[QGIS Commit] r10771 - in branches/symbology-ng-branch/src/ui: . symbollayer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue May 12 05:37:35 EDT 2009
Author: wonder
Date: 2009-05-12 05:37:34 -0400 (Tue, 12 May 2009)
New Revision: 10771
Added:
   branches/symbology-ng-branch/src/ui/qgsrendererv2propsdialogbase.ui
   branches/symbology-ng-branch/src/ui/qgsstylev2managerdialogbase.ui
   branches/symbology-ng-branch/src/ui/qgssymbolv2propertiesdialogbase.ui
   branches/symbology-ng-branch/src/ui/qgssymbolv2selectordialogbase.ui
   branches/symbology-ng-branch/src/ui/qgsvectorgradientcolorrampv2dialogbase.ui
   branches/symbology-ng-branch/src/ui/symbollayer/
   branches/symbology-ng-branch/src/ui/symbollayer/widget_linedecoration.ui
   branches/symbology-ng-branch/src/ui/symbollayer/widget_markerline.ui
   branches/symbology-ng-branch/src/ui/symbollayer/widget_simplefill.ui
   branches/symbology-ng-branch/src/ui/symbollayer/widget_simpleline.ui
   branches/symbology-ng-branch/src/ui/symbollayer/widget_simplemarker.ui
   branches/symbology-ng-branch/src/ui/symbollayer/widget_svgmarker.ui
   branches/symbology-ng-branch/src/ui/CMakeLists.txt
Added a bunch of UI files for new symbology.
Modified: branches/symbology-ng-branch/src/ui/CMakeLists.txt
--- branches/symbology-ng-branch/src/ui/CMakeLists.txt	2009-05-12 08:47:01 UTC (rev 10770)
+++ branches/symbology-ng-branch/src/ui/CMakeLists.txt	2009-05-12 09:37:34 UTC (rev 10771)
@@ -1,6 +1,7 @@
 FILE(GLOB QGIS_UIS "${CMAKE_CURRENT_SOURCE_DIR}/*.ui")
+FILE(GLOB SYMBOLLAYER_UIS "${CMAKE_CURRENT_SOURCE_DIR}/symbollayer/*.ui")
-QT4_WRAP_UI(QGIS_UIS_H ${QGIS_UIS})
+QT4_WRAP_UI(QGIS_UIS_H ${QGIS_UIS} ${SYMBOLLAYER_UIS})
 ADD_CUSTOM_TARGET(ui ALL DEPENDS ${QGIS_UIS_H})
Added: branches/symbology-ng-branch/src/ui/qgsrendererv2propsdialogbase.ui
--- branches/symbology-ng-branch/src/ui/qgsrendererv2propsdialogbase.ui	                        (rev 0)
+++ branches/symbology-ng-branch/src/ui/qgsrendererv2propsdialogbase.ui	2009-05-12 09:37:34 UTC (rev 10771)
@@ -0,0 +1,398 @@
+<ui version="4.0" >
+ <class>QgsRendererV2PropsDialogBase</class>
+ <widget class="QDialog" name="QgsRendererV2PropsDialogBase" >
+  <property name="geometry" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>612</width>
+    <height>398</height>
+   </rect>
+  </property>
+  <property name="windowTitle" >
+   <string>Renderer V2 properties</string>
+  </property>
+  <layout class="QGridLayout" >
+   <item row="0" column="0" >
+    <layout class="QVBoxLayout" >
+     <item>
+      <widget class="QLabel" name="label" >
+       <property name="text" >
+        <string>Renderer:</string>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <widget class="QRadioButton" name="radSingleSymbol" >
+        <string>single symbol</string>
+       </property>
+       <property name="checked" >
+        <bool>true</bool>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <widget class="QRadioButton" name="radCategorized" >
+        <string>categorized</string>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <widget class="QRadioButton" name="radGraduated" >
+       <property name="enabled" >
+        <bool>true</bool>
+       </property>
+        <string>graduated</string>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <spacer>
+       <property name="orientation" >
+        <enum>Qt::Vertical</enum>
+       </property>
+       <property name="sizeHint" >
+        <size>
+         <width>20</width>
+         <height>111</height>
+        </size>
+       </property>
+      </spacer>
+     </item>
+     <item>
+      <widget class="QPushButton" name="btnSymbolLevels" >
+        <bool>false</bool>
+       </property>
+        <string>Symbol levels...</string>
+       </property>
+      </widget>
+     </item>
+    </layout>
+   </item>
+   <item row="0" column="1" >
+    <widget class="Line" name="line" >
+     </property>
+    </widget>
+   </item>
+   <item row="0" column="2" >
+    <widget class="QStackedWidget" name="stackedWidget" >
+     <property name="currentIndex" >
+      <number>0</number>
+     </property>
+     <widget class="QWidget" name="pageSingleSymbol" >
+        <widget class="QLabel" name="label_2" >
+          <string>Symbol:</string>
+         </property>
+        </widget>
+       </item>
+        <widget class="QPushButton" name="btnChangeSingleSymbol" >
+          <string>Change</string>
+         </property>
+        </widget>
+       </item>
+        <spacer>
+          <enum>Qt::Horizontal</enum>
+         </property>
+          <size>
+           <width>40</width>
+           <height>20</height>
+          </size>
+         </property>
+        </spacer>
+       </item>
+       <item row="1" column="0" colspan="2" >
+        <spacer>
+         </property>
+          <size>
+           <width>271</width>
+           <height>181</height>
+          </size>
+         </property>
+        </spacer>
+       </item>
+      </layout>
+     </widget>
+     <widget class="QWidget" name="pageCategorized" >
+        <widget class="QLabel" name="label_3" >
+          <string>Column:</string>
+         </property>
+        </widget>
+       </item>
+       <item row="0" column="1" colspan="2" >
+        <widget class="QComboBox" name="cboCategorizedColumn" />
+       </item>
+       <item row="1" column="0" colspan="6" >
+        <widget class="QTreeView" name="viewCategories" >
+         <property name="iconSize" >
+          <size>
+           <width>16</width>
+           <height>16</height>
+          </size>
+         </property>
+         <property name="rootIsDecorated" >
+         </property>
+         <property name="allColumnsShowFocus" >
+          <bool>true</bool>
+         </property>
+        </widget>
+       </item>
+       <item row="2" column="1" >
+        <widget class="QPushButton" name="btnAddCategories" >
+          <string>Add</string>
+         </property>
+        </widget>
+       </item>
+       <item row="2" column="2" >
+        <widget class="QPushButton" name="btnDeleteCategory" >
+          <string>Delete</string>
+         </property>
+        </widget>
+       </item>
+       <item row="2" column="3" >
+        <widget class="QPushButton" name="btnDeleteAllCategories" >
+          <string>Delete all</string>
+         </property>
+        </widget>
+       </item>
+       <item row="2" column="4" >
+        <spacer>
+         </property>
+          <size>
+           <width>40</width>
+          </size>
+         </property>
+        </spacer>
+       </item>
+       <item row="2" column="5" >
+        <widget class="QPushButton" name="btnJoinCategories" >
+         </property>
+          <string>Join</string>
+         </property>
+        </widget>
+       </item>
+      </layout>
+     </widget>
+     <widget class="QWidget" name="pageGraduated" >
+       <item>
+          <widget class="QLabel" name="label_4" >
+           </property>
+          </widget>
+         </item>
+          <widget class="QComboBox" name="cboGraduatedColumn" />
+         </item>
+         <item row="1" column="0" >
+          <widget class="QLabel" name="label_6" >
+           </property>
+          </widget>
+         </item>
+         <item row="1" column="1" >
+          <widget class="QPushButton" name="btnChangeGraduatedSymbol" >
+           <property name="sizePolicy" >
+            <sizepolicy vsizetype="Fixed" hsizetype="Minimum" >
+             <horstretch>1</horstretch>
+             <verstretch>0</verstretch>
+            </sizepolicy>
+           </property>
+            <string>change</string>
+           </property>
+          </widget>
+         </item>
+         <item row="1" column="3" >
+          <widget class="QLabel" name="label_5" >
+            <string>Classes:</string>
+           </property>
+           <property name="alignment" >
+            <set>Qt::AlignRight|Qt::AlignTrailing|Qt::AlignVCenter</set>
+           </property>
+          </widget>
+         </item>
+         <item row="1" column="4" >
+          <widget class="QSpinBox" name="spinGraduatedClasses" >
+             <horstretch>0</horstretch>
+            </sizepolicy>
+           </property>
+           <property name="value" >
+            <number>5</number>
+           </property>
+          </widget>
+         </item>
+         <item row="2" column="0" >
+          <widget class="QLabel" name="label_7" >
+            <string>Color ramp:</string>
+           </property>
+          </widget>
+         </item>
+          <widget class="QComboBox" name="cboGraduatedColorRamp" />
+         </item>
+          <widget class="QLabel" name="label_8" >
+            <string>Mode:</string>
+           </property>
+           </property>
+          </widget>
+         </item>
+          <widget class="QComboBox" name="cboGraduatedMode" >
+           <item>
+             <string>Equal Interval</string>
+            </property>
+           </item>
+           <item>
+             <string>Quantile</string>
+            </property>
+           </item>
+          </widget>
+         </item>
+         <item rowspan="2" row="1" column="2" >
+          <spacer>
+           </property>
+            <size>
+             <width>20</width>
+            </size>
+           </property>
+          </spacer>
+         </item>
+        </layout>
+       </item>
+       <item>
+        <widget class="QTreeView" name="viewGraduated" />
+       </item>
+       <item>
+        <layout class="QHBoxLayout" >
+         <item>
+          <widget class="QPushButton" name="btnGraduatedClassify" >
+            <string>Classify</string>
+           </property>
+          </widget>
+         </item>
+         <item>
+          <widget class="QPushButton" name="btnGraduatedDelete" >
+            <string>Delete class</string>
+           </property>
+          </widget>
+         </item>
+         <item>
+          <spacer>
+           </property>
+            <size>
+             <width>40</width>
+            </size>
+           </property>
+          </spacer>
+         </item>
+        </layout>
+       </item>
+      </layout>
+     </widget>
+    </widget>
+   </item>
+   <item row="1" column="0" colspan="3" >
+    <widget class="QDialogButtonBox" name="buttonBox" >
+     </property>
+     <property name="standardButtons" >
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
+     </property>
+    </widget>
+   </item>
+  </layout>
+ </widget>
+ <resources/>
+ <connections>
+  <connection>
+   <sender>buttonBox</sender>
+   <signal>accepted()</signal>
+   <receiver>QgsRendererV2PropsDialogBase</receiver>
+   <slot>accept()</slot>
+   <hints>
+    <hint type="sourcelabel" >
+     <x>248</x>
+     <y>254</y>
+    </hint>
+    <hint type="destinationlabel" >
+     <x>157</x>
+     <y>274</y>
+    </hint>
+   </hints>
+  </connection>
+  <connection>
+   <signal>rejected()</signal>
+   <slot>reject()</slot>
+   <hints>
+     <x>316</x>
+     <y>260</y>
+    </hint>
+     <x>286</x>
+     <y>274</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
+</ui>
Added: branches/symbology-ng-branch/src/ui/qgsstylev2managerdialogbase.ui
--- branches/symbology-ng-branch/src/ui/qgsstylev2managerdialogbase.ui	                        (rev 0)
+++ branches/symbology-ng-branch/src/ui/qgsstylev2managerdialogbase.ui	2009-05-12 09:37:34 UTC (rev 10771)
@@ -0,0 +1,112 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
+ <class>QgsStyleV2ManagerDialogBase</class>
+ <widget class="QDialog" name="QgsStyleV2ManagerDialogBase">
+  <property name="geometry">
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>300</width>
+    <height>369</height>
+   </rect>
+  </property>
+  <property name="windowTitle">
+   <string>Style Manager</string>
+  </property>
+  <layout class="QVBoxLayout">
+   <item>
+    <widget class="QLabel" name="label">
+     <property name="text">
+      <string>Style item type:</string>
+     </property>
+    </widget>
+   </item>
+   <item>
+    <widget class="QComboBox" name="cboItemType"/>
+   </item>
+   <item>
+    <widget class="QListView" name="listItems">
+     <property name="editTriggers">
+      <set>QAbstractItemView::EditKeyPressed|QAbstractItemView::SelectedClicked</set>
+     </property>
+     <property name="iconSize">
+      <size>
+       <width>48</width>
+       <height>48</height>
+      </size>
+     </property>
+     <property name="movement">
+      <enum>QListView::Static</enum>
+     </property>
+     <property name="resizeMode">
+      <enum>QListView::Adjust</enum>
+     </property>
+     <property name="spacing">
+     </property>
+     <property name="viewMode">
+      <enum>QListView::IconMode</enum>
+     </property>
+    </widget>
+   </item>
+   <item>
+    <layout class="QHBoxLayout">
+     <item>
+      <widget class="QPushButton" name="btnAddItem">
+       <property name="toolTip">
+        <string>Add item</string>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <widget class="QPushButton" name="btnEditItem">
+        <string>Edit item</string>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <widget class="QPushButton" name="btnRemoveItem">
+        <string>Remove item</string>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <spacer>
+       <property name="orientation">
+       </property>
+       <property name="sizeHint" stdset="0">
+        <size>
+         <width>40</width>
+        </size>
+       </property>
+      </spacer>
+     </item>
+    </layout>
+   </item>
+   <item>
+    <widget class="QDialogButtonBox" name="buttonBox">
+     </property>
+     <property name="standardButtons">
+      <set>QDialogButtonBox::Close</set>
+     </property>
+    </widget>
+   </item>
+  </layout>
+ </widget>
+ <tabstops>
+  <tabstop>cboItemType</tabstop>
+  <tabstop>listItems</tabstop>
+  <tabstop>btnAddItem</tabstop>
+  <tabstop>btnEditItem</tabstop>
+  <tabstop>btnRemoveItem</tabstop>
+  <tabstop>buttonBox</tabstop>
+ </tabstops>
+ <resources/>
+ <connections/>
+</ui>
Added: branches/symbology-ng-branch/src/ui/qgssymbolv2propertiesdialogbase.ui
--- branches/symbology-ng-branch/src/ui/qgssymbolv2propertiesdialogbase.ui	                        (rev 0)
+++ branches/symbology-ng-branch/src/ui/qgssymbolv2propertiesdialogbase.ui	2009-05-12 09:37:34 UTC (rev 10771)
@@ -0,0 +1,275 @@
+<ui version="4.0">
+ <class>DlgSymbolV2Properties</class>
+ <widget class="QDialog" name="DlgSymbolV2Properties">
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>634</width>
+    <height>396</height>
+   </rect>
+  </property>
+   <string>Symbol properties</string>
+  </property>
+  <layout class="QGridLayout">
+   <item row="0" column="0">
+      <string>Symbol preview:</string>
+     </property>
+    </widget>
+   </item>
+   <item row="0" column="1" rowspan="5">
+     <item>
+       <item>
+        <widget class="QLabel" name="label_2">
+          <string>Symbol layer type:</string>
+         </property>
+        </widget>
+       </item>
+       <item>
+        <widget class="QComboBox" name="cboLayerType"/>
+       </item>
+      </layout>
+     </item>
+     <item>
+      <widget class="QGroupBox" name="groupBox">
+       <property name="sizePolicy">
+        <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
+        </sizepolicy>
+       </property>
+       <property name="title">
+        <string>Symbol layer properties</string>
+       </property>
+        <property name="margin">
+        </property>
+         <widget class="QStackedWidget" name="stackedWidget">
+          <property name="currentIndex">
+          </property>
+          <widget class="QWidget" name="pageDummy">
+            <item>
+             <widget class="QLabel" name="label_4">
+               <string>This symbol layer doesn't have GUI for settings.</string>
+              </property>
+             </widget>
+            </item>
+           </layout>
+          </widget>
+         </widget>
+        </item>
+       </layout>
+      </widget>
+     </item>
+    </layout>
+   </item>
+   <item row="1" column="0">
+    <widget class="QLabel" name="lblPreview">
+     <property name="minimumSize">
+      <size>
+       <width>100</width>
+       <height>100</height>
+      </size>
+     </property>
+     <property name="frameShape">
+      <enum>QFrame::StyledPanel</enum>
+     </property>
+     <property name="frameShadow">
+      <enum>QFrame::Sunken</enum>
+     </property>
+     <property name="alignment">
+      <set>Qt::AlignCenter</set>
+     </property>
+    </widget>
+   </item>
+   <item row="2" column="0">
+    <widget class="QLabel" name="label_3">
+      <string>Symbol layers:</string>
+     </property>
+    </widget>
+   </item>
+   <item row="3" column="0">
+    <widget class="QListView" name="listLayers">
+      <sizepolicy hsizetype="Preferred" vsizetype="Expanding">
+      </sizepolicy>
+     </property>
+    </widget>
+   </item>
+   <item row="4" column="0">
+     <item>
+      <widget class="QPushButton" name="btnAddLayer">
+        <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
+        </sizepolicy>
+       </property>
+        <string>Add symbol layer</string>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <widget class="QPushButton" name="btnRemoveLayer">
+        </sizepolicy>
+       </property>
+        <string>Remove symbol layer</string>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <spacer>
+       </property>
+       <property name="sizeType">
+        <enum>QSizePolicy::Preferred</enum>
+       </property>
+        <size>
+         <width>20</width>
+        </size>
+       </property>
+      </spacer>
+     </item>
+     <item>
+      <widget class="QPushButton" name="btnLock">
+        </sizepolicy>
+       </property>
+        <string>Lock layer's color</string>
+       </property>
+       <property name="checkable">
+        <bool>true</bool>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <spacer>
+       </property>
+       </property>
+        <size>
+         <width>20</width>
+        </size>
+       </property>
+      </spacer>
+     </item>
+     <item>
+      <widget class="QPushButton" name="btnUp">
+        </sizepolicy>
+       </property>
+        <string>Move up</string>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <widget class="QPushButton" name="btnDown">
+        </sizepolicy>
+       </property>
+        <string>Move down</string>
+       </property>
+      </widget>
+     </item>
+    </layout>
+   </item>
+   <item row="5" column="0" colspan="2">
+     </property>
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+     </property>
+    </widget>
+   </item>
+  </layout>
+ </widget>
+ <tabstops>
+  <tabstop>listLayers</tabstop>
+  <tabstop>btnAddLayer</tabstop>
+  <tabstop>btnRemoveLayer</tabstop>
+  <tabstop>btnLock</tabstop>
+  <tabstop>btnUp</tabstop>
+  <tabstop>btnDown</tabstop>
+  <tabstop>cboLayerType</tabstop>
+ </tabstops>
+ <resources/>
+ <connections>
+  <connection>
+   <receiver>DlgSymbolV2Properties</receiver>
+   <hints>
+    <hint type="sourcelabel">
+     <x>248</x>
+     <y>254</y>
+    </hint>
+    <hint type="destinationlabel">
+     <x>157</x>
+     <y>274</y>
+    </hint>
+   </hints>
+  </connection>
+  <connection>
+   <hints>
+     <x>316</x>
+     <y>260</y>
+    </hint>
+     <x>286</x>
+     <y>274</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
+</ui>
Added: branches/symbology-ng-branch/src/ui/qgssymbolv2selectordialogbase.ui
--- branches/symbology-ng-branch/src/ui/qgssymbolv2selectordialogbase.ui	                        (rev 0)
+++ branches/symbology-ng-branch/src/ui/qgssymbolv2selectordialogbase.ui	2009-05-12 09:37:34 UTC (rev 10771)
@@ -0,0 +1,212 @@
+ <class>QgsSymbolV2SelectorDialogBase</class>
+ <widget class="QDialog" name="QgsSymbolV2SelectorDialogBase" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>477</width>
+    <height>397</height>
+   </rect>
+  </property>
+   <string>Symbol selector</string>
+  </property>
+   <item>
+     <item rowspan="2" row="0" column="0" >
+      <widget class="QLabel" name="lblPreview" >
+        <sizepolicy vsizetype="MinimumExpanding" hsizetype="MinimumExpanding" >
+        </sizepolicy>
+       </property>
+       <property name="frameShape" >
+        <enum>QFrame::Box</enum>
+       </property>
+       <property name="frameShadow" >
+       </property>
+        <string/>
+       </property>
+       </property>
+      </widget>
+     </item>
+      <widget class="QPushButton" name="btnSymbolProperties" >
+        <string>Properties</string>
+       </property>
+      </widget>
+     </item>
+     <item rowspan="2" row="0" column="2" >
+       </property>
+       <widget class="QWidget" name="pageMarker" >
+            <string>Size:</string>
+           </property>
+          </widget>
+         </item>
+          <widget class="QSpinBox" name="spinSize" >
+           <property name="minimum" >
+            <number>1</number>
+           </property>
+           <property name="maximum" >
+            <number>1000</number>
+           </property>
+          </widget>
+         </item>
+            <string>Angle:</string>
+           </property>
+          </widget>
+         </item>
+          <widget class="QDoubleSpinBox" name="spinAngle" >
+           <property name="decimals" >
+           </property>
+            <double>360.000000000000000</double>
+           </property>
+          </widget>
+         </item>
+        </layout>
+       </widget>
+       <widget class="QWidget" name="pageLine" >
+         <item>
+            <string>Width:</string>
+           </property>
+          </widget>
+         </item>
+         <item>
+          <widget class="QSpinBox" name="spinWidth" >
+           </property>
+          </widget>
+         </item>
+        </layout>
+       </widget>
+       <widget class="QWidget" name="pageFill" />
+      </widget>
+     </item>
+     <item rowspan="2" row="0" column="3" >
+      <spacer>
+       </property>
+       <property name="sizeType" >
+       </property>
+        <size>
+         <width>50</width>
+         <height>81</height>
+        </size>
+       </property>
+      </spacer>
+     </item>
+      <widget class="QPushButton" name="btnSetColor" >
+        <string>Set color</string>
+       </property>
+      </widget>
+     </item>
+    </layout>
+   </item>
+   <item>
+      <string>Symbols from style:</string>
+     </property>
+    </widget>
+   </item>
+   <item>
+    <widget class="QListView" name="viewSymbols" >
+      <size>
+       <width>48</width>
+      </size>
+     </property>
+     <property name="flow" >
+      <enum>QListView::LeftToRight</enum>
+     </property>
+     <property name="resizeMode" >
+     </property>
+     <property name="spacing" >
+     </property>
+     <property name="viewMode" >
+     </property>
+    </widget>
+   </item>
+   <item>
+     </property>
+     </property>
+    </widget>
+   </item>
+  </layout>
+ </widget>
+ <resources/>
+ <connections>
+  <connection>
+   <receiver>QgsSymbolV2SelectorDialogBase</receiver>
+   <hints>
+     <x>248</x>
+     <y>254</y>
+    </hint>
+     <x>157</x>
+     <y>274</y>
+    </hint>
+   </hints>
+  </connection>
+  <connection>
+   <hints>
+     <x>316</x>
+     <y>260</y>
+    </hint>
+     <x>286</x>
+     <y>274</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
+</ui>
Added: branches/symbology-ng-branch/src/ui/qgsvectorgradientcolorrampv2dialogbase.ui
--- branches/symbology-ng-branch/src/ui/qgsvectorgradientcolorrampv2dialogbase.ui	                        (rev 0)
+++ branches/symbology-ng-branch/src/ui/qgsvectorgradientcolorrampv2dialogbase.ui	2009-05-12 09:37:34 UTC (rev 10771)
@@ -0,0 +1,149 @@
+ <class>QgsVectorGradientColorRampV2DialogBase</class>
+ <widget class="QDialog" name="QgsVectorGradientColorRampV2DialogBase" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>400</width>
+    <height>300</height>
+   </rect>
+  </property>
+   <string>Gradient color ramp</string>
+  </property>
+   <item>
+        <string>Color 1:</string>
+       </property>
+      </widget>
+     </item>
+      <widget class="QPushButton" name="btnColor1" >
+       </property>
+      </widget>
+     </item>
+      <spacer>
+       </property>
+       </property>
+        <size>
+         <width>40</width>
+         <height>71</height>
+        </size>
+       </property>
+      </spacer>
+     </item>
+        <string>Color 2:</string>
+       </property>
+      </widget>
+     </item>
+      <widget class="QPushButton" name="btnColor2" >
+       </property>
+      </widget>
+     </item>
+    </layout>
+   </item>
+   <item>
+    <spacer>
+     </property>
+     </property>
+      <size>
+       <width>20</width>
+       <height>40</height>
+      </size>
+     </property>
+    </spacer>
+   </item>
+   <item>
+    <widget class="QGroupBox" name="groupBox" >
+     <property name="title" >
+      <string>Preview</string>
+     </property>
+      <item>
+         <enum>QFrame::NoFrame</enum>
+        </property>
+         <string/>
+        </property>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
+   <item>
+     </property>
+     </property>
+    </widget>
+   </item>
+  </layout>
+ </widget>
+ <resources/>
+ <connections>
+  <connection>
+   <receiver>QgsVectorGradientColorRampV2DialogBase</receiver>
+   <hints>
+     <x>258</x>
+     <y>281</y>
+    </hint>
+     <x>168</x>
+     <y>256</y>
+    </hint>
+   </hints>
+  </connection>
+  <connection>
+   <hints>
+     <x>363</x>
+     <y>273</y>
+    </hint>
+     <x>371</x>
+     <y>259</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
+</ui>
Added: branches/symbology-ng-branch/src/ui/symbollayer/widget_linedecoration.ui
--- branches/symbology-ng-branch/src/ui/symbollayer/widget_linedecoration.ui	                        (rev 0)
+++ branches/symbology-ng-branch/src/ui/symbollayer/widget_linedecoration.ui	2009-05-12 09:37:34 UTC (rev 10771)
@@ -0,0 +1,73 @@
+ <class>WidgetLineDecoration</class>
+ <widget class="QWidget" name="WidgetLineDecoration" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>368</width>
+    <height>244</height>
+   </rect>
+  </property>
+   <string>Form</string>
+  </property>
+   <item>
+     <item>
+        <string>Color:</string>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <widget class="QPushButton" name="btnChangeColor" >
+        <sizepolicy vsizetype="Fixed" hsizetype="Preferred" >
+        </sizepolicy>
+       </property>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <spacer>
+       </property>
+       </property>
+        <size>
+         <width>112</width>
+         <height>21</height>
+        </size>
+       </property>
+      </spacer>
+     </item>
+    </layout>
+   </item>
+   <item>
+    <spacer>
+     </property>
+      <size>
+       <width>350</width>
+      </size>
+     </property>
+    </spacer>
+   </item>
+  </layout>
+ </widget>
+ <resources/>
+ <connections/>
+</ui>
Added: branches/symbology-ng-branch/src/ui/symbollayer/widget_markerline.ui
--- branches/symbology-ng-branch/src/ui/symbollayer/widget_markerline.ui	                        (rev 0)
+++ branches/symbology-ng-branch/src/ui/symbollayer/widget_markerline.ui	2009-05-12 09:37:34 UTC (rev 10771)
@@ -0,0 +1,93 @@
+ <class>WidgetMarkerLine</class>
+ <widget class="QWidget" name="WidgetMarkerLine" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>360</width>
+    <height>192</height>
+   </rect>
+  </property>
+  </property>
+   <item>
+        <string>Marker:</string>
+       </property>
+      </widget>
+     </item>
+      <widget class="QPushButton" name="btnChangeMarker" >
+       </property>
+      </widget>
+     </item>
+     <item rowspan="3" row="0" column="2" >
+      <spacer>
+       </property>
+       </property>
+        <size>
+         <width>40</width>
+        </size>
+       </property>
+      </spacer>
+     </item>
+        <string>Interval:</string>
+       </property>
+      </widget>
+     </item>
+      <widget class="QSpinBox" name="spinInterval" >
+       </property>
+      </widget>
+     </item>
+     <item row="2" column="0" colspan="2" >
+      <widget class="QCheckBox" name="chkRotateMarker" >
+        <string>Rotate marker</string>
+       </property>
+      </widget>
+     </item>
+    </layout>
+   </item>
+   <item>
+    <spacer>
+     </property>
+      <size>
+       <width>261</width>
+      </size>
+     </property>
+    </spacer>
+   </item>
+  </layout>
+ </widget>
+ <tabstops>
+  <tabstop>btnChangeMarker</tabstop>
+  <tabstop>spinInterval</tabstop>
+  <tabstop>chkRotateMarker</tabstop>
+ </tabstops>
+ <resources/>
+ <connections/>
+</ui>
Added: branches/symbology-ng-branch/src/ui/symbollayer/widget_simplefill.ui
--- branches/symbology-ng-branch/src/ui/symbollayer/widget_simplefill.ui	                        (rev 0)
+++ branches/symbology-ng-branch/src/ui/symbollayer/widget_simplefill.ui	2009-05-12 09:37:34 UTC (rev 10771)
@@ -0,0 +1,103 @@
+ <class>WidgetSimpleFill</class>
+ <widget class="QWidget" name="WidgetSimpleFill" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>335</width>
+    <height>154</height>
+   </rect>
+  </property>
+  </property>
+   <item>
+       </property>
+      </widget>
+     </item>
+       </property>
+      </widget>
+     </item>
+      <spacer>
+       </property>
+       </property>
+        <size>
+         <width>91</width>
+         <height>51</height>
+        </size>
+       </property>
+      </spacer>
+     </item>
+        <string>Fill style:</string>
+       </property>
+      </widget>
+     </item>
+      <widget class="QgsBrushStyleComboBox" name="cboFillStyle" />
+     </item>
+        <string>Border color:</string>
+       </property>
+      </widget>
+     </item>
+      <widget class="QPushButton" name="btnChangeBorderColor" >
+       </property>
+      </widget>
+     </item>
+    </layout>
+   </item>
+   <item>
+    <spacer>
+     </property>
+      <size>
+       <width>244</width>
+      </size>
+     </property>
+    </spacer>
+   </item>
+  </layout>
+ </widget>
+ <customwidgets>
+  <customwidget>
+   <class>QgsBrushStyleComboBox</class>
+   <extends>QComboBox</extends>
+   <header>qgsbrushstylecombobox.h</header>
+  </customwidget>
+ </customwidgets>
+ <tabstops>
+  <tabstop>btnChangeColor</tabstop>
+  <tabstop>btnChangeBorderColor</tabstop>
+  <tabstop>cboFillStyle</tabstop>
+ </tabstops>
+ <resources/>
+ <connections/>
+</ui>
Added: branches/symbology-ng-branch/src/ui/symbollayer/widget_simpleline.ui
--- branches/symbology-ng-branch/src/ui/symbollayer/widget_simpleline.ui	                        (rev 0)
+++ branches/symbology-ng-branch/src/ui/symbollayer/widget_simpleline.ui	2009-05-12 09:37:34 UTC (rev 10771)
@@ -0,0 +1,113 @@
+ <class>WidgetSimpleLine</class>
+ <widget class="QWidget" name="WidgetSimpleLine" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+   </rect>
+  </property>
+  </property>
+   <item>
+       </property>
+      </widget>
+     </item>
+        </sizepolicy>
+       </property>
+       </property>
+      </widget>
+     </item>
+      <spacer>
+       </property>
+       </property>
+        <size>
+         <width>50</width>
+         <height>91</height>
+        </size>
+       </property>
+      </spacer>
+     </item>
+        <string>Pen width:</string>
+       </property>
+      </widget>
+     </item>
+        </sizepolicy>
+       </property>
+       </property>
+       </property>
+      </widget>
+     </item>
+        <string>Pen style:</string>
+       </property>
+      </widget>
+     </item>
+      <widget class="QgsPenStyleComboBox" name="cboPenStyle" />
+     </item>
+    </layout>
+   </item>
+   <item>
+    <spacer>
+     </property>
+      <size>
+      </size>
+     </property>
+    </spacer>
+   </item>
+  </layout>
+ </widget>
+ <customwidgets>
+  <customwidget>
+   <class>QgsPenStyleComboBox</class>
+   <header>qgspenstylecombobox.h</header>
+  </customwidget>
+ </customwidgets>
+ <resources/>
+ <connections/>
+</ui>
Added: branches/symbology-ng-branch/src/ui/symbollayer/widget_simplemarker.ui
--- branches/symbology-ng-branch/src/ui/symbollayer/widget_simplemarker.ui	                        (rev 0)
+++ branches/symbology-ng-branch/src/ui/symbollayer/widget_simplemarker.ui	2009-05-12 09:37:34 UTC (rev 10771)
@@ -0,0 +1,158 @@
+ <class>WidgetSimpleMarker</class>
+ <widget class="QWidget" name="WidgetSimpleMarker" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>394</width>
+    <height>270</height>
+   </rect>
+  </property>
+  </property>
+   <item>
+       </property>
+      </widget>
+     </item>
+      <widget class="QPushButton" name="btnChangeColorBorder" >
+       </property>
+      </widget>
+     </item>
+     <item rowspan="4" row="0" column="2" >
+      <spacer>
+       </property>
+       </property>
+        <size>
+         <width>61</width>
+         <height>61</height>
+        </size>
+       </property>
+      </spacer>
+     </item>
+        <string>Fill color:</string>
+       </property>
+      </widget>
+     </item>
+      <widget class="QPushButton" name="btnChangeColorFill" >
+       </property>
+      </widget>
+     </item>
+       </property>
+      </widget>
+     </item>
+       </property>
+      </widget>
+     </item>
+     <item row="3" column="0" >
+       </property>
+      </widget>
+     </item>
+     <item row="3" column="1" >
+       </property>
+       </property>
+      </widget>
+     </item>
+    </layout>
+   </item>
+   <item>
+    <widget class="QListWidget" name="lstNames" >
+      <sizepolicy vsizetype="Expanding" hsizetype="Preferred" >
+      </sizepolicy>
+     </property>
+     <property name="editTriggers" >
+      <set>QAbstractItemView::NoEditTriggers</set>
+     </property>
+      <size>
+       <width>20</width>
+      </size>
+     </property>
+     <property name="movement" >
+     </property>
+     </property>
+      <number>4</number>
+     </property>
+     <property name="gridSize" >
+      <size>
+       <width>30</width>
+       <height>25</height>
+      </size>
+     </property>
+     </property>
+     <property name="uniformItemSizes" >
+      <bool>true</bool>
+     </property>
+     <property name="wordWrap" >
+      <bool>true</bool>
+     </property>
+    </widget>
+   </item>
+   <item>
+    <spacer>
+     </property>
+     </property>
+      <size>
+       <width>376</width>
+      </size>
+     </property>
+    </spacer>
+   </item>
+  </layout>
+ </widget>
+ <resources/>
+ <connections/>
+</ui>
Added: branches/symbology-ng-branch/src/ui/symbollayer/widget_svgmarker.ui
--- branches/symbology-ng-branch/src/ui/symbollayer/widget_svgmarker.ui	                        (rev 0)
+++ branches/symbology-ng-branch/src/ui/symbollayer/widget_svgmarker.ui	2009-05-12 09:37:34 UTC (rev 10771)
@@ -0,0 +1,139 @@
+ <class>WidgetSvgMarker</class>
+ <widget class="QWidget" name="WidgetSvgMarker" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>378</width>
+    <height>276</height>
+   </rect>
+  </property>
+  </property>
+   <item>
+        <sizepolicy vsizetype="Preferred" hsizetype="MinimumExpanding" >
+        </sizepolicy>
+       </property>
+       </property>
+      </widget>
+     </item>
+        <sizepolicy vsizetype="Fixed" hsizetype="MinimumExpanding" >
+        </sizepolicy>
+       </property>
+       </property>
+       </property>
+      </widget>
+     </item>
+      <spacer>
+       </property>
+        <size>
+         <width>115</width>
+        </size>
+       </property>
+      </spacer>
+     </item>
+       </property>
+      </widget>
+     </item>
+       </property>
+       </property>
+      </widget>
+     </item>
+    </layout>
+   </item>
+   <item>
+      <string>SVG Image:</string>
+     </property>
+    </widget>
+   </item>
+   <item>
+    <widget class="QListView" name="viewImages" >
+     </property>
+      <size>
+       <width>32</width>
+       <height>32</height>
+      </size>
+     </property>
+     </property>
+      <number>2</number>
+     </property>
+      <size>
+       <width>36</width>
+       <height>36</height>
+      </size>
+     </property>
+     </property>
+      <bool>true</bool>
+     </property>
+    </widget>
+   </item>
+   <item>
+    <spacer>
+     </property>
+      <size>
+       <width>20</width>
+      </size>
+     </property>
+    </spacer>
+   </item>
+  </layout>
+ </widget>
+ <tabstops>
+  <tabstop>spinSize</tabstop>
+  <tabstop>spinAngle</tabstop>
+  <tabstop>viewImages</tabstop>
+ </tabstops>
+ <resources/>
+ <connections/>
+</ui>
More information about the QGIS-commit mailing list
