[QGIS Commit] r10711 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Sun May 3 11:11:58 EDT 2009
Author: aghisla
Date: 2009-05-03 11:11:58 -0400 (Sun, 03 May 2009)
New Revision: 10711
docs/trunk/english_us/user_guide/features_at_a_glance.tex
docs/trunk/english_us/user_guide/forward.tex
some updates: features and plugins list.
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2009-05-03 03:56:49 UTC (rev 10710)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2009-05-03 15:11:58 UTC (rev 10711)
@@ -757,7 +757,8 @@
Here is a sampling of other ways to produce output files:
\begin{itemize}
\item Menu option \dropmenuopttwo{mActionSaveMapAsImage}{Save as Image} opens a
-file dialog where you select the name, path and type of image (PNG or JPG format).
+file dialog where you select the name, path and type of image (PNG or JPG format). From this
+release, a world file with extension PNGW or JPGW saved in the same folder georeferences the image.
\item Menu option \dropmenuopttwo{mActionFilePrint}{Print Composer} opens a dialog
where you can layout and print the current map canvas (see Section~\ref{label_printcomposer}).
\end{itemize}
Modified: docs/trunk/english_us/user_guide/forward.tex
--- docs/trunk/english_us/user_guide/forward.tex 2009-05-03 03:56:49 UTC (rev 10710)
+++ docs/trunk/english_us/user_guide/forward.tex 2009-05-03 15:11:58 UTC (rev 10711)
@@ -78,7 +78,7 @@
\item edit/view/search attributes
\item feature labeling
\item change vector and raster symbology
-\item add a graticule layer
+\item add a graticule layer now via fTools plugin
\item decorate your map with a north arrow scale bar and copyright label
\item save and restore projects
\end{itemize}
@@ -96,13 +96,15 @@
\item GPS tools to import and export GPX format, and convert other GPS
formats to GPX or down/upload directly to a GPS unit
\item create PostGIS layers from shapefiles with the SPIT plugin
-\item manage vector attribute tables with the table manager plugin
+\item improved handling of PostGIS tables
+\item manage vector attribute tables with the table manager plugin
+\item save screenshots as georeferenced images
\end{itemize}
\minisec{Analyse data}
You can perform spatial data analysis on PostgreSQL/PostGIS and other OGR
-supported formats using the ftools python plugin. QGIS currently offers
+supported formats using the fTools python plugin. QGIS currently offers
vector analysis, sampling, geoprocessing, geometry and database management
tools. You can also use the integrated GRASS tools, which
include the complete GRASS functionality of more than 300 modules (See
@@ -126,11 +128,14 @@
\\ Add Delimited Text Layer
\\ Coordinate Capture
\\ Decorations (Copyright Label, North Arrow and Scale bar)
+\\ Diagram Overlay
+\\ Dxf2Shp Converter
\\ Georeferencer
+\\ fTools
\\ GPS Tools
\\ GRASS integration
-\\ Graticules Creator
+% \\ Graticules Creator
\\ Interpolation Plugin
\\ OGR Layer Converter
\\ Quick Print
