[QGIS Commit] r10841 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sat May 23 11:42:24 EDT 2009
Author: wonder
Date: 2009-05-23 11:42:24 -0400 (Sat, 23 May 2009)
New Revision: 10841
trunk/qgis/src/app/qgsmaptoolsimplify.cpp
trunk/qgis/src/app/qgsmaptoolsimplify.h
Fixed a crash when simplifying geometries with larger coordinates. By Richard Kostecky.
Modified: trunk/qgis/src/app/qgsmaptoolsimplify.cpp
--- trunk/qgis/src/app/qgsmaptoolsimplify.cpp 2009-05-23 09:20:42 UTC (rev 10840)
+++ trunk/qgis/src/app/qgsmaptoolsimplify.cpp 2009-05-23 15:42:24 UTC (rev 10841)
@@ -49,11 +49,12 @@
void QgsSimplifyDialog::setRange(int minValue, int maxValue)
- horizontalSlider->setMinimum(minValue);
+ // let's have 20 page steps
+ horizontalSlider->setPageStep( (maxValue - minValue) / 20 );
+ horizontalSlider->setMinimum(minValue -1);// -1 for count with minimum tolerance end caused by double imprecision
horizontalSlider->setMaximum(maxValue);
- // let's have 20 page steps
- horizontalSlider->setPageStep( (maxValue - minValue) / 20 );
@@ -82,14 +83,18 @@
// create a copy of selected feature and do the simplification
QgsFeature f = mSelectedFeature;
- if ( mSelectedFeature.geometry()->type() == QGis::Line )
+ //QgsSimplifyFeature::simplifyLine(f, mTolerance);
+ if (mTolerance > 0)
- QgsSimplifyFeature::simplifyLine(f, mTolerance);
+ if ( mSelectedFeature.geometry()->type() == QGis::Line )
+ QgsSimplifyFeature::simplifyLine(f, mTolerance);
+ else
+ QgsSimplifyFeature::simplifyPolygon(f, mTolerance);
- else
- QgsSimplifyFeature::simplifyPolygon(f, mTolerance);
mRubberBand->setToGeometry(f.geometry(), false);
@@ -111,15 +116,29 @@
mCanvas->refresh();
-int QgsMapToolSimplify::calculateDivider(double num)
+int QgsMapToolSimplify::calculateDivider(double minimum, double maximum)
- double tmp = num;
+ double tmp = minimum;
long i = 1;
+ if (minimum == 0)
+ { //exception if min = 0 than divider must be counted from maximum
+ tmp = maximum;
+ //count divider in such way so it can be used as whole number
while (tmp < 1)
tmp = tmp*10;
i = i *10;
+ if (minimum == 0)
+ { //special case that minimum is 0 to have more than 1 step
+ i = i*100000;
+//taking care of problem when multiplication would overflow maxint
+ while (int(i * maximum) < 0)
+ i = i/10;
return i;
@@ -127,7 +146,7 @@
double minTolerance, maxTolerance;
- double tol = 0.0000001;
+ double tol = 0.000001;
bool found = false;
bool isLine = mSelectedFeature.geometry()->type() == QGis::Line;
QVector<QgsPoint> pts = getPointList(mSelectedFeature);
@@ -137,14 +156,35 @@
return false;
- // calculate min
+ // calculate minimum tolerance where no vertex is excluded
+ bool maximized = false;
+ int count = 0;
while (!found)
+ count++;
+ if (count == 30 && !maximized)
+ { //special case when tolerance is tool low to be correct so it's similat to 0
+ // else in some special cases this algorithm would create infinite loop
+ found = true;
+ minTolerance = 0;
if (QgsSimplifyFeature::simplifyPoints(pts, tol).size() < size)
- found = true;
- minTolerance = tol/ 2;
- } else {
+ { //some vertexes were already excluded
+ if (maximized) //if we were already in second direction end
+ found = true;
+ minTolerance = tol/ 2;
+ else //only lowering tolerance till it's low enough to have all vertexes
+ tol = tol/2;
+ else
+ { // simplified feature has all vertexes therefore no need we need higher tolerance also ending flag set
+ // when some tolerance will exclude some of vertexes
+ maximized = true;
tol = tol * 2;
@@ -152,25 +192,26 @@
int requiredCnt = (isLine ? 2 : 4); //4 for polygon is correct because first and last points are the same
bool bottomFound = false;
double highTol, lowTol;// two boundaries to be used when no directly correct solution is found
- // calculate max
+ // calculate minimum tolerance where minimum (requiredCnt) of vertexes are left in geometry
while (!found)
int foundVertexes = QgsSimplifyFeature::simplifyPoints(pts, tol).size();
if (foundVertexes < requiredCnt + 1)
+ { //requred or lower number of verticies found
if (foundVertexes == requiredCnt)
found = true;
maxTolerance = tol;
else
+ { //solving problem that polygon would have less than minimum alowed vertexes
bottomFound = true;
highTol = tol;
tol = (highTol + lowTol) /2;
if (highTol/lowTol < 1.00000001)
+ { //solving problem that two points are in same distance from line, so they will be both excluded at same time
+ //so some time more than required count of vertices can stay
found = true;
maxTolerance = lowTol;
@@ -181,19 +222,20 @@
lowTol = tol;
found = true;
else
+ { //still too much verticies left so we need to increase tolerance
lowTol = tol;
tol = tol * 2;
- toleranceDivider = calculateDivider(minTolerance);
+ toleranceDivider = calculateDivider(minTolerance, maxTolerance);
// set min and max
mSimplifyDialog->setRange( int(minTolerance * toleranceDivider),
int(maxTolerance * toleranceDivider) );
Modified: trunk/qgis/src/app/qgsmaptoolsimplify.h
--- trunk/qgis/src/app/qgsmaptoolsimplify.h 2009-05-23 09:20:42 UTC (rev 10840)
+++ trunk/qgis/src/app/qgsmaptoolsimplify.h 2009-05-23 15:42:24 UTC (rev 10841)
@@ -71,7 +71,7 @@
private:
/** Divider calculation, because slider can go only by whole numbers */
- int calculateDivider(double num);
+ int calculateDivider(double minimum, double maximum);
/** Function to calculate tolerance boudaries for simplifying */
bool calculateSliderBoudaries();
@@ -90,7 +90,7 @@
QgsFeature mSelectedFeature;
/** tolerance divider is value which tells with which delete value from sidebar */
- int toleranceDivider;
+ long toleranceDivider;
/** real value of tolerance */
double mTolerance;
