[QGIS Commit] r10752 - in docs/trunk/english_us/user_guide: . plugins_ftools_images
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu May 7 07:21:18 EDT 2009
Author: cfarmer
Date: 2009-05-07 07:21:18 -0400 (Thu, 07 May 2009)
New Revision: 10752
Added:
   docs/trunk/english_us/user_guide/other_core_plugins.tex
   docs/trunk/english_us/user_guide/plugins_ftools_images/analysis.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/basic_statistics.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/buffer.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/centroids.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/check_geometry.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/clip.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/convex_hull.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/define_projection.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/difference.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/dissolve.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/export_geometry.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/export_projection.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/extract_nodes.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/geometry.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/geoprocessing.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/intersect.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/intersections.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/join_attributes.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/join_location.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/management.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/matrix.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/mean.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/multi_to_single.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/neighbour.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/random_points.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/random_selection.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/regular_points.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/sampling.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/select_location.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/simplify.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/single_to_multi.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/split_layer.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/sub_selection.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/sum_lines.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/sum_points.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/sym_difference.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/to_lines.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/union.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/unique.png
   docs/trunk/english_us/user_guide/plugins_ftools_images/vector_grid.png
   docs/trunk/english_us/user_guide/plugins_quick_print.tex
use default icons for ftools chapter, add other plugins section, adjust quick print dialog size
Added: docs/trunk/english_us/user_guide/other_core_plugins.tex
--- docs/trunk/english_us/user_guide/other_core_plugins.tex	                        (rev 0)
+++ docs/trunk/english_us/user_guide/other_core_plugins.tex	2009-05-07 11:21:18 UTC (rev 10752)
@@ -0,0 +1,35 @@
+% vim: set textwidth=78 autoindent:
+\subsection{Other core plugins}
+% when the revision of a section has been finalized,
+% comment out the following line:
+% \updatedisclaimer
+The remaining core plugins are listed in Table \ref{tab:other_core}, along with references to
+the chapters in this manual which cover their usage.
+\begin{table}[H]
+\centering
+\caption{Other Core Plugins}\label{tab:other_core}\medskip
+\small
+ \begin{tabular}{|l|l|p{4in}|}
+\hline \textbf{Icon} & \textbf{Plugin} & \textbf{Manual Reference}\\
+\hline
+\includegraphics[width=0.6cm]{diagram_overlay}
+ & Diagram Overlay \index{plugins!diagram}& Chapter \ref{sec:diagram}\\
+\hline
+\includegraphics[width=0.6cm]{grass}
+ & GRASS \index{plugin!grass toolbox} & Chapter \ref{sec:grass} and Appendix \ref{appdx_grass_toolbox_modules}\\
+ \hline
+\includegraphics[width=0.6cm]{plugin_installer}
+ & Plugin Installer \index{plugins!Plugin Installer} & Chapter \ref{sec:python_plugin_installer}\\
+\hline
+\includegraphics[width=0.6cm]{spiticon}
+ & SPIT \index{plugins!spit}& Chapter \ref{sec:loading_postgis_data} \\
+ \hline
+\includegraphics[width=0.6cm]{mIconAddWfsLayer}
+ & WFS & Chapter \ref{sec:ogc-wfs} \\
+\hline
+\end{tabular}
+\end{table}
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/analysis.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/basic_statistics.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/buffer.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/centroids.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/check_geometry.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/clip.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/convex_hull.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/define_projection.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/difference.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/dissolve.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/export_geometry.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/export_projection.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/extract_nodes.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/geometry.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/geoprocessing.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/intersect.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/intersections.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/join_attributes.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/join_location.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/management.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/matrix.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/mean.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/multi_to_single.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/neighbour.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/random_points.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/random_selection.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/regular_points.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/sampling.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/select_location.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/simplify.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/single_to_multi.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/split_layer.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/sub_selection.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/sum_lines.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/sum_points.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/sym_difference.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/to_lines.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/union.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/unique.png
Modified: docs/trunk/english_us/user_guide/plugins_ftools_images/vector_grid.png
Modified: docs/trunk/english_us/user_guide/plugins_quick_print.tex
--- docs/trunk/english_us/user_guide/plugins_quick_print.tex	2009-05-07 08:16:23 UTC (rev 10751)
+++ docs/trunk/english_us/user_guide/plugins_quick_print.tex	2009-05-07 11:21:18 UTC (rev 10752)
@@ -22,6 +22,6 @@
 \begin{figure}[ht]
    \begin{center}
    \caption{Quick Print result as DIN A4 PDF using the alaska sample dataset\nixcaption}\label{fig:quickprint_result}\smallskip
-   \includegraphics[clip=true, width=11cm]{quick_print_result}
+   \includegraphics[clip=true, width=9cm]{quick_print_result}
 \end{center}
 \end{figure}
More information about the QGIS-commit mailing list
