[QGIS Commit] r10393 - in trunk/qgis/src: app
plugins/coordinate_capture
svn_qgis at osgeo.org
Sat Mar 21 18:04:51 EDT 2009
Author: timlinux
Date: 2009-03-21 18:04:51 -0400 (Sat, 21 Mar 2009)
New Revision: 10393
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
trunk/qgis/src/app/qgisappinterface.cpp
trunk/qgis/src/app/qgisappinterface.h
trunk/qgis/src/plugins/coordinate_capture/coordinatecapture.cpp
trunk/qgis/src/plugins/coordinate_capture/coordinatecapture.h
Enable plugins to dynamically change their theme if it is changed in app props. Its up to each plugin to individually support this
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-03-21 21:53:52 UTC (rev 10392)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-03-21 22:04:51 UTC (rev 10393)
@@ -1485,6 +1485,7 @@
mComposer->setupTheme();
+ emit currentThemeChanged( theThemeName );
void QgisApp::setupConnections()
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2009-03-21 21:53:52 UTC (rev 10392)
+++ trunk/qgis/src/app/qgisapp.h 2009-03-21 22:04:51 UTC (rev 10393)
@@ -599,6 +599,12 @@
//! emitted when a new bookmark is added
void bookmarkAdded();
+ /** Signal emitted when the current theme is changed so plugins
+ * can change there tool button icons.
+ * @note This was added in QGIS 1.1
+ void currentThemeChanged ( QString );
private:
/** This method will open a dialog so the user can select the sublayers
* to load
Modified: trunk/qgis/src/app/qgisappinterface.cpp
--- trunk/qgis/src/app/qgisappinterface.cpp 2009-03-21 21:53:52 UTC (rev 10392)
+++ trunk/qgis/src/app/qgisappinterface.cpp 2009-03-21 22:04:51 UTC (rev 10393)
@@ -36,6 +36,8 @@
// connect signals
connect( qgis->legend(), SIGNAL( currentLayerChanged( QgsMapLayer * ) ),
this, SIGNAL( currentLayerChanged( QgsMapLayer * ) ) );
+ connect( qgis, SIGNAL( currentThemeChanged( QString ) ),
+ this, SIGNAL( currentThemeChanged( QString ) ) );
Modified: trunk/qgis/src/app/qgisappinterface.h
--- trunk/qgis/src/app/qgisappinterface.h 2009-03-21 21:53:52 UTC (rev 10392)
+++ trunk/qgis/src/app/qgisappinterface.h 2009-03-21 22:04:51 UTC (rev 10393)
@@ -234,6 +234,9 @@
virtual QAction *actionHelpSeparator2();
virtual QAction *actionAbout();
+ signals:
+ void currentThemeChanged( QString );
private:
/// QgisInterface aren't copied
Modified: trunk/qgis/src/plugins/coordinate_capture/coordinatecapture.cpp
--- trunk/qgis/src/plugins/coordinate_capture/coordinatecapture.cpp 2009-03-21 21:53:52 UTC (rev 10392)
+++ trunk/qgis/src/plugins/coordinate_capture/coordinatecapture.cpp 2009-03-21 22:04:51 UTC (rev 10393)
@@ -83,6 +83,7 @@
mCrs.createFromSrsId( GEOCRS_ID ); // initialize the CRS object
connect( mQGisIface->mapCanvas()->mapRenderer(), SIGNAL( destinationSrsChanged() ), this, SLOT( setSourceCrs() ) );
+ connect( mQGisIface, SIGNAL( currentThemeChanged ( QString ) ), this, SLOT( setCurrentTheme( QString ) ) );
setSourceCrs(); //set up the source CRS
mTransform.setDestCRS( mCrs ); // set the CRS in the transform
@@ -251,6 +252,11 @@
delete mQActionPointer;
+void CoordinateCapture::setCurrentTheme ( QString theThemeName )
+ qDebug (" Current theme changed \n\n\n\n\n" );
+ mQActionPointer->setIcon( QIcon());
Modified: trunk/qgis/src/plugins/coordinate_capture/coordinatecapture.h
--- trunk/qgis/src/plugins/coordinate_capture/coordinatecapture.h 2009-03-21 21:53:52 UTC (rev 10392)
+++ trunk/qgis/src/plugins/coordinate_capture/coordinatecapture.h 2009-03-21 22:04:51 UTC (rev 10393)
@@ -103,6 +103,8 @@
void copy();
//! called when the project's CRS is changed
void setSourceCrs();
+ //! update the plugins theme when the app tells us its theme is changed
+ void setCurrentTheme ( QString theThemeName );
private:
//! Container for the coordinate info
