[QGIS Commit] r11877 -
trunk/code_examples/5_using_rubber_band_with_canvas
svn_qgis at osgeo.org
Sun Nov 1 01:53:31 EST 2009
Author: timlinux
Date: 2009-11-01 01:53:31 -0500 (Sun, 01 Nov 2009)
New Revision: 11877
Added:
trunk/code_examples/5_using_rubber_band_with_canvas/CMakeLists.txt
Added missing CMakeLists.txt file
Added: trunk/code_examples/5_using_rubber_band_with_canvas/CMakeLists.txt
--- trunk/code_examples/5_using_rubber_band_with_canvas/CMakeLists.txt (rev 0)
+++ trunk/code_examples/5_using_rubber_band_with_canvas/CMakeLists.txt 2009-11-01 06:53:31 UTC (rev 11877)
@@ -0,0 +1,116 @@
+cmake_minimum_required(VERSION 2.6)
+PROJECT(timtut5)
+SET(CMAKE_COLOR_MAKEFILE ON)
+# set path to additional CMake modules
+SET(CMAKE_MODULE_PATH ${CMAKE_CURRENT_SOURCE_DIR}/cmake_find_rules ${CMAKE_MODULE_PATH})
+FIND_PACKAGE(QGIS REQUIRED)
+IF (NOT QGIS_FOUND)
+ MESSAGE (SEND_ERROR "QGIS dependency was not found!")
+ENDIF (NOT QGIS_FOUND)
+IF (WIN32)
+ # expect that classes are being imported by default
+ # Note: MSVC doesn't like when the macros are quotes
+ # and MSYS doesn't like them unqouted (bacause of braces)
+ # import qgis classes
+ IF (MSVC)
+ ADD_DEFINITIONS("-DGUI_EXPORT=__declspec(dllimport)")
+ ADD_DEFINITIONS("-DCORE_EXPORT=__declspec(dllimport)")
+ ELSE (MSVC)
+ ADD_DEFINITIONS("\"-DGUI_EXPORT=__declspec(dllimport)\"")
+ ADD_DEFINITIONS("\"-DCORE_EXPORT=__declspec(dllimport)\"")
+ ENDIF (MSVC)
+ELSE (WIN32)
+ ADD_DEFINITIONS(-DGUI_EXPORT=)
+ ADD_DEFINITIONS(-DCORE_EXPORT=)
+ENDIF (WIN32)
+FIND_PACKAGE(GDAL REQUIRED)
+IF (NOT GDAL_FOUND)
+ MESSAGE (SEND_ERROR "GDAL dependency was not found!")
+ENDIF (NOT GDAL_FOUND)
+FIND_PACKAGE(GEOS REQUIRED)
+IF (NOT GEOS_FOUND)
+ MESSAGE (SEND_ERROR "GEOS dependency was not found!")
+ENDIF (NOT GEOS_FOUND)
+IF (CMAKE_BUILD_TYPE MATCHES Debug)
+ ADD_DEFINITIONS(-Dtimtut5DEBUG=1)
+ENDIF (CMAKE_BUILD_TYPE MATCHES Debug)
+# Files
+SET (timtut5_SRCS
+ main.cpp
+ mainwindow.cpp
+# This tut uses no UIs
+SET (timtut5_UIS
+ mainwindowbase.ui
+# This tut needs no MOC
+SET (timtut5_MOC_HDRS
+ mainwindow.h
+SET (timtut5_RCCS
+ resources.qrc
+SET (QT_USE_QT3SUPPORT FALSE)
+SET (QT_USE_QTGUI TRUE)
+SET (QT_USE_QTSQL TRUE)
+SET (QT_USE_QTSVG TRUE)
+SET (QT_USE_QTXML TRUE)
+SET (QT_USE_QTNETWORK TRUE)
+FIND_PACKAGE(Qt4 REQUIRED)
+INCLUDE( ${QT_USE_FILE} )
+# Build
+QT4_WRAP_UI (timtut5_UIS_H ${timtut5_UIS})
+QT4_WRAP_CPP (timtut5_MOC_SRCS ${timtut5_MOC_HDRS})
+QT4_ADD_RESOURCES(timtut5_RCC_SRCS ${timtut5_RCCS})
+ADD_EXECUTABLE (timtut5 ${timtut5_SRCS} ${timtut5_MOC_SRCS} ${timtut5_RCC_SRCS} ${timtut5_UIS_H})
+INCLUDE_DIRECTORIES(
+ ${GDAL_INCLUDE_DIR}
+ ${GEOS_INCLUDE_DIR}
+ ${CMAKE_CURRENT_BINARY_DIR}
+ ${QT_INCLUDE_DIR}
+ ${QGIS_INCLUDE_DIR}
+#This is probably no longer needed, but I will leave it in for Win machines for the moment
+IF(QT_QTSQL_FOUND)
+ FIND_LIBRARY(QT_QTSQL_LIBRARY NAMES QtSql QtSql5 PATHS ${QT_LIBRARY_DIR} NO_DEFAULT_PATH)
+ SET(QT_LIBRARIES ${QT_LIBRARIES} ${QT_QTSQL_LIBRARY})
+ENDIF(QT_QTSQL_FOUND)
+TARGET_LINK_LIBRARIES(timtut5
+ ${QT_LIBRARIES}
+ ${QGIS_CORE_LIBRARY}
+ ${QGIS_GUI_LIBRARY}
+ ${GEOS_LIBRARY}
+ ${GDAL_LIBRARY}
+IF (MSVC)
+ # Very important or you get all kinds of odd side
+ #effects like app crash on start up saying qtgui.dll
+ TARGET_LINK_LIBRARIES( timtut5
+ qtmain
+ENDIF (MSVC)
+# Install
