translation type="obsolete">Legal (8.5x14 inches)</translation>
</message>
<message>
<source>Portrait</source>
<translation type="obsolete">Hochformat</translation>
</message>
<message>
<source>Landscape</source>
<translation type="obsolete">Querformat</translation>
</message>
<message>
<source>Out of memory</source>
<translation type="obsolete">Speicher ist am Ende (Out-of-memory).</translation>
</message>
<message>
<source>Qgis is unable to resize the paper size due to insufficient memory.
It is best that you avoid using the map composer until you restart qgis.
</source>
<translation type="obsolete">QGIS kann die Papiergröße wegen zu wenig Speicher nicht anpassen. Am besten Sie verweden den Mapcomposer nicht mehr, so lange sie QGIS nicht neu gestartet haben.</translation>
</message>
<message>
<source>Label</source>
<translation type="obsolete">Beschriftung</translation>
</message>
<message>
</message>
<message>
</message>
@@ -5921,7 +5720,6 @@
<translation>Orientierung</translation>
</message>
<message>
<source>Resolution (dpi)</source>
<translation type="obsolete">Auflösung (dpi)</translation>
</message>
@@ -6108,17 +5906,14 @@
<translation>mit Fehler:</translation>
</message>
<message>
<source>The source spatial reference system (SRS) is not valid. </source>
<translation type="obsolete">Das Quell-Referenzsystem (SRS) ist nicht gültig. </translation>
</message>
<message>
<source>The coordinates can not be reprojected. The SRS is: </source>
<translation type="obsolete">Die Koordinaten können nicht reprojiziert werden. Das SRS ist: </translation>
</message>
<message>
<source>The destination spatial reference system (SRS) is not valid. </source>
<translation type="obsolete">Das Zielreferenzsystem (SRS) ist nicht gültig. </translation>
</message>
@@ -7304,7 +7099,6 @@
<context>
<name>QgsGPSPluginGui</name>
<message>
<source>Choose a filename to save under</source>
<translation type="obsolete">Bitte wählen Sie einen Dateinamen</translation>
</message>
@@ -7349,7 +7143,6 @@
<translation>Dazu muss GPSBabel an einem Ort installiert sein, den QGIS finden kann.</translation>
</message>
<message>
<source>Select a GPX input file name, the type of conversion you want to perform, a GPX filename that you want to save the converted file as, and a name for the new layer created from the result.</source>
<translation type="obsolete">Wählen Sie eine GPX-Eingabedatei, die Konvertierung, die Sie durchführen möchten, einen Namen für die Ausgabedatei und einen Namen für den Layer, der aus den Ergebnissen erstellt werden soll.</translation>
</message>
@@ -7404,7 +7197,6 @@
<translation>QGIS selbst kann nur GPX-Dateien laden, aber viele andere Formate können nach GPX konvertiert werden mit (%1).</translation>
</message>
<message>
<source>Select a GPS file format and the file that you want to import, the feature type that you want to use, a GPX filename that you want to save the converted file as, and a name for the new layer.</source>
<translation type="obsolete">Wählen SIe ein GPS-Dateiformat, die Datei, die Sie importieren möchten, den Objekttyp, den Sie benutzen möchten, einen GPX-Dateinamen, unter dem Sie die konvertierten Daten speichern möchten und einen Namen für den neuen Layer.</translation>
</message>
@@ -7680,7 +7472,6 @@
<translation>Name</translation>
</message>
<message>
<source>Remove selected row</source>
<translation type="obsolete">Gewählte Zeilen löschen</translation>
</message>
@@ -7690,7 +7481,6 @@
<translation>...</translation>
</message>
<message>
<source>Add values manually</source>
<translation type="obsolete">Werte hinzufügen</translation>
</message>
@@ -7809,7 +7599,6 @@
<context>
<name>QgsGeorefWarpOptionsDialog</name>
<message>
<source>unstable</source>
<translation type="obsolete">instabil</translation>
</message>
@@ -8265,17 +8054,14 @@
<translation>Knotenpunkt (2 Linien)</translation>
</message>
<message>
<source>Column</source>
<translation type="obsolete">Spalte</translation>
</message>
<message>
<source>Type</source>
<translation type="obsolete">Typ</translation>
</message>
<message>
<source>Length</source>
<translation type="obsolete">Länge</translation>
</message>
@@ -8300,7 +8086,6 @@
<translation>Rechts: </translation>
</message>
<message>
<source>Disp</source>
<comment>
@@ -8308,7 +8093,6 @@
<translation type="obsolete">Anz.</translation>
</message>
<message>
<source>Color</source>
<comment>
@@ -8316,7 +8100,6 @@
<translation type="obsolete">Farbe</translation>
</message>
<message>
<comment>
@@ -8324,7 +8107,6 @@
</message>
<message>
<source>Index</source>
<comment>
@@ -8365,7 +8147,6 @@
<translation>Darstellung</translation>
</message>
<message>
<source>Column 1</source>
<translation type="obsolete">Spalte 1</translation>
</message>
@@ -9237,42 +9018,34 @@
<context>
<name>QgsGrassNewMapset</name>
<message>
<source>GRASS database</source>
<translation type="obsolete">GRASS-Datenbank</translation>
</message>
<message>
<source>GRASS location</source>
<translation type="obsolete">GRASS-Location</translation>
</message>
<message>
<source>Projection</source>
<translation type="obsolete">Projektion</translation>
</message>
<message>
<source>Default GRASS Region</source>
<translation type="obsolete">Voreingestellte GRASS-'region'</translation>
</message>
<message>
<source>Mapset</source>
<translation type="obsolete">Mapset</translation>
</message>
<message>
<source>Create New Mapset</source>
<translation type="obsolete">Neues Mapset erzeugen</translation>
</message>
<message>
<source>Tree</source>
<translation type="obsolete">Baum</translation>
</message>
<message>
<source>Comment</source>
<translation type="obsolete">Kommentar</translation>
</message>
@@ -9302,7 +9075,6 @@
<translation>1. Location</translation>
</message>
<message>
<source>Owner</source>
<translation type="obsolete">Besitzer</translation>
</message>
@@ -9406,7 +9178,6 @@
<translation> Spalte </translation>
</message>
<message>
<source>Cannot create QgsSpatialRefSys</source>
<translation type="obsolete">Kann QgsSpatialRefSys nicht erzeugen</translation>
</message>
@@ -9499,7 +9270,6 @@
<context>
<name>QgsGrassNewMapsetBase</name>
<message>
</message>
@@ -9519,7 +9289,6 @@
<translation>Datenbank:</translation>
</message>
<message>
</message>
@@ -9629,7 +9398,6 @@
<translation>Mapset:</translation>
</message>
<message>
<source><html><head><meta name="qrichtext" content="1" /><style type="text/css">
p, li { white-space: pre-wrap; }
</style></head><body style=" font-family:'Verdana'; font-size:10pt; font-weight:400; font-style:normal;">
@@ -9642,7 +9410,6 @@
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;">Die GRASS Datenbank (Location) bildet die oberste Ebene in dieser Struktur.</p></body></html></translation>
</message>
<message>
@@ -9653,7 +9420,6 @@
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;">Die GRASS location ist eine Sammlung von Karten in einer definierten Projektion und räumlichen Ausdehnung.</p></body></html></translation>
</message>
<message>
@@ -9666,7 +9432,6 @@
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;">Es ist möglich, die 'default region' nachträglich zu ändern.</p></body></html></translation>
</message>
<message>
@@ -10284,7 +10049,6 @@
<translation>Bitte geben Sie einen Dateinamen ein, bevor Sie auf OK drücken!</translation>
</message>
<message>
</message>
@@ -11066,12 +10830,10 @@
<translation>&Eigenschaften</translation>
</message>
<message>
<source>More layers</source>
<translation type="obsolete">Weitere Layer</translation>
</message>
<message>
<source>This item contains more layer files. Displaying more layers in table is not supported.</source>
<translation type="obsolete">Dieser Eintrag enthält weitere Layerdateien. Die Anzeige von mehreren Layer in einer Tabelle wird nicht unterstützt.</translation>
</message>
@@ -11089,7 +10851,6 @@
<context>
<name>QgsLegendLayerFile</name>
<message>
<source>Attribute table - </source>
<translation type="obsolete">Attributtabelle - </translation>
</message>
@@ -11099,22 +10860,18 @@
<translation>Layer speichern als...</translation>
</message>
<message>
<source>Start editing failed</source>
<translation type="obsolete">Beginnen der Editierung fehlgeschlagen.</translation>
</message>
<message>
<source>Provider cannot be opened for editing</source>
<translation type="obsolete">Der Provider kann nicht zum Editieren geöffnet werden.</translation>
</message>
<message>
<translation type="obsolete">Digitalisieren stoppen</translation>
</message>
<message>
</message>
@@ -11124,22 +10881,18 @@
<translation>Fehler</translation>
</message>
<message>
<source>Could not commit changes</source>
<translation type="obsolete">Änderungen konnten nicht gespeichern werden.</translation>
</message>
<message>
<source>Problems during roll back</source>
<translation type="obsolete">Problem beim Rückgängigmachen (rollback).</translation>
</message>
<message>
<source>Not a vector layer</source>
<translation type="obsolete">Kein Vektorlayer</translation>
</message>
<message>
<source>To open an attribute table, you must select a vector layer in the legend</source>
<translation type="obsolete">Um eine Attributetabelle zu Öffnen müssen Sie in der Legende einen Layer auswählen.</translation>
</message>
@@ -11214,12 +10967,10 @@
</message>
<message>
<source>bad_alloc exception</source>
<translation type="obsolete">Speicher-Fehler</translation>
</message>
<message>
<source>Filling the attribute table has been stopped because there was no more virtual memory left</source>
<translation type="obsolete">Das Auffüllen der Attributtabelle wurde beendet, da kein virtueller Speicher mehr zur Verfügung steht</translation>
</message>
@@ -11298,12 +11049,10 @@
<context>
<name>QgsMapToolIdentify</name>
<message>
<source>No features found</source>
<translation type="obsolete">Keine Objekte gefunden</translation>
</message>
<message>
<source><p>No features were found within the search radius. Note that it is currently not possible to use the identify tool on unsaved features.</p></source>
<translation type="obsolete"><p>Es wurden keine Objekte innerhalb des Suchradius gefunden. Beachten Sie, dass das Identifizierwerkzeug nicht mit noch nicht abgespeicherten Objekten funktioniert.</p></translation>
</message>
@@ -11406,7 +11155,6 @@
<translation>MapServer map files (*.map);;Alle Dateien (*.*)</translation>
</message>
<message>
<source>QGIS Project Files (*.qgs);;All files (*.*)</source>
<comment>
@@ -11414,7 +11162,6 @@
<translation type="obsolete">QGIS-Projektdatei (*.qgs);;Alle Dateien (*.*)</translation>
</message>
<message>
<source> exists.
Do you want to overwrite it?</source>
<comment>
@@ -12132,12 +11879,10 @@
<translation>Suchradius</translation>
</message>
<message>
<source>Pro&jection</source>
<translation type="obsolete">Pro&jektion</translation>
</message>
<message>
<source>When layer is loaded that has no projection information</source>
<translation type="obsolete">Wenn ein Layer ohne Projektionsinformationen geladen wird</translation>
</message>
@@ -12372,17 +12117,14 @@
<translation>Markenstil</translation>
</message>
<message>
<source>Prompt for projection</source>
<translation type="obsolete">Projektion abfragen</translation>
</message>
<message>
<source>Project wide default projection will be used</source>
<translation type="obsolete">Projektweite Projektionsvoreinstellung</translation>
</message>
<message>
<source>Global default projection displa&yed below will be used</source>
<translation type="obsolete">Folgende globale Projektionsvoreinstellung wird benutzt</translation>
</message>
@@ -12864,7 +12606,7 @@
<message>
<location filename="../python/plugins/plugin_installer/i18n.cpp" line="33"/>
<source>Couldn't parse output from the repository</source>
- <translation>Konnte Ausgabe des Repositorys nicht interpretieren</translation>
+ <translation type="unfinished">Konnte Ausgabe des Repositories nicht interpretieren</translation>
</message>
<message>
<location filename="../python/plugins/plugin_installer/i18n.cpp" line="34"/>
@@ -12884,7 +12626,7 @@
<message>
<location filename="../python/plugins/plugin_installer/i18n.cpp" line="47"/>
<source>Install more plugins from remote repositories</source>
- <translation>Mehr Plugins von entfernten Repositorys installieren</translation>
+ <translation type="unfinished">Mehr Plugins von entfernten Repositories installieren</translation>
</message>
<message>
<location filename="../python/plugins/plugin_installer/i18n.cpp" line="50"/>
@@ -12909,7 +12651,7 @@
<message>
<location filename="../python/plugins/plugin_installer/i18n.cpp" line="60"/>
<source>Error reading repository:</source>
- <translation>Fehler beim Lesen des Repositorys</translation>
+ <translation type="unfinished">Fehler beim Lesen des Repositories</translation>
</message>
<message>
<location filename="../python/plugins/plugin_installer/i18n.cpp" line="66"/>
@@ -12937,12 +12679,12 @@
<message>
<location filename="../python/plugins/plugin_installer/i18n.cpp" line="117"/>
- <translation>Fehler beim Lesen des Repositorys:</translation>
+ <translation type="unfinished">Fehler beim Lesen des Repositories:</translation>
</message>
<message>
<location filename="../python/plugins/plugin_installer/i18n.cpp" line="118"/>
<source>all repositories</source>
- <translation>Alle Repositorys</translation>
+ <translation type="unfinished">Alle Repositories</translation>
</message>
<message>
<location filename="../python/plugins/plugin_installer/i18n.cpp" line="119"/>
@@ -13144,14 +12886,12 @@
<translation>Plugin erfolgreich installiert</translation>
</message>
<message>
<source>Python plugin installed.
You have to enable it in the Plugin Manager.</source>
<translation type="obsolete">Python-Plugin installiert.
Sie müssen es noch im Plugin-Manager aktivieren.</translation>
</message>
<message>
<source>Python plugin reinstalled.
You have to restart Quantum GIS to reload it.</source>
<translation type="obsolete">Python-Plugin erneut installiert.
@@ -13198,7 +12938,6 @@
<translation>Dieses Plugin ist inkompatibel mit Ihrer Quantum GIS-Version und wird wahrscheinlich nicht funktionieren.</translation>
</message>
<message>
<source>The required Python module is not installed.
For more information, please visit its homepage.</source>
<translation type="obsolete">Das benötigte Pythonmodul ist nicht installiert.
@@ -13282,7 +13021,7 @@
<message>
<location filename="../python/plugins/plugin_installer/i18n.cpp" line="204"/>
<source>You are about to add several plugin repositories that are neither authorized nor supported by the Quantum GIS team. Plugin authors generally make efforts to ensure that their work is useful and safe, however, we can assume no responsibility for them.</source>
- <translation>Sie sind dabei Plugin-Repositorys hinzufügen, die zwar vom Quantum GIS-Team weder autorisiert noch unterstützt werden, aber von von uns verbundenen Leuten zur Verfügung gestellt werden. Plugin-Autoren versuchen grundsätzlich ihre Arbeit nützlich und sicher zu machen, aber wir können uns auf deren Verantwortungsgefühl nicht verlassen. Seien Sie gewarnt!</translation>
+ <translation type="unfinished">Sie sind dabei Plugin-Repositories hinzufügen, die zwar vom Quantum GIS-Team weder autorisiert noch unterstützt werden, aber von von uns verbundenen Leuten zur Verfügung gestellt werden. Plugin-Autoren versuchen grundsätzlich ihre Arbeit nützlich und sicher zu machen, aber wir können uns auf deren Verantwortungsgefühl nicht verlassen. Seien Sie gewarnt!</translation>
</message>
</context>
<context>
@@ -13293,7 +13032,6 @@
<translation>QGIS-Python-Plugin-Installation</translation>
</message>
<message>
</message>
@@ -13385,7 +13123,7 @@
<message>
<location filename="../python/plugins/plugin_installer/qgsplugininstallerbase.ui" line="260"/>
<source>Repositories</source>
- <translation>Repositorys</translation>
+ <translation type="unfinished">Repositories</translation>
</message>
<message>
<location filename="../python/plugins/plugin_installer/qgsplugininstallerbase.ui" line="263"/>
@@ -13747,7 +13485,6 @@
<translation>Eingeschaltet</translation>
</message>
<message>
<source>[place for a warning message]</source>
<translation type="obsolete">[Eine Warnung hier]</translation>
</message>
@@ -13941,7 +13678,6 @@
<translation>Derzeit werden alle modifizierten Dateien im TIFF-Format geschrieben.</translation>
</message>
<message>
<source>-modified</source>
<comment>
@@ -14043,12 +13779,10 @@
<translation>Relation. Die Fehlermeldung der Datenbank war:</translation>
</message>
<message>
<source>No GEOS Support!</source>
<translation type="obsolete">Keine GEOS Unterstützung!</translation>
</message>
<message>
<source>Your PostGIS installation has no GEOS support.
Feature selection and identification will not work properly.
Please install PostGIS with GEOS support (http://geos.refractions.net)</source>
@@ -14605,12 +14339,10 @@
<translation>Pixelgröße:</translation>
</message>
<message>
<source>Raster Extent: </source>
<translation type="obsolete">Rasterausmaß:</translation>
</message>
<message>
<source>Clipped area: </source>
<translation type="obsolete">Ausschnittsbereich:</translation>
</message>
@@ -14833,7 +14565,6 @@
<translation>Ausgeflippt</translation>
</message>
<message>
<source>Palette</source>
<translation type="obsolete">Palette</translation>
</message>
@@ -14882,7 +14613,6 @@
<translation>Für diese Art von Raster können keine Pyramiden erstellt werden. </translation>
</message>
<message>
<source>Custom Colormap</source>
<translation type="obsolete">Individuelle Farbkarte</translation>
</message>
@@ -14912,7 +14642,6 @@
<translation>Diskret</translation>
</message>
<message>
<source>Linearly</source>
<translation type="obsolete">Linear</translation>
</message>
@@ -15152,7 +14881,6 @@
<translation>Allgemein</translation>
</message>
<message>
<source>Legend:</source>
<translation type="obsolete">Legende:</translation>
</message>
@@ -15212,7 +14940,6 @@
<translation>Zeilen:</translation>
</message>
<message>
<source>Palette:</source>
<translation type="obsolete">Palette:</translation>
</message>
@@ -15247,7 +14974,6 @@
<translation>Erneuern</translation>
</message>
<message>
<source>Change</source>
<translation type="obsolete">Wechseln</translation>
</message>
@@ -15522,7 +15248,6 @@
<translation>Klassifikationsmodus</translation>
</message>
<message>
<source>Spatial reference system</source>
<translation type="obsolete">Räumliches Bezugssystem</translation>
</message>
@@ -15542,7 +15267,6 @@
<translation>Minimum</translation>
</message>
<message>
<source>Show debug info</source>
<translation type="obsolete">Debug-Info anzeigen</translation>
</message>
@@ -15627,12 +15351,10 @@
<translation>Vorgabe R:1 G:2 B:3</translation>
</message>
<message>
<source>Save current band combination as default. This setting will be persistent between QGIS sessions.</source>
<translation type="obsolete">Aktuelle Bandkombination als Vorgabe speichern. Diese Einstellung wird zwischen Sitzungen anhalten.</translation>
</message>
<message>
<source>Save current band combination as a default. This setting will be persistent between QGIS sessions.</source>
<translation type="obsolete">Aktuelle Bandkombination als eine Vorgabe speichern. Diese Einstellung wird zwischen Sitzungen anhalten.</translation>
</message>
@@ -15983,7 +15705,6 @@
<translation>Suche Query Builder</translation>
</message>
<message>
@@ -16206,7 +15927,6 @@
<translation>Der Fehler war:</translation>
</message>
<message>
<source>... (rest of SQL trimmed)</source>
<comment>
@@ -16724,7 +16444,6 @@
<translation><p>In der gewählte Datenbank ist PostGIS nicht installiert. PostGIS wird jedoch zum Speichern von räumlichen Daten benötigt.</p></translation>
</message>
<message>
<source>Checking to see if </source>
<translation type="obsolete">Schaumermal...</translation>
</message>
@@ -16973,42 +16692,34 @@
<context>
<name>QgsVectorLayer</name>
<message>
<source>Could not commit the added features.</source>
<translation type="obsolete">Hinzugefügte Objekte konnten nicht gespeichert werden.</translation>
</message>
<message>
<source>No other types of changes will be committed at this time.</source>
<translation type="obsolete">Es werden keine weiteren Änderungen gespeichert.</translation>
</message>
<message>
<source>Could not commit the changed attributes.</source>
<translation type="obsolete">Die geänderten Attribute konnte nicht gespeichert werden.</translation>
</message>
<message>
<source>However, the added features were committed OK.</source>
<translation type="obsolete">Die hinzugefügten Objekte wurden allerdings gespeichert.</translation>
</message>
<message>
<source>Could not commit the changed geometries.</source>
<translation type="obsolete">Die geänderten Geometrien konnten nicht gespeichert werden.</translation>
</message>
<message>
<source>However, the changed attributes were committed OK.</source>
<translation type="obsolete">Die geänderten Attribute wurden jedoch gespeichert.</translation>
</message>
<message>
<source>Could not commit the deleted features.</source>
<translation type="obsolete">Die Löschung von Objekte konnte nicht vollzogen werden.</translation>
</message>
<message>
<source>However, the changed geometries were committed OK.</source>
<translation type="obsolete">Die geänderten Geometrien wurden jedoch gespeichert.</translation>
</message>
@@ -17146,7 +16857,6 @@
<translation>Räumlicher Index</translation>
</message>
<message>
<source>Creation of spatial index successfull</source>
<translation type="obsolete">Erstellung des räumlichen Indexes erfolgreich</translation>
</message>
@@ -17499,7 +17209,6 @@
<translation>Optionen</translation>
</message>
<message>
<source>Change SRS</source>
<translation type="obsolete">SRS ändern</translation>
</message>
@@ -17669,7 +17378,6 @@
<translation>WMS-Service-Ausnahme</translation>
</message>
<message>
<source>DOM Exception</source>
<translation type="obsolete">DOM-Ausnahme</translation>
</message>
@@ -17754,7 +17462,6 @@
<translation>Der WMS-Betreiber sagt folgendes:</translation>
</message>
<message>
<source>This is probably due to a bug in the QGIS program. Please report this error.</source>
<translation type="obsolete">Dieses Verhalten kommt wahrscheinlich durch einen Bug in QGIS. Bitte melden Sie den Fehler bei den Entwicklern.</translation>
</message>
@@ -18036,22 +17743,18 @@
<context>
<name>RepositoryDetailsDialog</name>
<message>
<source>Repository details</source>
<translation type="obsolete">Repository Details</translation>
</message>
<message>
<source>Name:</source>
<translation type="obsolete">Name:</translation>
</message>
<message>
<source>URL:</source>
<translation type="obsolete">URL:</translation>
</message>
<message>
<source>http://</source>
<translation type="obsolete">http://</translation>
</message>
@@ -18174,7 +17877,6 @@
<context>
<name>pluginname</name>
<message>
</message>
