[QGIS Commit] r10761 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Fri May 8 22:25:07 EDT 2009
Author: cengel
Date: 2009-05-08 22:25:07 -0400 (Fri, 08 May 2009)
New Revision: 10761
docs/trunk/english_us/user_guide/working_with_vector.tex
Added multiline labeling
Fixed a few typos in Chap5
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2009-05-08 22:45:24 UTC (rev 10760)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2009-05-09 02:25:07 UTC (rev 10761)
@@ -50,11 +50,6 @@
\index{shapefile!specification}.
\subsubsection{Loading a Shapefile}\label{sec:load_shapefile}
-\includegraphics[width=0.7cm]{mActionAddNonDbLayer}
-To load a shapefile, start
-QGIS and click on the \toolbtntwo{mActionAddNonDbLayer}{Add a vector layer}
-toolbar button\index{shapefile!loading} or simply type \keystroke{V}.
-This will bring up a new window (see Figure\ref{fig:addvectorlayer}).
\begin{figure}[ht]
\begin{center}
@@ -63,14 +58,6 @@
\end{center}
\end{figure}
-From the available options check \checkbox{File}. Click on \button{Browse}.
-That will bring up a standard open file dialog (see Figure
-\ref{fig:openshapefile}) which allows you to navigate the file system and load
-a shapefile or other supported data source.
-The selection box \selectstring{Files of type}{\ldots} allows you to preselect some OGR supported file formats.
-You can also select the Encoding type for the shapefile if desired.
\begin{figure}[ht]
\begin{center}
\caption{Open an OGR Supported Vector Layer Dialog \nixcaption}\label{fig:openshapefile}\smallskip
@@ -78,9 +65,6 @@
\end{center}
\end{figure}
-Selecting a shapefile from the list and clicking \button{Open} loads it into QGIS. Figure
-\ref{fig:loadedshapefile} shows QGIS after loading the \filename{alaska.shp} file.
\begin{figure}[ht]
\begin{center}
\caption{QGIS with Shapefile of Alaska loaded \nixcaption}\label{fig:loadedshapefile}\smallskip
@@ -88,6 +72,23 @@
\end{center}
\end{figure}
+\includegraphics[width=0.7cm]{mActionAddNonDbLayer} To load a shapefile, start
+QGIS and click on the \toolbtntwo{mActionAddNonDbLayer}{Add a vector layer}
+toolbar button\index{shapefile!loading} or simply type \keystroke{V}.
+This will bring up a new window (see Figure\ref{fig:addvectorlayer}).
+From the available options check \radiobuttonon{File}. Click on \button{Browse}.
+That will bring up a standard open file dialog (see Figure
+\ref{fig:openshapefile}) which allows you to navigate the file system and load
+a shapefile or other supported data source.
+The selection box \selectstring{Files of type}{\ldots} allows you to preselect some OGR supported file formats.
+You can also select the Encoding type for the shapefile if desired.
+Selecting a shapefile from the list and clicking \button{Open} loads it into QGIS. Figure
+\ref{fig:loadedshapefile} shows QGIS after loading the \filename{alaska.shp} file.
\begin{Tip}\caption{\textsc{Layer Colors}}
\qgistip{When you add a layer to the map, it is assigned a random color. When
adding more than one layer at a time, different colors are assigned to each layer. }
@@ -132,7 +133,7 @@
To load an ArcInfo binary coverage click on the
toolbar button or type \keystroke{V} to open the
-\dialog{Add Vector Layer} dialog. Select \checkbox{Directory}. Change to \selectstring {Type}{Arc/Ingo Binary Coverage}.
+\dialog{Add Vector Layer} dialog. Select \radiobuttonon{Directory}. Change to \selectstring {Type}{Arc/Ingo Binary Coverage}.
Navigate to the directory that contains the coverage files and select it.
Similarly, you can load directory based vector files in the UK National Transfer Format as well as the
@@ -170,7 +171,7 @@
\toolbtntwo{mActionAddLayer}{Add a PostGIS Layer} toolbar button, selecting the
\dropmenuopttwo{mActionAddLayer}{Add a PostGIS Layer...} option from the \mainmenuopt{Layer} menu or typing
\keystroke{D}. You can also open the open the
-\dialog{Add Vector Layer} dialog and select \checkbox{Database}.
+\dialog{Add Vector Layer} dialog and select \radiobuttonon{Database}.
The \dialog{Add PostGIS Table(s)} dialog will
be displayed. To access the connection manager\index{PostgreSQL!connection
manager}, click on the \button{New} button to display the \dialog{Create a New
@@ -436,7 +437,7 @@
option from the \mainmenuopt{Layer} menu or by typing \keystroke{L}.
This will bring up a window, which will allow you to either connect to a Spatialite database already known to QGIS, which
you can choose from the dropdown menu or to define a new connection to a new database. To define a new connection,
-click on \button{New} and use the file browsser to point to your SpatiaLite database,
+click on \button{New} and use the file browser to point to your SpatiaLite database,
which is a file with a \filename{.sqlite } extension.
\subsection{The Vector Properties Dialog}\label{sec:vectorprops}
@@ -568,6 +569,10 @@
We'll use \selectstring{Field containing label}{NAMES}.
\item Enter a default for lakes that have no name. The default label will be
used each time QGIS encounters a lake with no value in the \guilabel{NAMES} field.
+\item If have labels extending over several lines, check \checkbox{Multiline labels?}.
+QGIS will check for a true line return in your label field and insert the line breaks accordingly.
+A true line return is a \textbf{single} character \textbackslash n,
+(not two separate characters, like a backlash \textbackslash ~followed by the character n).
\item Click \button{Apply}.
\end{enumerate}
