[QGIS Commit] r10787 - trunk/qgis/src/plugins/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed May 13 15:11:00 EDT 2009
Author: rblazek
Date: 2009-05-13 15:10:59 -0400 (Wed, 13 May 2009)
New Revision: 10787
   trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
   trunk/qgis/src/plugins/grass/qgsgrassmodule.h
fixed ticket #1133: title adjusted on resize, use of option label; description used as tooltip; layout of vector fields combobox; dont use empty not required option
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp	2009-05-13 14:22:34 UTC (rev 10786)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp	2009-05-13 19:10:59 UTC (rev 10787)
@@ -1557,8 +1557,7 @@
 QgsGrassModuleOption::QgsGrassModuleOption( QgsGrassModule *module, QString key,
     QDomElement &qdesc, QDomElement &gdesc, QDomNode &gnode,
     QWidget * parent )
-    : QGroupBox( parent ),
-    QgsGrassModuleItem( module, key, qdesc, gdesc, gnode ),
+    :  QgsGrassModuleGroupBoxItem( module, key, qdesc, gdesc, gnode, parent ),
     mControlType( NoControl ), mValueType( String ), mOutputType( None ), mHaveLimits( false ), mIsOutput( false )
   QgsDebugMsg( "called." );
@@ -1568,18 +1567,6 @@
   mLayout = new QVBoxLayout();
-  QString tit;
-  if ( mDescription.length() > 40 )
-    tit = mDescription.left( 40 ) + " ...";
-  else
-    tit = mDescription;
-  setTitle( " " + tit + " " );
   // Is it output?
   QDomNode promptNode = gnode.namedItem( "gisprompt" );
   if ( !promptNode.isNull() )
@@ -1925,8 +1912,11 @@
     list.push_back( mKey + "=" + mAnswer );
   else
-    list.push_back( mKey + "=" + value() );
+    QString val = value();
+    if ( !val.isEmpty() ) {
+        list.push_back( mKey + "=" + val );
   return list;
@@ -1939,7 +1929,7 @@
   if ( mControlType == LineEdit )
-    if ( mLineEdits.at( 0 )->text().trimmed().length() == 0 )
+    if ( mLineEdits.at( 0 )->text().trimmed().length() == 0 && mRequired )
       error.append( tr( "%1: missing value" ).arg( title() ) );
@@ -1965,7 +1955,7 @@
   else
     setChecked( false );
-  setText( mDescription );
+  setText( mTitle );
 QStringList QgsGrassModuleFlag::options()
@@ -1982,14 +1972,25 @@
+void QgsGrassModuleFlag::resizeEvent ( QResizeEvent * event )
+  adjustText();
+void QgsGrassModuleFlag::adjustText()
+  QString t = fontMetrics().elidedText ( mTitle , Qt::ElideRight, width() - iconSize().width() - 20  );
+  setText( t );
 /************************** QgsGrassModuleInput ***************************/
 QgsGrassModuleInput::QgsGrassModuleInput( QgsGrassModule *module,
     QgsGrassModuleStandardOptions *options, QString key,
     QWidget * parent )
     mModuleStandardOptions( options ),
     mGeometryTypeOption( 0 ), mVectorLayerOption( 0 ),
     mRegionButton( 0 ), mUpdate( false )
@@ -1997,25 +1998,12 @@
   mGeometryTypeMask = GV_POINT | GV_LINE | GV_AREA;
-  QString tit;
-  if ( mDescription.isEmpty() )
+  if ( mTitle.isEmpty() )
-    tit = "Input";
+    mTitle = tr( "Input" );
-  else
-    else
+  adjustTitle();
   QDomElement promptElem = promptNode.toElement();
   QString element = promptElem.attribute( "element" );
@@ -2517,7 +2505,8 @@
                                         QDomElement &qdesc, QDomElement &gdesc, QDomNode &gnode )
     : mModule( module ),
     mKey( key ),
-    mHidden( false )
+    mHidden( false ),
+    mRequired (false)
   //mAnswer = qdesc.attribute("answer", "");
@@ -2540,21 +2529,41 @@
     mHidden = true;
+  QString label, description;
   if ( !qdesc.attribute( "label" ).isEmpty() )
-    mDescription = qdesc.attribute( "label" );
+    label = qdesc.attribute( "label" );
-  else
+  if ( label.isEmpty() )
-    QDomNode n = gnode.namedItem( "description" );
+    QDomNode n = gnode.namedItem( "label" );
     if ( !n.isNull() )
       QDomElement e = n.toElement();
-      mDescription = e.text().trimmed();
-      mDescription.replace( 0, 1, mDescription.left( 1 ).toUpper() );
+      label = e.text().trimmed();
+      label.replace( 0, 1, label.left( 1 ).toUpper() );
+  QDomNode n = gnode.namedItem( "description" );
+  if ( !n.isNull() )
+      QDomElement e = n.toElement();
+      description = e.text().trimmed();
+      description.replace( 0, 1, description.left( 1 ).toUpper() );
+  if ( !label.isEmpty() ) {
+      mTitle = label;
+      mToolTip = description;
+  } else {
+      mTitle = description;
+  if ( gnode.toElement().attribute( "required" ) == "yes" )
+    mRequired = true;
   mId = qdesc.attribute( "id" );
@@ -2564,34 +2573,48 @@
 QgsGrassModuleItem::~QgsGrassModuleItem() {}
+/***************** QgsGrassModuleGroupBoxItem *********************/
+QgsGrassModuleGroupBoxItem::QgsGrassModuleGroupBoxItem( QgsGrassModule *module, QString key,
+    QDomElement &qdesc, QDomElement &gdesc, QDomNode &gnode,
+    QWidget * parent )
+    : QGroupBox( parent ),
+    QgsGrassModuleItem( module, key, qdesc, gdesc, gnode )
+  adjustTitle();
+  setToolTip ( mToolTip );
+QgsGrassModuleGroupBoxItem::~QgsGrassModuleGroupBoxItem() {}
+void QgsGrassModuleGroupBoxItem::resizeEvent ( QResizeEvent * event )
+  adjustTitle();
+void QgsGrassModuleGroupBoxItem::adjustTitle()
+  QString tit = fontMetrics().elidedText ( mTitle, Qt::ElideRight, width() - 20  );
+  setTitle( tit );
 /***************** QgsGrassModuleGdalInput *********************/
 QgsGrassModuleGdalInput::QgsGrassModuleGdalInput(
   QgsGrassModule *module, int type, QString key, QDomElement &qdesc,
   QDomElement &gdesc, QDomNode &gnode, QWidget * parent )
     mType( type ), mOgrLayerOption( 0 ), mOgrWhereOption( 0 )
-  QString tit;
-    tit = "OGR/PostGIS/GDAL Input";
+    mTitle = "OGR/PostGIS/GDAL Input";
-  else
-    else
+  adjustTitle();
@@ -2614,7 +2637,7 @@
   // Read "whereoption" if defined
-  opt = qdesc.attribute( "whereoption" );
+  opt = qdesc.attribute( "where" );
   if ( !opt.isNull() )
     QDomNode optNode = QgsGrassModule::nodeByKey( gdesc, opt );
@@ -2797,29 +2820,15 @@
   QgsGrassModule *module, QgsGrassModuleStandardOptions *options,
     mModuleStandardOptions( options ), mLayerInput( 0 )
-  QString tit;
-    tit = tr( "Attribute field" );
+    mTitle = tr( "Attribute field" );
-  else
-    else
+  adjustTitle();
@@ -2836,7 +2845,9 @@
     connect( mLayerInput, SIGNAL( valueChanged() ), this, SLOT( updateFields() ) );
-  mFieldComboBox = new QComboBox( this );
+  QHBoxLayout *l = new QHBoxLayout( this );
+  mFieldComboBox = new QComboBox( );
+  l->addWidget( mFieldComboBox );
   // Fill in layer current fields
   updateFields();
@@ -2888,30 +2899,16 @@
     mModuleStandardOptions( options ), mLayerInput( 0 ),
     mVectorLayer( 0 )
-  QString tit;
+    mTitle = tr( "Selected categories" );
-  else
-    else
+  adjustTitle();
@@ -3005,29 +3002,15 @@
     mType( Old )
-  QString tit;
-    tit = tr( "File" );
+    mTitle = tr( "File" );
-  else
-    else
+  adjustTitle();
@@ -3126,7 +3109,7 @@
   QString path = mLineEdit->text().trimmed();
-  if ( path.length() == 0 )
+  if ( path.length() == 0 && mRequired )
     return error;
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodule.h
--- trunk/qgis/src/plugins/grass/qgsgrassmodule.h	2009-05-13 14:22:34 UTC (rev 10786)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodule.h	2009-05-13 19:10:59 UTC (rev 10787)
@@ -325,25 +325,61 @@
     //! Optional option id used by other options which depend on this
     QString mId;
-    //! GRASS description
-    QString mDescription;
+    //! Item title, GRASS label or description
+    QString mTitle;
+    //! Item tooltip, GRASS description if defined
+    QString mToolTip;
     //! Hidden option or displayed
     bool mHidden;
     //! Predefined answer from config
     QString mAnswer;
+    //! Is it required
+    bool mRequired;
   private:
+/****************** QgsGrassModuleGroupBoxItem ************************/
+/*! \class QgsGrassModuleGroupBoxItem
+ *  \brief GRASS module option box
+class QgsGrassModuleGroupBoxItem: public QGroupBox, public QgsGrassModuleItem
+  Q_OBJECT
+  public:
+    /*! \brief Constructor
+     * \param qdesc option element in QGIS module description XML file
+     * \param gdesc GRASS module XML description file
+     * \param gnode option node in GRASS module XML description file
+    QgsGrassModuleGroupBoxItem( QgsGrassModule *module, QString key,
+                        QWidget * parent = 0 );
+    //! Destructor
+    virtual ~QgsGrassModuleGroupBoxItem();
+    void resizeEvent ( QResizeEvent * event );
+  public slots:
+    //! Adjust title size, called on resize
+    void adjustTitle();
 /****************** QgsGrassModuleOption ************************/
 /*! \class QgsGrassModuleOption
  *  \brief  GRASS option
-class QgsGrassModuleOption: public QGroupBox, public QgsGrassModuleItem
+class QgsGrassModuleOption: public QgsGrassModuleGroupBoxItem
     Q_OBJECT
@@ -458,9 +494,15 @@
     //! Destructor
     ~QgsGrassModuleFlag();
     //! Retruns list of options which will be passed to module
     virtual QStringList options();
-  private:
+  public slots:
+    void adjustText();
 /************************ QgsGrassModuleInput **********************/
@@ -468,7 +510,7 @@
 /*! \class QgsGrassModuleInput
  *  \brief Class representing raster or vector module input
-class QgsGrassModuleInput: public QGroupBox, public QgsGrassModuleItem
+class QgsGrassModuleInput: public QgsGrassModuleGroupBoxItem
     Q_OBJECT
@@ -575,7 +617,7 @@
 /*! \class QgsGrassModuleGdalInput
  *  \brief GDAL/OGR module input
-class QgsGrassModuleGdalInput: public QGroupBox, public QgsGrassModuleItem
+class QgsGrassModuleGdalInput: public QgsGrassModuleGroupBoxItem
     Q_OBJECT
@@ -629,7 +671,7 @@
 /*! \class QgsGrassModuleField
  *  \brief GRASS vector attribute column.
-class QgsGrassModuleField: public QGroupBox, public QgsGrassModuleItem
+class QgsGrassModuleField: public QgsGrassModuleGroupBoxItem
     Q_OBJECT
@@ -676,7 +718,7 @@
 /*! \class QgsGrassModuleSelection
  *  \brief List of categories taken from current layer selection.
-class QgsGrassModuleSelection: public QGroupBox, public QgsGrassModuleItem
+class QgsGrassModuleSelection: public QgsGrassModuleGroupBoxItem
     Q_OBJECT
@@ -724,10 +766,10 @@
 /*********************** QgsGrassModuleFile **********************/
-/*! \class QgsGrassModuleSelection
+/*! \class QgsGrassModuleFile
  *  \brief Input/output file.
-class QgsGrassModuleFile: public QGroupBox, public QgsGrassModuleItem
+class QgsGrassModuleFile: public QgsGrassModuleGroupBoxItem
     Q_OBJECT
More information about the QGIS-commit mailing list
