[QGIS Commit] r10429 - trunk/qgis/src/app/attributetable
svn_qgis at osgeo.org
Fri Mar 27 13:42:35 EDT 2009
Author: jef
Date: 2009-03-27 13:42:35 -0400 (Fri, 27 Mar 2009)
New Revision: 10429
trunk/qgis/src/app/attributetable/BeataModel.cpp
fix #1598
Modified: trunk/qgis/src/app/attributetable/BeataModel.cpp
--- trunk/qgis/src/app/attributetable/BeataModel.cpp 2009-03-27 17:41:06 UTC (rev 10428)
+++ trunk/qgis/src/app/attributetable/BeataModel.cpp 2009-03-27 17:42:35 UTC (rev 10429)
@@ -88,8 +88,8 @@
mLastRow = NULL;
mLayer = theLayer;
mFeatureCount = mLayer->pendingFeatureCount();
- mFieldCount = mLayer->dataProvider()->fieldCount();
- mAttributes = mLayer->dataProvider()->attributeIndexes();
+ mFieldCount = mLayer->pendingFields().size();
+ mAttributes = mLayer->pendingAllAttributesList();
connect( mLayer, SIGNAL( layerModified( bool ) ), this, SLOT( layerModified( bool ) ) );
//connect(mLayer, SIGNAL(attributeAdded(int)), this, SLOT( attributeAdded(int)));
@@ -233,7 +233,7 @@
// not needed when we have featureAdded signal
if ( ins )
@@ -324,7 +324,7 @@
else
- QgsField field = mLayer->dataProvider()->fields()[section]; //column
+ QgsField field = mLayer->pendingFields()[ mAttributes[section] ]; //column
return QVariant( field.name() );
@@ -350,7 +350,7 @@
row = f.attributeMap();
pair.id = f.id();
- pair.columnItem = row[column];
+ pair.columnItem = row[ mAttributes[column] ];
mSortList.append( pair );
@@ -383,7 +383,7 @@
if ( !index.isValid() || ( role != Qt::TextAlignmentRole && role != Qt::DisplayRole && role != Qt::EditRole ) )
return QVariant();
- QVariant::Type fldType = mLayer->dataProvider()->fields()[index.column()].type();
+ QVariant::Type fldType = mLayer->pendingFields()[ mAttributes[index.column()] ].type();
bool fldNumeric = ( fldType == QVariant::Int || fldType == QVariant::Double );
if ( role == Qt::TextAlignmentRole )
@@ -403,10 +403,10 @@
return QVariant( "ERROR" );
mLastRowId = rowToId( index.row() );
- mLastRow = ( QgsAttributeMap * )( &( mFeat.attributeMap() ) );
+ mLastRow = ( QgsAttributeMap * ) & mFeat.attributeMap();
- QVariant& val = ( *mLastRow )[index.column()];
+ QVariant& val = ( *mLastRow )[ mAttributes[index.column()] ];
if ( val.isNull() )
@@ -512,7 +512,7 @@
return QVariant();
@@ -534,10 +534,10 @@
mFeat = mFeatureMap[rowToId( index.row() )];
+ QVariant &val = ( *mLastRow )[ mAttributes[index.column()] ];
if ( val.isNull() )
