[QGIS Commit] r10418 - trunk/qgis/mac/xcode/Qgis.xcodeproj
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Mar 26 00:24:26 EDT 2009
Author: kyngchaos
Date: 2009-03-26 00:24:25 -0400 (Thu, 26 Mar 2009)
New Revision: 10418
   trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
add bundle step for spatialite
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2009-03-26 00:05:54 UTC (rev 10417)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj	2009-03-26 04:24:25 UTC (rev 10418)
@@ -13405,7 +13405,7 @@
 			runOnlyForDeploymentPostprocessing = 0;
 			shellPath = /bin/sh;
-			shellScript = "# Note: quoting messes up the -change action in install_name_tool, so for now\n# dependency libraries should have no spaces in paths.  ***FIXME***\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls *.so`\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR\"\nliblist=`ls *.dylib`\n\ncd \"$PROJECT_DIR\"\n\n# Postgres\n\nPGSQLROOT=\"$PGSQL_PREFIX/lib\"\nif [ \"$BUNDLE_PGSQL\" = \"YES\" ] && [ -f \"$PGSQLROOT/libpq.dylib\" ] ; then\n\tcp -f \"$PGSQLROOT/libpq.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libpq.dylib\"\n\tplib=`otool -L \"$PGSQLROOT/libpq.dylib\" | grep -E -m 1 \"libpq.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPGSQL_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libpq.dylib\"\nfi\n\n# GDAL\n# *** Note: may need support files also ***\n\nGDALROOT=\"$GDAL_PREFIX/lib\"\nif [ \"$BUNDLE_GDAL\" = \"YES\" ] && [ \"$GDAL_FORM\" = \"shared\" ] && [ -f \"$GDALROOT/libgdal.dylib\" ] ; then\n\tcp -f \"$GDALROOT/libgdal.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgdal.dylib\"\n\tglib=`otool -L \"$GDALROOT/libgdal.dylib\" | grep -E -m 1 \"libgdal.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGDAL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgdal.dylib\"\nfi\n\n# PROJ\n# *** Note: may need support files also ***\n\nPROJROOT=\"$PROJ_PREFIX/lib\"\nif [ \"$BUNDLE_PROJ\" = \"YES\" ] && [ \"$PROJ_FORM\" = \"shared\" ] && [ -f \"$PROJROOT/libproj.dylib\" ] ; then\n\tcp -f \"$PROJROOT/libproj.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libproj.dylib\"\n\tplib=`otool -L \"$PROJROOT/libproj.dylib\" | grep -E -m 1 \"libproj.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPROJ_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libproj.dylib\"\nfi\n\n# GEOS\n\nGEOSROOT=\"$GEOS_PREFIX/lib\"\nif [ \"$BUNDLE_GEOS\" = \"YES\" ] && [ \"$GEOS_FORM\" = \"shared\" ] && [ -f \"$GEOSROOT/libgeos.dylib\" ] ; then\n\tcp -f \"$GEOSROOT/libgeos.dylib\" \"$GEOSROOT/libgeos_c.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/\"\n\tglib=`otool -L \"$GEOSROOT/libgeos.dylib\" | grep -E -m 1 \"libgeos.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GEOSROOT/libgeos_c.dylib\" | grep -E -m 1 \"libgeos_c.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGEOS_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgeos.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgeos_c.dylib\"\nfi\n\n# SQLite\n\nSQLITEROOT=\"$SQLITE_PREFIX/lib\"\nif [ \"$BUNDLE_SQLITE\" = \"YES\" ] && [ \"$SQLITE_FORM\" = \"shared\" ] && [ -f \"$SQLITEROOT/libsqlite3.dylib\" ] ; then\n\tcp -f \"$SQLITEROOT/libsqlite3.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tslib=`otool -L \"$SQLITEROOT/libsqlite3.dylib\" | grep -E -m 1 \"libsqlite3.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tSQLITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\nfi\n\n# GSL\n\nGSLROOT=\"$GSL_PREFIX/lib\"\nif [ \"$BUNDLE_GSL\" = \"YES\" ] && [ \"$GSL_FORM\" = \"shared\" ] && [ -f \"$GSLROOT/libgsl.dylib\" ] ; then\n\tcp -f \"$GSLROOT/libgsl.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgsl.dylib\"\n\tcp -f \"$GSLROOT/libgslcblas.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\n\tglib=`otool -L \"$GSLROOT/libgsl.dylib\" | grep -E -m 1 \"libgsl.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GSLROOT/libgslcblas.dylib\" | grep -E -m 1 \"libgslcblas.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGSL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgsl.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\nfi\n\n# change for all bundled libs now\n\necho \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/Qgis\\\"\"\ninstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/Qgis\"\n\nfor p in $pluglist\ndo\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\"\ndone\n\nfor l in $liblist\ndo\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\"\ndone\n\nif [ -f \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/core.so\" ] ; then\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/core.so\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/gui.so\"\nfi\n# other bundling\n\n# gpsbabel\n\nif [ \"$BUNDLE_GPSBABEL\" = \"YES\" ] && [ -f \"$GPSBABEL\" ] ; then\n\tcp -f \"$GPSBABEL\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"/\nfi\n\n# user bundling from bundle.sh\n\nif [ -f bundle.sh ] ; then\n\t./bundle.sh\nfi\n";
+			shellScript = "# Note: quoting messes up the -change action in install_name_tool, so for now\n# dependency libraries should have no spaces in paths.  ***FIXME***\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls *.so`\n\ncd \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR\"\nliblist=`ls *.dylib`\n\ncd \"$PROJECT_DIR\"\n\n# Postgres\n\nPGSQLROOT=\"$PGSQL_PREFIX/lib\"\nif [ \"$BUNDLE_PGSQL\" = \"YES\" ] && [ -f \"$PGSQLROOT/libpq.dylib\" ] ; then\n\tcp -f \"$PGSQLROOT/libpq.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libpq.dylib\"\n\tplib=`otool -L \"$PGSQLROOT/libpq.dylib\" | grep -E -m 1 \"libpq.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPGSQL_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libpq.dylib\"\nfi\n\n# GDAL\n# *** Note: may need support files also ***\n\nGDALROOT=\"$GDAL_PREFIX/lib\"\nif [ \"$BUNDLE_GDAL\" = \"YES\" ] && [ \"$GDAL_FORM\" = \"shared\" ] && [ -f \"$GDALROOT/libgdal.dylib\" ] ; then\n\tcp -f \"$GDALROOT/libgdal.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgdal.dylib\"\n\tglib=`otool -L \"$GDALROOT/libgdal.dylib\" | grep -E -m 1 \"libgdal.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGDAL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgdal.dylib\"\nfi\n\n# PROJ\n# *** Note: may need support files also ***\n\nPROJROOT=\"$PROJ_PREFIX/lib\"\nif [ \"$BUNDLE_PROJ\" = \"YES\" ] && [ \"$PROJ_FORM\" = \"shared\" ] && [ -f \"$PROJROOT/libproj.dylib\" ] ; then\n\tcp -f \"$PROJROOT/libproj.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libproj.dylib\"\n\tplib=`otool -L \"$PROJROOT/libproj.dylib\" | grep -E -m 1 \"libproj.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tPROJ_CHG=\"-change $plib @executable_path/$QGIS_LIB_SUBDIR/libproj.dylib\"\nfi\n\n# GEOS\n\nGEOSROOT=\"$GEOS_PREFIX/lib\"\nif [ \"$BUNDLE_GEOS\" = \"YES\" ] && [ \"$GEOS_FORM\" = \"shared\" ] && [ -f \"$GEOSROOT/libgeos.dylib\" ] ; then\n\tcp -f \"$GEOSROOT/libgeos.dylib\" \"$GEOSROOT/libgeos_c.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/\"\n\tglib=`otool -L \"$GEOSROOT/libgeos.dylib\" | grep -E -m 1 \"libgeos.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GEOSROOT/libgeos_c.dylib\" | grep -E -m 1 \"libgeos_c.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGEOS_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgeos.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgeos_c.dylib\"\nfi\n\n# SQLite\n\nSQLITEROOT=\"$SQLITE_PREFIX/lib\"\nif [ \"$BUNDLE_SQLITE\" = \"YES\" ] && [ \"$SQLITE_FORM\" = \"shared\" ] && [ -f \"$SQLITEROOT/libsqlite3.dylib\" ] ; then\n\tcp -f \"$SQLITEROOT/libsqlite3.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\n\tslib=`otool -L \"$SQLITEROOT/libsqlite3.dylib\" | grep -E -m 1 \"libsqlite3.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tSQLITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libsqlite3.dylib\"\nfi\n\n# SpatiaLite\n\nSPATIALITEROOT=\"$SPATIALITE_PREFIX/lib\"\nif [ \"$BUNDLE_SPATIALITE\" = \"YES\" ] && [ \"$SPATIALITE_FORM\" = \"shared\" ] && [ -f \"$SPATIALITEROOT/libspatialite.dylib\" ] ; then\n\tcp -f \"$SPATIALITEROOT/libspatialite.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\n\tslib=`otool -L \"$SPATIALITEROOT/libspatialite.dylib\" | grep -E -m 1 \"libspatialite.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tSPATIALITE_CHG=\"-change $slib @executable_path/$QGIS_LIB_SUBDIR/libspatialite.dylib\"\nfi\n\n# GSL\n\nGSLROOT=\"$GSL_PREFIX/lib\"\nif [ \"$BUNDLE_GSL\" = \"YES\" ] && [ \"$GSL_FORM\" = \"shared\" ] && [ -f \"$GSLROOT/libgsl.dylib\" ] ; then\n\tcp -f \"$GSLROOT/libgsl.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgsl.dylib\"\n\tcp -f \"$GSLROOT/libgslcblas.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\n\tglib=`otool -L \"$GSLROOT/libgsl.dylib\" | grep -E -m 1 \"libgsl.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tgclib=`otool -L \"$GSLROOT/libgslcblas.dylib\" | grep -E -m 1 \"libgslcblas.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tGSL_CHG=\"-change $glib @executable_path/$QGIS_LIB_SUBDIR/libgsl.dylib -change $gclib @executable_path/$QGIS_LIB_SUBDIR/libgslcblas.dylib\"\nfi\n\n# change for all bundled libs now\n\necho \"install_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \\\"$QGIS_BUILD_PATH/MacOS/Qgis\\\"\"\ninstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/Qgis\"\n\nfor p in $pluglist\ndo\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_PLUGIN_SUBDIR/$p\"\ndone\n\nfor l in $liblist\ndo\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/$l\"\ndone\n\nif [ -f \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/core.so\" ] ; then\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/core.so\"\n\tinstall_name_tool $PGSQL_CHG $GDAL_CHG $PROJ_CHG $GEOS_CHG $SQLITE_CHG $SPATIALITE_CHG $GSL_CHG \"$QGIS_BUILD_PATH/MacOS/$QGIS_DATA_SUBDIR/python/qgis/gui.so\"\nfi\n\n# other bundling\n\n# gpsbabel\n\nif [ \"$BUNDLE_GPSBABEL\" = \"YES\" ] && [ -f \"$GPSBABEL\" ] ; then\n\tcp -f \"$GPSBABEL\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_BIN_SUBDIR\"/\nfi\n\n# user bundling from bundle.sh\n\nif [ -f bundle.sh ] ; then\n\t./bundle.sh\nfi\n";
 			showEnvVarsInLog = 0;
 		727AD4FA0F7325CA002B9DCD /* install */ = {
More information about the QGIS-commit mailing list
