[QGIS Commit] r10410 - trunk/qgis/python/plugins/fTools
svn_qgis at osgeo.org
Mon Mar 23 11:43:18 EDT 2009
Author: cfarmer
Date: 2009-03-23 11:43:17 -0400 (Mon, 23 Mar 2009)
New Revision: 10410
trunk/qgis/python/plugins/fTools/fTools.py
on the fly theme change support for fTools -> 'default' and 'gis' themes available
Modified: trunk/qgis/python/plugins/fTools/fTools.py
--- trunk/qgis/python/plugins/fTools/fTools.py 2009-03-23 15:12:55 UTC (rev 10409)
+++ trunk/qgis/python/plugins/fTools/fTools.py 2009-03-23 15:43:17 UTC (rev 10410)
@@ -66,117 +66,124 @@
return QIcon( ":" + defaultPath )
else:
return QIcon()
+ def updateThemeIcons( self, theme ):
+ self.analysisMenu.setIcon( QIcon( self.getThemeIcon( "analysis.png" ) ) )
+ self.distMatrix.setIcon( QIcon( self.getThemeIcon( "matrix.png" ) ) )
+ self.sumLines.setIcon( QIcon( self.getThemeIcon( "sum_lines.png" ) ) )
+ self.pointsPoly.setIcon( QIcon( self.getThemeIcon( "sum_points.png" ) ) )
+ self.compStats.setIcon( QIcon( self.getThemeIcon( "basic_statistics.png" ) ) )
+ self.listUnique.setIcon( QIcon( self.getThemeIcon( "unique.png" ) ) )
+ self.nearestNeigh.setIcon( QIcon( self.getThemeIcon( "neighbour.png" ) ) )
+ self.meanCoords.setIcon( QIcon( self.getThemeIcon( "mean.png" ) ) )
+ self.intLines.setIcon( QIcon( self.getThemeIcon( "intersections.png" ) ) )
+ self.researchMenu.setIcon( QIcon( self.getThemeIcon( "sampling.png" ) ) )
+ self.randSel.setIcon( QIcon( self.getThemeIcon( "random_selection.png" ) ) )
+ self.randSub.setIcon( QIcon( self.getThemeIcon( "sub_selection.png" ) ) )
+ self.randPoints.setIcon( QIcon( self.getThemeIcon( "random_points.png" ) ) )
+ self.regPoints.setIcon( QIcon( self.getThemeIcon( "regular_points.png" ) ) )
+ self.vectGrid.setIcon( QIcon( self.getThemeIcon( "vector_grid.png" ) ) )
+ self.selectLocation.setIcon( QIcon( self.getThemeIcon( "select_location.png" ) ) )
+ self.layerExtent.setIcon( QIcon( self.getThemeIcon( "layer_extent.png" ) ) )
+ self.geoMenu.setIcon( QIcon( self.getThemeIcon( "geoprocessing.png" ) ) )
+ self.minConvex.setIcon( QIcon( self.getThemeIcon( "convex_hull.png" ) ) )
+ self.dynaBuffer.setIcon( QIcon( self.getThemeIcon( "buffer.png" ) ) )
+ self.intersect.setIcon( QIcon( self.getThemeIcon( "intersect.png" ) ) )
+ self.union.setIcon( QIcon( self.getThemeIcon( "union.png" ) ) )
+ self.symDifference.setIcon( QIcon( self.getThemeIcon( "sym_difference.png" ) ) )
+ self.clip.setIcon( QIcon( self.getThemeIcon( "clip.png" ) ) )
+ self.dissolve.setIcon( QIcon( self.getThemeIcon( "dissolve.png" ) ) )
+ self.erase.setIcon( QIcon( self.getThemeIcon( "difference.png" ) ) )
+ self.conversionMenu.setIcon( QIcon( self.getThemeIcon( "geometry.png" ) ) )
+ self.compGeo.setIcon( QIcon( self.getThemeIcon( "export_geometry.png") ) )
+ self.checkGeom.setIcon( QIcon( self.getThemeIcon( "check_geometry.png") ) )
+ self.centroids.setIcon( QIcon( self.getThemeIcon( "centroids.png") ) )
+ self.delaunay.setIcon( QIcon( self.getThemeIcon( "delaunay.png") ) )
+ self.extNodes.setIcon( QIcon( self.getThemeIcon( "extract_nodes.png") ) )
+ self.simplify.setIcon( QIcon( self.getThemeIcon( "simplify.png") ) )
+ self.multiToSingle.setIcon( QIcon( self.getThemeIcon( "multi_to_single.png") ) )
+ self.singleToMulti.setIcon( QIcon( self.getThemeIcon( "single_to_multi.png") ) )
+ self.polysToLines.setIcon( QIcon( self.getThemeIcon( "to_lines.png") ) )
+ self.dataManageMenu.setIcon( QIcon( self.getThemeIcon( "management.png") ) )
+ self.project.setIcon( QIcon( self.getThemeIcon( "export_projection.png") ) )
+ self.define.setIcon( QIcon( self.getThemeIcon( "define_projection.png" ) ) )
+ self.joinAttr.setIcon( QIcon( self.getThemeIcon( "join_attributes.png" ) ) )
+ self.spatJoin.setIcon( QIcon( self.getThemeIcon( "join_location.png" ) ) )
+ self.splitVect.setIcon( QIcon( self.getThemeIcon( "split_layer.png" ) ) )
+ self.ftools_aboot.setIcon( QIcon( self.getThemeIcon( "ftools_logo.png" ) ) )
def initGui( self ):
if int( self.QgisVersion ) < 1:
QMessageBox.warning( self.iface.getMainWindow(), "fTools",
QCoreApplication.translate( "fTools", "Quantum GIS version detected: " ) +unicode( self.QgisVersion )+".xx\n"
+ QCoreApplication.translate( "fTools", "This version of fTools requires at least QGIS version 1.0.0\nPlugin will not be enabled." ) )
return None
+ QObject.connect( self.iface, SIGNAL( "currentThemeChanged ( QString )" ), self.updateThemeIcons )
self.menu = QMenu()
self.menu.setTitle( QCoreApplication.translate( "fTools", "&Tools" ) )
self.analysisMenu = QMenu( QCoreApplication.translate( "fTools", "&Analysis Tools" ) )
- self.analysisMenu.setIcon( QIcon( self.getThemeIcon( "analysis.png" ) ) )
- self.distMatrix = QAction( QIcon( self.getThemeIcon( "matrix.png" ) ),
- QCoreApplication.translate( "fTools", "Distance matrix" ),self.iface.mainWindow( ) )
- self.sumLines = QAction( QIcon( self.getThemeIcon( "sum_lines.png" ) ),
- QCoreApplication.translate( "fTools", "Sum line lengths" ), self.iface.mainWindow() )
- self.pointsPoly = QAction( QIcon( self.getThemeIcon( "sum_points.png" ) ),
- QCoreApplication.translate( "fTools", "Points in polygon" ),self.iface.mainWindow() )
- self.compStats = QAction( QIcon( self.getThemeIcon( "basic_statistics.png" ) ),
- QCoreApplication.translate( "fTools", "Basic statistics" ),self.iface.mainWindow() )
- self.listUnique = QAction( QIcon( self.getThemeIcon( "unique.png" ) ),
- QCoreApplication.translate( "fTools", "List unique values" ),self.iface.mainWindow() )
- self.nearestNeigh = QAction( QIcon( self.getThemeIcon( "neighbour.png" ) ),
- QCoreApplication.translate( "fTools", "Nearest neighbour analysis" ),self.iface.mainWindow() )
- self.meanCoords = QAction( QIcon( self.getThemeIcon( "mean.png" ) ),
- QCoreApplication.translate( "fTools", "Mean coordinate(s)" ),self.iface.mainWindow() )
- self.intLines = QAction( QIcon( self.getThemeIcon( "intersections.png" ) ),
- QCoreApplication.translate( "fTools", "Line intersections" ) ,self.iface.mainWindow() )
+ self.distMatrix = QAction( QCoreApplication.translate( "fTools", "Distance matrix" ),self.iface.mainWindow( ) )
+ self.sumLines = QAction( QCoreApplication.translate( "fTools", "Sum line lengths" ), self.iface.mainWindow() )
+ self.pointsPoly = QAction( QCoreApplication.translate( "fTools", "Points in polygon" ),self.iface.mainWindow() )
+ self.compStats = QAction( QCoreApplication.translate( "fTools", "Basic statistics" ),self.iface.mainWindow() )
+ self.listUnique = QAction( QCoreApplication.translate( "fTools", "List unique values" ),self.iface.mainWindow() )
+ self.nearestNeigh = QAction( QCoreApplication.translate( "fTools", "Nearest neighbour analysis" ), self.iface.mainWindow() )
+ self.meanCoords = QAction( QCoreApplication.translate( "fTools", "Mean coordinate(s)" ),self.iface.mainWindow() )
+ self.intLines = QAction( QCoreApplication.translate( "fTools", "Line intersections" ) ,self.iface.mainWindow() )
self.analysisMenu.addActions( [ self.distMatrix, self.sumLines, self.pointsPoly,
self.listUnique, self.compStats, self.nearestNeigh, self.meanCoords, self.intLines ] )
self.researchMenu = QMenu( QCoreApplication.translate( "fTools", "&Research Tools" ) )
- self.researchMenu.setIcon( QIcon( self.getThemeIcon( "sampling.png" ) ) )
- self.randSel = QAction( QIcon( self.getThemeIcon( "random_selection.png" ) ),
- QCoreApplication.translate( "fTools", "Random selection" ),self.iface.mainWindow() )
- self.randSub = QAction( QIcon( self.getThemeIcon( "sub_selection.png" ) ),
- QCoreApplication.translate( "fTools", "Random selection within subsets" ),self.iface.mainWindow() )
- self.randPoints = QAction( QIcon( self.getThemeIcon( "random_points.png" ) ),
- QCoreApplication.translate( "fTools", "Random points" ),self.iface.mainWindow() )
- self.regPoints = QAction( QIcon( self.getThemeIcon( "regular_points.png" ) ),
- QCoreApplication.translate( "fTools", "Regular points" ), self.iface.mainWindow() )
- self.vectGrid = QAction( QIcon( self.getThemeIcon( "vector_grid.png" ) ),
- QCoreApplication.translate( "fTools", "Vector grid" ), self.iface.mainWindow() )
- self.selectLocation = QAction( QIcon( self.getThemeIcon( "select_location.png" ) ),
- QCoreApplication.translate( "fTools", "Select by location" ), self.iface.mainWindow() )
- self.layerExtent = QAction( QIcon( self.getThemeIcon( "layer_extent.png" ) ),
- QCoreApplication.translate( "fTools", "Polygon from layer extent" ), self.iface.mainWindow() )
+ self.randSel = QAction( QCoreApplication.translate( "fTools", "Random selection" ),self.iface.mainWindow() )
+ self.randSub = QAction( QCoreApplication.translate( "fTools", "Random selection within subsets" ),self.iface.mainWindow() )
+ self.randPoints = QAction( QCoreApplication.translate( "fTools", "Random points" ),self.iface.mainWindow() )
+ self.regPoints = QAction( QCoreApplication.translate( "fTools", "Regular points" ), self.iface.mainWindow() )
+ self.vectGrid = QAction( QCoreApplication.translate( "fTools", "Vector grid" ), self.iface.mainWindow() )
+ self.selectLocation = QAction( QCoreApplication.translate( "fTools", "Select by location" ), self.iface.mainWindow() )
+ self.layerExtent = QAction( QCoreApplication.translate( "fTools", "Polygon from layer extent" ), self.iface.mainWindow() )
self.researchMenu.addActions( [ self.randSel, self.randSub, self.randPoints,
self.regPoints, self.vectGrid, self.selectLocation, self.layerExtent ] )
self.geoMenu = QMenu( QCoreApplication.translate( "fTools", "&Geoprocessing Tools" ) )
- self.geoMenu.setIcon( QIcon( self.getThemeIcon( "geoprocessing.png" ) ) )
- self.minConvex = QAction( QIcon( self.getThemeIcon( "convex_hull.png" ) ),
- QCoreApplication.translate( "fTools", "Convex hull(s)" ),self.iface.mainWindow() )
- self.dynaBuffer = QAction( QIcon( self.getThemeIcon( "buffer.png" ) ),
- QCoreApplication.translate( "fTools", "Buffer(s)" ),self.iface.mainWindow() )
- self.intersect = QAction( QIcon( self.getThemeIcon( "intersect.png" ) ),
- QCoreApplication.translate( "fTools", "Intersect" ),self.iface.mainWindow() )
- self.union = QAction( QIcon( self.getThemeIcon( "union.png" ) ),
- QCoreApplication.translate( "fTools", "Union" ),self.iface.mainWindow() )
- self.symDifference = QAction( QIcon( self.getThemeIcon( "sym_difference.png" ) ),
- QCoreApplication.translate( "fTools", "Symetrical difference" ),self.iface.mainWindow() )
- self.clip = QAction( QIcon( self.getThemeIcon( "clip.png" ) ),
- QCoreApplication.translate( "fTools", "Clip" ),self.iface.mainWindow() )
- self.dissolve = QAction( QIcon( self.getThemeIcon( "dissolve.png" ) ),
- QCoreApplication.translate( "fTools", "Dissolve" ),self.iface.mainWindow() )
- self.erase = QAction( QIcon( self.getThemeIcon( "difference.png" ) ),
- QCoreApplication.translate( "fTools", "Difference" ),self.iface.mainWindow() )
+ self.minConvex = QAction( QCoreApplication.translate( "fTools", "Convex hull(s)" ),self.iface.mainWindow() )
+ self.dynaBuffer = QAction( QCoreApplication.translate( "fTools", "Buffer(s)" ),self.iface.mainWindow() )
+ self.intersect = QAction( QCoreApplication.translate( "fTools", "Intersect" ),self.iface.mainWindow() )
+ self.union = QAction( QCoreApplication.translate( "fTools", "Union" ),self.iface.mainWindow() )
+ self.symDifference = QAction( QCoreApplication.translate( "fTools", "Symetrical difference" ),self.iface.mainWindow() )
+ self.clip = QAction( QCoreApplication.translate( "fTools", "Clip" ),self.iface.mainWindow() )
+ self.dissolve = QAction( QCoreApplication.translate( "fTools", "Dissolve" ),self.iface.mainWindow() )
+ self.erase = QAction( QCoreApplication.translate( "fTools", "Difference" ),self.iface.mainWindow() )
self.geoMenu.addActions( [ self.minConvex, self.dynaBuffer, self.intersect,
self.union, self.symDifference, self.clip, self.erase, self.dissolve ] )
self.conversionMenu = QMenu( QCoreApplication.translate( "fTools", "G&eometry Tools" ) )
- self.conversionMenu.setIcon( QIcon( self.getThemeIcon( "geometry.png" ) ) )
- self.compGeo = QAction( QIcon( self.getThemeIcon( "export_geometry.png") ),
- QCoreApplication.translate( "fTools", "Export/Add geometry columns" ),self.iface.mainWindow() )
- self.checkGeom = QAction( QIcon( self.getThemeIcon( "check_geometry.png") ),
- QCoreApplication.translate( "fTools", "Check geometry validity" ),self.iface.mainWindow() )
- self.centroids = QAction( QIcon( self.getThemeIcon( "centroids.png") ),
- QCoreApplication.translate( "fTools", "Polygon centroids" ),self.iface.mainWindow() )
- self.delaunay = QAction( QIcon( self.getThemeIcon( "delaunay.png") ),
- QCoreApplication.translate( "fTools", "Delaunay triangulation" ),self.iface.mainWindow() )
- self.extNodes = QAction( QIcon( self.getThemeIcon( "extract_nodes.png") ),
- QCoreApplication.translate( "fTools", "Extract nodes" ),self.iface.mainWindow() )
- self.simplify = QAction( QIcon( self.getThemeIcon( "simplify.png") ),
- QCoreApplication.translate( "fTools", "Simplify geometries" ),self.iface.mainWindow() )
- self.multiToSingle = QAction( QIcon( self.getThemeIcon( "multi_to_single.png") ),
- QCoreApplication.translate( "fTools", "Multipart to singleparts" ),self.iface.mainWindow() )
- self.singleToMulti = QAction( QIcon( self.getThemeIcon( "single_to_multi.png") ),
- QCoreApplication.translate( "fTools", "Singleparts to multipart" ),self.iface.mainWindow() )
- self.polysToLines = QAction( QIcon( self.getThemeIcon( "to_lines.png") ),
- QCoreApplication.translate( "fTools", "Polygons to lines" ),self.iface.mainWindow() )
+ self.compGeo = QAction( QCoreApplication.translate( "fTools", "Export/Add geometry columns" ),self.iface.mainWindow() )
+ self.checkGeom = QAction( QCoreApplication.translate( "fTools", "Check geometry validity" ),self.iface.mainWindow() )
+ self.centroids = QAction( QCoreApplication.translate( "fTools", "Polygon centroids" ),self.iface.mainWindow() )
+ self.delaunay = QAction( QCoreApplication.translate( "fTools", "Delaunay triangulation" ),self.iface.mainWindow() )
+ self.extNodes = QAction( QCoreApplication.translate( "fTools", "Extract nodes" ),self.iface.mainWindow() )
+ self.simplify = QAction( QCoreApplication.translate( "fTools", "Simplify geometries" ),self.iface.mainWindow() )
+ self.multiToSingle = QAction( QCoreApplication.translate( "fTools", "Multipart to singleparts" ),self.iface.mainWindow() )
+ self.singleToMulti = QAction( QCoreApplication.translate( "fTools", "Singleparts to multipart" ),self.iface.mainWindow() )
+ self.polysToLines = QAction( QCoreApplication.translate( "fTools", "Polygons to lines" ),self.iface.mainWindow() )
self.conversionMenu.addActions( [ self.checkGeom, self.compGeo, self.centroids, self.delaunay,
self.simplify, self.multiToSingle, self.singleToMulti, self.polysToLines, self.extNodes] )
self.dataManageMenu = QMenu( QCoreApplication.translate( "fTools", "&Data Management Tools") )
- self.dataManageMenu.setIcon( QIcon( self.getThemeIcon( "management.png") ) )
- self.project = QAction( QIcon( self.getThemeIcon( "export_projection.png") ),
- QCoreApplication.translate( "fTools", "Export to new projection" ), self.iface.mainWindow() )
- self.define = QAction( QIcon( self.getThemeIcon( "define_projection.png" ) ),
- QCoreApplication.translate( "fTools", "Define current projection" ), self.iface.mainWindow() )
- self.joinAttr = QAction( QIcon( self.getThemeIcon( "join_attributes.png" ) ),
- QCoreApplication.translate( "fTools", "Join attributes" ), self.iface.mainWindow() )
- self.spatJoin = QAction( QIcon( self.getThemeIcon( "join_location.png" ) ),
- QCoreApplication.translate( "fTools", "Join attributes by location" ), self.iface.mainWindow() )
- self.splitVect = QAction( QIcon( self.getThemeIcon( "split_layer.png" ) ),
- QCoreApplication.translate( "fTools", "Split vector layer" ), self.iface.mainWindow() )
+ self.project = QAction( QCoreApplication.translate( "fTools", "Export to new projection" ), self.iface.mainWindow() )
+ self.define = QAction( QCoreApplication.translate( "fTools", "Define current projection" ), self.iface.mainWindow() )
+ self.joinAttr = QAction( QCoreApplication.translate( "fTools", "Join attributes" ), self.iface.mainWindow() )
+ self.spatJoin = QAction( QCoreApplication.translate( "fTools", "Join attributes by location" ), self.iface.mainWindow() )
+ self.splitVect = QAction( QCoreApplication.translate( "fTools", "Split vector layer" ), self.iface.mainWindow() )
self.dataManageMenu.addActions( [ self.project, self.define, self.joinAttr, self.spatJoin, self.splitVect ] )
- self.ftools_aboot = QAction( QIcon( self.getThemeIcon( "ftools_logo.png" ) ),
- QCoreApplication.translate( "fTools", "fTools Information" ), self.iface.mainWindow() )
+ self.ftools_aboot = QAction( QCoreApplication.translate( "fTools", "fTools Information" ), self.iface.mainWindow() )
+ self.updateThemeIcons( "theme" )
self.menu.addMenu( self.analysisMenu )
self.menu.addMenu( self.researchMenu )
self.menu.addMenu( self.geoMenu )
