[QGIS Commit] r10817 - trunk/qgis/src/plugins/grass/scripts
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon May 18 11:35:14 EDT 2009
Author: rblazek
Date: 2009-05-18 11:35:13 -0400 (Mon, 18 May 2009)
New Revision: 10817
   trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py
try if grass module can be imported
Modified: trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py
--- trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py	2009-05-18 13:31:58 UTC (rev 10816)
+++ trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py	2009-05-18 15:35:13 UTC (rev 10817)
@@ -72,7 +72,10 @@
 import sys
 import os
 import string
-import grass
+try:
+    import grass
+except:
+    raise Exception ("Cannot find 'grass' Python module. Python is supported by GRASS from version 6.4" )
 def main():
     host = options['host']
More information about the QGIS-commit mailing list
