[QGIS Commit] r10374 - in trunk/qgis/src: app/attributetable ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Mar 21 14:06:49 EDT 2009
Author: wonder
Date: 2009-03-21 14:06:49 -0400 (Sat, 21 Mar 2009)
New Revision: 10374
   trunk/qgis/src/app/attributetable/BeataDialog.cpp
   trunk/qgis/src/app/attributetable/BeataDialog.h
   trunk/qgis/src/ui/BeataGui.ui
attribute table: docking available again, better switching between all/selected rows, fixed editing toggle
Modified: trunk/qgis/src/app/attributetable/BeataDialog.cpp
--- trunk/qgis/src/app/attributetable/BeataDialog.cpp	2009-03-21 17:34:03 UTC (rev 10373)
+++ trunk/qgis/src/app/attributetable/BeataDialog.cpp	2009-03-21 18:06:49 UTC (rev 10374)
@@ -30,8 +30,25 @@
 #include "qgisapp.h"
 #include "qgssearchquerybuilder.h"
+class QBeataTableDock : public QDockWidget
+  public:
+    QBeataTableDock( const QString & title, QWidget * parent = 0, Qt::WindowFlags flags = 0 )
+        : QDockWidget( title, parent, flags )
+      setObjectName("AttributeTable"); // set object name so the position can be saved
+    virtual void closeEvent( QCloseEvent * ev )
+      deleteLater();
 BeataDialog::BeataDialog(QgsVectorLayer *theLayer, QWidget *parent, Qt::WindowFlags flags)
-  : QDialog(parent, flags)
+  : QDialog(parent, flags), mDock(NULL)
   mLayer = theLayer;
@@ -50,9 +67,17 @@
   mColumnBox = columnBox;
   columnBoxInit();
-  mShowBox = showBox;
-  mShowBox->addItem("Show unselected rows");
-  mShowBox->addItem("Hide unselected rows");
+  QSettings mySettings;
+  bool myDockFlag = mySettings.value( "/qgis/dockAttributeTable", false ).toBool();
+  if ( myDockFlag )
+    mDock = new QBeataTableDock( tr( "Attribute table - %1" ).arg( mLayer->name() ), QgisApp::instance() );
+    mDock->setAllowedAreas( Qt::BottomDockWidgetArea | Qt::TopDockWidgetArea );
+    mDock->setWidget( this );
+    QgisApp::instance()->addDockWidget( Qt::BottomDockWidgetArea, mDock );
+  setWindowTitle( tr( "Attribute table - %1" ).arg( mLayer->name() ) );
   mMenuActions = new QMenu();
   mMenuActions->addAction(tr("Advanced search"), this, SLOT(advancedSearch()));
@@ -69,12 +94,14 @@
   mActionToggleEditing->setCheckable( true );
   mActionToggleEditing->setEnabled( mLayer->dataProvider()->capabilities() & QgsVectorDataProvider::ChangeAttributeValues );
   // info from table to application
-  connect( this, SIGNAL( editingToggled( QgsMapLayer * ) ), parentWidget(), SLOT( toggleEditing( QgsMapLayer * ) ) );
+  connect( this, SIGNAL( editingToggled( QgsMapLayer * ) ), QgisApp::instance(), SLOT( toggleEditing( QgsMapLayer * ) ) );
   // info from layer to table
   connect( mLayer, SIGNAL( editingStarted() ), this, SLOT( editingToggled() ) );
   connect( mLayer, SIGNAL( editingStopped() ), this, SLOT( editingToggled() ) );
-  connect(mShowBox, SIGNAL(currentIndexChanged(const QString &)), this, SLOT(toggleShowDeselected(const QString &)));
+  connect(btnShowAll, SIGNAL(clicked()), this, SLOT(clickedShowAll()));
+  connect(btnShowSelected, SIGNAL(clicked()), this, SLOT(clickedShowSelected()));
   connect(searchButton, SIGNAL(clicked()), this, SLOT(search()));
   connect(actionsButton, SIGNAL(clicked()), this, SLOT(showAdvanced()));
@@ -82,6 +109,8 @@
   connect(mLayer, SIGNAL(layerDeleted()), this, SLOT( close()));
   connect(mView->verticalHeader(), SIGNAL(sectionClicked(int)), this, SLOT(updateRowSelection(int)));
   connect(mModel, SIGNAL(modelChanged()), this, SLOT(updateSelection()));
+  clickedShowAll(); // make sure the show all button is checked
   mLastClickedHeaderIndex = 0;
   mSelectionModel = new QItemSelectionModel(mFilterModel);
@@ -96,8 +125,11 @@
   QDialog::closeEvent( event );
-  QSettings settings;
-  settings.setValue( "/Windows/BetterAttributeTable/geometry", saveGeometry() );
+  if ( mDock == NULL )
+    QSettings settings;
+    settings.setValue( "/Windows/BetterAttributeTable/geometry", saveGeometry() );
@@ -188,18 +220,30 @@
   mLayer->removeSelection();
-void BeataDialog::toggleShowDeselected(const QString &text)
+void BeataDialog::clickedShowAll()
-  if (text == "Show unselected rows")
+  // the button can't be unchecked by clicking it
+  // gets unchecked when show selected is clicked
+  if (!btnShowAll->isChecked())
-    mFilterModel->mHideUnselected = false;
-    //TODO: divne
-    //mModel->changeLayout();
-    mFilterModel->invalidate();
-    return;
+    btnShowAll->setChecked(true);
+  btnShowSelected->setChecked(false);
+  mFilterModel->mHideUnselected = false;
+  mFilterModel->invalidate();
+  //TODO: weird
+  //mModel->changeLayout();
-  // show only selected
+void BeataDialog::clickedShowSelected()
+  if (!btnShowSelected->isChecked())
+    btnShowSelected->setChecked(true);
+  btnShowAll->setChecked(false);
   mFilterModel->mHideUnselected = true;
Modified: trunk/qgis/src/app/attributetable/BeataDialog.h
--- trunk/qgis/src/app/attributetable/BeataDialog.h	2009-03-21 17:34:03 UTC (rev 10373)
+++ trunk/qgis/src/app/attributetable/BeataDialog.h	2009-03-21 18:06:49 UTC (rev 10374)
@@ -35,6 +35,7 @@
 class QLineEdit;
 class QComboBox;
 class QMenu;
+class QDockWidget;
 class BeataModel;
 class BeataFilterModel;
@@ -60,8 +61,10 @@
   void updateSelectionFromLayer();
   void updateRowSelection(int index);
   void updateRowSelection(int first, int last, bool startNewSelection);
-  void toggleShowDeselected(const QString &text);
+  void clickedShowAll();
+  void clickedShowSelected();
   void startEditing();
   void invertSelection();
   void removeSelection();
@@ -98,6 +101,8 @@
   QItemSelectionModel* mSelectionModel;
   int mLastClickedHeaderIndex;
+  QDockWidget *mDock;
 #endif
Modified: trunk/qgis/src/ui/BeataGui.ui
--- trunk/qgis/src/ui/BeataGui.ui	2009-03-21 17:34:03 UTC (rev 10373)
+++ trunk/qgis/src/ui/BeataGui.ui	2009-03-21 18:06:49 UTC (rev 10374)
@@ -21,7 +21,7 @@
      <item>
       <widget class="QPushButton" name="searchButton" >
        <property name="text" >
-        <string>Search</string>
+        <string>&amp;Search</string>
        </property>
       </widget>
      </item>
@@ -46,21 +46,53 @@
       <widget class="QComboBox" name="columnBox" />
      </item>
      <item>
-      <widget class="Line" name="line" >
+      <spacer>
        <property name="orientation" >
-        <enum>Qt::Vertical</enum>
+        <enum>Qt::Horizontal</enum>
        </property>
-      </widget>
+       <property name="sizeHint" >
+        <size>
+         <width>40</width>
+         <height>20</height>
+        </size>
+       </property>
+      </spacer>
      </item>
      <item>
-      <widget class="QComboBox" name="showBox" />
-     </item>
-     <item>
-      <widget class="Line" name="line_2" >
-       <property name="orientation" >
+      <layout class="QHBoxLayout" >
+       <property name="spacing" >
+        <number>0</number>
        </property>
-      </widget>
+       <property name="leftMargin" >
+       </property>
+       <item>
+        <widget class="QPushButton" name="btnShowAll" >
+         <property name="focusPolicy" >
+          <enum>Qt::NoFocus</enum>
+         </property>
+         <property name="text" >
+          <string>&amp;All</string>
+         </property>
+         <property name="checkable" >
+          <bool>true</bool>
+         </property>
+        </widget>
+       </item>
+       <item>
+        <widget class="QPushButton" name="btnShowSelected" >
+         </property>
+          <string>S&amp;elected</string>
+         </property>
+          <bool>true</bool>
+         </property>
+        </widget>
+       </item>
+      </layout>
      </item>
      <item>
       <widget class="QPushButton" name="actionsButton" >
@@ -80,6 +112,15 @@
    <header>BeataView.h</header>
   </customwidget>
  </customwidgets>
+ <tabstops>
+  <tabstop>mView</tabstop>
+  <tabstop>searchButton</tabstop>
+  <tabstop>query</tabstop>
+  <tabstop>columnBox</tabstop>
+  <tabstop>btnShowAll</tabstop>
+  <tabstop>btnShowSelected</tabstop>
+  <tabstop>actionsButton</tabstop>
+ </tabstops>
  <resources/>
  <connections/>
 </ui>
More information about the QGIS-commit mailing list
