[QGIS Commit] r10791 - in trunk/qgis: python/core src/core
src/plugins/diagram_overlay
svn_qgis at osgeo.org
Thu May 14 11:58:25 EDT 2009
Author: mhugent
Date: 2009-05-14 11:58:24 -0400 (Thu, 14 May 2009)
New Revision: 10791
Added:
trunk/qgis/src/core/qgspalgeometry.cpp
trunk/qgis/src/core/qgspalgeometry.h
trunk/qgis/python/core/conversions.sip
trunk/qgis/python/core/core.sip
trunk/qgis/python/core/qgsoverlayobject.sip
trunk/qgis/python/core/qgsvectoroverlay.sip
trunk/qgis/src/core/CMakeLists.txt
trunk/qgis/src/core/qgsoverlayobject.h
trunk/qgis/src/core/qgsoverlayobjectpositionmanager.h
trunk/qgis/src/core/qgspalobjectpositionmanager.cpp
trunk/qgis/src/core/qgspalobjectpositionmanager.h
trunk/qgis/src/core/qgsvectorlayer.cpp
trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
Change in overlay classes such that pal object and geos geometry don't appear in the public interfaces (important for python bindings)
Modified: trunk/qgis/python/core/conversions.sip
--- trunk/qgis/python/core/conversions.sip 2009-05-14 14:11:46 UTC (rev 10790)
+++ trunk/qgis/python/core/conversions.sip 2009-05-14 15:58:24 UTC (rev 10791)
@@ -9,6 +9,7 @@
- QMap<QString, QVariant::Type>
- QMap<TYPE1, TYPE2*>
- QMultiMap<double, TYPE2>
+- QMap<int, QgsOverlayObject*>*
%ModuleHeaderCode
@@ -21,6 +22,7 @@
%End
template <TYPE>
%MappedType QVector< QVector<TYPE> >
@@ -737,3 +739,80 @@
return sipGetState(sipTransferObj);
%End
+%MappedType QMap<int, QgsOverlayObject*>
+%TypeHeaderCode
+#include <QMap>
+%End
+%ConvertFromTypeCode
+//convert map to a python dictionary
+ PyObject *d;
+ if ((d = PyDict_New()) == NULL)
+ return NULL;
+ for (QMap<int, QgsOverlayObject*>::iterator it = sipCpp->begin(); it != sipCpp->end(); ++it)
+ QgsOverlayObject* oobj = new QgsOverlayObject(*it.value());
+ PyObject* keyobj = PyInt_FromLong(it.key());
+ PyObject* pyOobj = sipConvertFromInstance(oobj, sipClass_QgsOverlayObject, sipTransferObj);
+ PyDict_SetItem(d, keyobj, pyOobj);
+ if(pyOobj == NULL || keyobj == NULL || PyDict_SetItem(d, keyobj, pyOobj) < 0)
+ Py_DECREF(d);
+ if (pyOobj)
+ Py_DECREF(pyOobj);
+ if (keyobj)
+ Py_DECREF(keyobj);
+ return NULL;
+ return d;
+%End
+%ConvertToTypeCode
+ PyObject *t1obj, *t2obj;
+#if PY_VERSION_HEX >= 0x02050000
+ Py_ssize_t i = 0;
+#else
+ int i = 0;
+#endif
+ QMap<int, QgsOverlayObject*> *qm = new QMap<int, QgsOverlayObject*>;
+ while (PyDict_Next(sipPy, &i, &t1obj, &t2obj))
+ int state;
+ int t1 = (int)(PyFloat_AsDouble(t1obj));
+ QgsOverlayObject* t2 = reinterpret_cast<QgsOverlayObject*>(sipConvertToInstance(t2obj, sipClass_QgsOverlayObject, sipTransferObj, SIP_NOT_NONE, &state, sipIsErr));
+ if (*sipIsErr)
+ sipReleaseInstance(t2, sipClass_QgsOverlayObject, state);
+ delete qm;
+ return 0;
+ qm->insert(t1, t2);
+ *sipCppPtr = qm;
+ return sipGetState(sipTransferObj);
+%End
Modified: trunk/qgis/python/core/core.sip
--- trunk/qgis/python/core/core.sip 2009-05-14 14:11:46 UTC (rev 10790)
+++ trunk/qgis/python/core/core.sip 2009-05-14 15:58:24 UTC (rev 10791)
@@ -42,6 +42,7 @@
%Include qgsmaptopixel.sip
%Include qgsmarkercatalogue.sip
%Include qgsmessageoutput.sip
+%Include qgsoverlayobject.sip
%Include qgspoint.sip
%Include qgsproject.sip
%Include qgsprovidermetadata.sip
@@ -70,4 +71,5 @@
%Include qgsvectordataprovider.sip
%Include qgsvectorfilewriter.sip
%Include qgsvectorlayer.sip
+%Include qgsvectoroverlay.sip
Modified: trunk/qgis/python/core/qgsoverlayobject.sip
--- trunk/qgis/python/core/qgsoverlayobject.sip 2009-05-14 14:11:46 UTC (rev 10790)
+++ trunk/qgis/python/core/qgsoverlayobject.sip 2009-05-14 15:58:24 UTC (rev 10791)
@@ -1,56 +1,39 @@
-class CORE_EXPORT QgsOverlayObject: public pal::PalGeometry
+class QgsOverlayObject
%TypeHeaderCode
#include "qgsoverlayobject.h"
%End
- public:
+ public:
QgsOverlayObject( int width = 0, int height = 0, double rotation = 0, QgsGeometry* geometry = 0 );
virtual ~QgsOverlayObject();
//copy constructor and assignment operator necessary because of mGeometry
QgsOverlayObject( const QgsOverlayObject& other );
- QgsOverlayObject& operator=( const QgsOverlayObject& other );
+ //this function fill not be wrapped to not depend on geos python bindings
/**Returns the feature geometry in geos format. The calling function does _not_ take
- ownership of the generated object*/
- GEOSGeometry* getGeosGeometry();
- /**Feature geometry is released when object is destructed so this function is empty*/
- void releaseGeosGeometry( GEOSGeometry *the_geom ) {}
+ ownership of the generated object. The geometry is in map coordinates
+ @note: this function is deprecated. Please use geometry() and QgsGeometry::asGeos instead*/
+ //GEOSGeometry* getGeosGeometry();
+ /**Feature geometry is released when object is destructed so this function is empty. This function is deprecated and does nothing*/
+ //void releaseGeosGeometry( GEOSGeometry *the_geom )
//getters
- int width() const {return mWidth;}
- int height() const {return mHeight;}
- double rotation() const {return mRotation;}
- QgsGeometry* geometry() {return mGeometry;}
- const QgsGeometry* geometry() const {return mGeometry;}
+ int width() const;
+ int height() const;
+ double rotation() const;
+ QgsGeometry* geometry();
+ //const QgsGeometry* geometry() const;
QgsPoint position() const;
- QList<QgsPoint> positions() const {return mPositions;}
+ QList<QgsPoint> positions() const;
//setters
- void setHeight( int height ) {mHeight = height;}
- void setWidth( int width ) {mWidth = width;}
- void setRotation( double rotation ) {mRotation = rotation;}
+ void setHeight( int height );
+ void setWidth( int width );
+ void setRotation( double rotation );
/**Set geometry. This class takes ownership of the object*/
void setGeometry( QgsGeometry* g );
/**Adds a position in map coordinates*/
void addPosition( const QgsPoint& position );
- private:
- /**Width of the bounding box in pixels*/
- int mWidth;
- /**Height of the bounding box in pixels*/
- int mHeight;
- /**Position of the object in map coordinates. Note that it is possible that an object
- has several positions, e.g. a multiobject or an object that is split into multiple parts
- by the edge of the view extent*/
- QList<QgsPoint> mPositions;
- /**Rotation of the object*/
- double mRotation;
- /**Copy of the feature geometry. A copy is necessary because in QGIS geometries are deleted
- after drawing*/
- QgsGeometry* mGeometry;
Modified: trunk/qgis/python/core/qgsvectoroverlay.sip
--- trunk/qgis/python/core/qgsvectoroverlay.sip 2009-05-14 14:11:46 UTC (rev 10790)
+++ trunk/qgis/python/core/qgsvectoroverlay.sip 2009-05-14 15:58:24 UTC (rev 10791)
@@ -1,4 +1,4 @@
-class CORE_EXPORT QgsVectorOverlay
+class QgsVectorOverlay
%TypeHeaderCode
#include "qgsvectoroverlay.h"
@@ -7,7 +7,7 @@
QgsVectorOverlay( QgsVectorLayer* vl );
virtual ~QgsVectorOverlay();
- /**Create the overlay objects contained in a view extent. Subclasses need to implement this method and assign width/height information to the overlay ovbjects*/
+ /**Create the overlay objects contained in a view extent. Subclasses need to implement this method and assign width/height information to the overlay objects*/
virtual void createOverlayObjects( const QgsRenderContext& renderContext ) = 0;
@@ -18,39 +18,22 @@
virtual void drawOverlayObjects( QgsRenderContext& context ) const = 0;
/**Gives direct access to oberlay objects*/
- QMap<int, QgsOverlayObject*>* overlayObjects() {return &mOverlayObjects;}
+ QMap<int, QgsOverlayObject*>* overlayObjects();
/**Describes the overlay type (e.g. "diagram" or "label")*/
virtual QString typeName() const = 0;
/**Set attribute indices necessary to fetch*/
- void setAttributes( const QgsAttributeList& list ) {mAttributes = list;}
+ void setAttributes( const QList<int>& list );
- bool displayFlag() const {return mDisplayFlag;}
+ bool displayFlag() const;
/**Display yes/no*/
- void setDisplayFlag( bool flag ) {mDisplayFlag = flag;}
+ void setDisplayFlag( bool flag );
/**Restore from project file*/
virtual bool readXML( const QDomNode& overlayNode ) = 0;
/**Save to project file*/
virtual bool writeXML( QDomNode& layer_node, QDomDocument& doc ) const = 0;
- protected:
- /**Pointer to the vector layer for this overlay*/
- QgsVectorLayer* mVectorLayer;
- /**True if overlay should be displayed*/
- bool mDisplayFlag;
- /**A list with attribute indexes that are needed for overlay rendering*/
- QgsAttributeList mAttributes;
- /**Key: feature ids, value: the corresponding overlay objects. Normally, they are created for each redraw and deleted before the next redraw*/
- QMap<int, QgsOverlayObject*> mOverlayObjects;
- /**Position constraints that may be set to be persistent after redraws. Key is the feature id, value the map point
- where the feature should be placed*/
- QMap<int, QgsPoint> mPositionConstraints;
Modified: trunk/qgis/src/core/CMakeLists.txt
--- trunk/qgis/src/core/CMakeLists.txt 2009-05-14 14:11:46 UTC (rev 10790)
+++ trunk/qgis/src/core/CMakeLists.txt 2009-05-14 15:58:24 UTC (rev 10791)
@@ -27,6 +27,7 @@
qgsmaptopixel.cpp
qgsmessageoutput.cpp
qgsoverlayobject.cpp
+ qgspalgeometry.cpp
qgspoint.cpp
qgsproject.cpp
Modified: trunk/qgis/src/core/qgsoverlayobject.h
--- trunk/qgis/src/core/qgsoverlayobject.h 2009-05-14 14:11:46 UTC (rev 10790)
+++ trunk/qgis/src/core/qgsoverlayobject.h 2009-05-14 15:58:24 UTC (rev 10791)
@@ -18,8 +18,8 @@
#ifndef QGSOVERLAYOBJECT_H
#define QGSOVERLAYOBJECT_H
+#include "qgsgeometry.h"
#include "qgspoint.h"
-#include "palgeometry.h"
#include <QList>
class QgsGeometry;
@@ -29,7 +29,7 @@
* to calculate object placement
* \note This class has been added in version 1.1
+class CORE_EXPORT QgsOverlayObject
public:
@@ -41,9 +41,10 @@
- ownership of the generated object. The geometry is in map coordinates*/
//getters
@@ -73,7 +74,8 @@
int mHeight;
+ by the edge of the view extent. It is also possible that there is no position (e.g. geometry too small). In
+ that case*/
double mRotation;
Modified: trunk/qgis/src/core/qgsoverlayobjectpositionmanager.h
--- trunk/qgis/src/core/qgsoverlayobjectpositionmanager.h 2009-05-14 14:11:46 UTC (rev 10790)
+++ trunk/qgis/src/core/qgsoverlayobjectpositionmanager.h 2009-05-14 15:58:24 UTC (rev 10791)
@@ -31,7 +31,8 @@
class QgsOverlayObjectPositionManager
public:
+ //virtual destructor needed for proper memory management
+ virtual ~QgsOverlayObjectPositionManager(){}
/**Adds a layer that may contain * overlays to the position manager. The overlay objects contained in the
overlays will then be considered in label placement*/
virtual void addLayer( QgsVectorLayer* vl, QList<QgsVectorOverlay*>& overlays ) = 0;
Added: trunk/qgis/src/core/qgspalgeometry.cpp
--- trunk/qgis/src/core/qgspalgeometry.cpp (rev 0)
+++ trunk/qgis/src/core/qgspalgeometry.cpp 2009-05-14 15:58:24 UTC (rev 10791)
@@ -0,0 +1,46 @@
+ qgspalgeometry.cpp - description
+ begin : May 2009
+ copyright : (C) 2009 by Marco Hugentobler
+ email : marco dot hugentobler at karto dot baug dot ethz dot ch
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+#include "qgspalgeometry.h"
+#include "qgsoverlayobject.h"
+#include <geos_c.h>
+QgsPALGeometry::QgsPALGeometry(QgsOverlayObject* op): mOverlayObjectPtr(op)
+QgsPALGeometry::QgsPALGeometry(): mOverlayObjectPtr(0)
+QgsPALGeometry::~QgsPALGeometry()
+GEOSGeometry* QgsPALGeometry::getGeosGeometry()
+ if(mOverlayObjectPtr)
+ if(mOverlayObjectPtr->geometry())
+ return mOverlayObjectPtr->geometry()->asGeos();
+ return 0;
Added: trunk/qgis/src/core/qgspalgeometry.h
--- trunk/qgis/src/core/qgspalgeometry.h (rev 0)
+++ trunk/qgis/src/core/qgspalgeometry.h 2009-05-14 15:58:24 UTC (rev 10791)
@@ -0,0 +1,49 @@
+ qgspalgeometry.h
+ begin : May 2009
+#ifndef QGSPALGEOMETRY_H
+#define QGSPALGEOMETRY_H
+#include "palgeometry.h"
+class QgsOverlayObject;
+/**A class to make the QGIS geometries known to the PAL library (PAL works on geos geometry). The main purpose of this class is to remove the visibility of PAL and geos classes in the python interface*/
+class CORE_EXPORT QgsPALGeometry: public pal::PalGeometry
+ public:
+ /**Constructor that takes the geometry representation as geos object. \
+ Note that the class does not take ownership*/
+ QgsPALGeometry(QgsOverlayObject* op);
+ ~QgsPALGeometry();
+ //methods inherited from PalGeometry
+ GEOSGeometry* getGeosGeometry();
+ void releaseGeosGeometry( GEOSGeometry *the_geom ){}
+ /**Returns pointer to the overlay object this geometry referrs to. Don't delete the returned object!*/
+ QgsOverlayObject* overlayObjectPtr() const {return mOverlayObjectPtr;}
+ private:
+ /**Default constructor forbidden*/
+ QgsPALGeometry();
+ /**Pointer to the related overlay object*/
+ QgsOverlayObject* mOverlayObjectPtr;
+#endif // QGSPALGEOMETRY_H
Modified: trunk/qgis/src/core/qgspalobjectpositionmanager.cpp
--- trunk/qgis/src/core/qgspalobjectpositionmanager.cpp 2009-05-14 14:11:46 UTC (rev 10790)
+++ trunk/qgis/src/core/qgspalobjectpositionmanager.cpp 2009-05-14 15:58:24 UTC (rev 10791)
@@ -16,6 +16,8 @@
#include "qgspalobjectpositionmanager.h"
#include "qgsrendercontext.h"
#include "qgsvectorlayer.h"
@@ -31,7 +33,7 @@
QgsPALObjectPositionManager::~QgsPALObjectPositionManager()
+ deletePALGeometries();
void QgsPALObjectPositionManager::addLayer( QgsVectorLayer* vl, QList<QgsVectorOverlay*>& overlays )
@@ -85,7 +87,10 @@
QMap<int, QgsOverlayObject*>::const_iterator objectIt = positionObjects->begin();
for ( ; objectIt != positionObjects->end(); ++objectIt )
- positionLayer->registerFeature( strdup( QString::number( objectNr ).toAscii().data() ), objectIt.value(), objectIt.value()->width(), objectIt.value()->height() );
+ QgsPALGeometry* palGeom = new QgsPALGeometry(objectIt.value());
+ mPALGeometries.push_back(palGeom); //insert object into list to delete memory later
+ char* featureLabel = QString::number( objectNr ).toAscii().data();
+ positionLayer->registerFeature(featureLabel, palGeom, objectIt.value()->width(), objectIt.value()->height() );
++objectNr;
@@ -135,22 +140,32 @@
return;
- QgsOverlayObject* currentOverlayObject = 0;
+ //pal geometry that the current label object refers to
+ QgsPALGeometry* referredGeometry = 0;
+ QgsOverlayObject* referredOverlayObject = 0;
std::list<pal::Label*>::iterator labelIt = resultLabelList->begin();
for ( ; labelIt != resultLabelList->end(); ++labelIt )
- currentOverlayObject = dynamic_cast<QgsOverlayObject*>(( *labelIt )->getGeometry() );
- if ( !currentOverlayObject )
+ referredGeometry = dynamic_cast<QgsPALGeometry*>(( *labelIt )->getGeometry() );
+ if ( !referredGeometry)
continue;
+ referredOverlayObject = referredGeometry->overlayObjectPtr();
+ if(!referredOverlayObject)
+ continue;
//QGIS takes the coordinates of the middle points
double x = (( *labelIt )->getX( 0 ) + ( *labelIt )->getX( 1 ) + ( *labelIt )->getX( 2 ) + ( *labelIt )->getX( 3 ) ) / 4;
double y = (( *labelIt )->getY( 0 ) + ( *labelIt )->getY( 1 ) + ( *labelIt )->getY( 2 ) + ( *labelIt )->getY( 3 ) ) / 4;
- currentOverlayObject->addPosition( QgsPoint( x, y ) );
+ referredOverlayObject->addPosition( QgsPoint( x, y ) );
+ //release memory for QgsPALGeometries
void QgsPALObjectPositionManager::removeLayers()
@@ -196,3 +211,13 @@
mPositionEngine.setSearch( pal::CHAIN );
+void QgsPALObjectPositionManager::deletePALGeometries()
+ QList<QgsPALGeometry*>::iterator geomIt = mPALGeometries.begin();
+ for(; geomIt != mPALGeometries.end(); ++geomIt)
+ delete (*geomIt);
+ mPALGeometries.clear();
Modified: trunk/qgis/src/core/qgspalobjectpositionmanager.h
--- trunk/qgis/src/core/qgspalobjectpositionmanager.h 2009-05-14 14:11:46 UTC (rev 10790)
+++ trunk/qgis/src/core/qgspalobjectpositionmanager.h 2009-05-14 15:58:24 UTC (rev 10791)
@@ -21,6 +21,8 @@
#include "qgsoverlayobjectpositionmanager.h"
#include "pal.h"
+class QgsPALGeometry;
/**A class that uses the PAL library for overlay object placement
@@ -40,5 +42,9 @@
private:
pal::Pal mPositionEngine;
int mNumberOfLayers;
+ /**Internal storage of the pal geometries between addLayer and findObjectPositions operations*/
+ QList<QgsPALGeometry*> mPALGeometries;
+ void deletePALGeometries();
#endif
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2009-05-14 14:11:46 UTC (rev 10790)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2009-05-14 15:58:24 UTC (rev 10791)
@@ -168,6 +168,14 @@
deleteCachedGeometries();
delete mActions;
+ //delete remaining overlays
+ QList<QgsVectorOverlay*>::iterator overlayIt = mOverlays.begin();
+ for(; overlayIt != mOverlays.end(); ++overlayIt)
+ delete (*overlayIt);
QString QgsVectorLayer::storageType() const
Modified: trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
--- trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp 2009-05-14 14:11:46 UTC (rev 10790)
+++ trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp 2009-05-14 15:58:24 UTC (rev 10791)
@@ -41,6 +41,11 @@
QgsDiagramOverlay::~QgsDiagramOverlay()
+ //memory cleanup
+ for ( QMap<int, QgsOverlayObject*>::iterator it = mOverlayObjects.begin(); it != mOverlayObjects.end(); ++it )
+ delete it.value();
delete mDiagramRenderer;
